Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2004 > BLACKBIRD MAYBE?
Author Thread: BLACKBIRD MAYBE?
Fireguy951
There is a lot on the blackbirds, if you have one , are you happy, and do you think that it will be here for a while or should I just wait for direect fix?
Relevant Product Info
Santos L Halper
Blackbird is awesome. I have over 1200 channels. No card to program either. GET IT NOW!!!!
What are the chances of the system going down though?
cali777
less than DTV
I gathered that much but being more specific it is possible for this system to go down, correct? I was told that there is no way this system will ever go down.
Cali777
Anything is possible but its definetely more secure than DTV.Do you want to buy an hu card...only $100
cali777 why do you try to f*ck ppl your new name should be snake sh!t the lowest form of sh!t there is......the blackbird is a wise investmentyou caqn read about it here http://www.dsscanada.ca/forums/index.php?
kbock00@dssmarines.com
Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2004 > BLACKBIRD MAYBE? [ « Previous ] [ Next » ]
