Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > Turn autorolls off enter keys manually
Author Thread: Turn autorolls off enter keys manually
Username: Silver1123
Mexico, DF
Mexico
Post Number: 329
Due to the changes in the stream done by DN, if you use a FTA, in order for it to work you need to:
1. Turn autorolls off
2. Enter keys manually
3. Install new bins when available
Username: Kirankumar
Post Number: 27
which keys do i put in
Mexico, DF
Mexico
Post Number: 330
Go to
http://www.dss-keys.com/
For key updates
Mexico, DF
Mexico
Post Number: 334
D!SH 0101 - Last Update: 10/31/07 01:09 PM
00: D6 1A 24 BF EA 89 B9 29 3D 84 14 3A 30 8F A4 C0
01: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F
B3V 0901 - Last Update: 10/31/07 11:34 AM
00: 47 FB 44 74 A3 FB FC 89 D3 08 FB F3 12 FB 6B D7
01: 34 96 C6 F7 62 EA 97 D7 89 CC 37 1B 33 72 F7 B2
Username: Karbum
Post Number: 45
thanks juan . The keys posted on some other forums had a couple keys changed in them , no wonder i couldn't get anything going :s
Username: Swirvin
Post Number: 51
do the dish keys work for 129 High Definition sat?
Mexico, DF
Mexico
Post Number: 340
If its Dish Network, they should.
Username: Tejneil
Post Number: 14
By putting these keys and also turning off autoroll it still does not work.
Help
Mexico, DF
Mexico
Post Number: 341
what box do you have?
Did you check for the latest keys?
DISH - Oct 30
86: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED
96: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F
0106: D6 9E 74 4D 0A CB ED 62 42 C6 A5 C1 AF AC BE 38
check here for latest updates
http://www.fta123.blogspot.com/
Username: Nydas
Post Number: 4378
DN - Provider ID 0101
Check the third number in Key 00 - it should be 24
Check the thirteenth number in Key 01 - it should be 5F
Username: Drmunna
Post Number: 12
above keys working fine,,,
Mexico, DF
Mexico
Post Number: 343
This are the latest keys working as of 6:30pm EST
Just tested them
Mexico, DF
Mexico
Post Number: 351
Other problems reported in some boxes, such as some polarities not working. In captivworks and viewsats
Username: Ekoneuno
Post Number: 16
juan
I have viewsat ultra and am in DN 01 01 00, I am seeing keys for 00, 08, 09, 88 and 89. The 00 has 16 keys while the others have 8 + 8 keys which are 00. CAn you help me on how to update these keys? Where do I change the 01 keys which you have posted above.
Username: Bill038
Post Number: 148
LINE 08=D6 1A 24 BF EA 89 B9 29
LINE 09=3D 84 14 3A 30 8F A4 C0
LINE 88=25 8D 8F 67 F7 5F DF 62
LINE 98=3D 7A 4D 7C E7 86 61 90
These are the latest bins. Do not change anything in line 00
Only change 8 sets of numbers per line.
Username: Donnie1973
Post Number: 1546
OMG eko... i told u how to do that. lol
Mexico, DF
Mexico
Post Number: 356
Eko: Just browse using the arrows on your remote, and enter keys on each of the boxes. When the box is full, it automatically skips you to the next.
Go to http://ftabins.net, enter the Viewsat category, and you will find tutorials and instructions
Username: Nydas
Post Number: 4398
Latest Viewsat BINs dated today are available at
http://www.totalfta.com
http://www.f2atv.com
Username: Nydas
Post Number: 4418
New Keys and BIN related help is now at
http://forum.ecoustics.com/bbs/messages/2/399896.html
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > Turn autorolls off enter keys manually [ « Previous ] [ Next » ]
