Thread: Toshiba SD V295 - Can't shut off Subtitles |
New member Username: Cscene
Post Number: 1 Registered: Dec-07
| Posted on Wednesday, December 19, 2007 - 10:41 am: |
Hi All- Recently picked up a Toshiba SD V295 VCR/DVD player combo for my basement TV. After a recent power failure I am unable to shut off the subtitles (or closed captions, can't tell) when playing a VCR tape. There is nothing in the VCR menu to control this, and subtitles are set to OFF in the DVD menu. Any ideas? Thanks in advance- |
Gold Member Username: Samijubal
Post Number: 3665 Registered: Jul-04
| Posted on Wednesday, December 19, 2007 - 01:40 pm: |
Turn off the CC on the TV. |
Post Number: 2 Registered: Dec-07
| Posted on Thursday, December 20, 2007 - 04:12 pm: |
I wish it was that easy...at this point I'm convinced it's shot. Thanks. |
Post Number: 3668 Registered: Jul-04
| Posted on Thursday, December 20, 2007 - 07:03 pm: |
I've never seen a VCR with CC capability. CC is done at the TV, the VCR just passes the info to the TV. |
Post Number: 3 Registered: Dec-07
| Posted on Thursday, December 20, 2007 - 07:43 pm: |
Agreed, there is no option in the VCR menu...but nonetheless, I am ONLY getting closed captioning/subtitles when viewing a tape in that VCR. No issues with my TV, DVR, DVD or even playing the tape in another VCR. |
Post Number: 3669 Registered: Jul-04
| Posted on Friday, December 21, 2007 - 12:42 am: |
I have a Toshiba DVD recorder that has the option for the recorder to do CC, it's possible that your combo does too. I don't use combos, so I don't know if it might or not. |
