Thread: Archive through December 11, 2007 |
Silver Member Username: Leafs_fan_4_eva
jammin wit Jamario MO...,
Post Number: 232 Registered: Jun-06
| Posted on Friday, December 07, 2007 - 06:32 pm: |
Nalin can you help me out, i have a question in the thread named "Antenna Settings" Thanks |
Relevant Product Info
Silver Member Username: Ather_da_don
Mississauaga,
Ontario
Post Number: 148 Registered: Oct-07
If you want new dish keys or new BIN files for Pansat, Viewsat, C00lSAT, etc., visit www.dishkeyz.blogspot.com |
Silver Member Username: Halo
Toronto,
Ontario
Post Number: 219 Registered: Oct-07
| Posted on Friday, December 07, 2007 - 06:53 pm: |
All new bin files also at www.dish-keys.blogspot.com |
Bronze Member Username: Westway11
Post Number: 45 Registered: Aug-07
| Posted on Friday, December 07, 2007 - 06:55 pm: |
What's the point of this? There is absolutely no need for a thread on keys, and everyone just spams shî† in here anyways. |
New member Username: Nsinha
Rochester Hills,
MI
Post Number: 5 Registered: Nov-07
| Posted on Friday, December 07, 2007 - 07:23 pm: |
FOlks...I just downloaded and applied the bin (343)for pansat 3500SD. All my signal strength has gone low and quality Zero. Tried scanning but with zero quality, none of the channels show up. It was all okay till the last outage.Any clue as to how to fix it? |
Rochester Hills,
MI
Post Number: 6 Registered: Nov-07
| Posted on Friday, December 07, 2007 - 07:47 pm: |
Never mind...I just swithced off the receiver and started...all is well now. The pansat bin (343) from Future-fta is good! |
Post Number: 134 Registered: Oct-07
| Posted on Friday, December 07, 2007 - 07:51 pm: |
visit www.ftasolutions.blogspot.com |
Silver Member Username: Oleg1474
New port richey,
Fl
Usa
Post Number: 477 Registered: Aug-06
| Posted on Friday, December 07, 2007 - 08:31 pm: |
EURO/ECM666 The BEST fta-program FTAnow@USA&EUROPE ...Thank you!!Oleg PHD |
New port richey,
Fl
Usa
Post Number: 482 Registered: Aug-06
| Posted on Friday, December 07, 2007 - 08:51 pm: |
December 2007 D+ switched all to Nagra 3 .(EURO/ECM666)Thank you . Oleg PHD. |
New port richey,
Fl
Usa
Post Number: 483 Registered: Aug-06
| Posted on Friday, December 07, 2007 - 08:57 pm: |
281 FUSE MOVED FROM Tp 2 on EchoStar 7 at 119w MPEG2 SD TO Tp 5 on EchoStar 8 at 110w MPEG2 SD RENAMED DIY 282 IMF MOVED FROM Tp 3 on EchoStar 8 at 110w MPEG2 SD TO Tp 5 on EchoStar 8 at 110w MPEG2 SD RENAMED CNBCW 283 FX MPEG2 SD REMOVED FROM Tp 12 on EchoStar 7 at 119w 284 GAC MPEG2 SD REMOVED FROM Tp 11 on EchoStar 8 at 110w 285 SHO-E MPEG2 HD REMOVED FROM Tp 13 on EchoStar 8 at 110w 288 SHO-E MPEG2 SD REMOVED FROM Tp 6 on EchoStar 7 at 119w 289 SHO-W MPEG2 SD REMOVED FROM Tp 8 on EchoStar 7 at 119w 290 SHOTO MPEG2 SD REMOVED FROM Tp 19 on EchoStar 7 at 119w 291 SHOCS MPEG2 SD REMOVED FROM Tp 21 on EchoStar 8 at 110w 292 SHOEX MPEG2 SD REMOVED FROM Tp 16 on EchoStar 7 at 119w 293 SBYND MPEG2 SD REMOVED FROM Tp 11 on EchoStar 8 at 110w 294 TMC-E MPEG2 SD REMOVED FROM Tp 10 on EchoStar 7 at 119w 295 TMCXE MPEG2 SD REMOVED FROM Tp 10 on EchoStar 7 at 119w 296 SUND MPEG2 SD REMOVED FROM Tp 12 on EchoStar 7 at 119w 297 FLIX MPEG2 SD REMOVED FROM Tp 17 on EchoStar 7 at 119w 531 HDPPV MOVED FROM Tp 17 on EchoStar 8 at 110w MPEG4 HD TO Tp 31 ConUS beam on EchoStar 5 at 129w MPEG4 HD 534 HDPPV MOVED FROM Tp 17 on EchoStar 8 at 110w MPEG4 HD TO Tp 31 ConUS beam on EchoStar 5 at 129w MPEG4 HD 668 JSTV MOVED FROM Tp 16 on EchoStar 9 at 121w MPEG2 SD TO Tp 13 on EchoStar 9 at 121w MPEG2 SD 675 TVJPN MOVED FROM Tp 5 on EchoStar 9 at 121w MPEG2 SD TO Tp 13 on EchoStar 9 at 121w MPEG2 SD 5722 ZGUJ MPEG2 SD REMOVED FROM Tp 25 on EchoStar 9 at 121w 5724 KBS MPEG2 SD REMOVED FROM Tp 15 on EchoStar 9 at 121w 5726 TVJPN ADDED TO Tp 5 on EchoStar 9 at 121w MPEG2 SD 6915 MT15 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6916 MT16 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6917 MT17 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6918 MT18 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6919 MT19 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6920 MT20 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6921 MT21 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6922 MT22 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6923 MT23 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6924 MT24 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6925 MT25 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6926 MT26 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6927 MT27 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6928 MT28 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6929 MT29 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6930 MT30 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6931 MT31 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6932 MT32 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6933 MT33 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6934 MT34 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6935 MT35 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6936 MT36 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6937 MT37 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6938 MT38 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6939 MT39 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG4 SD 6940 MT40 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG AUDIO 6941 MT41 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG AUDIO 6942 MT42 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG AUDIO 6943 MT43 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG AUDIO 6944 MT44 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG AUDIO 6945 MT45 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG AUDIO 6946 MT46 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG AUDIO 6947 MT47 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG AUDIO 6948 MT48 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG AUDIO 6949 MT49 ADDED TO Tp 20 on EchoStar 2 at 148w MPEG AUDIO 7039 INFO ADDED TO Tp 14 on EchoStar 9 at 121w MPEG2 SD 7048 INFO ADDED TO Tp 14 on EchoStar 9 at 121w MPEG2 SD 7769 INFO ADDED TO Tp 14 on EchoStar 9 at 121w MPEG2 SD 7777 INFO ADDED TO Tp 14 on EchoStar 9 at 121w MPEG2 SD 8024 KBBC ADDED TO Tp 3s5 on EchoStar 7 at 119w MPEG2 SD 9431 USA ADDED TO Tp 17 on EchoStar 8 at 110w MPEG4 HD 9432 SCIFI ADDED TO Tp 17 on EchoStar 8 at 110w MPEG4 HD 9651 HDBT2 ADDED TO Tp 2 on EchoStar 9 at 121w MPEG4 HD 9850 KBS MOVED FROM Tp 15 on EchoStar 9 at 121w MPEG2 SD TO Tp 13 on EchoStar 9 at 121w MPEG2 SD 19100 SHARP DATA REMOVED FROM Tp 8 on EchoStar 8 at 110w CHANGE COUNT 67 |
New port richey,
Fl
Usa
Post Number: 484 Registered: Aug-06
| Posted on Friday, December 07, 2007 - 09:01 pm: |
Att...DIRECTV - Software Updates: H20-100: 0x204C - Staggered National Release - Release Notes D11-300: 0x1069 - Staggered National Release - Release Notes HR21-700: 0x18F- Full National Release - Release Notes R15-300: 0x10C1 - Staggered National Release - Release Notes. (euro/ecm666)Thank you!! Oleg PHD |
Mississauaga,
Ontario
Post Number: 149 Registered: Oct-07
| Posted on Friday, December 07, 2007 - 09:53 pm: |
Toronto,
Ontario
Post Number: 220 Registered: Oct-07
| Posted on Friday, December 07, 2007 - 11:39 pm: |
Latest bin files at www.dish-keys.blogspot.com so make sure to check it out |
Bronze Member Username: Andreasmith
Post Number: 41 Registered: Mar-07
| Posted on Saturday, December 08, 2007 - 12:18 pm: |
Hi, Why are you trying to post again and again, to find keys in blogspot.com As you know, all receivers, autoroll is working good. Please do not post in this thread about to check some other site for keys. If you have so much time to post unnecessarily, please open a new thread and post again and again Nalin: I hope you will agree to my point. Thanks Andy |
Post Number: 42 Registered: Mar-07
| Posted on Saturday, December 08, 2007 - 12:21 pm: |
Yash: You really need to be patient. If you want a higher quality picture, it will take some time. Wait for one or more days, you will get it. Always keep an alternative to watch (may be cable). Norw is helping. So no reason to yell at them. This is not only applicable for Norw, also for BL as well. Thanks Andy |
Bronze Member Username: Hrrysoni
IL
U.S.A
Post Number: 32 Registered: Sep-06
| Posted on Saturday, December 08, 2007 - 01:57 pm: |
Hi, my pansat 3500 was working and all of sudden all the ethnic channels were scrambled, however certain english channels are coming. I found the new bin for pansat 3500 on fta, but i used the GTRom loader from pansat usa. And I used the RS232 null cable for download, but it does not work. Please help me! |
New member Username: Dzejlana
Post Number: 7 Registered: Mar-07
| Posted on Saturday, December 08, 2007 - 02:54 pm: |
i have a panasat 2700 A and i put in the new keys and it keep sayin scrambled or bad chanell i have the new file but how do i put it to the tv..... sorry im knew to all this |
New member Username: Sennis
Post Number: 10 Registered: Aug-07
| Posted on Saturday, December 08, 2007 - 03:09 pm: |
autoroll not working on my cw600s premium new 1.59 on it aswell |
Bronze Member Username: Samson
Post Number: 16 Registered: Jun-06
| Posted on Saturday, December 08, 2007 - 04:41 pm: |
Steve, you need new 1.60 |
Toronto,
Ontario
Post Number: 223 Registered: Oct-07
| Posted on Saturday, December 08, 2007 - 04:47 pm: |
bin files at www.dish-keys.blogspot.com |
Mississauaga,
Ontario
Post Number: 152 Registered: Oct-07
| Posted on Saturday, December 08, 2007 - 04:58 pm: |
Post Number: 135 Registered: Oct-07
| Posted on Saturday, December 08, 2007 - 05:06 pm: |
visit www.ftasolutions.blogspot.com for your latest keys... |
New member Username: Fcmiller
Post Number: 9 Registered: Nov-06
| Posted on Saturday, December 08, 2007 - 07:40 pm: |
I have a pansat 2700A I have downloaded the new 227 bin from futurefta but it did not come with a loader. I have some older loaders in my files but am unsure which one ( if any ) to use. Could someone please advise me> Thankyou |
New member Username: Thebear23
Post Number: 9 Registered: Sep-06
| Posted on Saturday, December 08, 2007 - 08:55 pm: |
is bev gone again? i got it last night and now i can it was gone.....i put the software again and still not working.....i came home to watch the leafs.....help please. |
Bronze Member Username: Laure
Fredericton,
NB
Post Number: 14 Registered: Mar-07
| Posted on Saturday, December 08, 2007 - 09:30 pm: |
Does anyone have the new keys yet??? |
Bronze Member Username: Thebear23
Post Number: 11 Registered: Sep-06
| Posted on Saturday, December 08, 2007 - 09:48 pm: |
my receiver is viewset ultra and is only 4 months old....i installed the new software last night and worked ok. tonight i could not find BEV but i have the others. is there a problem with my receiver or the software or what? please advise....thx |
Bronze Member Username: Someone13
Post Number: 12 Registered: Dec-07
| Posted on Saturday, December 08, 2007 - 10:01 pm: |
anyone still waiting on files... go visit... http://www.sluttyjasmine.com/preview01.htm until they come out |
Mississauaga,
Ontario
Post Number: 154 Registered: Oct-07
| Posted on Saturday, December 08, 2007 - 10:59 pm: |
Toronto,
Ontario
Post Number: 224 Registered: Oct-07
| Posted on Sunday, December 09, 2007 - 02:05 am: |
check out www.dish-keys.blogspot.com as well!! |
Bronze Member Username: Bluebee
Post Number: 24 Registered: May-06
| Posted on Sunday, December 09, 2007 - 09:29 am: |
I am unable to get Z sports. I have done blind scan after factory flash, still not getting it. Dish is pointing to 148. Do I have to edit TP or add any ? Any suggestion please ? Thanks. |
Silver Member Username: Dimwitt
Post Number: 282 Registered: Aug-06
| Posted on Sunday, December 09, 2007 - 10:32 am: |
Z sports is on 61.5 and 119. not on 148. http://ekb.dbstalk.com/dishlist.htm |
Mississauaga,
Ontario
Post Number: 157 Registered: Oct-07
| Posted on Sunday, December 09, 2007 - 01:53 pm: |
Florida
Usa
Post Number: 490 Registered: Aug-06
| Posted on Sunday, December 09, 2007 - 02:50 pm: |
HDNET TO BROADCAST LIVE, EXCLUSIVE COVERAGE OF THE LAUNCH OF SPACE SHUTTLE ATLANTIS - THURSDAY, DECEMBER 6 Network's coverage begins at 3:30 p.m. ET with launch from the Kennedy Space Center scheduled for 4:31 p.m. ET WHAT:HDNet to broadcast EXCLUSIVE coverage of the launch of Space Shuttle Atlantis, marking NASA's 24th US mission to the International Space Station. The mission of STS-122 is to deliver the European Space Agency's Columbus science laboratory module. The cylindrical, 23-foot long Columbus lab is the first all-European laboratory to be attached to the International Space Station. HDNet's coverage will be hosted by HDNet World Report Correspondent Greg Dobbs and former astronaut, Colonel Charles "Sam" Gemar. WHEN:EXCLUSIVE coverage begins on HDNet at 3:30 p.m. with the launch scheduled for 4:31 p.m. ET. _(EURO/ECM666)2008 nagra-3_________________ ...Oleg PHD ~ I am now a card-carrying member of Generation Rx, but I know that Life is not measured by the number of breaths we take, but by those moments that take our breath away. ~ next launch scheduled@january,2008 Thank you !!! Oleg PHD |
Florida
Usa
Post Number: 491 Registered: Aug-06
| Posted on Sunday, December 09, 2007 - 02:56 pm: |
December 2007 D+ switched all to Nagra 3 |
Florida
Usa
Post Number: 492 Registered: Aug-06
| Posted on Sunday, December 09, 2007 - 03:00 pm: |
DIGITAL TERRESTRIAL TV: Digital terrestrial TV coming but work remains More than half a century has passed since commercial television debuted in Japan, and now TVs are a main component of the mass culture. A countdown sign in the Bic Camera store in Yurakucho, Tokyo, last month pitches TV sets compatible with terrestrial Are you all set for HDTV? Mysteries of set-top boxes Are you ready for 2009? That's when broadcasters will pull the plug on old-fashioned standard definition TV, and with few exceptions, we'll all be moving to the brave new world of digital HDTV. The switch has been accompanied by a more interesting trend: New media role for BSkyB chief BSkyB chief executive James Murdoch was yesterday handed the task of leading his father Rupert's media empire in Europe and Asia. Mr Murdoch, who is 34, will take direct responsibility for the strategic and operational development of News Corporation's More details emerge on Wind's IPTV deployment - More details have emerged on the deployment of Italian telco Wind's IPTV service, with Alcatel-Lucent announcing that the service is based on its network solutions and the Microsoft Mediaroom platform. Alcatel-Lucent has stated that it deployed its PCCW boosts IPTV deployment with Juniper Networks broadband services routers - Juniper Networks has announced that Hong Kong-based telco PCCW has increased the scale and performance of its broadband network with E320 Broadband Services Routers, leveraging its existing installed base of Juniper E-series routers. PCCW has combined Motive partners with AT&T Knowledge Ventures to market end-to-end service assurance for IPTV - Motive, a US provider of service management software for broadband and mobile data services, has announced a partnership with AT&T Knowledge Ventures to market a service assurance solution for IPTV deployments. The solution provides customer care BSkyB tunes in to a new era BSKYB has an uncanny knack of exciting its shareholders and not always by piling on subscribers or operating profits. For the third time in four years, the satellite broadcaster faces a row over how the company is run. Rupert Murdoch, as Skys chairman, Tax agency padlocks Salem company: The department has listed AirCable, a digital wireless TV provider, as a delinquent debtor. AM Dec. 7--Agents from the Virginia Department of Taxation padlocked on Wednesday the Salem headquarters of AirCable of Roanoke, a provider of digital wireless television. Joel Davison, a spokesman for the department, said AirCable owes more than Magnify.net to Power Web Video Curation Platform With Amazon S3 AMNEW YORK, NY, December 7 / MARKET WIRE/ -- Magnify.net, a peer-driven online video discovery and broadcast channel for people, groups and businesses, today announced their use of Amazon Simple Storage Service (Amazon S3) to host its rapidly growing U.S. Equity News: IPTV Corporation Appoints Supercomputing Pioneer Dr. Steve Chen as a Member of Its Board of Directors and Amazon Customers Set Gift Expectations High This Holiday Season has appointed world renowned technologist Dr. Steve Chen as a member of its . Dr. Chen is widely considered one of the leading system architects and technologists in the United States having been described by the New York Times as a 'pioneer' and China Digital TV Holding Co. Enters the Bargain Bin We all know of the tremendous hype associated with anything China-related over the last year or so. The initial euphoria over China Digital TV Holding Co., Ltd.'s (STV) IPO back on Oct. 8th was no exception to this Phenomenon. After initially pricing at Comcast Taps Lobbyist for Digital TV Comcast Corp., the nation's largest cable television operator, hired LeClairRyan to lobby the federal government, according to a disclosure form.The firm will lobby for digital television and telecom issues and proposed legislation prohibiting states Dealzmodo: 47-inch 1080p Olevia LCD HDTV for $1599 If you've done your gadget homework and read this year's Wired Test, you'd know they were pretty fond of this . Now that they've dug up this deal at Target that lowers the TV's price to $1599 (regularly $2099), the Olevia looks like an even hotter a cheap alternative to our set-top-box wishlist item If you've been around long enough, you'll remember our series of fanciful and unlikely wishlist items that would totally make this the Best Holidays Ever if we got them. Here's one I've been wishing for for the better part of a decade: an all-in-one Digital TV switchover could slow e-government - people aren't getting information and technical support needed for switch. Digital TV switchover could slow e-government People who need it most arent getting the information and technical support to make a smooth switch to digital TV, according to the Going Digital report from the Consumer Panel. The pressure group Consumer UPGRADED TIVO DVRS NOW AVAILABLE IN CANADA Media Contact: Darin Tambascio WeaKnees.com 310-650-7129 darin.tambascio@gmail.com WeaKnees.com Offers Additional Hard Drive Capacity For Canadian TiVo Customers Los Angeles, CA - Now that the TiVo Series 2 Dual Tuner DVR (Digital Video Recorder) units BSkyB Group plc announces board changes YooMedia proposed acquisition of a majority holding in Fresh YooMedia has announced that it has conditionally agreed to acquire 95.2% of the issued share capital of Fresh Interactive Technologies SA ('Fresh'), a leading Spanish interactive television BSkyB finance boss Darroch replaces Murdoch as CEO BSkyB finance boss Darroch replaces Murdoch as CEO Jeremy Darroch moves to the top spot at satellite TV heavyweight after boardroom reshuffle David Jetuah, 07 Dec 2007 BSkyB's finance boss Jeremy Darroch has been named as the organisation's new CEO. Verizon adds HD Video on Demand to FiOS TV - US operator Verizon has added on-demand high-definition titles to its FiOS TV service in many of the markets where the service is available. HD VOD titles are now available to FiOS TV subscribers in Richmond and Virginia Beach (Virginia), Tampa IPTV Corporation Appoints Supercomputing Pioneer Dr. Steve Chen as a Member of Its Board of Directors and Amazon Customers Set Gift Expectations High This Holiday Season City of Industry, CA --(www.USEquityNews.com)-- 12/07/2007 - Business service industry alert provided by U.S. Equity News. IPTV Corporation (OTC: IPTV), has appointed world renowned technologist Dr. Steve Chen as a member of its Board of Directors. Dr. Macrovision seeks to own digital TV gateway with Gemstar purchase A company known more for its digital rights management technology, and which just last month purchased not only the BD+ DRM scheme outright but also a larger stake in set-top boxes, is about to become the publisher of TV Guide. Macrovision, whose history Comcast taps lobbyist for digital TV WASHINGTON The firm will lobby for digital television and telecom issues and proposed legislation prohibiting states from imposing taxes on video programming services, according to the form posted online Nov. 15 by the Senate's public records office. BSkyB, JSAT Name New CEOs SATELLITE TODAY :: DAILY NEWS FEED Email This Page Archives Copyright Permissions Related Stories Sea Launch Delivers XM-4 Satellite To OrbitNDS Sees Healthy Revenue and Profits Boost Iridium Receives DISA Contract; Completes Phase One Test With Marine Comcast Taps Lobbyist for Digital TV Comcast Corp., the nation's largest cable television operator, hired LeClairRyan to lobby the federal government, according to a disclosure form. The firm will lobby for digital television and telecom issues and proposed legislation prohibiting states Comcast Taps Lobbyist for Digital TV NEW YORK (Associated Press) - Comcast Corp., the nation's largest cable television operator, hired LeClairRyan to lobby the federal government, according to a disclosure form. The firm will lobby for digital television and telecom issues and proposed Rupert Murdoch stands down as chairman of BSkyB LONDON - Rupert Murdoch is retiring as chairman of British Sky Broadcasting Group PLC, and his son James is standing down as chief executive officer to take a new position in the News Corp. media empire, BSkyB said Friday. James Murdoch has been Comcast Taps Lobbyist for Digital TV WASHINGTON (AP) - Comcast Corp., the nation's largest cable television operator, hired LeClairRyan to lobby the federal government, according to a disclosure form. The firm will lobby for digital television and telecom issues and proposed legislation Comcast taps lobbyist for digital TV Comcast Corp., the nation's largest cable television operator, hired LeClairRyan to lobby the federal government, according to a disclosure form. The firm will lobby for digital television and telecom issues and proposed legislation prohibiting states Comcast Taps Lobbyist for Digital TV WASHINGTON (AP) -- Comcast Corp., the nation's largest cable television operator, hired LeClairRyan to lobby the federal government, according to a disclosure form.The firm will lobby for digital television and telecom issues and proposed legislation Thank you Oleg PHD |
Florida
Usa
Post Number: 493 Registered: Aug-06
| Posted on Sunday, December 09, 2007 - 03:09 pm: |
Ofcom Introduces Spectrum Licence Type for Broadband Wireless Access on Trains A new type of spectrum licence enabling broadband access on trains, via a satellite link, has been made available by UK communications industry regulator Ofcom. Eutelsat Selects Alcatel Alenia Space for the Delivery of W2A Satellite Eutelsat Communications (Euronext Paris : ETL) and Alcatel (Paris: CGEP.PA and NYSE:ALA) announced that Eutelsat has retained Alcatel Alenia Space, the European leader in satellite systems, for the design, manufacturing, assembling, tests and on-ground delivery of the W2A satellite. CanalDigitaal Delivers World's First Wireless Entire-Home Satellite Distribution Service The Netherlands' sole commercial direct broadcast satellite provider will offer its customers the Caton V2O Wireless Home Media Network, the world's first satellite wireless STB system capable of whole-home video streaming. The V2O Wireless Home Media Network incorporates Airgo's TrueMIMO Media technology within a master media server with PVR and up to two slave boxes to receive live and recorded content anywhere in a household. Iridium and Raytheon Provide First Responders Fully Interoperable Emergency Communications Iridium Satellite and Raytheon's JPS Communications announce a joint marketing initiative to provide first responders a fully interoperable communications service for use in disasters. The two companies are making Iridium voice and data communications services available to customers packaged with the JPS ACU Interoperability Technology. WiMAX Operators Outbid Satellite Industry for Advanced Wireless Spectrum (AWS) DBS operators in the United States have taken an aggressive approach to the Advanced Wireless Services (AWS) spectrum auction currently being held by the FCC. A consortium called Wireless DBS qualified as a bidder; it includes EchoStar, DirecTV, News Corp., Rupert Murdoch, and Charles Ergen as interested parties. However the DBS operators' bids, although initially among the highest submitted, were largely unsuccessful, and Wireless DBS has dropped out of the bidding. Stratellite Deal with NASA Crashes GlobeTel Communications Corp. (GTE.A) on Friday said it received a notice from the National Aeronautics and Space Administration, saying it would terminate the memorandum of agreement signed on June 13, 2007. Americom Government Services and Wheat International Set New Record for Transferring Data Wirelessly for Military and Marine Applications Americom Government Services, Inc. (AGS) and Wheat International announced that the companies set a new documented record for mobile broadband Internet services recently during a public test of the TeleSea Network (TeleSea) in the Norfolk, Va., area. These long-range wireless Internet systems, which support high-speed data and voice traffic, can be set up instantly and have many commercial and government wireless applications, including meeting first responder needs during disasters. Wireless Interactive Completes 900 MHz OFDM Wireless Deployment in Iraq Wireless Interactive Comm. Inc. announced the completion if its newest network in Iraq utilizing the Orion-900, 900 MHz radios as a network of wireless backbone infrastructure which then is redistributed using the RedFire-200, 2.4 GHz WIFI product line. Israel Company Receives $11 Million to Fund WiMAX Triple Play Technology WiNetworks announced that it successfully raised $11M in venture capital funding. In this round, most of the funding came from WiNetworks existing investors, Cedar Fund, Columbia Capital and Rho Capital, with Evergreen entering as a new investor. This is the second major financing round for WiNetworks, which was founded in 2003 with seed financing from Cedar Fund. The capital raised will be used to expand WiNetworks' operations and accelerate its 'Go to Market' plan. Stratellites Get U.S. Airforce Approval GlobeTel Communications Corp.'s (AMEX:GTE) wholly owned subsidiary, Sanswire Networks LLC, has been granted a Statement of Capability (SOC) by the Air Force Flight Test Center (AFFTC) of the United States Air Force, permitting Sanswire to flight test its Sanswire 2 high altitude airship technology demonstrator. Sanswire began to seek approval for the SOC in February of this year. NASA's Dryden Flight Research Center, also located at Edwards, will provide meteorological services to the Air Force Flight Test Center in support of Sanswire's flight test effort. Wayfinder Mobile Satellite Service Warns Motorists of Speed Cameras With the number of speed cameras on British roads increasing all the time, Wayfinder, the live mobile satellite navigation service is advising motorists to take caution when driving. Speed Camera sites, whether they are mobile or fixed camera locations are growing year on year. Over 11, 000 speed camera locations, including fixed, mobile, free standing, traffic light and temporary cameras sites can be located all over the country. Globalstar Files for Expanded ATC Authority Globalstar, a leader in providing mobile satellite voice and data services to business, announced that that it has filed an application with the U.S. Federal Communications Commission (FCC) for authority to use all of its assigned mobile satellite service (MSS) spectrum for Ancillary Terrestrial Component (ATC) services in the United States Roadpost Selects Info Directions' CostGuard XG OSS/BSS to Support Expanding Operations Info Directions, a leading developer of net-centric billing, rating, order management, workflow and selling solutions for the telecommunications industry, is pleased to announce that Toronto-based service provider, Roadpost Inc., has selected its CostGuard XG back office solution to help manage the launch of new services to the company's international business clients ND SatCom Deploys Telemedicine Solution in Kazakhstan ND SatCom, a leading global supplier of satellite-based broadband VSAT, broadcast and defence communication network solutions, delivered 16 SkyWAN terminals which support telemedicine applications in Kazakhstan SeaKey Selects World Access as Concierge and Emergency Assistance Service Provider for Next-Generation Telematics Solution SeaKey LLC, a provider of onboard safety, security and convenience telematics services announced that it has chosen World Access to provide Concierge and Emergency Assistance for its next-generation satellite communications product Falcon Communications, Inc. Signs on as New Intelsat Ampiage Distributor in U.S. Intelsat announced that Falcon Communications, Inc., a provider of integrated services to U.S.-operated telecommunications companies (telcos), has signed an agreement with Intelsat to distribute Ampiage, Intelsat's satellite-based MPEG-4 video, open-architecture, transport service, to telcos and other multichannel system operators in North America New Emergency Management Solution Decontaminates Spaces of Pandemic Causing Viruses What may be the collective answer to emergency preparedness for local, state and federal response and recovery from large scale natural disasters, including pandemic outbreaks, has been unveiled by Florida-based AeroClave, LLC DSP Experts Launch New RF Development Platform to Help Developers Bring Products to Market Quickly Digital systems design and development continues apace, new tools to speed the process are in continual demand AT&T Launches Rural Satellite Broadband Internet Service AT&T Inc. (NYSE: T) announced the availability of its new satellite-based broadband Internet access service, delivering a new service option to millions of rural homes and businesses where DSL and cable services are not offered today Seamobile Acquires Maritime Telecommunications Network (MTN) SeaMobile, Inc., a global provider of advanced at-sea wireless voice, data, and Internet communications services, announced that it has acquired Maritime Telecommunications Network, Inc. (MTN), a provider of satellite-based broadband communications and networking services for the maritime industry Verso to Exhibit at CommunicAsia EURO/ECM66Verso Technologies, Inc. (Nasdaq: VRSO - News ), a provider of next generation network solutions, announced its participation at CommunicAsia 2008 (June 20-23) in Singapore, at the Singapore Expo, Stand 6E1-14, Hall 6, U.S. International Pavilion Eagle Broadband to Host Meeting for the Philadelphia Financial Community Eagle Broadband, Inc. (AMEX: EAG), a national provider of broadband, Internet protocol (IP) and communications technology and services, will host a special luncheon for Philadelphia financial analysts on Tuesday, May 23 to introduce them to the company, its services and future plans Eagle Broadband Announces a Second SatMAX Purchase Order From Textron Systems Eagle Broadband, Inc. (AMEX: EAG), a national provider of broadband, Internet protocol (IP) and communications technology and services, announced that the company has received another purchase order for its SatMAX non-line-of-sight satellite communications technology from Textron Systems Corporation WCC Launches Docking Station for Iridium Secure Military Satellite Phones World Communication Center (WCC), a provider of global satellite voice and data communications, announced the launch of the first docking station for the completely secure military/Department of Defense (DOD) Iridium satellite phones for indoor, maritime, or vehicle use Eagle Broadband Showcases Satellite Communications System at GSA International Products and Services Expo Eagle Broadband, Inc (AMEX: EAG), a provider of broadband, Internet protocol (IP) and communications technology and services, will showcase its SatMAX indoor/outdoor Iridium-based satellite communications system at the U.S. General Services Administration (GSA) International Products and Services Expo in San Antonio from May 15-18,2008 Evaluate The Latest Developments in the Australian Broadband Marketplace Research and Markets has announced the addition of 2006 Australia - Wireless Broadband - Personal Broadband to their offering AT&T Initiatives Expand Availability of Advanced Communications Technologies AT&T Inc. (NYSE:T) announced a series of moves that underscore the company's commitment to widely delivering the benefits of broadband Internet access and IP-based services to businesses and consumers throughout its traditional 13-state local service territory Stratos Announces First Quarter Financial Results Stratos Global Corp. (TSX: SGB), a global provider of advanced mobile and fixed-site remote communications solutions, announced financial results for the first quarter ended March 31, 2006 WCC Celebrates 2nd Anniversary of GSA Contract World Communication Center (WCC), a provider of global satellite voice and data communications, marks the second anniversary of its U.S. General Services Administration (GSA) contract, providing federal agencies with availability and competitive pricing on WCC satellite products and services ND SatCom Becomes Partner in Indian Joint Venture ND SatCom, a global supplier of satellite-based broadband VSAT, broadcast and defence communication network solutions announced the formation of a 50/50 joint venture with Grintex India Ltd |
Florida
Usa
Post Number: 494 Registered: Aug-06
| Posted on Sunday, December 09, 2007 - 03:11 pm: |
Att. (EURO/ECM666) coming soon !!!!! |
Toronto,
Ontario
Post Number: 225 Registered: Oct-07
| Posted on Sunday, December 09, 2007 - 03:55 pm: |
visit www.dish-keys.blogspot.com |
Post Number: 12 Registered: Sep-06
| Posted on Sunday, December 09, 2007 - 04:02 pm: |
so, do we still have BEV? because i can't get it after last night, i installed the new software and i had it for one night and then it was gone. my receiver is viewsat ultra. i still have every thing else, but not BEV. Does everyone else has it. please let me know. |
Silver Member Username: Rekman
Mntl-Quebec-...
Post Number: 236 Registered: Jun-06
| Posted on Sunday, December 09, 2007 - 05:06 pm: |
Hi, PLEASE Can someone refer me to a person who can FIX my Dish. Montreal Region THANK |
Gold Member Username: Dude123
Post Number: 1529 Registered: Jul-06
| Posted on Sunday, December 09, 2007 - 05:08 pm: |
whats wrong with your dish? May be we can help you here.... |
Bronze Member Username: Prince
Post Number: 54 Registered: Jun-06
| Posted on Sunday, December 09, 2007 - 06:34 pm: |
hi all - i have flu2700 and for some reason i cannot get channel #611. can someone please help. Thank you |
Post Number: 13 Registered: Sep-06
| Posted on Sunday, December 09, 2007 - 06:42 pm: |
