Thread: Viewsat down please help |
New member Username: Chip_la
Post Number: 10 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 05:47 pm: |
I puy in new keys shut of autoroll and still no picture any ideas would be great. Thanks Chip |
Bronze Member Username: Drmunna
Post Number: 11 Registered: Oct-07
| Posted on Wednesday, October 31, 2007 - 06:24 pm: |
u must have entered wrong keys,,, mine working ok,,,double check keys |
Silver Member Username: Bill038
Post Number: 146 Registered: Sep-06
| Posted on Wednesday, October 31, 2007 - 06:27 pm: |
I did the same thing, triple checked the numbers and have a no audio no video coming up on the screen. Any suggestions? |
Silver Member Username: Silver1123
Mexico,
DF
Mexico
Post Number: 342 Registered: Jul-07
Yes, you must have wrong keys. Other viewsats are working fine. check latest keys http://www.fta123.blogspot.com/ also, turn all autoroll options off, including EPG autoroll |
Gold Member Username: Nydas
Post Number: 4380 Registered: Jun-06
| Posted on Wednesday, October 31, 2007 - 06:30 pm: |
Minor key morphing last day or so. Keep auto roll off. Use keys as posted DN - Provider ID 0101 Check the third number in Key 00 - it should be 24 Check the thirteenth number in Key 01 - it should be 5F |
Post Number: 147 Registered: Sep-06
| Posted on Wednesday, October 31, 2007 - 06:31 pm: |
I only have a line 00 and a line 01. Wher4e is the line 106? |
Bronze Member Username: Vacarosie
Post Number: 31 Registered: Aug-07
| Posted on Wednesday, October 31, 2007 - 06:55 pm: |
I put the new key from B3V in Viewsat Platinum but didn't works. Need a new bin or new keys. The keys was from this morning |
Bronze Member Username: Bassi911
Post Number: 69 Registered: Jun-06
| Posted on Wednesday, October 31, 2007 - 06:57 pm: |
yea i put in the new keys in the viewsat plat and i changed the autoroll to off and still i get no audio and no video. My keys are correct i checked them 34 times |
Post Number: 32 Registered: Aug-07
| Posted on Wednesday, October 31, 2007 - 07:24 pm: |
Suppose it need a new bin |
Mexico,
DF
Mexico
Post Number: 349 Registered: Jul-07
| Posted on Wednesday, October 31, 2007 - 07:30 pm: |
To enter keys manually, you should select the entry that contains: 1 Nagravision or Nagra 2 Ident DishNetwork 0001 or 0101, depending on the programming of your box 3. There you will find 4 boxes or lines to input keys. the 00 and 01 divided each by two To change key 106, which you shouldnt do now, you need to do the same as above: 1. Select Nagravision or Nagra 2. Ident 0006 or 0106 3. Same four lines of boxes to enter codes |
Mexico,
DF
Mexico
Post Number: 350 Registered: Jul-07
| Posted on Wednesday, October 31, 2007 - 07:31 pm: |
If you entered new keys and get no picture, do as adviced in other posts by Nalin, reset your box. Turn off from back switch or unplug and re plug to electric outlet |
Gold Member Username: Donnie1973
Post Number: 1535 Registered: May-06
| Posted on Wednesday, October 31, 2007 - 07:57 pm: |
if u dont have picture after entering new keys. U did something wrong... |
Bronze Member Username: Ekoneuno
Post Number: 13 Registered: Nov-06
| Posted on Wednesday, October 31, 2007 - 08:47 pm: |
I need some help. I put auto roll off. I am going to Code Menu, then to Nagra and within that going to Dish. I have two options on Dish - 01 01 00 and 00 01 00. In the first series, I have codes for 00, 08,09,88 and 89. In the second series, I have codes for o8, 09, 88, 89. I am confused on which of these to update with the new keys. Please help.Thanks |
Post Number: 1537 Registered: May-06
| Posted on Wednesday, October 31, 2007 - 08:51 pm: |
01 01 00. the active keys are the 89 keys. Enter keys for 01 after the 89. |
Post Number: 14 Registered: Nov-06
| Posted on Wednesday, October 31, 2007 - 08:55 pm: |
01 01 00 For 00 I see the following B4 ED 24 E3 BC.........C8 A1 For 89 , the last 8 keys are 00. 00 01 00, I do not see 01 at all. only 08, 09, 88, 89 |
Post Number: 1539 Registered: May-06
| Posted on Wednesday, October 31, 2007 - 09:05 pm: |
right, u need 01 01 00 dont change 00 dont change 08 dont change 09 change 88 to:25 8D 8F 67 F7 5F DF 62 change 89 to :3D 7A 4D 7C E7 86 61 90 |
Post Number: 1540 Registered: May-06
| Posted on Wednesday, October 31, 2007 - 09:07 pm: |
i meant enter keys 01 in to the 88 AND 89 keys but my last post is what u need to do. make SURE u turn off autoroll |
Bronze Member Username: Martinpraguer
Bohemia
Post Number: 49 Registered: Nov-06
| Posted on Wednesday, October 31, 2007 - 09:40 pm: |
Thanks dantetn, your posted keys work. I am using "manula mode" since all FTA sites (that I've tried so far) with bin files are overloaded with traffic. Cheers |
Post Number: 1548 Registered: May-06
| Posted on Wednesday, October 31, 2007 - 09:46 pm: |
yeah, I know pansat has released their files, but it is near impossible to get it right now... the keys are easy to input... not too terrible |
Post Number: 149 Registered: Sep-06
| Posted on Wednesday, October 31, 2007 - 09:47 pm: |
LINE 08=D6 1A 24 BF EA 89 B9 29 LINE 09=3D 84 14 3A 30 8F A4 C0 LINE 88=25 8D 8F 67 F7 5F DF 62 LINE 98=3D 7A 4D 7C E7 86 61 90 These are the latest bins. Do not change anything in line 00 |
New member Username: Harchi777
Surrey,
Bc
| Posted on Thursday, November 01, 2007 - 02:35 am: |
by mistake i have changed 00 line and saved the changes.pl give me numbers for 00.(for viewsat) |
Bronze Member Username: Harchi777
Surrey,
Bc
| Posted on Thursday, November 01, 2007 - 02:38 am: |
or pl write me complete list for(viewsat ultra) 00 o8 09 88 89 ( all five lines) thanks |
New member Username: Yogibaba
Post Number: 5 Registered: Feb-07
| Posted on Thursday, November 01, 2007 - 08:39 am: |
YOU can go to Totalfta.com to get all viewsat bin. |
