Home > Message Board > Home Video > DVD Recorders > Can you record up to 4 hr's on a sing...
Author Thread: Can you record up to 4 hr's on a single dvd ????
Username: Kc2j
I would like to know if you can buy a dvd recorder that will let you record up to 4 hr's. and what brand to I need to buy... thank you for you help ...kj
Relevant Product Info
Username: Samijubal
Post Number: 3679
You can record 6-8 hours depending on the recorder. You'll sacrifice a lot of picture quality on anything over 2 hours though.
Username: Kc2j
is the picture quality as good as a vhs tape ??
Username: Samijubal
Post Number: 3683
Far better. But you're going to get macroblocks in LP(4hrs) that you won't get in SP(2hrs).
Username: Kc2j
Do they make a dvd recorder, that will let you burn a cd, of a fight and also let you make copys of that cd all with the same dvd recorder??
Username: Samijubal
Post Number: 3684
If you meant DVD and not CD, you need a HDD recorder to make multiple copies. It'd be far cheaper to use a PC burner to copy discs. HDD recorders have pretty much come to the end of their run. They are expensive and hard to find.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > DVD Recorders > Can you record up to 4 hr's on a sing... [ « Previous ] [ Next » ]
