Thread: Anik F3 Help |
Bronze Member Username: Sam5002
Ny,
Ny
Usa
Post Number: 50 Registered: Jan-06
| Posted on Thursday, November 01, 2007 - 09:42 pm: |
My DISH is pointed to 121W, there is a new Circular LNB with higher frequency out there. My concern is, If I use new LNB and turn the dish to 118W still i am going to catch channels from 121w or not? or is there any trick to set the dish to catch from 118 to 121? |
Bronze Member Username: Scorp7
Post Number: 63 Registered: Mar-06
| Posted on Thursday, November 01, 2007 - 11:36 pm: |
You need one LNB for each dish. Yes there are dishes and brackets available where u can mount mutiple LNBs on one dish to get nearby satellites. Mounting 3 is pretty common and u can go upto 4/5 easily with new brackets. |
Bronze Member Username: Ftaexplorer
Post Number: 39 Registered: Oct-07
| Posted on Friday, November 02, 2007 - 12:18 am: |
Echo 9 is a linear sat with linear transmission. Anik f3 is circular transmission, but with the special cb200 or cb2ooa circular lnb with 10750 output u can only use it on circular sats,and anik f3. Your linear lnb from echo 9 won't work on anik f3, or vise versa. |
Post Number: 40 Registered: Oct-07
| Posted on Friday, November 02, 2007 - 12:26 am: |
circular sats need a deferential of 9 degrees apart, linear is min of 3 dgrees apart, attach the cb2ooa beside the echo 9 lnb and scan it should work, but i cannot confirm it ,as i've not tryed those two sats combined,but theroritically it's a go. I have echo 3,5,7,8/10,nimiq 1/3 and 2 ,dtv101 . my linear dishes are disconnected at moment,use them for true fta. |
Post Number: 41 Registered: Oct-07
| Posted on Friday, November 02, 2007 - 12:31 am: |
and i have the cb200a as my echo7,anikf3 lnb,working great,[f3> 101] channels, and some radio too. |
Ny,
Ny
Usa
Post Number: 51 Registered: Jan-06
| Posted on Friday, November 02, 2007 - 06:23 am: |
Thanks everyone for the help.. |
