Home > Message Board > Home Video > Direct View TVs > Problem hooking up DVD/Player recorde...
Author Thread: Problem hooking up DVD/Player recorder to TV
Username: Jdg1341
I have a Sony WEGA KV-36hs420 tv and a Magnivox BZV420MW8 DVD/VHS Player/Recorder combo. After hooking the player up first with an S cable then with the component cord that came with the player I still cannot get the TV to recognize that the player is hooked up to it. Any suggestions out there?
Username: Imjross
NJ
Post Number: 36
Sony will display picture and sound ONLY IF:
1. Correct output from DVD/VHS (S or Componet) is connected to Input of TV (S or componet) (VIDEO 1 - IN is ok)
2. Then select "video 1" using the SONY remote.
NOTE: S or componet is PICTURE only....you must also hook up the AUDIO too....
jr
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Direct View TVs > Problem hooking up DVD/Player recorde... [ « Previous ] [ Next » ]
