Home > Message Board > Home Video > HDTV Reception > Samsung le32r78
Author Thread: Samsung le32r78
Username: Wabster01
Notts
Uk
hello there iv got a samsung le32r78 and when im playing ps3 it looks like the tv carnt cope with the graphics and lines go through the screan like graphic glitchs. i had the repair man out today that fitted a new board or whatever it is and its still doing it,so now they are saying its my ps3 even though it does it on my mates ps3 and xbox 360 but when i take my ps3 to his it doesnt do it.anyboady know or heard anything else like this?
Relevant Product Info
Username: John_s
Columbus, Ohio
US
Post Number: 1965
I am assuming you are using an HDMI cable from the PS3 to the TV. Defective HDMI cable? Maybe. Have you tried component into the Samsung? You do have to get a special cable to fit the PS3's proprietary A/V output, but I'll bet that will work better.
Username: John_s
Columbus, Ohio
US
Post Number: 1966
Before you try component, make sure you haven't configured the PS3 to output 1080p. The PS3 should be sending 1080i to the Samsung.
Username: Wabster01
Notts
Uk
iv tried 2 different hdmi cables and 2 different ps3s.iv also got it set to 720 not 1080
Username: John_s
Columbus, Ohio
US
Post Number: 1967
The video should be fine with the PS3 at 720...Upload
Even so it would be interesting to see if you have the same problem with the PS3 at 1080i.
Also, does the "gaming mode" on this TV make any difference?
Username: Wabster01
Notts
Uk
it does this at 1080 and no the game mode doesnt make any difference.my mate came to look at it the other day and said its nowhere near his picture on his tv which is the very same model
Username: John_s
Columbus, Ohio
US
Post Number: 1968
If the TV works well with regular TV (freeview, cable, satellite, or what have you) then how can you blame the repair people for pointing their finger at the PS3?
Did you use HDMI when you tested your mate's xbox 360?
Username: Wabster01
Notts
Uk
i used his hdmi cable and i also took my ps3 to his house.it all points to my tv.when i watch normal tv via sky the picture is very ghosty and looks very boxy
Username: John_s
Columbus, Ohio
US
Post Number: 1971
I would get an exchange. It does sound like there's a definite problem with this TV.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > HDTV Reception > Samsung le32r78 [ « Previous ] [ Next » ]
