Home > Message Board > Home Video > DVD Recorders > Archive through January 14, 2005 > Hooking up VCR/VHS to DVD to copy tap...
Author Thread: Hooking up VCR/VHS to DVD to copy tapes to DVD
I got an RCA DRC8000N DVD Recorder yesterday. I have DirecTV and everything is hooked up to a stereo system. Everything seems to work fine, but when I play a home VHS tape (for the purpose of recording to a DVD), I can't get the picture to show (through the DVD Recorder), although I hear the sound. I can see the picture in normal TV mode. I guess that means I have the audio jacks correct, but not the video jack. If you've seen the reviews of this recorder, you would know that the manual is terrible. Any suggestions? Thanks, Larry
Username: Foudemusique
Montreal, Quebec
if you live in montreal check for a digital video stabilizer
Username: Xol
I'm not sure the protection is your problem.
In case it is this one will help you
<http://www.dimax.com.ua/english/dvd_recorder.htm>
Also try to check it with another VHS which you know is not protected (non comercial)
Username: Xol
Sorry
http://www.dimax.com.ua/English/dvd_recorder.htm
Username: Nysoftwareman
Please dont bother with the the DVD Red Pro.
Get the SIMA GO DVD or the SIMA SCC-2
Available at VIDEOGUYS.COM
An Authorized dealer with a 30 day Full Refund Policy.
Hi Andy.
Just a couple of lines to inform you that this morning I have received my order of DVD Red PRO in Italy, safe and sound.
I've just been testing it with both PAL and NTSC signal, and it's really an excellent product!
Thank you very much for your advice and cooperation!
Best regards
Paolo Gosio - Turin, Italy
Username: Andyyanov
Post Number: 19
Paolo!
I am glad that it help you.
I have dvd red pro in my own and I can say
good word about it and guys that developed it.
It works and it work good.
Nothing to say more.
Good luck.
Andy.
AimeAlain
I want to copy my vhs tapes to dvd, Can somebody please advise how to go about it and the software/hardware needed. Many thanks.
Regards
Alain
Home > Message Board > Home Video > DVD Recorders > Archive through January 14, 2005 > Hooking up VCR/VHS to DVD to copy tap... [ « Previous ] [ Next » ]
