Thread: Archive through October 31, 2007 |
Gold Member Username: Asharfi
Post Number: 1244 Registered: Aug-06
| Posted on Monday, October 29, 2007 - 10:25 pm: |
cs, - Turn OFF your unit from the back - Disconnect the satellite cable - Wait 10 seconds - Reconnect the satellite cable - Turn your unit ON |
New member Username: Mikemo
Torrance,
California
Usa
Post Number: 4 Registered: Sep-07
| Posted on Monday, October 29, 2007 - 10:26 pm: |
hi guys i new kid on block here,can someone please help me i did the factory default reset everthing did all over again, now i missing some of the channel.and some channel are double. how can i get the missing channel back> i have VS2000 PLATINUM. Pleaed advise what to do. |
New member Username: Casgzz
Post Number: 10 Registered: Oct-07
| Posted on Monday, October 29, 2007 - 10:29 pm: |
AV, I did that but i aint getting signal, need to find another sat or something? i got the 218 bin, i was reading something about 218v1 but did not understand at all |
Post Number: 1248 Registered: Aug-06
| Posted on Monday, October 29, 2007 - 10:32 pm: |
cs, Yes, there are some stupid problems going on with the latest Jvvh bin. Jvvh didn't make this bin, it's this other new kid who made it. |
Post Number: 1251 Registered: Aug-06
| Posted on Monday, October 29, 2007 - 10:35 pm: |
ZIA, Please check this thread for the Pansat 2500 conversion : http://forum.ecoustics.com/bbs/messages/2/398851.html |
Bronze Member Username: Casgzz
Post Number: 11 Registered: Oct-07
| Posted on Monday, October 29, 2007 - 10:39 pm: |
AV, so i will have to wait for the bin?? no need to do anything else? |
Post Number: 1255 Registered: Aug-06
| Posted on Monday, October 29, 2007 - 10:44 pm: |
cs, The new working bin for the converted FLUs and P2500s is out, but has some little bugs ... you can load it and watch TV ... all DN and BEV is working fine ... |
Post Number: 12 Registered: Oct-07
| Posted on Monday, October 29, 2007 - 10:50 pm: |
AV, mine is not converted is 2700a, just reloaded the 218 bin but i keep getting no signal =( |
Post Number: 1258 Registered: Aug-06
| Posted on Monday, October 29, 2007 - 10:55 pm: |
Oh, so you have the original Pansat 2700? If yes, then please try to do FACTORY RESET and the check your ANTENNA SETTINGS. Then, re-scan your sats |
New member Username: Gq78
Post Number: 2 Registered: Oct-07
| Posted on Monday, October 29, 2007 - 10:56 pm: |
can anyone please tell me how I can get my Pantec 2500 Ultra receiver working again?? It's a clone receiver of a pansat I believe.. What do I need to do now? pls anyone.. ty |
Bronze Member Username: Halo
Toronto,
Ontario
Post Number: 40 Registered: Oct-07
| Posted on Monday, October 29, 2007 - 11:01 pm: |
For latest dish / bev keys PID 0101 and 0106 and latest bin files at www.dish-keys.blogspot.com Converting info and files also available |
Post Number: 13 Registered: Oct-07
| Posted on Monday, October 29, 2007 - 11:04 pm: |
the question is what sat should i rescan? i get 0% of quality on whatever the sat i choose =( |
Post Number: 1262 Registered: Aug-06
Guy Anderson, From what I know, those receivers are Pansat 2500 CLONES, am I right? Well, now you have to convert Pansat 2500 CLONES to a Pansat 2700 in order to watch TV. |
New member Username: Crazypal
Post Number: 2 Registered: Aug-07
| Posted on Monday, October 29, 2007 - 11:06 pm: |
guys can anyone tell me which file to use for a fortec lifetime ultra? |
Post Number: 14 Registered: Oct-07
| Posted on Monday, October 29, 2007 - 11:15 pm: |
I am lost, stuck and everything, nothing is working for me =( did echo 8, 6 change to g25 or something? |
New member Username: Tehrani
Iran,
Tehran
Iran
Post Number: 6 Registered: Oct-07
| Posted on Monday, October 29, 2007 - 11:16 pm: |
hiall Hussam Arif you give us the sit but there is 3or4 number i put it the N2 but it doesnot showed. could you give the right Dish keys please? thanks |
Post Number: 1265 Registered: Aug-06
| Posted on Monday, October 29, 2007 - 11:25 pm: |
majid khan, You HAVE to convert your receiver to a Pansat 2700 and then use Pansat 2700 modded bins. There will be no support for Fortec STAR Lifetime Ultra receivers. In order to watch TV, you either convert your receiver to a Pansat 2700 or buy a new FTA unit. |
Post Number: 15 Registered: Oct-07
| Posted on Monday, October 29, 2007 - 11:34 pm: |
i am about to smash my pansat 2700a, i got neither quality nor signal! i did a factory reset but i am lost not, do not know what to do, need a manual or something} |
New member Username: Maldito
Post Number: 6 Registered: Aug-07
| Posted on Monday, October 29, 2007 - 11:54 pm: |
Alguien sabe por qué los xxx y los ppv no se pueden ver?? y de paso, me explica sobre esto: Dish Network New PID - 0106 [Last update: Tue. Oct 23, 1:14 PM CDT] 86: D6 9E 74 4D 0A CB ED 62 42 C6 A5 C1 AF AC BE 38 New 96: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 gracias estimados!! |
Post Number: 16 Registered: Oct-07
| Posted on Monday, October 29, 2007 - 11:56 pm: |
si, neitas actualizar el bin, el ultimo es el 218 y le pones las llaves y listo |
Post Number: 7 Registered: Aug-07
| Posted on Monday, October 29, 2007 - 11:58 pm: |
Sorry for the post in spanish, basically it says that I can't watch xxx and ppv channels And I wondered about the new dn key and how to use it Dish Network New PID - 0106 [Last update: Tue. Oct 23, 1:14 PM CDT] 86: D6 9E 74 4D 0A CB ED 62 42 C6 A5 C1 AF AC BE 38 New 96: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 thanks |
Post Number: 17 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 12:01 am: |
ok i loaded the channel list, now how do i the signal and quality thing to work???? =( |
Post Number: 8 Registered: Aug-07
| Posted on Tuesday, October 30, 2007 - 12:02 am: |
no uso autorroll porque no tengo el cable. Todo lo hago manual hay alguna forma de realizar el cambio así? (I don't have autoroll turned on, cause I don't have the cable. Is there a way to do it manually? the bin change, that is) |
Post Number: 18 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 12:08 am: |
no, neitas el cable para poder conectarlo a la caja y actualizar |
Bronze Member Username: Manthedent
Post Number: 29 Registered: Sep-06
is there any new fix for pansat 2300  |
Post Number: 19 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 12:10 am: |
ok i think my pansat is f**ck*d up now..... oh well...... |
Platinum Member Username: Lklives
Post Number: 13272 Registered: Jan-06
| Posted on Tuesday, October 30, 2007 - 12:21 am: |
ma..No fix for the 2300 since over 1 year....its a door stop now...get a new receiver...no other choices for ya... conexsat mini sonicview 4000 viewsat ultra |
Post Number: 20 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 12:25 am: |
my pansat is now frozen on 5 from b-75 and nothing happens, is there anything i can do or is it gone for good????? |
Post Number: 30 Registered: Sep-06
| Posted on Tuesday, October 30, 2007 - 12:29 am: |
lk my dish used to work fine before the new thing that DN did which more specifically on the 23rd now i do get some channels except no PPv or the international channles |
Post Number: 13274 Registered: Jan-06
| Posted on Tuesday, October 30, 2007 - 12:33 am: |
ma...if thats all U want...then keep it and use it...but pansat does NOT release any more 2300 files since 10-27-2006... |
Bronze Member Username: Ather_da_don
Mississauaga,
Ontario
| Posted on Tuesday, October 30, 2007 - 08:12 am: |
Need new dish keys, New bin files, or converting files? Visit www.dishkeyz.blogspot.com |
Bronze Member Username: Bruce69
| Posted on Tuesday, October 30, 2007 - 09:12 am: |
LK OR ANYONE PLEASE HELP; I AM CONVERTING MY PANSAT 2500A TO 2700 USING THE CONVERTING KIT I AM USING RS232 STRAIGHT CABLE(I HAVE USED THE SAME CABLE BEFORE TO DOWNLOAD BINS)IT GIVES ME AN ERROR MESSAGE WHEN I CHOSE COM 1,2,3,4 (CANT OPEN SERIAL PORT)WHAT IM I DOING WRONG? |
Bronze Member Username: Dandaniels
Post Number: 11 Registered: Aug-07
| Posted on Tuesday, October 30, 2007 - 09:21 am: |
HUSSAM AND ATHER. WHY DO YOU INSIST ON REPEATING THE SAME THREAD OVER AND OVER AGAIN. PEOPLE CAN READ IT AND WE KNOW SO IF YOU HAVE NOTHING ELSE TO ADD, BUZZ OFF AND GO PLAY SOMEWHERE ELSE. THANKS. |
Bronze Member Username: The_messenger
Post Number: 32 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 10:13 am: |
dannyboy if you read their first post there is no need for you to read the rest. others may have missed their over & over post. makes sense to me. |
| Posted on Tuesday, October 30, 2007 - 11:23 am: |
WHY ISN'T THERE ANYONE ANSWERING MY QUESION? |
Bronze Member Username: Harjun
Post Number: 57 Registered: Sep-06
| Posted on Tuesday, October 30, 2007 - 11:46 am: |
i have ariza700 and old bin number is 281 and now i try download the new bin 299,293 but it always say no right the model. anyone have new loader and bin please send me johal18@hotmail.com thanks |
Toronto,
Ontario
Post Number: 41 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 05:47 pm: |
Thank you king arthur maybe some people (dannyboy) are just slow at getting stuff |
Gold Member Username: Nydas
Post Number: 4364 Registered: Jun-06
| Posted on Tuesday, October 30, 2007 - 05:49 pm: |
Ariza 700 and others looking for advice on new receiver purchase. The Viewsat Ultra and Sonicview 4000 are similar. They both have USB input for new files, which is a great help. They are priced around $160-$195. For the Viewsat Ultra you have to be ultra careful about purchasing a clone - so you must buy one from a reliable authorised dealer. The CaptiveWorks 600P is a great receiver for about $100. It has had a good support all along and uses serialinputfor new files. |
Post Number: 4365 Registered: Jun-06
| Posted on Tuesday, October 30, 2007 - 06:01 pm: |
Majid Khan and Guy Anderson and others with Pansat 2500 and clones and FLU Your receiver will work in a limited way for"local channels" ,etc. It will still give you NBC, ABC, PBS, an some other channels. Notably, you will NOT get PPV and all of International channels. I have posted recommendations for a new receiver. If you do not wish to budget for a new one, I suggest you get the Pansat 2500 clone to Pansat 2700 conversion kit and convert to 2700. The kit requires you to upgrade first to a jvvh 205, then jvvh 208. Then you go up to perhaps jvvh 213 and then jvvh 218 which is the latest. YOU MUST FOLLOW THE EXACT PROCEDURE. Waiting and patience are a great virtue in this upgrade as in many BIN uploads. You just use BL Updater 1.4 only You must use jvvh BINs only. One special note: jvvh himself has advised lately that for the first time upgrade, not to use 205 but to start with 208. I have not done it that way yet, so I do not know. Also there is a zip file for converting back to 2500should something go wrong. It is called 2700 to 2500 via serial port.zip This would be a very useful file. All files have to be unzipped before use. This applies to loaders, and BIN files. Read the instructions carefully. Most of the problems arise from haste. The following sites have a lot of files and instructions. http://www.f2atv.com http://www.ftatalk.com http://www.totalfta.com http://www.al7bar*tk http://www.future-fta.info |
New member Username: Eddym
Post Number: 5 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 06:25 pm: |
I converted my FLU to Pansat 2700 "by the book" several days ago. I scanned Echo 7 (119.0) and Echo 8/10 (110.0) satellites and everything seems to work fine. However, about every other day I lose all the channels of one satellite (usually 110.0). So, I have to rescan the missing satellite every time it goes out to get it working again. I never had this problem before. Is this one of the bugs with bin jvvh_228_pT? Is there any fix available? Any help will be greatly appreciated. |
Silver Member Username: Fortec01
Post Number: 109 Registered: Sep-06
| Posted on Tuesday, October 30, 2007 - 06:42 pm: |
any1 have the new keys i jus got back from vaction |
Bronze Member Username: Bih
Post Number: 43 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 06:43 pm: |
anny 1 got the keys?????? |
| Posted on Tuesday, October 30, 2007 - 06:44 pm: |
NALIN CAN YOU HELP ME;I AM CONVERTING PANSAT 2500A TO 2700 USING RS232 CABLE(I HAVE USED THE SAME CABLE BEFORE TO DOWNLOAD BINS)WHEN I CHOSE THE COM1,2,3,4 GIVES ME AN ERROR MESSAGE(CANT OPEN SERIAL PORT..THE SYSTEM CANT FIND THE FILE SPECIFIED)WHAT AM I DOING WRONG? |
Bronze Member Username: Cacalad
Post Number: 42 Registered: Apr-07
| Posted on Tuesday, October 30, 2007 - 06:45 pm: |
new keys please for dish |
New member Username: Yumna18
| Posted on Tuesday, October 30, 2007 - 06:46 pm: |
hey did the keys come for ariza700?????????????????????????????????????????????????????????? |
Post Number: 31 Registered: Sep-06
LK is it safe to buy reciver from ebay? |
Post Number: 43 Registered: Apr-07
| Posted on Tuesday, October 30, 2007 - 06:52 pm: |
anyone got new keys for dish please!!!! |
Post Number: 13289 Registered: Jan-06
| Posted on Tuesday, October 30, 2007 - 06:56 pm: |
ma...stay away from ebay... here a few good site to buy from www.globalwholesalers.biz www.viewsatonline.com www.worldwidesatellites.com |
New member Username: Ncroldan
Post Number: 5 Registered: Feb-07
| Posted on Tuesday, October 30, 2007 - 07:03 pm: |
Nag2 keys ---------------------------------------- Dish Provider 0101: Last Updated (30 Oct '07 5:53 PM EST) Key 0: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED Key 1: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F (Active Bev Provider 0901: Last Updated (30 Oct '07 5:53 PM EST) Key 0: 5E CF F5 EE AA F0 37 F9 43 78 54 4A A2 9E B3 98 Key 1: 34 96 C6 F7 62 EA 97 D7 89 CC 37 1B 33 72 F7 B2 (Active) |
| Posted on Tuesday, October 30, 2007 - 07:06 pm: |
LK CAN YOU ANSWER MY QUESION PLEASE |
Bronze Member Username: Jppatelahd
Post Number: 12 Registered: Sep-07
Dish Network Main - 0101 [Last update: Tue. Oct 30, 5:34 PM CDT] 86: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED 96: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F New Dish Network New PID - 0106 [Last update: Tue. Oct 23, 1:14 PM CDT] 86: D6 9E 74 4D 0A CB ED 62 42 C6 A5 C1 AF AC BE 38 New 96: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ----------------------- Bell ExpressVu Main - 0901 [Last update: Tue. Oct 30, 1:25 PM CDT] 86: 5E CF F5 EE AA F0 37 F9 43 78 54 4A A2 9E B3 98 96: 34 96 C6 F7 62 EA 97 D7 89 CC 37 1B 33 72 F7 B2 New ------------- Bell ExpressVu PB - 0905 [Last update: Thurs. Mar 15, 2:01 AM CDT] 86: B7 2F 03 35 70 4A CD B0 6D 43 33 59 92 E2 1D F3 96: D5 51 BA FE 58 50 BE 61 A4 BD 09 F3 54 4F C5 FC Bell ExpressVu HD - 0906 [Last update: Thurs. Mar 15, 6:17 PM CDT] 86: 8D 1A 1C F4 2C B9 7F 85 38 65 D6 7A 5D 59 5D 88 96: 11 FE 27 1D 89 9E D3 B4 DB 8E CB C8 10 D3 E7 F7 Bell ExpressVu New PID - 0907 [Last update: Tue. Oct 30, 3:47 AM CDT] 86: 89 E0 33 90 CD BA DA D0 3E 04 C6 B4 59 A7 84 7B 96: 60 B8 E2 A1 25 9F 09 6F FB 9B 30 FF 61 95 EE 65 New ------------------ Globecast - C101 [Last update: Sat. Oct 13, 5:18 PM CDT] 86: 85 9A 02 EC 13 CF F2 AF FD 84 D0 16 9C 24 6F A9 96: 0F 2B 8A 31 84 D7 2D 2B 40 FF 5E 0B B7 DB 0D 4A } |
New member Username: Loko100
Post Number: 8 Registered: Aug-06
| Posted on Tuesday, October 30, 2007 - 07:08 pm: |
Here are the New Key: 01: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F |
Bronze Member Username: Leafs
| Posted on Tuesday, October 30, 2007 - 08:20 pm: |
new keys posted on www.ftasolutions.blogspot.com |
Toronto,
Ontario
Post Number: 42 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 08:33 pm: |
Dish and bev keys and Latest bin files on www.dish-keys.blogspot.com |
Gold Member Username: Donnie1973
Post Number: 1526 Registered: May-06
| Posted on Tuesday, October 30, 2007 - 08:47 pm: |
bruce, have u unzipped the files? |
Post Number: 110 Registered: Sep-06
| Posted on Tuesday, October 30, 2007 - 08:49 pm: |
can i get ppv channels on my fortec because i got the new keys i hav been gone for while dont know wats goin on can sum explain to me please |
Iran,
Tehran
Iran
Post Number: 7 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 08:59 pm: |
hi all. I Thing there is no body know about Ariza700. Thanks alots |
Silver Member Username: Ustaad_hc
Post Number: 313 Registered: Oct-06
| Posted on Tuesday, October 30, 2007 - 09:36 pm: |
there is lot lot people waiting for ariza fix. |
Post Number: 4368 Registered: Jun-06
| Posted on Tuesday, October 30, 2007 - 09:56 pm: |
Bruce : Use BL updater 1.4 - NOTHING ELSE. Unzip the files before use. |
Post Number: 4369 Registered: Jun-06
| Posted on Tuesday, October 30, 2007 - 09:59 pm: |
Canon labtec: You have to join the 2500 to 27000 conversion club. Please don't ask for alternatives because then you sill have to buy a new receiver. |
New member Username: Alyas_ali
Post Number: 1 Registered: Oct-07
| Posted on Tuesday, October 30, 2007 - 10:15 pm: |
i have pansat 2500 clone any one tell me where and how i can get new bins and wot loader plz help me all |
Bronze Member Username: Tupas1
Post Number: 23 Registered: Jan-07
| Posted on Tuesday, October 30, 2007 - 10:39 pm: |
Alyas : use this link :http://ftabins.net/showthread.php?t=7475 which hve loader and everything. just follow the instruction and load. After u r done with that find this file Jvvh_218_pT and load itand then connect yr receiver to tv and scan satalite and add new key and u r fine. I did and working good. |
Post Number: 24 Registered: Jan-07
| Posted on Tuesday, October 30, 2007 - 10:42 pm: |
u can down load jwh_218 from this url : http://ftabins.net/showthread.php?t=11282 |
Bronze Member Username: Agf
Post Number: 12 Registered: Aug-06
| Posted on Tuesday, October 30, 2007 - 11:00 pm: |
I have done the 2500 to 2700 conversion and it works fine. My question, how do I put the manuel keys, at the moment I can only see option for 0101- 00 nothing else How do I put the following Dish Network Main - 0101 [Last update: Tue. Oct 30, 5:34 PM CDT] 86: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED 96: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F New Dish Network New PID - 0106 [Last update: Tue. Oct 23, 1:14 PM CDT] 86: D6 9E 74 4D 0A CB ED 62 42 C6 A5 C1 AF AC BE 38 New 96: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Appreciate any help in this regard |
Toronto,
Ontario
| Posted on Tuesday, October 30, 2007 - 11:16 pm: |
Bronze Member Username: Bubbus
Post Number: 16 Registered: Jan-07
| Posted on Tuesday, October 30, 2007 - 11:21 pm: |
Nalin, I'm trying to convert 2500A to 2700, but the screens continuously displaying - - - - back and forth. I don't see anything else. I tried loading Jvvh 218, more than once, using BL1.4, but still no response. Please advise, you been always great help to me. |
Post Number: 17 Registered: Jan-07
| Posted on Tuesday, October 30, 2007 - 11:30 pm: |
AGF, HOW DID YOU CONVERT 2500 TO 2700. PLEASE TELL ME I AM TRYING WITH 2500A, AND IT'S NOT RESPONDING ONLY DASHES (- - - - ) ARE BLINKING |
Bronze Member Username: Tehrani
Iran,
Tehran
Iran
| Posted on Tuesday, October 30, 2007 - 11:44 pm: |
hi all. could you give us the realy keys? 86: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED With this key we can get a few chanall.we canot get PPV and some others chanalls. thanks |
Mississauaga,
Ontario
| Posted on Wednesday, October 31, 2007 - 07:58 am: |
Anyone need new dish keys, bin files or converting files? Visit www.dishkeyz.blogspot.com |
Post Number: 13 Registered: Aug-06
| Posted on Wednesday, October 31, 2007 - 08:46 am: |
Bubbus, One trick to upload the bin file is after you have connected the receiver to the computer and have the bin file on the loader, click on the write option on the loader on your computer and then switch the receiver on. This will load the bin file. All the best |
Silver Member Username: Dr_dss
Post Number: 195 Registered: Sep-07
| Posted on Wednesday, October 31, 2007 - 08:50 am: |
Ather Ahmed I check your site a few times yesterday and You are SLooooooooooooooooooooow on updating the keys hours behind other sites. |
Post Number: 4375 Registered: Jun-06
| Posted on Wednesday, October 31, 2007 - 10:53 am: |
Pansat 2500 to 2700 conversion. First time conversion, use jvvh 205 or jvvh 208 BIN. Get ready to write and using one hand on receiver back turn on switch and immediately click on write. Wait WAit WAit for B75 to appear. and then wait even more. For later upgrades to newer BIN, do the same as above except that you click on write soon after "b" appears. Latest BIN is jvvh 218 All files have to be unzipped before use. This applies to loaders, and BIN files. Read the instructions carefully. Most of the problems arise from haste. The following sites have a lot of files and instructions. http://www.f2atv.com http://www.ftatalk.com http://www.totalfta.com http://www.al7bar*tk http://www.future-fta.info |
Silver Member Username: Rtap
FL
Post Number: 814 Registered: Jan-07
| Posted on Wednesday, October 31, 2007 - 12:49 pm: |
Dish Network Main - 0101 [Last update: Tue. Oct 30, 5:34 PM CDT] 86: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED 96: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F New Dish Network New PID - 0106 [Last update: Tue. Oct 23, 1:14 PM CDT] 86: D6 9E 74 4D 0A CB ED 62 42 C6 A5 C1 AF AC BE 38 New 96: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Satsmurf.com Bell ExpressVu Main - 0901 [Last update: Wed. Oct 31, 11:40 AM CDT] 86: 47 FB 44 74 A3 FB FC 89 D3 08 FB F3 12 FB 6B D7 New 96: 34 96 C6 F7 62 EA 97 D7 89 CC 37 1B 33 72 F7 B2 Bell ExpressVu PB - 0905 [Last update: Thurs. Mar 15, 2:01 AM CDT] 86: B7 2F 03 35 70 4A CD B0 6D 43 33 59 92 E2 1D F3 96: D5 51 BA FE 58 50 BE 61 A4 BD 09 F3 54 4F C5 FC Bell ExpressVu HD - 0906 [Last update: Thurs. Mar 15, 6:17 PM CDT] 86: 8D 1A 1C F4 2C B9 7F 85 38 65 D6 7A 5D 59 5D 88 96: 11 FE 27 1D 89 9E D3 B4 DB 8E CB C8 10 D3 E7 F7 Bell ExpressVu New PID - 0907 [Last update: Tue. Oct 30, 3:47 AM CDT] 86: 89 E0 33 90 CD BA DA D0 3E 04 C6 B4 59 A7 84 7B 96: 60 B8 E2 A1 25 9F 09 6F FB 9B 30 FF 61 95 EE 65 New |
Silver Member Username: Satgrl
Post Number: 339 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 12:58 pm: |
RTAP ONE IS FROM DSS_KEYS AND ONE FROM UR POST ABOVE WHICH ONE IS CORRECT? THE SECOND NUMBER IN 00 HAS CHANGED!.. Bell ExpressVu Main - 0901 [Last update: Wed. Oct 31, 11:40 AM CDT] 86: 47 FB 44 74 A3 FB FC 89 D3 08 FB F3 12 FB 6B D7 New 96: 34 96 C6 F7 62 EA 97 D7 89 CC 37 1B 33 72 F7 B2 47 7B 44 74 A3 FB FC 89 D3 08 FB F3 12 FB 6B D7 01: 34 96 C6 F7 62 EA 97 D7 89 CC 37 1B 33 72 F7 32 |
FL
Post Number: 819 Registered: Jan-07
| Posted on Wednesday, October 31, 2007 - 01:02 pm: |
my post above was from tvkeyzdotcom.and this is from dss-keys. D!SH 0101 - Last Update: 10/30/07 03:55 PM 00: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED 01: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F B3V 0901 - Last Update: 10/31/07 10:53 AM 00: 47 FB 44 74 A3 FB FC 89 D3 08 FB F3 12 FB 6B D7 01: 34 96 C6 F7 62 EA 97 D7 89 CC 37 1B 33 72 F7 32 |
Post Number: 341 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 01:04 pm: |
ok thnxs i guess it got updated now;) |
FL
Post Number: 820 Registered: Jan-07
| Posted on Wednesday, October 31, 2007 - 01:07 pm: |
your welcome.peace |
New member Username: Binpro
Post Number: 7 Registered: Sep-05
| Posted on Wednesday, October 31, 2007 - 02:05 pm: |
my receiver isn't auto rolling... Need a new DN key for 10/31/07 can anyone help? |
Bronze Member Username: Depalmaj
Wa.
Post Number: 47 Registered: May-06
| Posted on Wednesday, October 31, 2007 - 02:06 pm: |
new keys ??? or what |
New member Username: Amber551
Post Number: 3 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 02:07 pm: |
Can someone give me new dn keys? Thanks |
Wa.
Post Number: 48 Registered: May-06
just DN up to old tricks for halloween guess a new bin will be soon man i just got 333 bin |
Bronze Member Username: K98
Post Number: 93 Registered: Jan-07
| Posted on Wednesday, October 31, 2007 - 02:09 pm: |
mine didnot a.r. keys need d.n. keys plz |
Wa.
Post Number: 50 Registered: May-06
| Posted on Wednesday, October 31, 2007 - 02:12 pm: |
i dont think keys will work its a new ECM and a bin fix will be the only fix for autoroll expect BL with a new bin soon i hope man no more east cost shows 2 night gotta watch cable  |
Post Number: 9 Registered: Sep-05
| Posted on Wednesday, October 31, 2007 - 02:13 pm: |
DN: 96: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F New |
Post Number: 10 Registered: Sep-05
| Posted on Wednesday, October 31, 2007 - 02:14 pm: |
it just the keys. I am back up.. BinPro |
Bronze Member Username: Indopak
Post Number: 45 Registered: May-06
| Posted on Wednesday, October 31, 2007 - 02:18 pm: |
my autoroll is rolling but its not working.. whats the new dn keys? someone please post them up.. thanks!! |
Wa.
Post Number: 51 Registered: May-06
thanks man was stressin im back up this testing isnt as fun in morning when ur doing 420 alittle to early  |
Wa.
Post Number: 52 Registered: May-06
| Posted on Wednesday, October 31, 2007 - 02:19 pm: |
Turn autoroll OFF then it works any 1 thats getting continue autoroll |
Post Number: 94 Registered: Jan-07
4 d.n. put in o1 keys ; oc 7a ae 74 38 74 e1 27 . 18 51 f8 1a 5f 19 96 8f should have ppv t.v. |
Bronze Member Username: Kardary7
Nashville,
T.N
Post Number: 14 Registered: Apr-07
| Posted on Wednesday, October 31, 2007 - 02:28 pm: |
hi any body have new keys please |
Silver Member Username: Silver1123
Mexico,
DF
Mexico
Post Number: 321 Registered: Jul-07
| Posted on Wednesday, October 31, 2007 - 02:32 pm: |
Turn autorolls off and enter keys manually. Again, DN is morphing keys, the 5F is being changed for DF. |
FL
Post Number: 830 Registered: Jan-07
| Posted on Wednesday, October 31, 2007 - 02:37 pm: |
juan it worked.thanks. |
Mexico,
DF
Mexico
Post Number: 323 Registered: Jul-07
| Posted on Wednesday, October 31, 2007 - 02:42 pm: |
DN is testing again. Now they have all the channels in the same key. 101 is working for all channels, PPV, Movies, Variety... 86: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED 96: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F You should have the new 96 or 01 key, as shown, to be able to view all channels. DN might go back to the 106 key for PPV anytime. Turn off autorolls and enter correct keys. Wait for new bins. |
New member Username: Pk4ever
Alta loma,
Ca
U.s.
Post Number: 7 Registered: Jul-07
| Posted on Wednesday, October 31, 2007 - 02:45 pm: |
its not working for me, cnx duo says autoroll processing on all scrambled channels. Any 1 know if there are new bins coming soon? |
Post Number: 95 Registered: Jan-07
does anyone know why 1# on the o1 keeps fliping from 5f to 1f and i put in 5f an it brings the picture in then goes out again then i re enter 5f to get it back whats going on help plz. |
Mexico,
DF
Mexico
Post Number: 325 Registered: Jul-07
| Posted on Wednesday, October 31, 2007 - 02:51 pm: |
Cotton: There is a modified stream in the satellite feed, that makes the keys change. In order to avoid the changes, turn autoroll options off. Paul: Check here for new bins: http://ftabins.net/ Its free, just register. Search for the brand of your box. New bins shouls start appearing by tonight for Pansat, and the rest will follow in the next couple of days |
Bronze Member Username: Majikone
Post Number: 11 Registered: Jun-06
| Posted on Wednesday, October 31, 2007 - 03:00 pm: |
Hi Any keys for the BEV?? Thanks |
New member Username: Desiinfluence
Canton,
Michigan
America
Post Number: 9 Registered: Oct-07
allrite guyz...i have converted my FLU to pansat2700a...everything working great...except...wen i m watching 61.5...my signal get lost for 119...in order to fix dat...i have to keep turning it off from da back and den turn it on back..den it starts working...does anyone know...y its behaving like dis..??? |
Post Number: 46 Registered: May-06
| Posted on Wednesday, October 31, 2007 - 03:04 pm: |
when i went to the code section i already ad the new key in it, but i had to change the one letter cuz it was wrong.... after i cahnged it my channels were back, but after around 5 mins that same letter goes back and ihave to change it again ot make my channels work, why? what shoudl i do? |
New member Username: Bigga123
| Posted on Wednesday, October 31, 2007 - 03:34 pm: |
Good Good |
