Thread: No Channels |
New member Username: Lemonman
Post Number: 4 Registered: Aug-07
| Posted on Wednesday, January 02, 2008 - 12:21 am: |
i did a factory reset on my ariza 700 and now when i scan for chanells i am not getting anything. plz help! |
Gold Member Username: Donnie1973
Post Number: 2548 Registered: May-06
| Posted on Wednesday, January 02, 2008 - 12:37 am: |
u lost ur ant settings. If u want DN 119 and 110 do this if u have a dish pro lnb (no disecq switch) lnb type- dishpro disecq 119=1 disecq 110=2 |
Silver Member Username: Kirankumar
Kenya
Post Number: 580 Registered: Oct-07
| Posted on Wednesday, January 02, 2008 - 12:46 am: |
Guys, we were trying to help this thing,but it turns out it is a F#cking guy.posing as a fudi Ghazala Go Screw yourself,whoever you F@cking are,and don't bother ask for any help.khote |
Post Number: 5 Registered: Aug-07
| Posted on Wednesday, January 02, 2008 - 12:49 am: |
still isnt working. im not getting any quality on any tp. |
Kenya
Post Number: 591 Registered: Oct-07
| Posted on Wednesday, January 02, 2008 - 12:57 am: |
Post Number: 2552 Registered: May-06
| Posted on Wednesday, January 02, 2008 - 12:59 am: |
its cause u dont have ur ant settngs correct. if u know how to check signal on a tp, then u should be able to set up the ant settings. Good luck |
Post Number: 6 Registered: Aug-07
| Posted on Wednesday, January 02, 2008 - 01:09 am: |
for 119W the level is 28% and 0% quality. so if there is a way to get some quality i should find channels. only problem is i don't know how |
Gold Member Username: Tapeman
New York City in-HD,
NY
Post Number: 1992 Registered: Oct-06
| Posted on Wednesday, January 02, 2008 - 01:18 am: |
Lemonman Yo have a great question There is nothing wrong with your receiver But the answer is In new ECM They took away hardware signal level and quality All I can tell yo Wait for new bin Don't mess with your settings |
Gold Member Username: Ke5aqn
IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 2856 Registered: Sep-06
| Posted on Wednesday, January 02, 2008 - 01:50 am: |
Lemonman, please ignore King and African. We need to know your set up in order to help you further. What is your lnb, switchs, antenna, receivers, everything connected to your receiver. You have a setting problem someware with al your setup info we will be able to help you.. |
Post Number: 8 Registered: Aug-07
| Posted on Wednesday, January 02, 2008 - 04:34 pm: |
its ariza satelite is echo 7 (119W) lnb power is on lnb type is standard lnb local frequency is 11250 22kHz is off Dieseqc is off legeacy SW is none Positioner setting is disabled and still the level is only 39% i always did it like this and it always worked but now for some reason it isnt |
