Thread: Samsung DLP TV service mode key sequence |
Bronze Member Username: Konikgarbusek
Post Number: 16 Registered: Sep-05
| Posted on Friday, November 02, 2007 - 05:43 pm: |
Samsung DLP TV model HLN. Does anybody know what is the remote control key sequence to enter the service mode? I need to adjust picture's heihght. Thanks for any tips... |
New member Username: Auto1129
Post Number: 1 Registered: Nov-07
| Posted on Saturday, November 03, 2007 - 10:25 am: |
I have a Samsung DLP 56" TV bought in early 2006 (model HLR5678) and it's been GREAT until just this past week when a gray "shaded" vertical line appeared (about an inch wide) on the far left edge of the screen. You can still see the picture through this area but it has just happened. Could this be something to do with the bulb? We have never left the TV on "paused" so am not sure what may have caused the line to appear. Any ideas on how to correct this? Thanks! |
New member Username: Ajax_one
| Posted on Saturday, November 17, 2007 - 02:02 pm: |
To enter service mode Samsung DLP model HLN With tv off...on the remote... push Mute, 1, 8, 2, Power set comes on with SM menu screen 1 using arrows...arrow down to Option and press enter. up comes screen 2 lamp hours and reset are there. Be careful! Left and right arrows change things! Press Menu to go back a screen. Power off and back on quickly to exit the SM and watch. |
Post Number: 2 Registered: Nov-07
| Posted on Saturday, November 17, 2007 - 02:21 pm: |
Samsung DLP random shut down model HLN 4365W Had this TV for 3 years 100% trouble free. It now turns off at random just like somebody hit the power switch. On one occasion the temp light was on, but just the one time. Hit the power on the remote it comes back on and works fine. There is no pattern to these shut downs, this can happen after the TV is on 5 minutes or 2hrs or it does not happen at all. I have 5456 hrs on the lamp. Does anybody have suggestions on what is wrong? |
New member Username: Dtrj
| Posted on Wednesday, November 21, 2007 - 06:04 pm: |
Have a HLR 5677. JUST REPLACED THE BULB AT 8434 HOURS. WENT TO RESET THE BULB COUNTER IN SERVICE MENU BUT IT WONT RESET. PUT IN MUTE182/POWER. WENT TO OPTIONS. FIRST ITEM SAYS CLEAR LAMP, SECOND ITEM SAYS USER RESET. CLICKING ON CLEAR LAMP DOES NOTHING. AM I SUPPOSED TO CLICK ON USER RESET AS WELL? NOT SURE AND I DONT WANT TO SCREW UP THE SET THANKS |
New member Username: Mpw3rd
Post Number: 1 Registered: Dec-07
| Posted on Friday, January 11, 2008 - 10:42 pm: |
hello samsung suffers and everyone else, my leftside shadow condition as related to samsung customer service yield a referral to exec customer service from whom i have not heard a word. they need to be hounded to no end in order to get compensation for the gross defect that is the "shadow condition" appearing on the screens of hundreds if not thousands of sets like mine (hlr5668w aug. 2005). please keep calling and emailing as often as possible. good luck, mpw3rd |
