Home > Message Board > Home Video > Rear Projection TVs > Archive through October 23, 2004 > HELP! My Mitsubishi won't work
Author Thread: HELP! My Mitsubishi won't work
Username: Djtorch
Post Number: 36
Hello, I'm so upset. My TV was working fine until I decided to move a few things around. After carefully sliding the TV a few feet here and there, the TV now fails to turn on! The light comes on momentarily, I can hear a few clicks and then the light immediately goes out. What did I do??????? HELLLLLLP
Username: Djtorch
Post Number: 37
By the way, the model number of my Mitsu is wt-46805. I press the button, I hear one click, the light goes out, I then hear one or two other clicks then nothing.
crobi
Same exact thing happened to me but I have a different model number - has anyone responded?
Asuquita
Same here. My TV turns on and stays on sometimes for a while. However, sometimes it does not turn on at all.
Austin
Their is something wrong with the power supply because my tv has the same problem.
Username: Genesis
Farmersville, Calif
United states
hitachi
model 60sx2k
chassis ap-24
has digital convergense
whats the steps to adjust the conv,ce
559 747.6931
Username: Genesis
Farmersville, Calif
United states
bad sordering joint first step
for austin june 18
Does anyone have the convergence codes for an Hitachi Projection TV, Model 60xs2k?
Username: Spike21
EVERYBODY HAS THE SAME QUESTION BUT NO ONE HAS THE ANSWER???!!!!!quote mmc
Username: Djtorch
Post Number: 48
I paid 200.00 and waited a month to get my TV repaired. It now turns on , but the picture sux. I cannot seem to get the TV to respond to 1080i. The highest resolution U can get out of it now is 980 or something, but the picture looks all bent. It's more noticeable with my samsung HDTV directv tuner. I can still see it when i play the dvd. Does anyone know what's going on here??
Username: Djtorch
Post Number: 49
Someone please help me.
Username: 25delaine
does anyone know how to fix the picture and the convergence codes for a hitachi 60sx2k?
My mitsubishi TS-5045 does the same thing. The power light goes on and stays on for about 3 seconds and then turns off. Has anyone found out the proplem
Home > Message Board > Home Video > Rear Projection TVs > Archive through October 23, 2004 > HELP! My Mitsubishi won't work [ « Previous ] [ Next » ]
