Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > For all those who are having problem ...
Author Thread: For all those who are having problem with 2700 converted
Username: Kb1
Post Number: 22
I converterd my 2500 clone to 2700 clone and uploaded the new bin. I scan and blind scan but only get internationl channel no matter what I do.
I have two dishes one for loacl channel and one for internationl channel.
So can some one tell me what should I do to get my local channel back.
I know lots of people are have the same problem so let us help each other,
Thanks
Username: Viruscauser
Leesburg, Georgia
Post Number: 319
If you noted your antenna settings before you converted, reenter them. If you did not note your settings down, try these:
Echo 7 - LNB Standard, Diseqc #1
Echo 8 - LND Standard, Diseqc #2
Echo 3 - LNB Standard, Diseqc #3
Don't worry about the skew etc and don't worry if a sat shows no quality. Enter those settings and scan again. See if that helps.
Username: Kb1
Post Number: 23
Thankyou I will try this
Username: Ak2011
Okay I'm having the complete opposite problem. I can only get local channels but not international channels. I have tried doing a scan and blind on all Echo 7, 4, and 3 with all the Diseqc settings but am getting NO results. Please Please Help. It will be greatly appreciated.
P.S. Is this a problem with the bin??
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > For all those who are having problem ... [ « Previous ] [ Next » ]
