Thread: Need help connecting a tunerless DVR to TV and Cable Box |
New member Username: Johnny_rego
Post Number: 2 Registered: Dec-07
| Posted on Sunday, December 30, 2007 - 02:27 pm: |
Hello, I purchased a Toshiba D-VR600 Multiformat DVD Recorder/VCR Combo with Progressive Scan. It says that an External tuner source is required to record television programming. I was told that my cable box can serve as the tuner (Motorola 2500 for FIOS TV- verizon). I tried connecting everything through the cable box but cannot get it to work. I have attached a picture of the back of my box. As you will see, the picutre gives the examples of connecting everything through the DVD/VCR (which is how i know to do it) but b/c this product does not have a built in tuner, I really need help to figure out how to connect through my box so I can record TV
Relevant Product Info
Gold Member Username: Samijubal
Post Number: 3682 Registered: Jul-04
| Posted on Sunday, December 30, 2007 - 05:35 pm: |
Substitute DVD for VCR and connect like the diagram. Set the recorder on whatever input you used. |
New member Username: Kevinrob
Post Number: 2 Registered: Jan-08
| Posted on Thursday, January 10, 2008 - 10:38 pm: |
Good advice - I had the same question. I'm looking at buying a new DVD recorder but I don't see the advantage to buying one with a tuner. Is it necessary if I am going to connect it through my DirecTv HD DVR unit? The hook-up would be just like in the picture above, except substitute the DirecTv unit for the Cable box and I would use Component video to connect to the TV instead of RCA. Am I missing something here? Why do I need the tuner on the DVD Recorder? What is the advantage? |
Bronze Member Username: Ieee488
Post Number: 14 Registered: Dec-07
| Posted on Saturday, January 12, 2008 - 05:03 pm: |
Yes, that's all you need to do. I have a DVD recorder with a tuner. I don't have a cable box. I think that the manufacturers are making the DVD recorders without a tuner to cut down on cost especially since many people have cable boxes and satellite boxes etc. |
Post Number: 4 Registered: Jan-08
| Posted on Sunday, January 13, 2008 - 11:05 am: |
Thanks LK. The DVD recorders w/o a tuner are $50 cheaper. |
New member Username: Melpokornymaccom
Post Number: 1 Registered: Jan-08
| Posted on Friday, January 18, 2008 - 01:10 am: |
HELP!!! I have a Verizon FIOS DVR/Cablebox that has only "ONE" RF-COAX connection. It is an RF-COAX "INPUT" (for use for the connection from the wall outlet to the cable box). There is NOT an RF COAX-OUTPUT on the FIOS DVR/cablebox. However, it does have A/V (RCA-style) input and output jacks (yellow/white/red). When Verizon installed their DVR/Cablebox, they connected it as follows: 1) Coax cable from wall to FIOS DVR/cablebox RF-COAX INPUT. 2) A/V RCA-Yellow/White/Red OUT to A/V RCA-Yellow/White/Red IN on RF-Modulator. 3) Coax to-TV (OUT) connection on RF Modulator to COAX Cable/Antenna Input on the back of the Magnavox TV. I want to be able to: 1) make DVDs out of the items I have recorded on FIOS DVR/Cablebox RAM drive (DVR audio/video OUT to DVDR audio/video IN) while simultaneously viewing another cable program...is this even possible? 2) watch DVDs from DVDR unit (DVDR audio/video OUT to TV) 3) be able to record televised programs direct to DVDR (DVDR OUT to TV). I do have a four-port RF Modulator that can be used but I need to know how to wire the FIOS DVR/cablebox to it as the cablebox has no RF COAX OUTPUT and only ONE SET of A/V-RCA-style (yellow, white, red) OUTPUT jacks. note: both the FIOS DVR/Cablebox AND the Panasonic DVDR units have Svideo jacks, and the Panasonic DVDR has both RF COAX IN and RF COAX OUT. The RF Modulator has the following: 1 each RF COAX OUT (to TV) 1 each RF COAX IN (antenna/cable) 1 each Channel Select (3 or 4) 1 each RCA-Style OUTPUT - Audio Left/Audio Right/Video with a corresponding SVideo jack 4 each RCA-Style INPUT - Audio Left/Audio Right/Video with 4 corresponding SVideo jacks - (Input 1, 2, & 3 on back of unit; Input 4 on front of unit). AC connection. I need to know how to connect the FIOS DVR to a Panasonic DMR-ES15 AND my very old Magnavox TV (which only has a single COAX INPUT on the back of the unit). I have seen many wiring diagrams but they always have an RF OUTPUT coming from the DVR/Cablebox, of which there is not one on the Verizon FIOS box. if anyone knows how to wire this mess, I'd love to know! I've tried several different ways, one of which was recommended by Verizon (and which didn't work - there was no picture or sound - only snow on the TV screen).
mel |
Post Number: 15 Registered: Dec-07
| Posted on Friday, January 18, 2008 - 11:57 am: |
mel, This is what I would do first. Disconnect the cable that is connected to your TV and connect it instead to the RF IN of your Panasonic. Then get another RF cable, and connect the RF OUT of Panasonic to TV. Make sure your Panasonic is powered on. You should be able to record on the Panasonic whatever channel your cablebox is set to and at the same time be able to watch that channel on your TV. Then, play a store-bought DVD in your Panasonic which you should see on your TV. Let me know what you find. |
