Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through October 29, 2007
Author Thread: Archive through October 29, 2007
Username: Lklives
Post Number: 13177
This is how to load your 2500,FLU or clone to a 2700 clone via the SERIAL PORT
NO Need to Jtag!!!!...Just follow these instructions...Pay attention to these steps and specifically the Timing of Bin uploads..
You will Need a Pansat remote, but others have been sucessful with their receiver remotes.
READ your Channel list with Channel MAster and leave open in background.
Read and write down your antenna receiver settings, some place.VERY IMPORTANT
1. Open/Run the Blacklist updater V 1.4..
2. Make sure BIN is Selected not BOOT you are writing a Bin
3. Click select BIN
4. Choose j27_205_1.bin
5. Reboot reciever, on first light/dash, Click write bin. let it write. Timing is Important here!...be persistent!
When it is done, Be PATIENT!!!! Let it reboot, after 2-3 minutes you will see B-75 Flash on display of reciever. Be patient while this occurs. Do NOT interrupt this..
6. Click select BIN
7. Choose jvvh_208_1.bin
8. Reboot reciever on first light Click write bin. let it write. Again , Timing is Important here, be persistent. Let it reboot after 1 minute you will see B-75 Flash on display of reciever.
9. Now Rewrite your Channel list back, BUT, you must now select the 2700 settings in Channel master. If U prefer, U can do sat scans instead of using channel lists and channel master.
10. Reconnect to Tv, select default key from parental options (key menu)..let it autoroll
11. Now U have ONLY just done the conversion and must now upload latest Jvvh BIN..
OK...now U have done the conversion but now U need the and upload latest and most current jvvh bin, and do new channel scan or upload your channel list, and set default key, be patient when keys roll...U can use the same remote and loader that U have used during the conversion..
Username: Marca835
Post Number: 11
Hi
please help my buzz S2010f regular jump.
Someone told me i have to download factory bin nov,15,2005 and after that rest factory, and download bin oct,26, 2007.
but i have same problem when i download factory bin.
please help help me
thank you very much
Username: Lklives
Post Number: 13178
Skyview info...
the 500 is a pansat 2500 clone, so is basically useless now..
the 600 can be converted to a Captiveworks 600
U want more info, then read here..
http://forums.f2atv.com/forumdisplay.php?f=878
Username: Leafs
Post Number: 8
visit www.ftasolutions.blogspot.com
Username: Nydas
Post Number: 4327
marc rayan:
Buzz was the original receiver from which came the Sonicview models. I think, therefore, that the
http://www.totalfta.com site is reliable.
Since you are having problems, you could read in their forums at
http://www.totalfta.com/forums/forumdisplay.php?f=134
Also you could try uploading an older buzz file such as
s2010f_11sep2007.zip (1,007.3 KB) and then the latest.
Username: Ali3
Post Number: 8
Hi everyone I have a viewsat extreme 2000 I can get reg channels and japenese channels but cannot get any of the arabic,turkish and hindi channels what do I need to do? Thanks
Username: Nydas
Post Number: 4329
Converting 2500 to 2700.
Latest instructions from jvvh are to ignore his previous suggestion to start with jvvh BIN 205 and instead to start the conversion with jvvh 208.
Username: Nydas
Post Number: 4330
Ali3: Which sats are you scanning?
Username: Ather_da_don
Mississauaga, Ontario
Post Number: 10
Visit www.dishkeys.blogspot.com for latest dish keys and new bin files!!
Username: Halo
Toronto, Ontario
Post Number: 29
Can someone find the latest JWH bin files that i have to upload onto my pansat 2700 after converting from a 2500 plzzz and thank you!
Username: Ariza700
Markham, On
Post Number: 7
Nalin,
Do you know if older bin like 293eEU is working partially for Ariza700 ? Or any suggestion for ariza700
Thx
Post Number: 11
Username: Living_legend
Couple of question.....
everything is working fine now, my question is i only enter my keys manually and a couple of things has changed. parental is gone, it say cas control menu now.
another thing is when i go to nagravision 2 i don't see the 0106, i only have 0101 and 0901 in provider id. IS THERE SOMETHING WRONG? DO I SET MY AUTOROLL OFF? that's what i did last time.
btw i own a pansat 3000, i guess they've converted it already. paid 20 for it.
i'd appreciate any help
Username: Ali3
Post Number: 9
Nalin, I have it set to echostar 1,2 148.0W
Username: Nydas
Post Number: 4334
Ali3: You should get Hindi channels on 148. Do a Blind scan or Advanced scan. If no success, load and older BIN, then load the latest, and do rescanning.
Username: Halo
Toronto, Ontario
Post Number: 30
Nalin Nyda,
can u giv me the latest JWH bin file that i have to upload onto my pansat 2700 after converting it from a 2500 to 2700 (my pansat was a clone) plzzz and thank you!
Username: Nydas
Post Number: 4335
Sonny Jaworski : Set autoroll on. It seems that the BIN writer has got the 0106 ID programmed in, but is not showing it. If you try to enter keys manually, it may not work.
Till you scan one sat, you will not be able to use cas control. You also have to do all user settings and antenna settings before you start scanning.
Username: Devenw
MISIS
Post Number: 43
HELP ME PLEASE ON THIS ONE.
I have converted my Fortec life time ultra to Pansat 2700, everything was fine while i was using last eve, when i see this moring no power on my receiver.
Your help is greatly appricated
Username: Asharfi
Post Number: 1196
I told you that you have to JTAG ...
Post Number: 7
Nalin, thanks for the reply
scan? sorry i'm confused. i've scanned it and everything is working fine. i got ppv now. what i'm worried about is when i have to change keys next time. i've read that 0106 now. do i still use the 0101 keys?
Username: Marca835
Post Number: 12
thank you nalin i will try it
Username: Kamranca
Post Number: 67
Hi AV,
I did everything as per your advice..Upload jvvh_218_pt in my clone panset 2700 receiver..What about my next step..
Thanks AV
Username: Asharfi
Post Number: 1202
Scan your sats ... then check if u have the latest working keys ... watch TV :-)
Username: Nydas
Post Number: 4343
Sonny Jaworski : Keep autoroll on and the keys will come in. Prayers might help!!!
Username: Halo
Toronto, Ontario
Post Number: 31
Nalin Nyda,
can u plzz giv me the latest JWH bin file that i have to upload onto my pansat 2700 after converting it from a 2500 to 2700 (my pansat was a clone) plzzz and thank you!
Username: Lklives
Post Number: 13194
kamran...U don't put jvvh 218 in a pansat 2700 clone receiver....jvvh 218 is ONLY for 2500 and its clones, CONVERTED to a 2700 receiver..
Post Number: 8
Nalin, thanks for your time
i guess i'm just gonna have to wait and see what happens.
Username: Asharfi
Post Number: 1207
no ... they meant the converted box .... they told me they have flu
Username: Ali3
Post Number: 10
Nalin I apoligize but I am not very good at this where do I go to get the Bin and after that how do I download the bin onto the reciever? Sorry but much thanks for your time your wonderfull.
Username: Nydas
Post Number: 4344
Hussam Arif : Look for the files and instructions at
http://www.ftatalk.com
http://www.f2atv.com
The conversion is first using jvvh 205 or jvvh 208. Latest file to load is jvvh 218.
There is also a thread here with a lot of instructions and discussions.
Follow the insturctions carefully, except that you should use BL updater 1.4 for loading files into your receiver.
Username: Gagan
Post Number: 9
anyone have update for ariza 700????????? plzzz post backk replyyyyy
Username: Asharfi
Post Number: 1211
Ali,
Go to www.totalfta.com and download the latest bin for Viewsat Xtremes
Username: Nydas
Post Number: 4345
Ali3 : To download files, to unzip them and to read instructions, etc., is computing knowledge.
To become a member at a site is also computing knowledge, and the fact that you are posting here means that you know how to.
The knowledge you do not have is contained in the instructions in those files that you download. It also is there with a lot of people who are helping in that particular type of expertise.
Username: Wineskm
Post Number: 15
I've been out of town and returned to no FTA! I'm running a FLU. I've been reading about a new provider. Please point me in the right direction to get back on-line. - KmW
Username: Nydas
Post Number: 4346
KimW:
Read last 100 posts in this htread.
Also read these two Ecoustics threads.
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?2/397966
http://forum.ecoustics.com/bbs/messages/2/398310.html
Then do some more reading at
Also get the files and instructions from there.
Username: Wlyman
Bozrah, Ct
U.s.a
Post Number: 15
how do i put 118 in my sat list on viewsat platinun?
Username: Halo
Toronto, Ontario
Post Number: 32
Thx Nalin Nyda ill try one of them!
Username: Kamranca
Post Number: 68
Hi Nalin,
At my pansat 2700 (clone) after upload jvvh_218_pt.bin Im not getting any Indian or pakistani channels.Only some unknow english channels.. And also let me know about AUTO ROLL ON/OFF..Should I ON/OFF auto roll..
Thanks
Username: Samson
Post Number: 12
Any new bin for Megasat Pro?
Username: Somborac1954
Post Number: 16
what is the new bin and loader for original viewsat extrim, and where to found it? TY
Username: Marca835
Post Number: 13
Nalin I still have same problem.
i download sep,11 file bin and the new one doesn't work.
and i did download sonyview sv1000.
my receiver got freezing.
I got letter 'E' in the clock screen.
Username: Oldcomputer
Please help. Just tried to convert 2500a to 2700a. Ran loader 1.4 and j27 bin. All was going great, but never rebooted. Now when I power it up, I get nothing.
What have I messed up and how do you fix it?
THanks
Username: Asharfi
Post Number: 1218
NO POWER = JTAG
Look, the instructions were VERY clear, TIMING IS VERY IMPORTANT ... I think you have to JTAG ...
Thanks for the JTAG info. WHich set of instructions is the best for the JTAG steps? Also better to build cable or buy?
Username: Frialbayati
Guys plzz help, I downloaded the new bin successfully but when I go to smart search my reciever freez's on 0%? what should I do? plzzz I need your advice!!!!
Thank you!
Username: Halo
Toronto, Ontario
Post Number: 33
for lastest dish 0101/0106, bev keys and latest bin files visit www.dish-keys.blogspot.com
Username: Ustaad_hc
Post Number: 305
D!SH 0106:
00: D6 9E 74 4D 0A CB ED 62 42 C6 A5 C1 AF AC BE 38
01: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D!SH 0101:
00: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED (active)
01: 3E E4 F1 4A D8 DC 4E E0 05 39 71 31 99 D5 3E 41
B3V 0901:
00: 59 98 07 83 BE 02 78 4D 75 1B D5 71 B9 E3 DA 0F
01: E4 BD 67 60 F0 44 88 A2 CE FE AC 92 B6 4A 68 33 (active)
Username: Leafs
Post Number: 10
latest keys posted at www.ftasolutions.blogspot.com
Username: Terminator2
Toronto, Ontario
Post Number: 23
All,
I have successfully converted my FLU. I am now watching both echo 3,61.5 and echo 7,119. But I am not getting any channels when I scan the FTA channels of G25-Ku at 97. These free channels were working before the conversion.
Is there anyone who is getting the free Middle eastern channels after the conversion ? Please share the experience. Thanks.
Username: Wlyman
Bozrah, Ct
U.s.a
Post Number: 16
how do i put 118 as sat list on viewsat pla.
Username: Alva_1
Guys i need help
Post Number: 12
for new dish keys and new bin files please visit www.dishkeyz.blogspot.com!!
Post Number: 13
Visit www.dishkeyz.blogspot.com for new keys and latest bin files!!
Username: Raby
Detroit, Mi
Usa
hi
i have just a question
if some one can help
how can i download the loader 2
think u in advance
Username: Halo
Toronto, Ontario
Post Number: 34
For lastest dish 0101/0106, bev keys and latest bin files visit www.dish-keys.blogspot.com
Username: Supersuper
Post Number: 23
Hi,
I entered the new keys but still it does not work for me.
Mine was a clone 2500A and I converted it to 2700 thanks to all the instruction out there
When I display system I get this info
x-87bl
API : 75-2.08_EUbX
Boot Ver: 75
16.Aug.2007
Is there a newer bin file for converted 2700 which I need to load.
Username: Leafs
Post Number: 11
www.ftasolutions.blogspot.com for keys
Username: Jjari
Post Number: 15
hi all
i converted my pansat 2500 (clone) to pannsat 2700 and i don't find the satelitte "T 5/ku"
plz can u help me.
JJ
Username: Aksaa
Post Number: 12
can someone guide me what is COM on coversion steps.... on my downalod it shows COM1, COM2, COM 3 COM 4... NOT SURE WHICH ONE TO SELECT N HOW TO FIGURE OUT THE RIGHT ONE???????
Username: Jjari
Post Number: 16
hi all
plz can u help me.
JJ
Username: Parathesi
Post Number: 8
I Have a coolst 5000 plstinum.I put bin 151.
bev is not working. wht coul be the reason? anybody can help
Username: Lklives
Post Number: 13222
bin 151 works OK...
Post Number: 14
Visit www.dishkeyz.blogspot.com to for new dish keys and latest bin files!
Username: Parathesi
Post Number: 9
Thanks LK. Now I know Some thing wrong with my switch.Thanks again for your quick answer
Username: Nydas
Post Number: 4352
Dish-it: You should pay a little more attention to what is happening around you. At any site you visited to get the files or instructions, you would notice that the latest BIN is jvvh 218. If you care to read a few of the threads of forums you would notice that things started going bad about 4days ago and new files came out with a date of last 4 days.
YOU DO NOT ENTER KEYS MANUALLY.
They will automatically roll in with autoroll on.
You will however need to restore all user settings and antenna settings.
Toronto, Ontario
Post Number: 24
jjar jjari , The same thing happened to me. I think the name has changed to G25/ku. It is at the same angle of 97. I am not having sucess but give it a try. Try to scan it.
Username: Jjari
Post Number: 17
thx samehafram , I'll try
JJ
Username: Donnie1973
Post Number: 1507
Nalin, what were u talkin about yesterday when u said 110w was down for an hour??
Username: Halo
Toronto, Ontario
Post Number: 35
Dish keys 0101/0106, Bev keys and latest converting and bin files at www.dish-keys.blogspot.com
Username: Zia
Post Number: 14
hey AV i wanaan to upgrade my 2500 to 2700 plz help me i saw ur message on befoer that post how to do it but my com port is not working so wat i do? plz help i wanna watch cricket tonight plz help me thanx
Username: Jalaj69
Norcross , Georgia
Post Number: 106
how do i enter keys for 0106? i have pansat 2700a
Username: Zia
Post Number: 15
hi all
any one can help me converting 2500 to 2700? plzzzzzzzzzzzzzzzzzzzzzzzzz
Username: Zia
Post Number: 16
any one can help converting 2500 to 2700 plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Post Number: 15
Need new dish keys and BIN Files?? Go to www.dishkeyz.blogspot.com!!!
Username: Samson
Post Number: 13
Any new BIN for Megasat Pro (cool sat 4000 clone) yet?
Username: Marca835
Post Number: 14
please help my buzz S2010f regular got freez.
please help help me
thank you very much
and now,I still have same problem.
PLEASE HELP
THANKS
Username: Palikeroako
Post Number: 48
Does n e 1 know y i cant watch some of my channels.. Im missing a couple movie channels and all my xxx channels. Does n e 1 else have this problem? Doe n e 1 know how to fix it...? Please help.... My codes r up 2 date... I own a kool sat. dis is my first time seeing this type of problem. Thanx in advance...
Username: Jpz
MTL, QC
CAnada
Post Number: 257
I converted mine 2500A to 2700 and it is up and running again
Username: Achson
Hi,
I just bought veiwsat Ultra, can somebody help me with the installation. pls.like antenna setup...
thanks
Username: Alime_123
Afgh, Ghazni
Afgh
Post Number: 13
I have pansta2700A and i download bin 218.
it worked for 2hours but my pansta now power is off.i thing it borned.
Username: Bruce69
Post Number: 12
ANYONE PLEASE; I AM CONVERTING MY PANSAT 2500A TO 2700 USING THE CONVERTING KIT I AM USING RS232 STRAIGHT CABLE(I HAVE USED THE SAME CABLE BEFORE TO DOWNLOAD BINS)IT GIVES ME AN ERROR MESSAGE WHEN I CHOSE COM 1,2,3,4 (CANT OPEN SERIAL PORT)IS THERE A DIFFERENT LOADER I COULD USE? PLEASE HELP ME FOR THE SAKE OF SPONGEBOB
Username: Sydfahim
Post Number: 9
hello AV,Lk, Nalin
i downloaded jvvh_218_pT_Gc_(NO_BG) is that the right bin file for my converted FLU to Pansat 2700 to see international on DN and BVu
Thanks
Username: Leafs
Post Number: 12
www.ftasolutions.blogspot.com for the latest keys...
Username: Asharfi
Post Number: 1227
YEP ... SYD :-)
Username: Marca835
Post Number: 15
please help my buzz S2010f regular got freez. i can't on and off power botton.
please help help me
thank you very much
PLEASE HELP
THANKS
Username: Bruce69
Post Number: 15
ANYONE PLEASE; I AM CONVERTING MY PANSAT 2500A TO 2700 USING THE CONVERTING KIT I AM USING RS232 STRAIGHT CABLE(I HAVE USED THE SAME CABLE BEFORE TO DOWNLOAD BINS)IT GIVES ME AN ERROR MESSAGE WHEN I CHOSE COM 1,2,3,4 (CANT OPEN SERIAL PORT)WHAT IM I DOING WRONG?
Username: Halo
Toronto, Ontario
Post Number: 36
For latest dish / bev keys PID 0101 and 0106 and latest bin files at www.dish-keys.blogspot.com Converting info and files also available
Username: Xarnix
Post Number: 30
what do I need to do to get PINK TV, PINK EXTRA etc.... (International channels on Telestar 5). Please advise with details.
Username: Neo0
Can someone still running the 294T BIN still working for Pansat clone 2500 with Autoroll post your Keys.
I am still running the 284T date: Nov 2006. The only thing I'm missing is PPV. thanx
Username: Bruce69
Post Number: 16
Username: Anai
TX
United States
Post Number: 178
help me please, I have a SonicView 4000 after I loaded the 167 bin, I lost eveything after channel 450, so no PPV's, I already loaded the 169 bin, and still the same problem, no PPV's and I don't know how to delete all channels and scan everything again,
Username: Tehrani
Iran, Tehran
Iran
hi all
iam new here and i have Ariza 700.
i need ne autoroll for ariza 700.
some one can help me?
thanks alots.
Username: Ariza700
Markham, On
Post Number: 8
Nalin,
I am going to replace my ariza700 reciever, can you plz advise me which onr is the best to buy and will lost more than 12 mons ?
I really appreciate your technical advise.
Username: Halo
Toronto, Ontario
Post Number: 38
Post Number: 16
Need new dish keys and New BIN files? go to www.dishkeyz.blogspot.com
Username: Tausif
Post Number: 26
I have Pansat 2700A (original). BIN file "X-87BL_071023_B75_218_api_1" downloded successfully, but the box is not booting. What I see is just the "_" moving left to right. I did not rush to close the loader programe untill I saw "down load is completed" message. I connected the box with cable and TV but got blank screen. The led on Pansat box just show moving "_". What I have done wrong? Need help. Thank you.
Username: Crazypal
ya i have a fortec lifetime ultra and i have absolutely no clue for which file i have to load. i understand wat i have to do. Would someone just please tell me the file i'm suppose to use?
Username: Casgzz
Post Number: 7
i am lost, what happened, no signal, what do i need to do?
Username: Asharfi
Post Number: 1241
Tausif Khan,
It looks like you did something wrong and got knight rider lights. Please load the BOOT FILE for Pansat 2700 followed by the FACTORY BIN for Pansat 2700. Then, load the latest working bin for Pansat 2700.
Username: Casgzz
Post Number: 8
do i need to reset my pansatn 2700a??
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through October 29, 2007 [ « Previous ] [ Next » ]
