Home > Message Board > Home Video > HDTV Reception > HDMI / DVI Compared to HDMI
Author Thread: HDMI / DVI Compared to HDMI
Username: Dizzle613
Ottawa, Ontario
k. Im going to be getting the Rogers DCT3250 High Definition Cable Box to go along with a Sony bravia tv. The HD cable box is DVI output and the TV is HDMI, so if i buy a monster HDMI/DVI cable would i experience the same picture quality as an HDMI cable? I know sound will be different so in that case im assuming a monster optical audio cable will replace whatever audio signal the monster HDMI cable provided.. so in the end the HDMI/DVI cable with the optical audio cable will be equivalent to a monster HDMI cable in terms of sound and picture quality right?
Relevant Product Info
Username: John_s
Columbus, Ohio
US
Post Number: 1960
Because there will be no audio signal on the cable box's DVI output, you will have no sound on the TV's speakers with just the DVI/HDMI cable going into the TV. So you'll have to hookup analog audio into the the TV, or use the cable box's digital audio output into an external audio system.
Since HDMI is backwards compatible with DVI, the digital video on your display should be outstanding.
Username: Joelqin
Post Number: 37
Audio-video DIVX function HDMI portable DVD player
Model: D6148H
Product Detail: portable DVD player
Support: SD/MMc/MS card, USB port, DIVX function
TV systerm: PAL/NTSC
Power adaptor: AC INPUT:110V-240V; DC OUTPUT:12V
Unit size: 180mm x 150mm x 30mm
This portable DVD player includes a rechargeable battery pack enabling 2 hours continuous play time.
It's Sleek, Simple to use and Powerful. This portable entertainment system allows you to view your favourite DVDs or CDs on the go. Compatible DIVX player, capable of playing most DVDs and CDs, including MP3, MP4, VCD, DIVX and JPEG files, DVD player enables you to view pictures and movies and listen to CDs, all with the one unit.
LCD display with superior video quality, built-in surround sound effect stereo speakers, with Dolby Digital decoding and anti shock suspension for those restless kids.
Exclusive design, super slim unit
High definition multimedia interface (HDMI) output
HDTV/YUV output
Support SD/MMC/MS card and with USB port & DIVX function
DVD,DVD-R,SVCD,DVCD,VCD,CD,MP3,mp4,CD-R/RW,JPEG compatible
Multi function appearance adjustment and more clear picture
Super anti-shock
VGA output
Audio-video output function
Optical fiber 5.1ch output
Zoom of picture function
Full TV systerm:PAL/NTSC
Multi language menu
Support multi regional disc.
power adaptor (AC INPUT:110V-240V; DC OUTPUT: 12V)
Unit size:180mm x 150mm x 30mm
Username: John_s
Columbus, Ohio
US
Post Number: 2001
???Upload???
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > HDTV Reception > HDMI / DVI Compared to HDMI [ « Previous ] [ Next » ]
