Thread: Archive through October 23, 2007 |
Bronze Member Username: Indopak
Post Number: 39 Registered: May-06
| Posted on Tuesday, October 23, 2007 - 07:07 pm: |
we all know that we need a bin...but there is a new bin out.. where do we find a new bin that has a new provider id as 0106? i need a fortec ultra, fortec classic na, and digiwave 7000? where can i find them.. and are they even out yet/? |
Bronze Member Username: Diggy101
Post Number: 16 Registered: Aug-07
Thanks Dude! I was wondering where the heck u were! |
Bronze Member Username: Bant07
Post Number: 19 Registered: Oct-07
LK why does all the dish receivers say scrambled channel how do i fix my pansat how do i change the provider ID from 0101 to 0106 .... |
Post Number: 40 Registered: May-06
| Posted on Tuesday, October 23, 2007 - 07:08 pm: |
yea is there a file name.. or number so we know what to download |
New member Username: Sharaz
Post Number: 1 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 07:09 pm: |
Hi Nalin Nyda, I have Coolsat6000 Premium receiver. I am new and need some help. I never did it before. Can you or someone direct me to the technical info (step by step)for uploading a new bin. How do i transfer the bin, and from where do I get it? I appreciate ur help. Thanx a lot From reading above I think I need the BLupdater 1.4 and the new bin 249T, is this correct? Where can I download the updater and bin from? |
Post Number: 20 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 07:11 pm: |
i have pansat 2500A i have heard that DISHNETWORK has changed the provider ID from 0101 to 0106.......how do i fix this problem it says SCRAMBLED CHANNEL, i put new keys but it does not work, i need procedure on how to change from 0101 to 0106??????....is the only solution left to convert to pansat 2700? or is there another way? |
Bronze Member Username: Karbum
Post Number: 28 Registered: Aug-07
| Posted on Tuesday, October 23, 2007 - 07:13 pm: |
someone just type the freakin filename from ftabin to download for viewsat extreme |
Platinum Member Username: Lklives
Post Number: 13032 Registered: Jan-06
| Posted on Tuesday, October 23, 2007 - 07:14 pm: |
All U need to do is upload the latest bins released today!...they have the provider 0106 provider included... if U don't know which bin to use, they all have 1023 date in the newest ones and file name!...U can't miss which ones are the newest..and they are categorized and identified by receiver make and model too! |
Post Number: 22 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 07:15 pm: |
thanks so much LK ... |
Silver Member Username: Silver1123
Mexico,
DF
Mexico
Post Number: 305 Registered: Jul-07
| Posted on Tuesday, October 23, 2007 - 07:16 pm: |
LK is right, always go to known sites such as ftabins. And use some common sense, to get the latest bins, check for the date posted and for the version it carries. In cool sat, for example, the latest is 149, and the next will be 150... The Viewsat bins are from last week. Since the change was done today by DN, any new bins that fix the problem should be posted today or later. |
Bronze Member Username: Halo
Toronto,
Ontario
Post Number: 14 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 07:18 pm: |
visit www.dish-keys.blogspot.com |
Gold Member Username: Nydas
Post Number: 4169 Registered: Jun-06
| Posted on Tuesday, October 23, 2007 - 07:23 pm: |
Banti: I have already tried manually entering a 0106 ID on Pansat 2500A clone, and it does NOT work. I am confirming again that Sonicview 4000 is NOT working except for some channels. Pansat 2700 is reported working with the latest 218 BIN, but make sure you use it on a genuine Pansat 2700 - do not use it on a clone or a converted receiver |
Post Number: 13034 Registered: Jan-06
| Posted on Tuesday, October 23, 2007 - 07:26 pm: |
Ftabins had bogus Viewsat files posted earlier for quite a long time...I knew they were bogus and wouldn't post them...I posted the correct working files at www.ftaprosupport.com and www.dsscommunity.c*om Finally ftabins removed the bogus Viewsat files!...Sh*it happens...azzholes post bad things, and we cannot control everything all the time..I'm good friends with PRFRMNJ, and I know he would have removed the files , had he known... |
Post Number: 4171 Registered: Jun-06
| Posted on Tuesday, October 23, 2007 - 07:32 pm: |
Shariq Raza : There is a major ECM going on. C00LSATS are usually one day behind Viewsats and coming out with a new BIN. the fix is simple , so they may come out with it soon. Try http://www.f2atv.com later tonight. The site would be busy now. Get the latest file with today's date or later and the loader and the instructions. |
Post Number: 29 Registered: Aug-07
| Posted on Tuesday, October 23, 2007 - 07:37 pm: |
LK there is no bin for viewsat on ftaprosupport.com , someone plz provide a direct link to viewsat file |
Bronze Member Username: Cw2269
Post Number: 16 Registered: Jun-07
| Posted on Tuesday, October 23, 2007 - 07:38 pm: |
have the keys for dn changed |
Post Number: 4177 Registered: Jun-06
| Posted on Tuesday, October 23, 2007 - 07:39 pm: |
No new BINs yet for Viewsat, C00LSATs and for Sonicviews. |
New member Username: Kiki09
Post Number: 3 Registered: Sep-07
| Posted on Tuesday, October 23, 2007 - 07:47 pm: |
is there any new keys for dn..... |
Mexico,
DF
Mexico
Post Number: 306 Registered: Jul-07
| Posted on Tuesday, October 23, 2007 - 07:55 pm: |
PPV are down on the 500s, but they are open on most boxes on the 5000s, so, in the mean time that new bins are released, U can watch PPVs on the 5000s |
Bronze Member Username: Kamranca
Post Number: 42 Registered: Oct-06
| Posted on Tuesday, October 23, 2007 - 07:58 pm: |
Hi All Is any new BIN file for Fortec Star life time ultra.Because im getting Bad Channel and Srambled...please anyone help. Thanks in advance |
New member Username: Ekoneuno
Post Number: 8 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 07:59 pm: |
Have they released new bins for Fortec Lifetime Classic NA? |
Silver Member Username: Asharfi
Post Number: 958 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 08:00 pm: |
Kamran, Sorry, friend! There's no new bin for Fortec STAR Lifetime Ultra receivers.  |
Post Number: 43 Registered: Oct-06
| Posted on Tuesday, October 23, 2007 - 08:01 pm: |
Hello Nalin.. We have a Sonic set Can you tell me how old is SONIC SET..And is there any BIN FILe... Thanks In Advance |
Post Number: 44 Registered: Oct-06
| Posted on Tuesday, October 23, 2007 - 08:04 pm: |
Hi AV Then what is the solution of our reciver  |
New member Username: Hello112
Post Number: 6 Registered: Sep-07
| Posted on Tuesday, October 23, 2007 - 08:05 pm: |
did the keys change?? |
Bronze Member Username: Manthedent
Post Number: 24 Registered: Sep-06
i know its A Q that many of us are asking but is there any bins for pansat 2300A or not anymore. thanks for helping many of us who realy want ur help. |
Post Number: 7 Registered: Sep-07
| Posted on Tuesday, October 23, 2007 - 08:07 pm: |
can someone please tell why the dish is not working? |
New member Username: Aksaa
Post Number: 9 Registered: Dec-06
| Posted on Tuesday, October 23, 2007 - 08:09 pm: |
new keys plzzzz |
Post Number: 8 Registered: Sep-07
| Posted on Tuesday, October 23, 2007 - 08:10 pm: |
can sum1 post the new keys plzzz |
New member Username: Yammino
| Posted on Tuesday, October 23, 2007 - 08:11 pm: |
Hi, Is there a new BIN for Fortec Lifetime Ultra. Thank you |
Post Number: 46 Registered: Oct-06
Hi AV Then what is the solution of our reciver(which is FORTEC ALTRA LIFETIME) Thanks In advance |
New member Username: Rowz
Castor,
Alberta
Post Number: 4 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 08:13 pm: |
hey! could anyone plz ive me the new keys for 0101! |
Bronze Member Username: Tata3401
Post Number: 43 Registered: Jun-06
| Posted on Tuesday, October 23, 2007 - 08:14 pm: |
I have Panset 2700. And I am getting some english channel but not getting Indian Channel. Message is scramble channel. Can some one help me how to fix the problem? |
Bronze Member Username: Maro
Post Number: 16 Registered: May-06
| Posted on Tuesday, October 23, 2007 - 08:15 pm: |
can someone tell me wich site or wich bin do i have to download for a pansat 2500A clone and if there are none, how do i do to change 0101 to 0106 thx in advance |
New member Username: Alva_1
| Posted on Tuesday, October 23, 2007 - 08:17 pm: |
so how can i find the new bins for fortecstar lifetime ultra??? |
Post Number: 959 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 08:19 pm: |
Kamran, You should convert your FLU to a Pansat 2700 and then use bins by JJVH. Right now, converted FLUs are also down, but their fixes will be out anytime today or tomorrow. |
Bronze Member Username: Iqqies
Post Number: 43 Registered: Jul-07
| Posted on Tuesday, October 23, 2007 - 08:20 pm: |
NEW KEYYSSSS. Grrrrrrr. |
Post Number: 17 Registered: May-06
| Posted on Tuesday, October 23, 2007 - 08:22 pm: |
can someone tell me wich site or wich bin do i have to download for a pansat 2500A clone and if there are none, how do i do to change 0101 to 0106 thx in advance) |
Castor,
Alberta
Post Number: 5 Registered: Oct-07
hey AV! your answring some questions! could u tell me what shall i do to get the new keys for dish network 0101! cause nothing is working! plz and Thankyou! |
Post Number: 4183 Registered: Jun-06
For the genuine Pansat 2700, there is BIN 218 out with today's date. Do NOT use it on Converted or clone receivers. Expect new BINs for cloned 2700 and conversions tomorrow. |
Post Number: 2 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 08:24 pm: |
??? come on people help us out... |
New member Username: Tanhoura
Post Number: 4 Registered: Aug-07
| Posted on Tuesday, October 23, 2007 - 08:25 pm: |
plz need the DN keysssssssssssssss |
Post Number: 963 Registered: Aug-06
Azqa Iqbal, Go to www.tvkeyz.com for the latest Dishnetwork, and/or BellExpressVu keys. Only few receivers are working, the rest of them are down on Dishnetwork. There's an ECM on Dishnetwork, so we have to wait for the new fixes. |
Post Number: 5 Registered: Aug-07
| Posted on Tuesday, October 23, 2007 - 08:26 pm: |
anybody there are u guys sleeping hellooooooo |
Post Number: 964 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 08:27 pm: |
Rawand, Like I said, there's an ECM on Dishnetwork, and that's why some receivers aren't working. They've released fixes for some receivers, such as Viewsats, and Pansats. But, some receivers are still down and waiting for the fix to arrive. |
Post Number: 47 Registered: Oct-06
| Posted on Tuesday, October 23, 2007 - 08:28 pm: |
AV.. Please let me know the step by step details for convert my FLU to Pansat 2700 (whatever you suggested). Thanks |
New member Username: Ghauri1
Mississauga,
On
Post Number: 2 Registered: Jun-06
I tried but cannot get it working. Cmmon LK and Nalin. where are uuuuuuu |
Post Number: 4185 Registered: Jun-06
| Posted on Tuesday, October 23, 2007 - 08:29 pm: |
Rawand : and lolita white : and al va : Have you considered reading the last 50 posts above yours? |
Castor,
Alberta
Post Number: 6 Registered: Oct-07
loltia nobody is answering us |
Post Number: 965 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 08:30 pm: |
Lolita White, Please visit www.tvkeyz.com for the latest DN and BEV keys, but make sure you have the latest bin for DN. There's an ECM on DN. |
Castor,
Alberta
Post Number: 7 Registered: Oct-07
i did but i didnt get anything! and what d u guys mean by changing 0101 to 0106? thanx |
Castor,
Alberta
Post Number: 8 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 08:32 pm: |
well i did! but i dnt get wat u guys said about changing 0101 to 0106 in the DN! thanx |
Post Number: 9 Registered: Sep-07
tvkeyz.com doesnt work for me so can sum1 jus paste the new keys here |
Post Number: 44 Registered: Jul-07
thanks AV that's helpful! } |
Post Number: 45 Registered: Jul-07
| Posted on Tuesday, October 23, 2007 - 08:35 pm: |
yeaahh. can someone just paste the new keys here. i cant go on www.tvkeys.com. PLEASEEEE |
Post Number: 4187 Registered: Jun-06
| Posted on Tuesday, October 23, 2007 - 08:38 pm: |
Current working receivers with today's new BINs: Pansats 2700 and above. Captiveworks CONEXTANT THAT'S IT!!! The change required is small and the software writers will come out with new BINs very soon. |
Post Number: 48 Registered: Oct-06
| Posted on Tuesday, October 23, 2007 - 08:41 pm: |
Hello Nalin... Please let me know the step by step details for convert my FLU to Pansat 2700 (whatever you suggested). Thanks in advance |
Post Number: 968 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 08:44 pm: |
Dishnetwork Keys Key 00: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED (Active) Key 01: 3E E4 F1 4A D8 DC 4E E0 05 39 71 31 99 D5 3E 41 Attention: Like I said, these are the current DN keys, but they will NOT work because of the ECM. You need the latest bin which has the fix to today's ECM. From now on, Dishnetwork keys will work on provider ID 0106, but again, you NEED the latest bin which has the fix to today's ECM.
Post Number: 969 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 08:48 pm: |
Kamran, Here, checkout my thread : http://forum.ecoustics.com/bbs/messages/2/389206.html Read the first post and download the files from the links given. Read the instrutions file at least 3 times before you start the conversion. You DO NOT need any JTAG or some special cable, just use your normal serial cable that you use to load new bins/files to your FLU. |
New member Username: Marca835
| Posted on Tuesday, October 23, 2007 - 08:50 pm: |
hi nalin please I need bin for buzz s2010f thank you |
Post Number: 4189 Registered: Jun-06
Good work, AV. Keep it up. Repetition is the only way to get the message accros, that there are NO NEW KEYS, but that you need a new BIN - and these are only available so far today for Pansat 2700 and upo, Captiveworks and for Conextant. |
Post Number: 970 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 08:55 pm: |
yeah ... lol ..... i m waiting for flu - pansat 2700 bin .... only few locals are working .... lol |
Bronze Member Username: Gusification
Post Number: 54 Registered: Nov-06
| Posted on Tuesday, October 23, 2007 - 09:00 pm: |
anyone know y the ppv rnt workin????? |
New member Username: Ill0_ill
| Posted on Tuesday, October 23, 2007 - 09:19 pm: |
Fix is now available for Pansat 3500,2700 |
Post Number: 4199 Registered: Jun-06
| Posted on Tuesday, October 23, 2007 - 09:20 pm: |
There are no new keys to look for till you get a new BIN in your receiver with today's date or a later date. |
Castor,
Alberta
Post Number: 9 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 09:22 pm: |
last question! and how do we get the new bin? plz NALIN |
Post Number: 973 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 09:25 pm: |
Rawand, First, please tell us which receiver you have and then I'll tell you where you can find its latest bin, if there's any out. |
Castor,
Alberta
Post Number: 10 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 09:26 pm: |
pansat SD 3500! |
Post Number: 4200 Registered: Jun-06
| Posted on Tuesday, October 23, 2007 - 09:27 pm: |
For latest BINs, go to these sites. http://www.future-fta.info/forum/index.php http://www.f2atv.com/ http://www.totalfta.com http://www.al7bar*tk http://www.dsstester*com right now there are files for Pansat 2700 and above, Conextant, Captiveworks and couple of others. Notably there are no new files YET for fortec, Viewsats, Sonicview and C00LSATS |
| Posted on Tuesday, October 23, 2007 - 09:30 pm: |
Av is there a bin out for fortec ultra? |
Bronze Member Username: Rowz
Castor,
Alberta
Post Number: 11 Registered: Oct-07
what abut for pansat 3500! could i find a bin for it? |
New member Username: Stlaurent
| Posted on Tuesday, October 23, 2007 - 09:33 pm: |
i have a pansat 2700 please can i get the bin |
Post Number: 976 Registered: Aug-06
Haz Sh, No, friend! There's NO NEW BIN for Fortec STAR Lifetime Ultra receivers. Rawand, Yes, there's a new bin for Pansat 3500 receivers, please vist www.ftabins.net for the latest bin. |
Bronze Member Username: Ill0_ill
| Posted on Tuesday, October 23, 2007 - 09:35 pm: |
Av can you tell me if there's a latest bin for fortec ultra. thanks |
New member Username: Ather_da_don
Mississauaga,
Ontario
| Posted on Tuesday, October 23, 2007 - 09:36 pm: |
For latest dish keys and BEV keys visit www.dishkeyz.blogspot.com |
Post Number: 978 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 09:37 pm: |
Haz Sh, I just told you that there's no new working bin for Fortec Ultras. |
Post Number: 12 Registered: Oct-07
ok thanks av for your help  |
Bronze Member Username: Terminator2
Toronto,
Ontario
Post Number: 13 Registered: Sep-06
| Posted on Tuesday, October 23, 2007 - 09:41 pm: |
Hello All, I have been offline for sometime, but how do you convert FLU to pansat 2700 ? and what is the advantages? Thanks |
Post Number: 979 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 09:44 pm: |
New Dishnetwork keys working with Provider ID 0160 Key 00: D6 9E 74 4D 0A CB ED 62 42 C6 A5 C1 AF AC BE 38 (Active) Key 01: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Last Updated: October 23, 2007 at 5:01 PM. The above keys will only work with the latest bin that fixes today's ECM. |
Post Number: 4206 Registered: Jun-06
samehafram : You should have read AV'spost above. Here, checkout my thread : http://forum.ecoustics.com/bbs/messages/2/389206.html
Post Number: 980 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 09:52 pm: |
samehafram, Please visit my thread at http://forum.ecoustics.com/bbs/messages/2/389206.html. Read the first post and download the files from the 3 links given. Read the instructions file at least 3 times before you start the conversion. FLU - Pansat 2700 Advantages: - Autoroll Fixes - Faster Performance - Sort channels by their letter - Satellite scanning is faster - TP scanning is faster\ They use Pansat 2700 bins by Blacklist which are later modded by JVVH. |
Toronto,
Ontario
Post Number: 14 Registered: Sep-06
| Posted on Tuesday, October 23, 2007 - 09:54 pm: |
Thanks to both Nalin and AV. I will give it a try. |
New member Username: Fais3209
| Posted on Tuesday, October 23, 2007 - 09:55 pm: |
what does it mean when a bin file in its name states "NOCARD"... im suspecting this means you can't load it via sd? am i correct? |
Post Number: 981 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 09:56 pm: |
NOCARD? I think it means you don't need any card to watch channels. But, I'm not really sure ... sorry!  |
Bronze Member Username: Hanany75
Post Number: 11 Registered: May-06
| Posted on Tuesday, October 23, 2007 - 09:58 pm: |
if you please Naline or Av, what about clone pansat 2700A? is there any new bin for it? |
New member Username: Jjari
there any new bin for Pansat 2500 thx for the help |
Post Number: 4209 Registered: Jun-06
| Posted on Tuesday, October 23, 2007 - 10:01 pm: |
For latest BINs, go to these sites. http://www.future-fta.info/forum/index.php http://www.f2atv.com/ http://www.totalfta.com http://www.al7bar*tk http://www.dsstester*com Right now there are files for Pansat 2700 and above, Conextant, Captiveworks and couple of others. Notably there are no new files YET for fortec, Viewsats, Sonicview and C00LSATS |
New member Username: Zebrazebare
New york,
Ny
Usa
| Posted on Tuesday, October 23, 2007 - 10:04 pm: |
do someone has bin for rex-1 |
Post Number: 983 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 10:06 pm: |
All Pansat 2500 and its clones are DEAD! Blacklist will NOT suuport those receivers from now on. So, if you have a Pansat 2500 or its clone, please convert it to Pansat 2700. |
Post Number: 3 Registered: Oct-07
| Posted on Tuesday, October 23, 2007 - 10:08 pm: |
thx AV who we can convert pansat 2500 to 2700 ? |
Post Number: 984 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 10:11 pm: |
jjar jjari, Please visit www.fortecfiles.com or www.ftabins.net and there you will find the conversion file for Pansat 2500 to Pansat 2700 receivers. MUST REGISTER to download file, registration is FREE! |
| Posted on Tuesday, October 23, 2007 - 10:18 pm: |
i have just upload the file in my receiver? thx |
New member Username: Mag16
| Posted on Tuesday, October 23, 2007 - 10:19 pm: |
hello, please is there new BIN for pantec ultra |
New member Username: Jigga19
Post Number: 7 Registered: Feb-07
| Posted on Tuesday, October 23, 2007 - 10:20 pm: |
i had the jvvh_213 bin do i have to install 217 din for the keys to work? |
Post Number: 985 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 10:24 pm: |
Rohail Malik, Bin 217 also down! We are all waiting for JVVH to release bin 218. |
Post Number: 8 Registered: Feb-07
| Posted on Tuesday, October 23, 2007 - 10:26 pm: |
thank you AV.. Just wanted to ask the keys mention above working with which bin. it says its working with the latest bin. |
Post Number: 986 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 10:30 pm: |
The were some new bins today for some receivers, such as Viewsats, Pansats, etc, so if you have any of those receivers, then the above keys will work after you load the latest bin. |
Bronze Member Username: Kikim
Windsor,
Ontario
Post Number: 36 Registered: Oct-06
| Posted on Tuesday, October 23, 2007 - 10:32 pm: |
i stel having broplem dowloading the latest bin for pansat 2700a ,im using GTrom 27,v..it use to work good befor but now the resiver count faster than louder on pc if any one can help me,thanks. |
Post Number: 9 Registered: Feb-07
| Posted on Tuesday, October 23, 2007 - 10:33 pm: |
i have pansat 3500 but i did a conversion 2500 to 2700.. so what is the latest bin for that. 217 or 218 |
Post Number: 987 Registered: Aug-06
| Posted on Tuesday, October 23, 2007 - 10:35 pm: |
218 |
