Thread: Archive through October 26, 2007 |
New member Username: Neesha
Post Number: 5 Registered: Oct-07
| Posted on Thursday, October 25, 2007 - 09:44 pm: |
NALIN NYDA CAN YOU ANSWER MY QUESTION ABOVE THANK YOU |
Bronze Member Username: Maro
Post Number: 21 Registered: May-06
| Posted on Thursday, October 25, 2007 - 09:45 pm: |
come on someone help me i have a 2500a pansat clone and i tryed to convert it to 2700a/e and it dont work and it shows lines going left and right plz someone answer me thx |
Gold Member Username: Nydas
Post Number: 4269 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 09:46 pm: |
CoolSatFV : You don't change provider ID. If you have C00LSAT 5000 OR 6000 load the latest BIN and comes with it. Obtain the BIN from http://www.f2atv.com or http://www.totalfta.com or http://www.future-fta.info |
Post Number: 22 Registered: May-06
| Posted on Thursday, October 25, 2007 - 09:48 pm: |
i have a pnasat 2500a clone not a cool sat |
Post Number: 26 Registered: May-06
| Posted on Thursday, October 25, 2007 - 09:51 pm: |
hey guys i m an humain can some one help me |
Post Number: 4270 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 09:54 pm: |
neesha s: USB ports are notorious for giving problems when used as serial ports. 1. Use the drivers that came with the usb to serial adaptor. 2. there are only two types of serial cables - straight and null modem. Buy a M/F RS232 to Null modem adaptor and then with it in or out of the series you will get both types of cables. One of them should work. 3. Most uploaders use only Com1 or com2. Try and get that setting right. |
Post Number: 6 Registered: Oct-07
CAN YOU U USE A BRIDGE WITH A USB WIRE AND MY COMPUTER IS NOT READING THE PORT ON MY OTHER COMPUTER I CAN'T DOWN LOAD THE BIN HELP PLEASE THANK YOU IN ADVANCE |
Silver Member Username: Jalaj69
Norcross ,
Georgia
Post Number: 102 Registered: Sep-06
| Posted on Thursday, October 25, 2007 - 09:55 pm: |
man I have the same problem with the line going left to right! I have pansat 2700a clone! HELP |
Post Number: 4271 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 09:57 pm: |
marawan : You will have to follow instructions PRECISELY and reinstall. There are no short cuts and no haste. Your receiver is NOT dead. Look at conversion thread here and try and find out what you didn't do right. |
Post Number: 4272 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 09:58 pm: |
Jalar you should stick to either the vortex or the tivo files -whichever you have been using befre and use the apporpriate loader. |
Silver Member Username: Anai
TX
United States
Post Number: 172 Registered: Jun-05
| Posted on Thursday, October 25, 2007 - 10:00 pm: |
ok, I uploaded the Vo167P to my sonicview, and I didnt get all the channels, nothing after 453. suggestions? |
Post Number: 27 Registered: May-06
i did and follow the instruction precisley and they say that after we put the first bin it have to show b75 and it didn t and then its start the line left and right |
Post Number: 4273 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 10:01 pm: |
Sccrskills : You have the right attitude. Without the jvvh 218 BIN, there is nothing to gain right now by converting. Others in the conversion quandry read his posts above. |
Post Number: 4274 Registered: Jun-06
ana : do a Blind scan again |
Post Number: 28 Registered: May-06
| Posted on Thursday, October 25, 2007 - 10:03 pm: |
hey nalin can u just tell me wich bin would be right to convert a pansat 2500a CLONE to a 2700a/e thanx |
TX
United States
Post Number: 174 Registered: Jun-05
| Posted on Thursday, October 25, 2007 - 10:04 pm: |
ill try that, thx |
Bronze Member Username: Shyi
Post Number: 12 Registered: Jun-06
heloooooo please anyone or pros can tell me how to enter key in viewsat plat. after downloading new bin without code option in menu thanks in advance |
Post Number: 4275 Registered: Jun-06
Barnaby Granado: You have a good receiver and there is a new BIN for it. Go to one of the sites and read about it. http://www.f2atv.com http://www.totalfta.com http://www.dsstester*com |
Bronze Member Username: Jigga19
Post Number: 34 Registered: Feb-07
| Posted on Thursday, October 25, 2007 - 10:06 pm: |
i currently have flu and i know i have to convert it to 2700 to watch tv. isnt there any other option for me to watch tv with flu and if i have to convert it is there anyother option than using jvh bins and tool kits. is there any other bin and kits or anythin else that can be done with flu to watch the tv. |
Gold Member Username: Asharfi
Post Number: 1061 Registered: Aug-06
Marawan, Please checkout my thread, it's called: FLU-Pansat 2700 Converting Procedure! |
Post Number: 13 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 10:08 pm: |
Nalin Nyda or LK please give me any advise please for view sat plat how to entre keys . thanks |
Post Number: 29 Registered: May-06
ok thx AV i will sheck it but is it for clones to |
Post Number: 7 Registered: Oct-07
| Posted on Thursday, October 25, 2007 - 10:09 pm: |
TRY 0000 FOR THE KEY |
Post Number: 35 Registered: Feb-07
i currently have flu and i know i have to convert it to 2700 to watch tv. isnt there any other option for me to watch tv with flu and if i have to convert it is there anyother option than using jvh bins and tool kits. is there any other bin and kits or anythin else that can be done with flu to watch the tv. what tool kit i can use so that i can use either the vortex or the tivo files - |
Gold Member Username: Donnie1973
Post Number: 1395 Registered: May-06
| Posted on Thursday, October 25, 2007 - 10:12 pm: |
muhammed its an AUTOROLL BIN, no need to enter keys. |
Post Number: 4276 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 10:13 pm: |
marawan : Installing the jvvh_208_1.bin (448Kb) and any new serial load 2500to2700 conversion file: Use a 2500 style loader, specify the model "Pansat 2700A" if necessary. Download the modded and compressed jvvh_208_1.bin. Starting download just as you start box and see the first "b" of the "b-75" on the LED display. When completed let the box re-boot. Then load the jvvh 211 first. jvvh_211_pwTd.ZIP Then load jvvh 217. Wait for jvvh218 and load it when it comes out. |
Post Number: 14 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 10:14 pm: |
HELLO ANYONE OUT THERE TO HELP THENKS
Post Number: 36 Registered: Feb-07
| Posted on Thursday, October 25, 2007 - 10:18 pm: |
nalin. is it possible you can answer my question since you seem to know alot about this.. |
Post Number: 15 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 10:20 pm: |
HI, DANTETN} ITS NOT AUTO ROLLING AND IT HAS NO OPTION FOR CODE /NAGRA AS WE USE TO HAVE IN OLD BIN CURRENTLY I HAVE NOTHING JUST BLANK SCREEN .. THANKS FOR REPLY clipart{rofl} |
Bronze Member Username: Kamranca
Post Number: 58 Registered: Oct-06
| Posted on Thursday, October 25, 2007 - 10:21 pm: |
Hi Nalin welcome back, After convert fortec altra to Pansat 2700 Clone receiver im getting following problems.. 1.Im not getting any picture just a massage SCRUMBLE BAD CHANNEL 2. I did BLIND SCAN,Enter latest Dish keys.. What should I do now please help.what about auto roll and provider keys im waiting for your reply. Thanks a lot |
Post Number: 1063 Registered: Aug-06
| Posted on Thursday, October 25, 2007 - 10:27 pm: |
Marawan, That thread is for CLONES and FLUs ONLY ... I've another thread for the original Pansat 2500 |
Post Number: 8 Registered: Oct-07
| Posted on Thursday, October 25, 2007 - 10:29 pm: |
I'm still having the same problems. The driver that came with the CD is installed. My computer recognizes the cable. The issue is when I go to upload the bin file to the Loader it sends info to my reciever but there is no progress. It does not upload constantly remaining @ zero % (progress) Please help!!!!  |
Post Number: 1065 Registered: Aug-06
Kamran, There was an ECM 2 days ago, and that's why all the converted FLUs are down. We're all waiting for JVVH to release bin 218 for the conveted FLUs and Pansat 2500 CLONES |
Post Number: 1399 Registered: May-06
| Posted on Thursday, October 25, 2007 - 10:32 pm: |
uh... which bin did u load mohammed? |
Post Number: 59 Registered: Oct-06
| Posted on Thursday, October 25, 2007 - 10:33 pm: |
AV does it mean i have to wait.. |
Bronze Member Username: Halo
Toronto,
Ontario
Post Number: 24 Registered: Oct-07
| Posted on Thursday, October 25, 2007 - 10:36 pm: |
For the converting of Pansat 2500 to 2700 latest dish 0101 and 0106 keys. Bev keys visit www.dish-keys.blogspot.com |
Post Number: 16 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 10:38 pm: |
DANTETN I HAVE LOAD DBPSW-071024P FROM TOTALFTA.... |
Post Number: 1402 Registered: May-06
| Posted on Thursday, October 25, 2007 - 10:41 pm: |
I would get a factory bin file from ftabins or ftaprosupport factory default- load factory bin- load new bin again. see if it works after u put on factory bin. If it does, load new bin |
Post Number: 17 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 10:45 pm: |
OK DENTENT I WILL TRY THAT.. LETS HOPE FOR BETTER....... THANKS FOR YOUR QUICK REPLY |
Post Number: 1403 Registered: May-06
| Posted on Thursday, October 25, 2007 - 10:47 pm: |
yes sir. good luck |
New member Username: Bashir77ca
Post Number: 6 Registered: Jun-07
| Posted on Thursday, October 25, 2007 - 10:54 pm: |
there is new bin 218 by tivo is it for converted 2500 to 2700? thans |
New member Username: Huremkic
| Posted on Thursday, October 25, 2007 - 10:55 pm: |
hi guys I have fortec star lifetime ultra and I loaded new bin and my reciver went dead, no # nothing . is my box dead, can I fix it and how it is not converted it is regular fortec star lifetime ultra |
Post Number: 1067 Registered: Aug-06
| Posted on Thursday, October 25, 2007 - 10:56 pm: |
Kamran, Yes we have to wait! Dawood, That TiVo bin is not for the converted boxes. It's for the clones and genuine boxes only. |
| Posted on Thursday, October 25, 2007 - 10:58 pm: |
AV help please |
Post Number: 18 Registered: Jun-06
HI DANTETN I TRIED AGAIN ON COPUTER SCREEN ITS SAY DOWNLOADING COPLETED BUT ON RECEIVER AFTER 1OO % ITS SAY FAILD NOW ITS THE SAME AGAIN |
| Posted on Thursday, October 25, 2007 - 10:59 pm: |
Post Number: 1405 Registered: May-06
| Posted on Thursday, October 25, 2007 - 11:00 pm: |
Download the bin again from totalfta make sure u unzip (extract) the folder. Did u put a factory bin on it?? |
Post Number: 9 Registered: Oct-07
| Posted on Thursday, October 25, 2007 - 11:03 pm: |
anybody please |
Post Number: 1407 Registered: May-06
| Posted on Thursday, October 25, 2007 - 11:05 pm: |
hure, which bin did u download? |
Post Number: 10 Registered: Oct-07
| Posted on Thursday, October 25, 2007 - 11:06 pm: |
218 |
Post Number: 1408 Registered: May-06
| Posted on Thursday, October 25, 2007 - 11:07 pm: |
the clone bin or not?? |
Post Number: 37 Registered: Feb-07
totalfta is shut down its not lettin anyone to the forums. why everyone keeps saying go there... |
Bronze Member Username: Huremkic
Post Number: 11 Registered: Oct-07
| Posted on Thursday, October 25, 2007 - 11:08 pm: |
not a clone |
Post Number: 1409 Registered: May-06
| Posted on Thursday, October 25, 2007 - 11:09 pm: |
try ftabins ftaprosuppoprt dssrookie dsstester dsscentral some are .net not .com |
Bronze Member Username: Terminator2
Toronto,
Ontario
Post Number: 18 Registered: Sep-06
| Posted on Thursday, October 25, 2007 - 11:11 pm: |
Nalin, I have an FLU that I am ready to junk. Which receiver out there you feel will be supported in the next few years. Viewsat ... CW or ..etc Thanks |
Post Number: 1411 Registered: May-06
| Posted on Thursday, October 25, 2007 - 11:16 pm: |
PTA may not last that long, but i'd say sv4000 or vs ultra. Great recievers, low cost, good memory and speed |
New member Username: Zia
| Posted on Thursday, October 25, 2007 - 11:17 pm: |
hi every one i need your help plz zzzzzzzzzz i have a pansat2500 i can see my programs but no ppv or any sport is coming on or any desi chanels my box was working fine but i can see only regular programs now no more ppv movies plz help me wat to do to watch my ppv?}} |
New member Username: 6will03
Hollywood,
Florida
Post Number: 1 Registered: Oct-07
| Posted on Thursday, October 25, 2007 - 11:24 pm: |
guys how's everybody doing, i am the newest guy using sta, and i do't know how to install the new bin in my sonicview sv-100 can anybody show me how and where to get it!!!! pleaseeee.....! i lost almost all channels |
Post Number: 19 Registered: Jun-06
| Posted on Thursday, October 25, 2007 - 11:25 pm: |
Hi Dantetn Thanks buddy with your help I'm up and running thanks a lot
Post Number: 1414 Registered: May-06
| Posted on Thursday, October 25, 2007 - 11:26 pm: |
i cant help on those, i think u need to convert to a 2700. MANY have asked how to do this lately. There are MANY posts that tell u how to do this. There is not a fix yet for the converted boxes, so, u may want to wait. but u can read up on how to do it in the mean time |
Post Number: 1415 Registered: May-06
| Posted on Thursday, October 25, 2007 - 11:27 pm: |
u are welcome. Glad it works for ya |
New member Username: Jjari
| Posted on Thursday, October 25, 2007 - 11:46 pm: |
hi all i have pansat 2500 , any help plz thx a lot jjari |
| Posted on Thursday, October 25, 2007 - 11:48 pm: |
hi all i have pansat 2500 , any help plz thx a lot jjari} |
Post Number: 1422 Registered: May-06
| Posted on Thursday, October 25, 2007 - 11:49 pm: |
william... read here u may need to register for free. http://www.dssrookie.com/forums/b-font-color-00cc00-sv-guides-faqs-font-b/ |
| Posted on Thursday, October 25, 2007 - 11:51 pm: |
hi all i have pansat 2500 , any help plz thx a lot jjar |
| Posted on Thursday, October 25, 2007 - 11:53 pm: |
hi i have a pansat2500 . i can see all other programs but not the movies or indian programs wat do i have to do to see those programs? scan or blindscan or antina setup? don't no wat to do plz HELP MEEEEEEEEEEEE THANX |
Post Number: 1427 Registered: May-06
| Posted on Thursday, October 25, 2007 - 11:57 pm: |
zia there are no bins for the 2500 anymore. I answered u a little while ago. a couple posts after u asked the first time. |
| Posted on Thursday, October 25, 2007 - 11:58 pm: |
plz where can i downlod jvvh218 thx |
Bronze Member Username: Falcon21
Van,
Bc
Ca
Post Number: 13 Registered: Aug-07
| Posted on Friday, October 26, 2007 - 12:01 am: |
Dantetn, After a pretty good research on most of the sites.. I think my Viewsat Xtreme is dead... Maybe one of the chip is burned... I even have try to use other box's power supply it still doesn't work. Thanks Fal |
Bronze Member Username: Qasim
Montreal,
QC
Post Number: 20 Registered: May-06
| Posted on Friday, October 26, 2007 - 12:06 am: |
how can i get the indian channel on the pansat 2700 or in the other word international channels |
Post Number: 1429 Registered: May-06
| Posted on Friday, October 26, 2007 - 12:08 am: |
u can try to connect to a working VS with a factory bin on it. connect with the null modem cable from one to the other. turn on the on with the factory file- go to menu-reciever upgrade-main s/w- click ok turn on other reciever from back. worth a shot, see what happens. u can send it to viewsat for repair. there is a good waranty on it if u have ur reciept |
New member Username: Ganjaa007
Post Number: 6 Registered: Nov-06
| Posted on Friday, October 26, 2007 - 12:22 am: |
hi guys i have a cools*t i loaded the 1.51 bin my sat 119 is working fine however my 61.5 is not working at all anyone know why?? |
New member Username: Sharaz
Post Number: 3 Registered: Oct-07
| Posted on Friday, October 26, 2007 - 12:46 am: |
Hi all, Can somebody tell me that if Sonicsat is clone of Sonicview 4000....thnx a lot |
Bronze Member Username: Pitbullk_9
Post Number: 32 Registered: Oct-06
| Posted on Friday, October 26, 2007 - 01:10 am: |
hi guy can anyone tell me how to get the bin for colsat 4000. my ppv channels are not working. is that the reason why? |
Van,
Bc
Ca
Post Number: 14 Registered: Aug-07
| Posted on Friday, October 26, 2007 - 04:36 am: |
any good receiver other than Viewsat out there?? any suggestions? |
Toronto,
Ontario
Post Number: 25 Registered: Oct-07
| Posted on Friday, October 26, 2007 - 07:29 am: |
For dish bin files , Bev/Dish (0101,0106) keys and converting 2500 to 2700 files and instructions visit, www.dish-keys.blogspot.com |
New member Username: Sunny416
| Posted on Friday, October 26, 2007 - 09:42 am: |
Hey guys i have Pansat 2700a i m trying to upload the bin file but it keeps on saying "Unknown File Type" anyone know how to fix it?? thanks Sunny |
Van,
Bc
Ca
Post Number: 15 Registered: Aug-07
| Posted on Friday, October 26, 2007 - 11:01 am: |
How can I tell if my Xtreme is a clone or not... on the outside it looks all the same... some people r saying there is a clone kill in the new bin... I have bought it from a local dealer.. It will be hard for me to tell if it is a clone or not... So I guess everyone bought the Xtreme online won't have the problem? |
New member Username: Kiarra12
| Posted on Friday, October 26, 2007 - 11:04 am: |
Can anyone help me? I'm a newbie and my sat has been down for days. I have an echostar 3100 and need the bin file for it? I would greatly appreciate any help. |
New member Username: Boling
| Posted on Friday, October 26, 2007 - 11:48 am: |
Can anyone help me? I'm a newbie and my sat has been down for days. I have an Pansat 3500 and need the bin file for it? I would greatly appreciate any help. |
New member Username: Mattalca
| Posted on Friday, October 26, 2007 - 11:51 am: |
PPV movies not working, other channels are working for me. Don't know what to do since no new keys are out. Any Help? Thanks |
Post Number: 38 Registered: Feb-07
| Posted on Friday, October 26, 2007 - 12:37 pm: |
wat the heck is wrong with this jvvh guy...why isnt he releasing like others.. |
New member Username: Falafel1
Ny,
Ny
Usa
| Posted on Friday, October 26, 2007 - 12:43 pm: |
Where can I find the bin file for Pansat2700A. Thanks, Falafel |
Bronze Member Username: Sccrskills
Post Number: 77 Registered: Dec-06
| Posted on Friday, October 26, 2007 - 12:47 pm: |
go to ftabins.net register its free and go under file section and into pansat 2700. and ur set. |
Silver Member Username: Dr_dss
Post Number: 114 Registered: Sep-07
| Posted on Friday, October 26, 2007 - 12:53 pm: |
Rohail malik wat the heck is wrong with this jvvh guy Nothing wrong with him. What the heck wrong with you! He owes your nothing! Remember that. He does the bin's as a service to the hobby. He doesn't work for anyone or get paid for doing it. You are lucky he helps. Remember that before you post your next give-me-give-me Whinner-baby message. |
New member Username: Achson
| Posted on Friday, October 26, 2007 - 01:21 pm: |
Thanks for all ur Help Nalin & Sonny!!! NAlin: now that i have to buy a new receiver can u give me suggestions what i should be looking for and for how much. |
Post Number: 1445 Registered: May-06
| Posted on Friday, October 26, 2007 - 01:25 pm: |
falcon, read... this may help c/p OK,Now Look at the register NO# on the box.Its on the lid,Open box cover and make sure NO# Match,With the same VS# inside on the mother board. If a Clone,they will replace box and the NO# on the mother board will no longer match,also the price of the unit should have been around 170-180.00. w/null cable and a VS41 or DiSEqC switch 4x1 inside.Thats another clue. If you bought it on flea-bay,watch out.From a Viewsat dealer your OK, but there again check the ID no# inside the unit.Here is what it should look like. Now one photo show's what everything is inside(NO jumpers).Real Viewsat,Clones have jumpers inside box.Second photo is for VS ID tag.Look at where it is inside your box,and if it has another sticker over top it,that means it would have been sub'd out from china,still no big deal. Now your asking 100%,yes or no.Your the only person that can answer that question,you have all the information,Where you bought it,From Whom,how much you gave,ID no# match or not. I wouldnt care much about the size of the box remember viewsat has alot of company's making them now.Clone's are easy to spot.If your not sure,send it back as long as you can get a refund. Odd |
Bronze Member Username: Dannienjulie
Post Number: 37 Registered: Jul-07
| Posted on Friday, October 26, 2007 - 01:42 pm: |
I have a Quantum 4700 and I am only getting a variety of channels. I don't get any PPV, A&E,Disc, or TLC. Can anyone help fix this problem.PLZZZZZ} |
Post Number: 4 Registered: Oct-07
| Posted on Friday, October 26, 2007 - 01:47 pm: |
how about viewsatultra or sonicview4000 |
Post Number: 1074 Registered: Aug-06
| Posted on Friday, October 26, 2007 - 02:00 pm: |
huremkic, Why did you download that bin 218? There aren't any new bins for FLUs, which means you downloaded the wrong bin and KILLED your unit. If you're getting no power, etc, you have to JTAG.  |
Bronze Member Username: Manthedent
Post Number: 27 Registered: Sep-06
| Posted on Friday, October 26, 2007 - 02:31 pm: |
nalin do these recivers have the new bins or i have to waint for it to be released and do they show the international channles Sonicview 4000 - USB and serial input Viewsat Ultra - USB and serial input Captiveworks 600 Premium - serial input only |
Silver Member Username: Jpz
MTL,
QC
CAnada
Post Number: 256 Registered: Jun-06
| Posted on Friday, October 26, 2007 - 02:39 pm: |
still nothing for pansat 2500 clone ? |
Post Number: 28 Registered: Sep-06
| Posted on Friday, October 26, 2007 - 02:42 pm: |
Post Number: 78 Registered: Dec-06
| Posted on Friday, October 26, 2007 - 02:45 pm: |
nope you have to wait for jvh218 bin untill then nothing more than what you have right now. |
Post Number: 4279 Registered: Jun-06
| Posted on Friday, October 26, 2007 - 03:07 pm: |
All receivers are sold with factory BINs. These usually will work with real Free to Air Channells. The BINs and files discussed in many forums are files that make the receiver work better and correct any deffects in the software. You see the software is right inside the box, and they cannot take out each box to update the receiver. So what you have to do is to add the latest software after you have got the box. It's really quite simple. |
Post Number: 4280 Registered: Jun-06
| Posted on Friday, October 26, 2007 - 03:14 pm: |
C00LSAT 4000 new BIN released. http://forums.f2atv.com/showthread.php?t=172849 COOLSAT4000_NORW_151_20071025.zip (1,006.7 KB) do not use on clones, such as cooltec and megasat pro. |
Post Number: 4281 Registered: Jun-06
| Posted on Friday, October 26, 2007 - 03:17 pm: |
Sonia: these are good receivers, with reasonably good support. Sonicview 4000 - USB and serial input - about $170 Viewsat Ultra - USB and serial input - about $180 Captiveworks 600 Premium - serial input only - about $110 |
Post Number: 1112 Registered: Aug-06
| Posted on Friday, October 26, 2007 - 03:29 pm: |
Fiinally, that JVVH released bin 218 for the converted FLUs and Pansat 2500 Clones. It's an use at your own risk file. Here's the link to download: http://forum.ecoustics.com/bbs/messages/2/389206.html I'm gonna test it now and tell ya people the response. Also available at www.dssrookie.com |
Post Number: 1113 Registered: Aug-06
Sorry, here's the link to that new file: http://www.hostclip.com/download.php?file=1eb059eeb29f648541475b7c2eff1bf6 |
Post Number: 2 Registered: Oct-07
| Posted on Friday, October 26, 2007 - 03:30 pm: |
Where can I find bin files for pansat 3500? |
