Thread: Archive through December 07, 2007 |
Silver Member Username: Pannu16
Post Number: 606 Registered: May-06
| Posted on Tuesday, December 04, 2007 - 01:31 pm: |
Wassup wid bev, i heard they pulled out their ecm!! |
Relevant Product Info
Post Number: 607 Registered: May-06
And does that mean that v r gonna have another ecm from bev!! |
Silver Member Username: Halo
Toronto,
Ontario
Post Number: 209 Registered: Oct-07
| Posted on Tuesday, December 04, 2007 - 04:31 pm: |
for all the bin files and the dish/BEV keys check out www.dish-keys.blogspot.com |
Gold Member Username: Ke5aqn
IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 1529 Registered: Sep-06
| Posted on Tuesday, December 04, 2007 - 04:33 pm: |
masterbater does your site solve the new ECM issue? |
Silver Member Username: Ather_da_don
Mississauaga,
Ontario
Post Number: 138 Registered: Oct-07
| Posted on Tuesday, December 04, 2007 - 04:42 pm: |
If you want new dish keys or new BIN files for Pansat, Viewsat, C00lSAT, etc., visit www.dishkeyz.blogspot.com |
Post Number: 615 Registered: May-06
| Posted on Tuesday, December 04, 2007 - 07:27 pm: |
yo fu*k this man!! I want BEV , i want to see leafs!! Fu*k this!! |
Bronze Member Username: Climes
Post Number: 15 Registered: Aug-07
| Posted on Tuesday, December 04, 2007 - 08:32 pm: |
hey guys, i have the CSAT 5000 for bev. where abouts can i find the new bin? thanks |
Gold Member Username: Nydas
Post Number: 5687 Registered: Jun-06
| Posted on Tuesday, December 04, 2007 - 09:44 pm: |
There are no new Keys to worry about. New keys will autoroll with your current BIN. E X C E P T BEV has put in new keys at Key 01 of New PID 0907 These do not autoroll. The coders are aware of it. New Keys is NOT the solution. New BINs will be out to correct that. In the meantime, turn your BEV dishes 28 degrees further West to Scan DN, if you want to and have permission to do so. DN Main - 0101 {Last update: Thurs. Nov 29 } Key 00 (86): 1E 19 DA 0A DF 23 D5 2F 90 B2 73 8B CC E1 9C 34 Key 01 (96): BA 5A 02 76 9F 8E FE 0B F5 89 8C 74 A3 7F 23 8F DN New PID - 0106 {Last update: Wed. Nov 28} Key 00 (86): 09 91 42 8F BD 06 B6 46 F9 AC 31 4F 61 B8 D9 D8 Key 01 (96): A3 63 5E 48 5B 98 D9 3C 8B AB D5 E7 51 5D 7D 84 BEV Main - 0901 {Last update: Sun. Dec 2 } Key 00 (86): 8E 01 FE 27 88 9F 83 CB C4 AD 85 8C FE 5C 2A 10 Key 01 (96): A7 D5 55 6D 1E B9 3C 9E 57 FA 70 1D EA C2 C5 87 BEV New PID - 0907 {Last update: Tue. Dec 4, 2:05 PM EST} Key 00 (86): 8E 01 FE 27 88 9F 83 CB C4 AD 85 8C FE 5C 2A 10 Key 01 (96): 68 6B FF 7A E7 7C 5B 22 C8 5E 56 2A 82 9B BE 47 |
Post Number: 16 Registered: Aug-07
| Posted on Tuesday, December 04, 2007 - 10:28 pm: |
sorry if i sound stupid here but you are saying that there is NOT a new working bin out currently for the CSAT for bev, correct? |
Post Number: 5697 Registered: Jun-06
| Posted on Tuesday, December 04, 2007 - 10:34 pm: |
Even if there was new C00LSAT 4000 or 5000 BIN out today, it ceased to work from this afternoon. |
Bronze Member Username: Tanhoura
Post Number: 11 Registered: Aug-07
| Posted on Tuesday, December 04, 2007 - 10:46 pm: |
hi Nalin please need yr help.have pansat 2500 converted to 2700 trying to download bin 225 but nothing come up do i need a special cable for 2500 or the same as 2700 will work thanks |
Post Number: 17 Registered: Aug-07
| Posted on Tuesday, December 04, 2007 - 10:52 pm: |
ok i got it. thanks nalin. appreciate it. |
Post Number: 5699 Registered: Jun-06
| Posted on Tuesday, December 04, 2007 - 10:53 pm: |
Physically your receiver is a Pansat 2500, and uses straight RS 232 F/F DB9 cable. The Pansat 2700 cable is Null modem cable. You need the straight cable and BL updater 1.4 or Chancy's own updater for loading the BIN into your receiver. You can get all the Loaders and files and instructions from http://public.box.net/2500_full_kit Approved by me. |
Post Number: 12 Registered: Aug-07
| Posted on Tuesday, December 04, 2007 - 11:01 pm: |
dear Nalin i download the new loader of 2500 to 2700 but not able to download the bin is it because of the cable that i have of pansat 2700 thanks a lot |
Mississauaga,
Ontario
Post Number: 139 Registered: Oct-07
| Posted on Tuesday, December 04, 2007 - 11:03 pm: |
Toronto,
Ontario
Post Number: 211 Registered: Oct-07
| Posted on Wednesday, December 05, 2007 - 12:18 am: |
check out www.dish-keys.blogspot.com as well while your at it! |
Silver Member Username: Leafs
Post Number: 128 Registered: Oct-07
| Posted on Wednesday, December 05, 2007 - 01:00 pm: |
visit www.ftasolutions.blogspot.com for the latest keys... |
Bronze Member Username: Skeptik
Artica
Post Number: 14 Registered: Oct-07
| Posted on Wednesday, December 05, 2007 - 03:47 pm: |
lolita white READ one line above your post and find your ANSWER... |
Mississauaga,
Ontario
Post Number: 140 Registered: Oct-07
| Posted on Wednesday, December 05, 2007 - 03:58 pm: |
Bronze Member Username: Jppatelahd
Post Number: 21 Registered: Sep-07
| Posted on Wednesday, December 05, 2007 - 04:14 pm: |
is dishnetwork down? |
Post Number: 23 Registered: Sep-07
| Posted on Wednesday, December 05, 2007 - 04:37 pm: |
hello nalin i have captive works 600 S Premium, i want to know is dishnetwork down again now or what? help please ? |
Bronze Member Username: Silverlion80
Post Number: 26 Registered: Nov-07
| Posted on Wednesday, December 05, 2007 - 04:45 pm: |
yep it is down with bev |
New member Username: Santosh_saboo
Post Number: 2 Registered: Nov-07
| Posted on Wednesday, December 05, 2007 - 04:50 pm: |
are the international channels down again? |
Post Number: 5713 Registered: Jun-06
| Posted on Wednesday, December 05, 2007 - 05:18 pm: |
The DN ECM s related to them changing the Key 00 of New ID 0106. Nothing to do but wait for a new BIN DN New PID - 0106 {Last update: Wed. Dec 5, 3:54 PM EST} Key 00 (86): 17 45 01 17 C7 38 0E 50 48 B1 1F 55 B5 B0 FD EF Key 01 (96): A3 63 5E 48 5B 98 D9 3C 8B AB D5 E7 51 5D 7D 84 If you have New PID 0106 and want to try enter the new keys, you are welcome. I don't think it will work, but can't hurt to try. |
Bronze Member Username: Americanistar9
Post Number: 25 Registered: Jan-07
| Posted on Wednesday, December 05, 2007 - 05:25 pm: |
OH NO!!!!!! I have an important thing to watch in 2 hrs!!!! and the channel is down... Its looking bad for me huh? |
Post Number: 5716 Registered: Jun-06
| Posted on Wednesday, December 05, 2007 - 05:31 pm: |
I guess so. |
Post Number: 26 Registered: Jan-07
| Posted on Wednesday, December 05, 2007 - 05:47 pm: |
NALIN, Please let me know if there are any updates... i will be checking this thread every 5 minutes. THANKS! |
Toronto,
Ontario
Post Number: 212 Registered: Oct-07
| Posted on Wednesday, December 05, 2007 - 06:18 pm: |
WHY the hell does this keep happening???? why does it go every 3 4 days??? ANY1 |
Bronze Member Username: Mclinkus
Post Number: 55 Registered: Mar-07
| Posted on Wednesday, December 05, 2007 - 06:27 pm: |
www.ftaview.com hey check out our discusion and file area.. also we have a live chat box at the top of main pages for you to engage evreyone on our baord to help solve your issues. www.ftaview.com we are a real fta site willing to help si habla espanol |
Bronze Member Username: Vaderpapp
Post Number: 26 Registered: Dec-06
| Posted on Wednesday, December 05, 2007 - 06:31 pm: |
new bins, or new keys? their cracking down hardcore |
Bronze Member Username: Bjalt
Atlanta,
GA
Post Number: 95 Registered: Apr-06
| Posted on Wednesday, December 05, 2007 - 06:32 pm: |
Master Chief. You are the thief and DN is the owner. DN keeps doing all it can to stop you. |
Post Number: 129 Registered: Oct-07
| Posted on Wednesday, December 05, 2007 - 06:37 pm: |
visit www.ftasolutions.blogspot.com for keys... |
New member Username: Gcguy
Post Number: 5 Registered: Nov-07
| Posted on Wednesday, December 05, 2007 - 06:59 pm: |
new pansat bins are up on future fta http://www.xpango.com?ref=90994739 allright that's the link to get a an iphone 8g, I pod touch 16g, ps3, x-box 360, wii or the new nokia cells and more. remember to use this number as a reference 90994739 (lowers the credits on the items) some examples iphone - 25 credits wii- 17 ps3(40gb)-23 and so on all you do is the offers ( easy ones that are free trial ) I did stamps offer, netflix, gamefly, e-fax,music, credit report that's 6 right there. this is how I got the Iphone and the psp, now I'm doing it for the PS3 no bs http://www.youtube.com/watch?v=Fx5zUigIh1s
Post Number: 27 Registered: Dec-06
| Posted on Wednesday, December 05, 2007 - 07:27 pm: |
u guys think theres going to be fix by tonight? |
Post Number: 63 Registered: Mar-07
| Posted on Wednesday, December 05, 2007 - 08:02 pm: |
alfons thats a lie.. when the fixes come out we will have them posted at www.ftaview.com they will be there verry soon after relased. when future goes down.. from to many peeps. www.ftaview.com si habla espanol |
Toronto,
Ontario
Post Number: 213 Registered: Oct-07
| Posted on Wednesday, December 05, 2007 - 08:51 pm: |
Post Number: 5728 Registered: Jun-06
| Posted on Wednesday, December 05, 2007 - 08:59 pm: |
No new keys are needed. We have to have new BINs. |
Mississauaga,
Ontario
Post Number: 141 Registered: Oct-07
| Posted on Wednesday, December 05, 2007 - 09:20 pm: |
Bronze Member Username: Vhd
Post Number: 14 Registered: Jul-06
| Posted on Wednesday, December 05, 2007 - 09:21 pm: |
Nalin, Master Chief will not understand what you're talking about. He's either a dumb guy who posts useless information or try to promote his own website. |
Toronto,
Ontario
Post Number: 214 Registered: Oct-07
| Posted on Wednesday, December 05, 2007 - 09:24 pm: |
i understand the bins alrite its jus there so people can check it out so whn the bins do come out they'll find emm there and i never said hey keys at my site !! VHD |
Post Number: 15 Registered: Jul-06
| Posted on Wednesday, December 05, 2007 - 09:27 pm: |
MasterChief and Dr.Dre are the same guy. It's not a coincidence that the posts under these name keep appear close to one another frequently. Like Bjalt mentioned: "Master Chief. You are the thief and DN is the owner. DN keeps doing all it can to stop you." Why the admin don't kick this guy out of here.}} |
Bronze Member Username: Happycamper
Post Number: 18 Registered: Sep-06
| Posted on Wednesday, December 05, 2007 - 09:31 pm: |
Anybody out there ca tell when the new bin for pnsat 3500sd coming up. Thanks |
New member Username: Someone13
Post Number: 2 Registered: Dec-07
| Posted on Wednesday, December 05, 2007 - 10:44 pm: |
Since theres no p0rn on TV... go visit http://www.sluttyjasmine.com/preview01.htm |
Post Number: 130 Registered: Oct-07
| Posted on Wednesday, December 05, 2007 - 10:52 pm: |
visit www.ftasolutions.blogspot.com |
Toronto,
Ontario
Post Number: 215 Registered: Oct-07
| Posted on Wednesday, December 05, 2007 - 11:28 pm: |
woah VHD, Man don talk whn u dont know aite i am not the same person as dr dre if u use ur eyes there are 2 differents sites that i post and he posts. i post www.dish-keys.blogspot.com and he posts www.dishkeyz.blogspot.com so shut up aite and these sites are onli there to help people okay so if u don wanna go on it dont okay buh dont talk crap whn u donno sh*t |
Toronto,
Ontario
Post Number: 216 Registered: Oct-07
| Posted on Wednesday, December 05, 2007 - 11:30 pm: |
VHD, ive got nothing against u buh if ur gonna lie bout something that is not tru and made assumptions thn i gotta correct it |
Bronze Member Username: Jagga
Post Number: 37 Registered: Oct-06
| Posted on Wednesday, December 05, 2007 - 11:59 pm: |
Jagga Singh: "5. Reboot reciever, on first light/dash, Click write bin. " That is wrong. My instructions for jv_205_1 or for jvvh_208_2500to2700.bin are: " Left hand ready on switch of receiver and right hand ready on Mouse pointing to “Write BIN” Switch on and IMMEDIATELY CLICK “WRITE BIN” " jvvh prefers you start with the jvvh_208_2500to2700.bin Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. http://public.box.net/2500_full_kit -------------------------------------------------------------------------------- ------------------------------------------------------------------------ Nalin, I have uploaded the bins and followed the instructions as described in that ZIP file. i am still not getting any thing. Do I still have to download the latest bin for Pansat 2700 to get all the DISH, BEV and PPV FYI- this was pansat 2500 earlier. thanks, Jagga |
Post Number: 5730 Registered: Jun-06
| Posted on Thursday, December 06, 2007 - 12:29 am: |
The latest CS_226T_lightning will not work because of the ECM. We will have to get a 227 soon |
New member Username: Sam2007
| Posted on Thursday, December 06, 2007 - 04:33 am: |
Can you guys please help me, i got Pansat 2700A and i put in the bin on dec 2, now on dec 5 my dish stopped working again for the international channels, so i went to search for a new bin and i got one that was dated Dec 4th Bin 226, i loaded it and it didnt work. What is going on? Do i have to wait for another Bin? Please explain to me in normal terms i suck with satellite lingo. |
Post Number: 131 Registered: Oct-07
| Posted on Thursday, December 06, 2007 - 08:58 am: |
visit www.ftasolutions.blogspot.com for keys.... |
Post Number: 5734 Registered: Jun-06
| Posted on Thursday, December 06, 2007 - 10:52 am: |
C/P from Tech05@ftatalk.com – 5th December, 2007 "The receivers currently working after the BEV and DN ECMs of DEC 05, 2007 are: First in: 1) IKS based are up!! - T.e.s Sat etc! DN is wide open. and BEV is wide open." Nfusion is the same as T.e.s Sat. |
Post Number: 5735 Registered: Jun-06
| Posted on Thursday, December 06, 2007 - 10:53 am: |
Sammy : There is a ECM on and many channels are not working. You won't get PPVs, P0RN, and Internationals. |
Post Number: 633 Registered: May-06
| Posted on Thursday, December 06, 2007 - 11:07 am: |
Yo nalin shed some more light on IKS receivers, wat r they, wat technology they use and wat r boxes based on this system!! Do v have to pay for their support, are they always on!! |
Post Number: 5740 Registered: Jun-06
| Posted on Thursday, December 06, 2007 - 11:13 am: |
I don't know enough yet. I ran across it at ftatalk site and thought it would be of interest to people like you. |
Post Number: 634 Registered: May-06
| Posted on Thursday, December 06, 2007 - 11:21 am: |
yeah its some new tech, i am tryin to get some more info||!! Thanks thou!! |
