Home > Message Board > Home Video > TV Basics > Archive through June 21, 2008 > 52" Rear Projection RCA TV Audio prob...
Author Thread: 52" Rear Projection RCA TV Audio problem ???
Username: Kourso
Plaquemineq, LA
US
I have a 52" RCA {Regular Rear Projection) TV about 5 yr. old and it loses all audio sound randomly BUT IF you turn it off and unplug the AC power for about 5 min., it may come back on for anywhere from a minute to hours. If you turn it on in the morning it almost routinely cuts off sound at 4 pm for whatever reason???
I tried to flip the rear switch back/forth between internal/external speakers and once it seemed to reset.
Any ideas, otherwise the TV is fine. Getting ready to hit the trash, it is soo frustrating.
Please give me some assistance.
Thanks
Kenny
Username: Imjross
NJ
Post Number: 18
kourso
You found the fix.....unplug tv wait 5 min...
Design error.....Cable signal intermittanly..
loads a buffer and audio cuts out....set NOT broken....No fix as per RCA tech support....jr
Home > Message Board > Home Video > TV Basics > Archive through June 21, 2008 > 52" Rear Projection RCA TV Audio prob... [ « Previous ] [ Next » ]
