Home > Message Board > Home Video > Satellite TV > Archive through January 02, 2008 > Signal weak - DN channels down
Author Thread: Signal weak - DN channels down
Username: Girls_respect
Post Number: 8
I put in the new bin for CW 800 and I'm getting a "signal is weak" msg instead of the usual scrambled channel which signifies that the channels r down. Are the DN channels down OR is there a problem with my CW box??
Username: Imauser
Post Number: 46
Take out the power outlet, wait 30 sec and put in back again. It won't show anymore..
If its still shows "Signal is week" then it means that its a bad weather outside...Just wait till the weather is clear and then try it again...
Post Number: 9
Thanks a lot FM..ur right the weather is bad outside, perhaps its b/c of that
Username: Imjross
NJ
Post Number: 8
....weather....
Home > Message Board > Home Video > Satellite TV > Archive through January 02, 2008 > Signal weak - DN channels down [ « Previous ] [ Next » ]
