Thread: My box flashing b-75 non stop! |
New member Username: Mrkhan
Post Number: 1 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 06:57 pm: |
Hello, Can someone please help me! I had convert my clone box from 2500a to 2700a, it was successfully. Then after connecting to the satellite, I am not getting any Indian channels, but only local and some few channels. Then I loaded pansat 2700a bin file 218 and after while now my box is acting funny. Its flashing b-75 non stop. What is there for me to do to stop and have the box working with all my Indian channels? A very Thank you in advance. |
Gold Member Username: Asharfi
Post Number: 1278 Registered: Aug-06
| Posted on Wednesday, October 31, 2007 - 07:06 pm: |
Firoz Khan, Download Black Tyger's Bin 01 from www.ftabins.net. |
Post Number: 2 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 07:32 pm: |
Hi, So I look under pansat for this BLACK TYGER'S BIN 01? Thank you. mrkhan |
Post Number: 1279 Registered: Aug-06
| Posted on Wednesday, October 31, 2007 - 07:44 pm: |
no ... they posted it under the Fortec Lifetime ultra section ... but it works on pansat 2500 too |
Post Number: 3 Registered: Oct-07
| Posted on Thursday, November 01, 2007 - 10:52 am: |
Hi AV, I thank you so much for helping me and having patient with me (I hope) I am very new at this. I found the Black Tyger's bin 01, my question is do I load it from the BL loader 27.02, from Fortec loader or from 2500a loader 1.4 verison. Also I would like to know is that now that I have convert my box to 2700a, so from now on I will be only looking for bin files under 2700a clone from either Fortec & Pansat correct? Thank you once again. Firoz |
Gold Member Username: Nydas
Post Number: 4396 Registered: Jun-06
| Posted on Thursday, November 01, 2007 - 10:59 am: |
Firoz Khan : Genuine Pansat 2700: Use Blacklist 219 BIN or the Tivo equivalent. Clone Pansat 2700: Currently Tivo or vortex 218 BINs. 219 BINs expected soon. For the above two, you need the appropriate 27.02 loader - each has its own 27.02 loader. For converted 2700 (from Flu or from 2500), do not use any of the above Use jvvh converion BIN 208 first, followed by jvvh 218 or BLACK TYGER'S BIN 01. If you want your receiver to stay alive, better readd and read and read before doing anything. |
Post Number: 4 Registered: Oct-07
| Posted on Thursday, November 01, 2007 - 11:11 am: |
Thanx Nydas, so where can I find the jvvh 218? So I have to look for jvvh 218t <--- correct since I have an clone box or it dosen't matter? I have already put in the jvvh 205 and jvvh 208 to convert the box then follow with that I putting jvvh 213, I then connected to my tv, and was able to pick up local and few outside channels, but couldn't pick up any Indian channels. Now suddenly my box is flashing b-75 non stop, I even load the Black Tyger's bin 01 from BL loader 1.4, cuz I tried from BL Loader 27.02 and Clone Loader 27.02 it didn't let me, but with the 1.4 it did but after 100% it said it failed to write. What is that I should do now? I thank you so much for helping me. Firoz |
Post Number: 4399 Registered: Jun-06
| Posted on Thursday, November 01, 2007 - 11:22 am: |
You DO NOT use 27.02 loader on converted Pansat 2700 IGNORE everything about genuine Pansat 2700 and clone Pansat 2700 Use only BL update 1.4. Get ready to write the jvvh 218 BIN. It must be unzipped .BIN file. Keep one hand on switch at the back and one hand on the mouse. Switch on and as soon as "b" appears click on the mouse. |
Post Number: 5 Registered: Oct-07
| Posted on Thursday, November 01, 2007 - 11:37 am: |
Ok Nyda, I did what you told me to do, it went thru and I got the number back on the box. I want to let you know that I put in jvvh 219 bin is that ok? |
Gold Member Username: Dude123
Post Number: 1228 Registered: Jul-06
| Posted on Thursday, November 01, 2007 - 01:58 pm: |
if you put jwh 219 bin, it just came out today its the latest file "key morphing fixed" so go ahead and it should do the trick |
Post Number: 1229 Registered: Jul-06
| Posted on Thursday, November 01, 2007 - 02:01 pm: |
I personnaly havn't tested the file yet...but its been tested and said that its in working condition so if you are familure with jtaging and wants to try it out go for it but looks like you are a little new with this stuff I am going to test the file out as soon as I am done work and will post the results.... |
Bronze Member Username: Joel_eduardo
Cd. victoria,
Tamaulipas
Mexico
Post Number: 52 Registered: Nov-06
| Posted on Thursday, November 01, 2007 - 03:44 pm: |
Alguien sabe si ya salió algun bin para pansat 2700A |
