Thread: HDTV Recption |
New member Username: Maxdout38
South Bend,
IN
United States
Post Number: 1 Registered: Nov-07
| Posted on Thursday, November 22, 2007 - 07:29 am: |
Hello All: I live on the south side of South Bend Indiana. I would like to pick up the HD in Chicago. They are approx. (70 to 90) miles away for their towers. I know some of the HD is VHF and most is UHF (http://www.antennasdirect.com/HDTV_station_lists.html) Is this feasible with an outdoor antenna? I am sure I need a tower. Are there companies that still install towers? I am trying to do some homework before I try something I might regret. Any help would be appreciated. Thank you |
Gold Member Username: Tapeman
New York City in-HD,
NY
Post Number: 1817 Registered: Oct-06
| Posted on Thursday, November 22, 2007 - 11:03 am: |
- Yo need the new HD amplified antennas (winegard GS-2200 or Terk) - Do a survey at: http://www.antennaweb.org/aw/Address.aspx - Check my few different listed antenna brands at: http://forum.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1062457#POST1062457 If yo buy it from Best Buy or Circuit City they may install it for yo for yo for about $50 - Or yo can follow my simple steps here: http://forum.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1077210#POST1077210 |
Gold Member Username: Samijubal
Post Number: 3624 Registered: Jul-04
| Posted on Saturday, November 24, 2007 - 01:19 am: |
I get channels 65 miles away with an old antenna in the attic fine. I use a booster, but I don't know if I actually need one or not. |
New member Username: Jayko7
Post Number: 1 Registered: Jan-08
| Posted on Monday, January 14, 2008 - 04:43 pm: |
Hi, I am new to this so if I am asking a ? that has already been asked please direct me to the right place. I just recently purchased a Sony 32" HDTV LCD. In the area I live in (Hillsboro OR.) the receiver picked up 40 some Digital Channels. But when I put my TV on these channels the Picture breaks up or sometimes I loose the Single. Do I need to purchase a Digital Antena? & if so what do you recomend? & how is it set up? |
NY
Post Number: 2131 Registered: Oct-06
| Posted on Monday, January 14, 2008 - 09:00 pm: |
Do yo have an indoor or outdoor antenna? |
Post Number: 2 Registered: Jan-08
| Posted on Tuesday, January 15, 2008 - 01:49 pm: |
Neither, the TV is hooked uped to Comcast Cable. During the set up it searched for Regular Cable Channels then Digital channels. That is why I was wondering, if I hooked up an Indoor Antenna, would it help with the reception of those channels? Thank You George |
NY
Post Number: 2166 Registered: Oct-06
| Posted on Tuesday, January 15, 2008 - 07:16 pm: |
If I were yo Never buy an indoor antenna Unless if yo absolutly must to Indoor antenna loses at least half of the signal |
New member Username: Juniorcal
Lakewood,
California
La
Post Number: 1 Registered: May-08
| Posted on Saturday, May 31, 2008 - 11:57 am: |
PROBLEM ON MY HDTV SONY WEGA ENGINE 3LCD MODEL # KDFE60A20 IS PICTURE AND SOUNDS ARE OFF FOR 2 MINS & ON FOR 1 MIN BUT THE POWER IS STILL ON THE GREEN LIGHT |
