Home > Message Board > Home Video > DVD Recorders > Magnavox dvd recorder error message E...
Author Thread: Magnavox dvd recorder error message E4 54040990
Username: Musiclover1956
i get error message e454040990 when i try to record. i am sure i am using the right disk i have cleaned the recorder, i dont know what to do to fix this problem.
Relevant Product Info
Username: Dilbert68
Cathy
Try using a DVD / CD cleaner disc in the unit - this might fix the problem - I had the same format error on a Toshiba unit using Sony and VBerbatim discs - once cleaned the unit worked fine
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > DVD Recorders > Magnavox dvd recorder error message E... [ « Previous ] [ Next » ]
