Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > How do i put keys in ?
Author Thread: How do i put keys in ?
Username: Scabz
Knoxville, Tn
Us
Post Number: 11
the keys are 7 lines long on my box and the new keys are 14 lines long. Am I in the wrong place ? I have a vs platinum. thanks
Username: Dimwitt
Post Number: 166
C/P
VIEWSAT RECEIVERS
Go to Menu, Installation,Code
than pick Nagra, than left key 4 times
and it'll show Dish 01 01 00 and you'll have something like
00
08
09
88
98
Only change the key on 08 and 09
08 ---- F2 98 74 44 1C 65 77 D8 (substitute latest keys)
09 ---- 17 E3 E1 1D 89 4E 53 45 (substitute latest keys)
after you are done exit and save then watch TV
KEY 00=08
KEY 01=09
Username: Hshakarchi
Post Number: 128
Thanks Tooter,
one correction though,
each set of keys have 32 numbers:
for viewsat:
KEY 00 = has 32 numbers
08 = (1st 16 )
09 = (2nd 16 )
KEY 01 = has 32 numbers
88 = (1st 16 )
98 = (2nd 16 )
Username: Silver1123
Mexico, DF
Mexico
Post Number: 347
Bins, instructions and tutorials on how to input keys manually:
http://ftabins.net/
Username: Bassi911
Post Number: 67
i changed the keys and they are correct i checked them and i turned autoroll off, i have a viewsat plat, and it still doesnt work it says no audio or video. What do i do
Username: Scabz
Knoxville, Tn
Us
Post Number: 13
Like I said I can only put in 7 lines and not 8 to 16. 7 meaning ( bb bb bb bb bb bb bb ) . I can only put in 7 lines of codes and no more. 7 per each 00 = 7 and 01 = 7. Total 14 but on 2 different lines.
Username: Donnie1973
Post Number: 1569
naw, u have 16 after 08
16 after 09
same for 88 and 89.
the keys 00 go AFTER 08 AND 09
keys 01 go after 88 AND 89
Post Number: 1570
if u dont... reboot receiver. Still no... reload factory bin, then the last bin, try again... still no? I dont have a clue. 99-100 percent of the time, problems like this are just an oversight by the user.
Username: Lklives
Post Number: 13314
Here's how to manual input keys for ALL receivers...
http://forum.ecoustics.com/bbs/messages/2/390294.html
I suggest people use the SEARCH feature here...there's tons of good info available...
Enjoy!
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > How do i put keys in ? [ « Previous ] [ Next » ]
