Thread: DVD recorder interruption during vcr to dvd dubbing |
New member Username: Mickw
Naples,
Florida
Post Number: 2 Registered: Nov-07
| Posted on Friday, November 30, 2007 - 04:03 pm: |
During vcr to dvd dubbing with a sony rdr-vx525, the recorder stops periodically--sometimes as often as every sixty seconds--and leaves the following message "Updating the information of disc. Please wait for a moment". At the same time the front panel of the recorder displays "INF WRITE". When the disc is finalized and played back, I can neither fastforward or backup past the location where the disc "Updating...". I have to watch a pause, about 5 seconds of tv, and then the disc will play until the next "Updating.." occurrance. Interestingly I have tried re-dubbing these vhs tapes and they always are "Updating .." at the exact same spot. The spot does not necessarily fall at a point where the original recording was turned off or on or interrupted in any way. This is very annoying. Any thoughts? Thank You |
Relevant Product Info
Gold Member Username: Samijubal
Post Number: 3641 Registered: Jul-04
| Posted on Sunday, December 02, 2007 - 12:24 pm: |
Are you using RCA jacks for dubbing? Sounds like a weak VHS signal making the recorder think there's no signal. Some recorders are more prone to this problem than others. |
New member Username: Ieee488
Post Number: 1 Registered: Dec-07
| Posted on Wednesday, December 05, 2007 - 11:46 am: |
maybe "bad" DVD blanks which brand are you using? |
New member Username: Sonybuff
| Posted on Thursday, December 27, 2007 - 05:23 pm: |
Help - I have the same problem - on a brand new out-of-the box VX-525 machine - I'm using Verbatim DVD +R disks. The RX525 dubs VHS to DVD internally, There are no RCA cables involved. What brand and type of DVD disk have all the successful users been using? |
Post Number: 4 Registered: Dec-07
| Posted on Thursday, December 27, 2007 - 05:41 pm: |
Verbatim discs are suppose to be some of the better ones. I only use made-in-Japan discs that are very difficult to find in retail stores. |
Post Number: 3674 Registered: Jul-04
| Posted on Friday, December 28, 2007 - 12:48 pm: |
Are the Verbatim discs made in Taiwan or India? If they are MIT discs, it's not the discs. It's either a problem with the recorder or the VHS signal is too weak and the recorder thinks there's no signal. |
New member Username: Blue2
New Jersey
| Posted on Sunday, December 30, 2007 - 08:43 am: |
I have the exact same problem with Sony RDR VX525. Purchased different/faster DVD blanks with no change in results. |
Post Number: 3680 Registered: Jul-04
| Posted on Sunday, December 30, 2007 - 12:57 pm: |
I think Sony is using Samsuck for thier recorders these days. If so, that's surely the problem. |
New member Username: Wfred
Post Number: 1 Registered: Jan-08
| Posted on Sunday, January 06, 2008 - 09:21 pm: |
I had the same problem, trying all types of disks-ruining many. I finally called the helpline and was told that since I was using Sony disks and still having problems, that is was the equipment. I sent it out for warrenty repair. It was fixed, and has been working fine since then. Now I accidently reset the remote command to DVD 1, while trying to understand what each one did. Now I can't use the remote to get out of it, so I can't finalize any DVDs. I also can't figure out if there is a setting I can use for the DVD's to be able to edit the DVD scenes on my computer. I can play back the DVD's on my computer without finalizing them. Any success with anyone? |
New member Username: Maxproducts
| Posted on Sunday, January 06, 2008 - 09:27 pm: |
does anyone know what type of compression the vhs-dvd transfer process uses in the high quality mode? ie. mpeg mpeg2 ( is there a substantial difference? |
Post Number: 2 Registered: Jan-08
| Posted on Sunday, January 06, 2008 - 09:28 pm: |
sorry, for the sony rdr-vx525 steve} |
New Jersey
Post Number: 2 Registered: Dec-07
| Posted on Monday, January 07, 2008 - 05:49 pm: |
I went on different forums and found out that it might be the VHS tapes. I tried a different VHS tape and had no problems dubbing it. |
