Home > Message Board > Home Video > Satellite TV > Archive through January 02, 2008 > Taking the time to
Author Thread: Taking the time to
Username: Poopoohed
Post Number: 54
i thought i'd take this down time to move my dish ..long story short i'm now getting 97% on bird 119 but only 67% on 110 .
played with it most of the day so real answers only plz
Username: Jgrumby
Did you try peaking the dish on 110 as opposed to 119?
Also, are you sure there are no obstructions in the line of sight since you moved the dish?
Username: Poopoohed
Post Number: 55
yea i peaked the 110 by moving the dish but it makes the 119 go offline as far as the field of view is better at this location
Username: Carpie
Post Number: 31
Try moving your house.
Username: Poopoohed
Post Number: 56
yea thanx fishman that helps since moving my house i can see into your mommas bedroom window alot better FOOL!
Username: Razzorwyre
Post Number: 119
When I set my dish I used the cals from Dishpointer that combined 110 and 119 and it got it at about 97% on both dishes. This may help instead of lining one at a time.
Username: Jgrumby
If you were getting good quality on both sats before you moved the dish, your mounting pole might not be plumb. Make sure your bracket is not slightly tilted in one direction or the other. You also might be able to make up the difference by adjusting the dish skew if it is off a bit.
Username: Poopoohed
Post Number: 57
ill ttry both sugests thnx raz & grum
Home > Message Board > Home Video > Satellite TV > Archive through January 02, 2008 > Taking the time to [ « Previous ] [ Next » ]
