Thread: Viewsat xtreame. File load problem |
Bronze Member Username: Ptaha
Post Number: 11 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 07:27 pm: |
Hi there. I had connected my VS to the serial port... Started the loader found the file and pc to stb option... This took me to the window that said something something sending and nothing happened What's wrong? please help P.S. Got all the files from totalfta.com |
Bronze Member Username: Saqeeb9000
Post Number: 42 Registered: Oct-07
| Posted on Thursday, November 01, 2007 - 07:40 pm: |
have u ever tried loading the file before from totalfta.com? or is it ur first time. u have to turn of ur reciever from back and when it says sending just turn it on from back.. it should work.. double check connection + right file for right reciver... |
Post Number: 12 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 08:23 pm: |
first time i'm trying to do this.. can you please give me the links for the correct file? please? thx |
Gold Member Username: Donnie1973
Post Number: 1581 Registered: May-06
| Posted on Thursday, November 01, 2007 - 08:28 pm: |
totalfta.c0m new files right on the front page. U may need to copy/paste that zmodem file in to ur system folder on the c drive. Also, where did u get the cable? Where did u get the loader? Whats the name of the loader program? |
Post Number: 13 Registered: Aug-07
| Posted on Thursday, November 01, 2007 - 09:11 pm: |
the guy who installed the thing gave me cable... the loader from fta asked for a link loader 2 was the name I think... Can u please give ma a link to files/loader so I can a correct one if possible HELP is APPRECIATED |
Post Number: 1588 Registered: May-06
| Posted on Thursday, November 01, 2007 - 09:34 pm: |
totalfta.c0m has it on the main page |
Bronze Member Username: Guanajuatos_best
Post Number: 93 Registered: Jul-07
| Posted on Thursday, November 01, 2007 - 10:31 pm: |
YO SON TRY TO UNZIP THE FILE |
Post Number: 1602 Registered: May-06
| Posted on Thursday, November 01, 2007 - 10:45 pm: |
ahhh, the simple things.... Sometimes u forget not everyone uses a pc much. my money is on that paisa |
Silver Member Username: Timscarlet
Usa
Post Number: 262 Registered: Feb-05
| Posted on Thursday, November 01, 2007 - 10:47 pm: |
viewsats need to be turned off first, load loader, press pc to stb, turn on viewsat in back, this will start load |
Post Number: 1604 Registered: May-06
| Posted on Thursday, November 01, 2007 - 10:58 pm: |
sada said that earlier. There is a great pdf file with pics at total. It comes with the loader 2 zip file. |
