Thread: Archive through October 24, 2007 |
Gold Member Username: Nadadesat
Post Number: 1164 Registered: Jun-07
| Posted on Tuesday, October 23, 2007 - 06:48 pm: |
BUENO AHORA SI BYEEEEEE. |
Post Number: 1165 Registered: Jun-07
| Posted on Tuesday, October 23, 2007 - 06:50 pm: |
QUISE DECIR SKEW EN EL POST DE LA ANTENA. AHORA SI BYEEEEEEEEEEEEEEEEEEEEEEEEEEEEE. |
Bronze Member Username: Canada_havana
High river,
Alberta
Post Number: 60 Registered: Sep-07
| Posted on Tuesday, October 23, 2007 - 07:18 pm: |
ERNESTO M. M. disculpa lo ante dicho,,, saludos y bendiciones ,,,, canada,,,, |
New member Username: Salzsilva
San diego,
Ca
Usa
Post Number: 10 Registered: Jan-07
| Posted on Tuesday, October 23, 2007 - 07:22 pm: |
AYUDA POR FAVOR!!!! ALGUEN ME PUEDE DECIR COMO PONER EL BIN A UN CAPTIVEWORKS 600S PASO A PASO QUE TIPO YA TENGO EL CABLE, EL BIN 1.45. qUE SUGUE DE ALLI? COMO LO HAGO UNZIP? QUE PROGRAMA USO? SE LOS AGRADESCO A TODOS} |
Gold Member Username: Javy_gza
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1093 Registered: Oct-06
| Posted on Tuesday, October 23, 2007 - 07:42 pm: |
sal aqi va algo de c w mientras sale el sr ernesto m saludos claro tmbn al sr chino y a toda la raza . |
Bronze Member Username: Lribon
London ,
On
Post Number: 52 Registered: Jan-07
| Posted on Tuesday, October 23, 2007 - 08:03 pm: |
alguien sabe donde bajar los ultimos bines para una Panset 2500A, por favor... |
Bronze Member Username: Oijaz
Post Number: 13 Registered: May-07
| Posted on Tuesday, October 23, 2007 - 08:22 pm: |
Masters Tengo una Pansat 2700E y hace alrededor de tres horas que pedio senal. revise los bines y estan correctos, no creo tener problemas con el autorroll y la antena esta sin alterar. Pero no se por que razon no le cae la senal. Alguien me puede ayudar? |
London ,
On
Post Number: 54 Registered: Jan-07
| Posted on Tuesday, October 23, 2007 - 08:35 pm: |
alguien me podria decir como se llama el cable que se utiliza para conectar la caja al computador para bajar los bins??? gracias |
Silver Member Username: Silver1123
Mexico,
DF
Mexico
Post Number: 307 Registered: Jul-07
| Posted on Tuesday, October 23, 2007 - 08:39 pm: |
Luis, es un cable null o de impresora, de 9 pines, lo consigues en Steren o Radio Shack |
London ,
On
Post Number: 55 Registered: Jan-07
| Posted on Tuesday, October 23, 2007 - 08:43 pm: |
gracias juan! |
Bronze Member Username: Cherrysalas
Tampa,
Fl
Pinellas
Post Number: 66 Registered: Oct-06
| Posted on Tuesday, October 23, 2007 - 08:57 pm: |
SALUDOS Y SALUDOS A TODOS...SE CAYERON LOS PPV, QUE PASO? HASTA CUANDO HAY QUE ESPERAR, HAY ALGUN BIN NUEVO?. ALGUIEN ME PUEDE RESPONDER?. gracias mi raza, TENGO UN PANSAT 2500 ORIGINAL |
Bronze Member Username: Nikk
Post Number: 15 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 09:15 pm: |
Cherry... Hubo un ECM....ya estan saliendo los bines... |
London ,
On
Post Number: 56 Registered: Jan-07
| Posted on Tuesday, October 23, 2007 - 09:16 pm: |
Juan me puedes decir donde puedo bajar el software para instalar los bins en la caja???? o alguien que sepa.. gracias |
Bronze Member Username: Frankp
Post Number: 28 Registered: Jun-06
| Posted on Tuesday, October 23, 2007 - 09:32 pm: |
yo tengo un lava 3200 ya no tiene solucion? estoy frito se va a la basura , por favor ayuda |
Bronze Member Username: Rolando
Post Number: 18 Registered: Sep-07
| Posted on Tuesday, October 23, 2007 - 09:38 pm: |
Puedo usar este bin X-85BL 071016 299 Tivo api. zip. Para mi pansat 2500a combertido a 2700 En el lugar que lo baje dice que es para el 2500a. Tenia entendido que los bins para los 2500a ya no ivan a salir y que para los combertidos enpiesan con las letras jvvh. |
Post Number: 16 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 09:45 pm: |
luis ribon... El cable para los clones del Pansat 2500 es el RS232 "straight", es un cable uno a uno, luce exactamente como el de la foto pero interiormente sus pines estan conectados en una configuracion que se llama uno a uno, es decir el pin 1 de un extremo esta conectado al pin 1 del otro extremo y asi con los demas pines.. Los bines los bajas de ftabins.net, hay una seccion de archivos, buscas los que sean para clon de 2500 |
Post Number: 17 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 09:47 pm: |
Billy the kid...... Para los equipos convertidos requieres por fuerza un bin jvvh_, si le pones uno diferente corres el riesgo de dañar tu equipo.... Si tienes varios equipos y te gusta el testeo y no te importa _hacer JTag puedes probar poniendole uno de los bines que dices... Si no es asi, entonces hay que esperar a que salga el fix jvvh.. |
Gold Member Username: Juancho
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1539 Registered: Dec-06
esperando por el bin de VS, no parches como los del 7 y 8 de oct, saldra esta noche o manana. El pansat2700a trabajando desde ha*ce 9 horas con el bin de este dia , el que esta en ftabins, |
Post Number: 18 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 09:49 pm: |
frank.... Tu equipo es un clon de Pansat 2500, puede ser convertido a clon de Pansat 2700, hay una serie de archivos y pasos para efectuar la conversion...una vez hecha la conversion debes instalarle los bines que comienzan con jvvh_ |
Silver Member Username: Lord_marius
Post Number: 265 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 09:51 pm: |
Clone de Pansat 2500a -------------------------------------------------------------------------------- Me acava de Caér me imajino que un Clone de Pansat 2500, este equipo se llema "panset 2500a- N2" su ultima actualizacion se la hicieron el 1 de octubre del 2005, quisiera saber que es lo que tengo que acer para actualizarlo, que Loader tengo que descargar, que Fix tengo que meterle, o todo lo que tenga que acer para echarlo andar... Todo comentario sera Muy bien aceptado!! |
Post Number: 19 Registered: Oct-07
Saludos Juan Ramirez...... |
Post Number: 266 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 09:52 pm: |
Clone de Pansat 2500a -------------------------------------------------------------------------------- Me acava de Caér me imajino que un Clone de Pansat 2500, este equipo se llema "panset 2500a- N2" su ultima actualizacion se la hicieron el 1 de octubre del 2005, quisiera saber que es lo que tengo que haser para actualizarlo, que Loader tengo que descargar, que Fix tengo que meterle, o todo lo que tenga que haser para echarlo andar... Todo comentario sera Muy bien aceptado!! |
Post Number: 20 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 09:54 pm: |
Esau.... Los clones de Pansat 2500 hay que bajarle el bin 294T que es el ultimo para esos receptores...no creo que funcionen ya con este ultimo ECM.. La otra que puedes _hacer es convertirlo a clon de 2700 y ponerle los bines jvvh_.....mandame PV con tus datos... |
Post Number: 267 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 09:59 pm: |
Nikk Mty skateboardrt@hotmail.com Gracias por tu pronta y amable respuesta hermano... por favor echame la mano amigo, estoy muy desorientado, nose que haser!! |
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1541 Registered: Dec-06
| Posted on Tuesday, October 23, 2007 - 10:01 pm: |
saludos al nuevo nick nikk, haber si no hay confusion para cuando estes llegando al # de posts que hay en los archivos, el post #816 del primer nikk y el post #816 del segundo nikk.lol |
Post Number: 268 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 10:08 pm: |
Juan me podrias ayudar... |
Post Number: 21 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 10:13 pm: |
Esau.... Ya te llego un regalo de navidad anticipado |
Bronze Member Username: Simple30
Oxnar,
California
Los angeles
Post Number: 70 Registered: Mar-07
| Posted on Tuesday, October 23, 2007 - 10:15 pm: |
he hola atodos avisando que aun seven los canales de ppv pero en la numeracion (5816) y lla veran que aun estan bueno espero que les sirva la informacion bueno me despido que pasen buenas noches |
Post Number: 22 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 10:17 pm: |
Esau.... Hubo un ECM y apenas estan saliendo nuevos bines...el ultimo bin para los equipos convertidos a clon de 2500 es el jvvh_217...lo mas seguro es que con ese ya no se vean todos los canales, pero es el mas actual, esperemos que en el transcurso de hoy o mañana salgan las actualizaciones de bines jvvh_.... |
Bronze Member Username: Titu72
Tecate,
Baja california
Mexico
Post Number: 93 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 10:18 pm: |
Hola saludos a todos alguien sabe si ya hay bin para el 2500/2700 clon? |
Post Number: 24 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 10:20 pm: |
francisco javier.... Si te refieres al convertido...aun no sale nada... |
Silver Member Username: Mrrasec
Post Number: 245 Registered: Jul-06
| Posted on Tuesday, October 23, 2007 - 10:22 pm: |
alguien sabe algo como de agregar un provider id 0106 con sus keys y ya? yo intente agregarlo pero la ultra no salva el 01 06 00 y me quede con la espina. alguien lo intento? |
Post Number: 269 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 10:23 pm: |
nikk mty agregame a tu correo por favor tengo demasiadas dudas |
Post Number: 26 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 10:27 pm: |
Asi es Juan.....esperemos que no pase nada....jejeje |
Tecate,
Baja california
Mexico
Post Number: 94 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 10:35 pm: |
Nikk Mty si me refiero al convertido y pues ni modo a esperar gracias saludos |
Bronze Member Username: Jacova
Montreal,
Quebec
Post Number: 87 Registered: Oct-06
| Posted on Tuesday, October 23, 2007 - 10:36 pm: |
buenas noches julio ramos no entiendo a que te refieres con (5816) ya que yo no tengo tantos canales ha no se me ven los ppv y los HBO puedes guiarme mejor para verlos de antemano gracias |
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1542 Registered: Dec-06
| Posted on Tuesday, October 23, 2007 - 10:43 pm: |
Savoy. solo se le puede agregar manualmente provider ID a los reciveres que trabajan con tarjetas, pero no a los fta. |
Gold Member Username: Tetuscosmicus
Post Number: 1502 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 10:45 pm: |
NUEVOS BINs. PARA PANSAT.. Pansat Clone 2700 Ace 2700 clone loader v27.02 2700 clone loader v1.4.0.0 2700 clone loader Boot v7.5 -10 mars 07 Bin v203t -11 avril 07 Bin v204t -15 juillet 07 Bin v209t -05 sept. 07 Bin v213v1 -13 sept. 07 Bin v217v3 -10 oct. 07 Oui Pansat Clone 3500 GTrom Loader v3.42 X05BL Loader v35.01 Boot v8.0 -05 jan. 07 Bin v332t -15 oct. 07 |
Post Number: 1503 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 10:47 pm: |
Pansat 2500a 2500 Loader v2.1b 2700 à 2500 back jvvh v208 -19 aout 07 jvvh v209 -06 sept. 07 jvvh v211 -11 sept. 07 jvvh v217 -09 oct. 07 Bin v299 -16 oct. 07 |
Post Number: 1166 Registered: Jun-07
| Posted on Tuesday, October 23, 2007 - 10:52 pm: |
EMILIO VENTO MIS RESPETOS HACIA TI, LO DE LAS OPKEY ERA UN JUEGO. COMO CREES QUE TE VOY A DISCULPAR SI SIEMPRE TE HAS PORTADO DE MARVILLA. BENDICIONES HERMANO. |
Post Number: 1504 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 11:27 pm: |
ESTA BUENO TU POST... SALUDOS.. Corn_Flakes Gold Member Username: Jorge_luis La Ignorancia es el único pecado existente en el mundo. Causa de todos los males y sufrimientos. , CONOCE LA VERDAD Y ELLA TE HARÁ LIBRE Post Number: 1039 Registered: Jul-06 Posted on Monday, October 22, 2007 - 11:57 pm: MOY.......Uploadclick en la imagen |
Bronze Member Username: Juniorcm
Hialeah,
Fl
Usa
Post Number: 29 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 11:52 pm: |
buenas noches necesito saber si a alquien que tenga una viewsat se le estan biendo los ppv o los HBO porque yo no los puedo ver |
Silver Member Username: Rrios01
Monterrey,
N.L.
Mexico
Post Number: 279 Registered: Oct-06
| Posted on Wednesday, October 24, 2007 - 12:01 am: |
Saludos a todo el foro, pues confirmando lo que mi compadre ernesto dijo, el fix del cw600 premium funcionando al 100% para los que tiene dudas como cargarlo utilicen el loaderv1.06, ese se puede utilizar para el cw600 regular y tambien para el premium, solo conecta tu cable al receptor y a la pc enciendelo y espera a que haga el boot, despues lo apagas del boton de encendido de la parte de enfrente y se queda en stanby "--:--" abres el loader abres el bin ya descompactado y le das start espera a que en el display ponga end y listo apagalo de atraz desconectalo de la pc y ponlo en la tele y ya saludos compi ernesto javi garza, juan cavazos nikk etc, etc |
Bronze Member Username: Jmendozab
Post Number: 67 Registered: Jul-06
| Posted on Wednesday, October 24, 2007 - 12:09 am: |
No, en viewsat no se ven los PPV ¿Podemos poner las keys manuales? |
Hialeah,
Fl
Usa
Post Number: 30 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 12:13 am: |
me pueden dar las keys para ponerlas |
Hialeah,
Fl
Usa
Post Number: 31 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 12:29 am: |
alquien me podria dar las keys por favor |
Post Number: 1505 Registered: Nov-06
| Posted on Wednesday, October 24, 2007 - 12:33 am: |
www.dsskeys.com |
Post Number: 1506 Registered: Nov-06
| Posted on Wednesday, October 24, 2007 - 12:34 am: |
www.expressfr.com |
Post Number: 1507 Registered: Nov-06
| Posted on Wednesday, October 24, 2007 - 12:40 am: |
Keys -------------------------------------------------------------------------------- Keymaster ---------------------------------------- DN and Bev Keys Feed Nag2 keys ---------------------------------------- Dish Provider 0101: Last Updated (16 Oct '07 6:31 PM EST) Key 0: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED (Active) Key 1: 3E E4 F1 4A D8 DC 4E E0 05 39 71 31 99 D5 3E 41 Bev Provider 0901: Last Updated (21 Oct '07 6:29PM EST) Key 0: 59 98 07 83 BE 02 78 4D 75 1B D5 71 B9 E3 DA 0F Key 1: E4 BD 67 60 F0 44 88 A2 CE FE AC 92 B6 4A 68 33 (Active) Sun, 21 Oct 2007 17:29:10 CDT |
Hialeah,
Fl
Usa
Post Number: 32 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 12:45 am: |
hetor tengo todos esos numeros puestos pero sique en autoroll puedes decirme que pasa |
Hialeah,
Fl
Usa
Post Number: 33 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 12:51 am: |
hetor estas por aqui por favor contestame |
Silver Member Username: Nica
Matagalpa,
Matagalpa
Nicaragua
Post Number: 196 Registered: Dec-06
| Posted on Wednesday, October 24, 2007 - 01:14 am: |
Dish Network Main - 0101 [Last update: Tue. Oct 16, 3:21 PM CDT] 86: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED New 96: 3E E4 F1 4A D8 DC 4E E0 05 39 71 31 99 D5 3E 41 Dish Network New PID - 0106 [Last update: Tue. Oct 23, 1:14 PM CDT] 86: D6 9E 74 4D 0A CB ED 62 42 C6 A5 C1 AF AC BE 38 New |
Post Number: 1508 Registered: Nov-06
| Posted on Wednesday, October 24, 2007 - 01:25 am: |
--JUNIOR-- YO TENGO UNA FORTEC 2500 CLON LIFE TIME NO COMBERTIDA..Y USO EL BIN 293t..Y SI NINGUN PROBLEMA......CLARO.... Yo he tenido que poner a trabajar manualmente mi fortec (le pongo las yaves a mano)y responde muy bien, y dejando la opcion... keycode ON y las otras 3 opciones OFF... |
Post Number: 1509 Registered: Nov-06
| Posted on Wednesday, October 24, 2007 - 01:30 am: |
---JUNIOR--- SI TIENES ESA CAJITA..PUEDES ASER LO QUE TE DIGO..Y SINO AGUNNO DE LOS MAESTRO QUE TENGA CAJA IGUAL A LA TUYA...TE CONTESTARA.. ES IMPORTANTE QUE DIGAS QUE CAJA TIENES PARA SABER QUE RESPUESTA DAR... SALUDOS Y SUERTE..... |
Hialeah,
Fl
Usa
Post Number: 34 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 01:34 am: |
no logro ver nada |
Hialeah,
Fl
Usa
Post Number: 35 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 01:40 am: |
tengo una viewsat p y asta hoy estubo trabajando bien pero los ppv y los HBO NO SE ESTAN VIENDO |
Bronze Member Username: Cperdomomesa
Toronto,
Ont
Post Number: 12 Registered: Feb-07
| Posted on Wednesday, October 24, 2007 - 02:14 am: |
Grupo no se ven los PPV? |
Bronze Member Username: Shadow45
Mty,
Nuevo Leon
Mexico
Post Number: 95 Registered: Aug-07
| Posted on Wednesday, October 24, 2007 - 02:51 am: |
raza, para que no se desesperen.... DN hizo un cambio de Provider ID , es por eso qeu unos canales no se pueden ver, por lo visto ya se esta trabajando en un "arreglo" para esta situacion. Asi que no se desesperen y solo hay que aguantar hasta que salga el bin adecuado para la caja que tengan...Todo esto ya a sido explicado en los posts de mas arriba, por favor lean para que no haya exceso de posts sin info. Saludos. |
Bronze Member Username: Johndow
Post Number: 40 Registered: Nov-06
| Posted on Wednesday, October 24, 2007 - 06:52 am: |
Saludos, Alguien podría ilustrar cual es el mas reciente "BIN" para una "viewsat 2000 Platino" Gracias, arriba la hispanidad........ |
Post Number: 41 Registered: Nov-06
| Posted on Wednesday, October 24, 2007 - 07:22 am: |
Post Number: 42 Registered: Nov-06
| Posted on Wednesday, October 24, 2007 - 07:23 am: |
Perdón por la duplicidad..........arriba la hispanidad |
New member Username: Alx_luc
Post Number: 7 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 07:37 am: |
Mi Gente, saludos a todos, primero muchas gracias por toda la ayuda que me han brindado, he aprendido mucho de todos ustedes, segundo tan pronto sepan cuales son los nuevos bin que arregle este problema con los PPV, 300's y demas para la viewsat lite, me dejan saber. Gracias y Cuidesen... |
Hialeah,
Fl
Usa
Post Number: 36 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 07:57 am: |
alquien sabe las nuevas llaves tengo una viewsat platinum y no se ven los PPV/HBO alquien me puede ayudar |
Mexico,
DF
Mexico
Post Number: 310 Registered: Jul-07
| Posted on Wednesday, October 24, 2007 - 09:01 am: |
Junior, es cuestion de instalarle el nuevo bin a tu viewsat, pero todavía no sale. Checa ftabins^net constantemente para ver cuando pongan los nuevos bins entre hoy y mañana. |
High river,
Alberta
Post Number: 61 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 09:36 am: |
estos son los ==bines== para los viewsat extrenmen y platino... no lo he comprobado .... pongalo a su propio riesgo,,,,, bendiciones ....canada,,,,DBPSW-102307X PGM,,,,,DBPSW-102307,P PGM,,,,, |
Hialeah,
Fl
Usa
Post Number: 37 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 09:45 am: |
emilio pero donde lo encuentro |
High river,
Alberta
Post Number: 62 Registered: Sep-07
http://www.fortecfiles.com/viewsat-extreme/14417-viewsat-xtreme-ar-key-issue-010 6-resolved-new-post.html......canada |
High river,
Alberta
Post Number: 63 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 09:48 am: |
http://www.fortecfiles.com/viewsat-platinum-lite/14419-viewsat-platinum-ar-key-i ssue-0106-resolved-new-post.html.....canada... |
High river,
Alberta
Post Number: 64 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 09:51 am: |
www.fortecfiles.com.... es una pagina de pago... mandame tu correo y te lo embio,,,, canada.. |
High river,
Alberta
Post Number: 65 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 09:52 am: |
los dejo luego mas tarde regreso,,,, bendiciones,,,,,canada....... |
High river,
Alberta
Post Number: 66 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 09:59 am: |
Viewsat Viewsat Files We Support the following Viewsat files: Bins, Loaders, Firmware and other Downloads. Viewsat Keys We always have new Viewsat Keys codes Posted. Viewsat FTA Forum Support We are an FTA Forum here to Help you, we Support ALL Viewsat FTA Models Inclduing: Viewsat Platinum Viewsat Lite Viewsat Extreme Viewsat Ultra Viewsat Pro Viewsat 7000 PVR Viewsat 9000 HD Viewsat OpKey Keywords Viewsat, Viewsat Bins, Viewsat Files, Viewsat Loaders, Viewsat Downloads, Viewsat Keys, Viewsat Codes, Viewsat Firmware, Viewsat FTA, Viewsat Forum, Viewsat Help, Viewsat Support....canada... |
Hialeah,
Fl
Usa
Post Number: 38 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 10:04 am: |
emilio no logro encontrarlo |
Hialeah,
Fl
Usa
Post Number: 39 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 10:05 am: |
mi correo es yaime123@yahoo.es |
Hialeah,
Fl
Usa
Post Number: 40 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 10:12 am: |
emilio esta aqui o te fuistes me pudes mandar el da la viewsat platinum y el de la extreme tengo una en la sala y otra en mi cuarto |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1094 Registered: Oct-06
| Posted on Wednesday, October 24, 2007 - 10:20 am: |
saludos a todos reportando q mi pansat 2700a trabajando perfectamanete con el bin 217 NO le esta pasando lo q al view sat |
New member Username: Josemiami
Post Number: 7 Registered: Jul-06
| Posted on Wednesday, October 24, 2007 - 10:22 am: |
Saludos desde Hialeah amigos. |
Hialeah,
Fl
Usa
Post Number: 41 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 10:24 am: |
quien me puede mandar el nuevo bins de la viewsat |
Hialeah,
Fl
Usa
Post Number: 42 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 10:25 am: |
jose por casualidad tienes el nuevo bin de la viewsat |
Post Number: 9 Registered: Jul-06
| Posted on Wednesday, October 24, 2007 - 10:35 am: |
El nuevo bin para la viewsat no ha salido todavia Junior. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1095 Registered: Oct-06
| Posted on Wednesday, October 24, 2007 - 10:43 am: |
a toda la raza q piden los bines de vw sat valla a http://www.ftabins.net |
Post Number: 10 Registered: Jul-06
| Posted on Wednesday, October 24, 2007 - 10:49 am: |
Latest News: Oct 24 2007 3:08am EST VS & SV are UP on BEV VS & SV Problems reported on Charlie PPV & Adult (HD not affected) VS files should be reelased within hours |
Bronze Member Username: Scastroq
GDL,
Jal
Mexico
Post Number: 54 Registered: Oct-06
| Posted on Wednesday, October 24, 2007 - 10:53 am: |
Ahí esta el nuevo link para el Viewsat: ------------------------------------------- http://www.ftabins.net/forumdisplay.php?f=47 -------------------------------------------
Bronze Member Username: Josemiami
Post Number: 11 Registered: Jul-06
| Posted on Wednesday, October 24, 2007 - 11:00 am: |
Esta es la pagina oficial de la viewsat. http://totalfta.com/ |
Bronze Member Username: Rulomaracas
Post Number: 24 Registered: Nov-06
| Posted on Wednesday, October 24, 2007 - 11:01 am: |
mi pansat 2700a si cayo solo quedan algunos canales funcionando con el bin 217 |
Bronze Member Username: Carloschempolo
Post Number: 48 Registered: Aug-06
| Posted on Wednesday, October 24, 2007 - 11:03 am: |
y para el pansat 2700 alguien sabe si ya salio el bin nuevo para ver hbo y ppv |
Post Number: 12 Registered: Jul-06
| Posted on Wednesday, October 24, 2007 - 11:06 am: |
El bin nuevo 218 para la pansat 2700A lo puedes encontrar en la siguiente pagina. http://www.ftaprosupport.com/forums/index.php |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1096 Registered: Oct-06
| Posted on Wednesday, October 24, 2007 - 11:10 am: |
corrigiendo no esta trabajando el 217 bin con el pansat 2700. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1097 Registered: Oct-06
| Posted on Wednesday, October 24, 2007 - 11:16 am: |
raza la mayoria de los bines los encuentras en http://www.ftabins.net y al rato nos vemos xq voi a lavar la troka saludos. |
High river,
Alberta
Post Number: 67 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 11:29 am: |
%2C,busquen,http://www.fortecfiles.com/attachments/pansat-2700a-e/7635d119317368 1-pansat-2700-v218-10-23-07-x-87bl_071023_b75_218_api_1.zip,,,,busquen el bim para los pansa en esta pagina,,,,,canada,,, |
High river,
Alberta
Post Number: 68 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 11:32 am: |
los ===viewsat estan,, trabajando con las llaves ,manualmente,,,,,,,,,el bim anterior no trabajo,,, disculpen ,,, canada,,,, |
New member Username: Curda_ceiba_1
Miami,
Florida
Post Number: 1 Registered: Oct-07
| Posted on Wednesday, October 24, 2007 - 11:44 am: |
Emilio Vento....please cuales son las llaves de ahora? Muchas Gracias |
High river,
Alberta
Post Number: 69 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 11:53 am: |
[08]2b-d6=f6=c6=e5=b2=f4=c8=////[09]79=f2=3a=ff=10=4d=05=ed====/////[88]3e=e4=f1 =4a=d8=dc=4e=e0===////[89] 05=39=71=31=99=d5==3e=41== estas las tome directo de mi reciver....canada,,,, |
High river,
Alberta
Post Number: 70 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 11:56 am: |
Nag2 keys ---------------------------------------- Dish Provider 0101: Last Updated (16 Oct '07 6:31 PM EST) Key 0: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED (Active) Key 1: 3E E4 F1 4A D8 DC 4E E0 05 39 71 31 99 D5 3E 41 |
High river,
Alberta
Post Number: 71 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 11:59 am: |
Miami,
Florida
Post Number: 2 Registered: Oct-07
| Posted on Wednesday, October 24, 2007 - 12:00 pm: |
Gracias Emilio |
High river,
Alberta
Post Number: 72 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 12:01 pm: |
DISH - Oct 16 86: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED 96: 3E E4 F1 4A D8 DC 4E E0 05 39 71 31 99 D5 3E 41
High river,
Alberta
Post Number: 73 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 12:06 pm: |
Dish Network Main - 0101 [Last update: Tue. Oct 16, 3:21 PM CDT] 86: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED New 96: 3E E4 F1 4A D8 DC 4E E0 05 39 71 31 99 D5 3E 41 Dish Network New PID - 0106 [Last update: Tue. Oct 23, 1:14 PM CDT] 86: D6 9E 74 4D 0A CB ED 62 42 C6 A5 C1 AF AC BE 38 New 96: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |
High river,
Alberta
Post Number: 74 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 12:09 pm: |
D!SH 0101 - Last Update: 10/16/07 03:21 PM 00: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED 01: 3E E4 F1 4A D8 DC 4E E0 05 39 71 31 99 D5 3E 41 B3V 0901 - Last Update: 10/21/07 08:56 AM 00: 59 98 07 83 BE 02 78 4D 75 1B D5 71 B9 E3 DA 0F 01: E4 BD 67 60 F0 44 88 A2 CE FE AC 92 B6 4A 68 33 |
Bronze Member Username: Huasausky
WANATOS,
XALISCO
Mexico
Post Number: 55 Registered: Aug-07
| Posted on Wednesday, October 24, 2007 - 12:23 pm: |
Que tal amigos!!! Ya esta el nuevo bin para los cw600s y lo puedes bajar de ftabins.net CW600SV1.45 saludos. |
Monterrey,
N.L.
Mexico
Post Number: 280 Registered: Oct-06
| Posted on Wednesday, October 24, 2007 - 12:37 pm: |
mike huasausky, por favor reporta si trabaja bien el bin 1.45 en el cw600 regular saludos |
