Thread: Captiveworks -CW600 installation |
New member Username: Falcon2691
Post Number: 1 Registered: Jan-08
| Posted on Wednesday, January 02, 2008 - 09:59 am: |
Ok i bought this thing and it was suppose to be a plug and play the guy said. To make a long story short, I believe i have messed up all the settings in the setup. what i have done now is i do a 1.auto search 2check only FTA channels -> NO (to check all channels) 3.delete existing program ->YES AND NO (i have tried both) 4. when its running i get on average strength of 75% +/- and quality is almost always 0% from time to time it jumps as much as 50% so, am i suppose to do a blind search and it will find the settings frequencies and all...or auto...or? also i have seen something like auto roll over or something like that, is this for the codes? and if so since i have downloaded these codes should i have this set to no? (just to let you know it always just says 'weak signal') my dish may not be 100% alinged but i measured it out, and today im going to just buy the tool to check the signal...i think its like 30$ thanks guys. |
Silver Member Username: Rescate
VENEZUELA, M...
Post Number: 128 Registered: Nov-07
| Posted on Wednesday, January 02, 2008 - 10:13 am: |
http://forum.ecoustics.com/bbs/messages/2/412602.html#POST1344411
Silver Member Username: One_eye_jack
Post Number: 179 Registered: Nov-07
| Posted on Wednesday, January 02, 2008 - 10:22 am: |
Steve check Bruce Post # 920 here....http://forum.ecoustics.com/bbs/messages/2/429286.html |
