Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through October 23, 2007
Author Thread: Archive through October 23, 2007
Username: Huremkic
what loader,bin I need for pansat 2700a
Username: Espn3
Post Number: 108
Nalin Nyda, you stated that GC is not working with most BINs.
Tells us ONE FTA and BIN were GC is working. Thanks.
Username: Priya777
i have coolreceiver 5000 and also i have dishnetwork connection where i get international channels. there was free upgrade(dish person just changed the some part of dish but the position is same) by dish network people so we did it. so after that when we connected coolreceiver(after 5 days) some channels are missing and when we did re scan some channels are misiing... and some channels are coming but its coming for sometime then its going scramble channel. what to do? Please help me.. when we did re scan especially we are not getting international channels and ppv.
I appreciate ur help...
Username: Nydas
Post Number: 4139
john johnson: It is humanly impossible to check ALL the receivers and their latest BINs - even if I had the receivers. Even checking and reading through forums to find what is the current state of affairs - that in itself is a very time consuming task.
Therefore,the best I can truthfully post is that
"GC is not working with most BINs" or
"to the best of my knowledge GC is not working"
Username: Rtap
FL
Post Number: 686
if you have triple lnb from dish network you would not be able to get both 110/119.what lnb do you have
Username: Nydas
Post Number: 4140
raksha : You should mention which BIN there is in your C00LSAT 5000, and which Sats you are attempting to scan and how many LNBs you have. If possible, give your letting on the LNB(s).
Username: Ariana_70
Sorel-Tracy, Quebec
Post Number: 100
Can anyone help me? Please my receiver keeps turning off by itself i have already turned it off in front , in back, took it off the power supply, i even reset it but as soon as i plug it to the wall supply it turns off and on , turns off and off and it could continue all day i guess , i have even left it on and the TV off , i have changed the batts on my control remote , and nothing , i have no idea what else i could do , please this has been going on for 3 days , can anyone help me or give me contructive advise on what to do , i have a norsat receiver , with the fortek and pansat program, it has the 294t bin for dishnet, please i really need help i am in blanc territory.
Username: Priya777
nalin nyda: 143 bin currently, 148,110,121,119 scanning. 2 lnb's
Username: Gastrognome
Post Number: 74
Monica, try reloading the 294t bin.
turn on from back switch then download
Username: Ariana_70
Sorel-Tracy, Quebec
Post Number: 101
Gastrognome , i tryed that already ...could it be that the bin i am downloading is bad ?
Post Number: 75
could be i guess, try a different bin.
loading a file this way may not always take on the first try, could also try hit download then turn on by backswitch.
Username: Ariana_70
Sorel-Tracy, Quebec
Post Number: 102
i'll try , tell you tomorrow if it worked or not , thx for advise
Post Number: 76
also does it turn off/on with the input from the sat disconnected?
Username: Ariana_70
Sorel-Tracy, Quebec
Post Number: 104
no i haven't tried to take off the cable of the sat , i'll try that.
Thx for the input
Username: Ather_da_don
Mississauaga, Ontario
New and Latest Dish keys and cricket links at: http://www.dishkeyz.blogspot.com/
Username: Nydas
Post Number: 4142
Monica: DO NOT take off cable from back without switching off receiver.
Currently the older BIN 293T for Pansat 2500A clones is working better with key autoroll. Try up loading that BIN. Keep autoroll on with this BIN.
If you reload with 294T, keep autoroll off and manually enter the keys.
Use BL updater 1.4 -NOTHING ELSE.
If reloading of BIN is difficult, try uploading BIN 280Tor 281T, then 293T.
Always redo the User settings after a new upload, particually the date/time settings.
Username: Nydas
Post Number: 4143
Raksha: The current BIN for C00LSAT 5000 is version 149
http://forums.f2atv.com/forumdisplay.php?f=634
You should install that and see if it works better for you. In any case, it is good to be a member of the f2atv site, as they are very knowledgEable about C00LSATS.
Username: Nydas
Post Number: 4145
Raksha: Also scanning four LNBs, takes away a fair amount of real estate (memory). It would be a good idea to remove some of the channels - the ones that are duplicate and you do not see.
Try to keep your total list of available channels to about 500 or less.
Not everybody will agree with this but if it does not hurt you why not implement it?
Username: Kingusama
Post Number: 413
visit www.ftasolutions.blogspot.com for the latest keys...
Username: Espn3
Post Number: 109
thanks Nalin for the answer regarding gc.
hope jvvh will take care of this.
Username: Elvirm
Post Number: 10
I have problem with my receiver FLU, Level show about 90, but qualiti is 0, that's mean I can't see anything. Is anybody can help, thanks!
Username: Crazy_greek
Post Number: 1256
Hey Raksha
Even tho Nalin is one of us the good guys
I will have to disagree.If you was to Scan in only 500 Channels or less you could only Scan in EchoStar 7 on that Bird I have 334 TV and 153 Radio Stations.Today FTA Receivers have a Channel Memory (TV & Radio) 3,000, 5,000 and 10,000.
I would like to HIT 10,000
Username: Nydas
Post Number: 4153
Kevin: You have sound knowledge. I do not want to create a technical controversy in this thread.
I had already stated "Not everybody will agree with this"
One day when we both have time we will discuss this in an independent thread.
Username: Nydas
Post Number: 4154
elvir maric : See my post above on Friday, October 19, 2007 - 07:48 pm:
It applies equally to FLU if it is not converted to jvvh 2700.
Visit http://www.dishkeyz.blogspot.com for latest dish keys and more cricket links!!!
Username: Necrozzy
factory file for vs xtreme?
Username: Necrozzy
factory file for locked viewsats?
Username: Albino_midget
Post Number: 620
factory files
www.viewsatusa.com/support.htm
Username: Necrozzy
My Viewsat xtreme is locked!! Suggestions on how to unlock?
Username: Elvirm
Post Number: 11
Nalin:
It is already converted to 2700.
Post Number: 621
you could try this --be aware i don't own a vs or do i know exactly what your asking about.
http://www.hostclip.com/download2.php?a=44c2649e73cffe3d8c5916a288d04341&b=596be 3e41dea00aedf68826956e6f352
Username: Necrozzy
all channel are locked
Username: Halo
Toronto, Ontario
Post Number: 11
For latest dish keys visit www.dish-keys.blogspot.com!!!}
Username: Nydas
Post Number: 4161
One of the best sites for Viewsat files and discussion is
http://www.totalfta.com
Other very good sites are:
http://www.future-fta.info
http://www.f2atv.com
Membership is required, but is free.
Username: Kingusama
Post Number: 416
visit www.ftasolutions.blogspot.com for the latest keys ...
Username: Kingusama
Post Number: 417
latest files have been posted on the site for viewsat,pansat and captiveworks for those of you who require it... and bev keys will be posted from now on... gc keys will be posted if requested a lot... www.ftasolutions.blogspot.com
Username: Jpz
MTL, QC
CAnada
Post Number: 254
Hi guys !!!
Username: Dr_dss
Post Number: 68
One of the quickest ways to get get your needed 32 character hexadecimal string in a fast and easy way is to use irc there be a key channel.
http://gogloom.com/Gigacrew/Fta-Keys/
Username: Rockin473
Post Number: 19
Can anybody help me with my Viewsat Extreme, before my boyfriend comes home?
All of a sudden, I lost all channels on all satelites. I tried doing a blind scan, it didn't work, I desperate, Thanks to all the lads out there!
Ashley.
Username: Asharfi
Post Number: 953
If you're getting some "Bad or Scrambled Channel" message, then please turn OFF your receiver from the back and turn it back ON after 10 seconds. Or turn OFF your receiver from the back, disconnect the satellite cable, then reconnect the cable after 5 seconds and turn ON your receiver after 5 seconds. And, make sure you have the latest bin and keys.
Username: Halo
Toronto, Ontario
Post Number: 12
For latest dish keys and soon to be added BEV keys visit www.dish-keys.blogspot.com
Username: Nub2fta
N/a, N/a
Post Number: 52
c-p: About a year and a half ago this same thing happened before all the stb's went down. The DN provider is testing the impact of the ECM on certain channels and will probably add more channels to the list of blackouts. Stand by for a new update to fix this situation. He too tests his recievers to see if his updates work. Just keep in mind this hobby is about testing aftermarket recievers and by law the providers have to try to keep us testing.
Username: Nub2fta
N/a, N/a
Post Number: 53
FYI:
DN is introducing a new ecm. This is why some channels are being scrambled and some not. We will have to wait for a new file for the fix
nub
Username: Indopak
Post Number: 37
new dn keys?
Username: Kimykim1
Toronto
new dn keys plz
Username: Indopak
Post Number: 38
KEYS PPL!!!!!
Username: Dnkeys0001
KEY PLS
Username: Silver1123
Mexico, DF
Mexico
Post Number: 288
Guys, read above. It´s not a key issue. There are changes in DN. You need to read and understand that the way DN scrambles its signal, is different.
You need to install the latest bins. Check around in these posts, there are several fixes already for several boxes.
Username: Kingusama
Post Number: 424
Username: Bant07
but some dishes do not have latest bins and i doubt this is bin problemm..
Username: Diggy101
Post Number: 11
Any one have new keys? Help!
Username: Bant07
2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED
3E E4 F1 4A D8 DC 4E E0 05 39 71 31 99 D5 3E 41
Username: Kimykim1
Toronto
these are old keys banti it's not working :-(
Username: K98
Post Number: 92
new keys plz come on nalin
Username: Diggy101
Post Number: 12
LK where the hek are you....lol!
Mexico, DF
Mexico
Post Number: 289
Again, Dish PPV & Adult moved to new provider 0106, instead of the main 0101 provider that handled all Dish channels. New files will be needed.
Since you insist, here are the new keys, but, they won´t do you much good since you need a new software bin to be able to include them:
Dish Network Main - 0101 [Last update: Tue. Oct 16, 3:21 PM CDT]
86: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED New
96: 3E E4 F1 4A D8 DC 4E E0 05 39 71 31 99 D5 3E 41
Dish Network New PID - 0106 [Last update: Tue. Oct 23, 1:14 PM CDT]
86: D6 9E 74 4D 0A CB ED 62 42 C6 A5 C1 AF AC BE 38 New
96: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Username: Kingusama
Post Number: 426
keys latest up to now posted at www.ftasolutions.blogspot.com
Username: Bant07
Post Number: 12
THOSE ARE NOT NEW THOSE ARE THE SAME OLD KEYS WHY DONT U UNDERSTAND?
Username: Kingusama
Post Number: 427
lol but they are the latest technically....
Username: Halo
Toronto, Ontario
Post Number: 13
latest dish keys and BEV keys on www.dish.blogspot.com
Mexico, DF
Mexico
Post Number: 290
If you haven`t been following what´s been going on with BEV from Canada, similar to DN, they have been changing keys and streams.
Currently, BEV has four different sets of keys to be able to watch different programming.
Now DN has two sets of keys, one for PPV and Adult channels, and other for the rest.
It is speculated that DN will have other key sets for NFL and other programming.
Check here for keys:
http://www.tvkeyz.com/
Username: Bant07
Post Number: 14
HUSSAM THERE IS NO KEY PROBLEM ITS A DIFFERENT PROBLEM...IT SAYS SCRAMBLED CHANNEL NOT WAIT FOR PICTURE!!!!IF U HAD A RECEIVER MAYBE U WOULD UNDERSTAND A BIT BETTER!!!!;)
Username: Jppatelahd
Post Number: 10
is anybody have new latest bin for captive works. if yes than plz can u give me.. thanks in advance help will be appreciated..
Username: R1010
Post Number: 116
these are not working86: 2B D6 F6 C6 E5 B2 FA C8 79 F2 3A FF 10 4D 05 ED New
plz post working keys thanks
Mexico, DF
Mexico
Post Number: 292
Banti, this are the latest keys:
Posted on Tuesday, October 23, 2007 - 06:01 pm:
Please try to enter them on Provider 0106 on your box, just remember to install a new bin before, since your box only has provider 0101
Username: Bant07
Post Number: 15
thank u sooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo much
Username: Liala
Lodi, Ca
Ca
Username: Samswe
hello guys new bin file please !!!!
Username: Liala
Lodi, Ca
Ca
i need help any one ther i cant get no channels bad scarmebld
Username: Kingusama
Post Number: 429
guyz visit www.ftasolutions.blogspot.com...
Mexico, DF
Mexico
Post Number: 294
New bins working smoothly:
Captive Works
http://ftabins.net/forumdisplay.php?f=43
View Sat:
http://ftabins.net/forumdisplay.php?f=47
Pan SAT
http://ftabins.net/forumdisplay.php?f=48
Fortec:
http://ftabins.net/forumdisplay.php?f=54
Still waiting for Cool Sat and others
Username: Kikim
Windsor, Ontario
Post Number: 35
hello ,wen im downloading the new bin for pansat 2700a,im using the GTrom loader v27... at was ok befor,now the broblem the reciver count faster than the pc,if eny one can help,thanks.
Username: The_devil
Post Number: 13
anyone getting 611 to 621
Username: Dghumman
Ontario
Post Number: 116
which is the latest bin for viewsat extreme that has 0106 provider on the box please tell me the file no
Username: Bant07
Post Number: 16
HEY MAN I TRIED THIS...biut i have pansat 2500A hot do i put it in there? i try to change the provider ID to 0106 but it does not work ....and why did u put 00 00 00 00...for keycode 96?
juan Cavazos
Mexico , DF mexico Post Number: 292
Posted on Tuesday, October 23, 2007 - 06:11 pm:
Mexico, DF
Mexico
Post Number: 296
To all:
New rules for DN:
Before, there was only one key, entered in CAS: Nagravision; Ident: Dish Network 0001 or 0101, then enter the keys in 10 (86) or 20 (96)
Today, DN has introduced a second key, enterd in CAS: Nagravision; Ident: Dish Network 0106, then enter the keys in 10 (86) or 20 (96).
In order to be able to enter the new set of keys, you need to install a new bin, since older ones have capacity for only one set of keys.
And beware that maybe DN will introduce other keys, such as BEV that has four keys, for different channels
Username: Karbum
Post Number: 21
can someone tell me what the hell is a bin??? i've tried to find a guide all over the place i can't find squat regarding that!! plz someone... i've got a viewsat extreme receive and how the hell do i transfer the bin to it? plz someone tell me
Username: Diggy101
Post Number: 13
Juan
How do we find new the new bin files for reciever?
Mexico, DF
Mexico
Post Number: 297
Damindar: Scroll three messages up for viewsat bins...
Banti: Scroll up three messages up for pansat bins. You need to install a new bin that modifies your pansat to be able to get two sets of keys
Username: Pike_376
Post Number: 20
I have a pansat2500. Does anyone have the new bin file so that I may load the new stuff I need please. I would greatly appreciate them please
Username: Karbum
Post Number: 22
Username: Bant07
Post Number: 17
but pansat 2500 does not have new bins and i dont want to convert it to 2700....how about for viewsat xtreme do u have to put these codes in and change the provider ID from 01 01 to 0106 what is the procedure for this? please help me
Username: Ill0_ill
Does anybody know where to get the new bin?
Username: Dghumman
Ontario
Post Number: 117
can u please tell me the bin no for viewsat extreme
Mexico, DF
Mexico
Post Number: 298
Chip:
I look for them in these sites, some require registration, but are free.
Look for your box brand and model. Also, you will find information on how to download and install.
Be sure to get the latest bin (software) according to your model, and also, be sure to get the loader with instructions.
In order to install the bin, you need another piece of software called loader, also found where you get the bins. You need a cable, usually a 9 pin null or printer cable, found at any Radio Shack, to connect your computer to the satellite receiver to install the software.
http://ftabins net/ (put a . before net)
http://www.dssrookie.com/forums/
http://www.dsstester com/ (put a . before com)
Be patient, there will be a lot of traffic on the sites
Username: Diggy101
Post Number: 14
Thanks dude!
Mexico, DF
Mexico
Post Number: 299
To all:
Basic knowledge:
FTAs need software in order to work. These software codes are called bins.
Depending on the model and brand of your box, you will need a very specific bin, or software. For example, if you have a view sat, you need a bin for that box, if you use a bin for PanSat, your box will not work.
Steps:
1. Find the correct bin:
Captive Works
View Sat:
Pan SAT
Fortec:
2. Also, find other piece of software, called loader, to be found in the same place as the bins.
3. Read tha instructions, found also at the sites
4. Launch the loader in your computer.
5. Turn off the satellite box. Connect a 9 pin null or printer cable found at any Radio Shack from your computer to your satellite box.
6. Turn on the satellite box.
7. Follow instructions on the loader, it will verify the software installed in your box, then it will ask you to direct it to the new bin you downloaded,
8. It might seem hard, but its really easy.
check ftabins*net for instructions on your specific brand.
Rembember some words are restricted, thats why I write them different so I am able to post it
Mexico, DF
Mexico
Post Number: 300
Banti, I heard that 2500 has no support for new bins.
There are a lot of posts around here about how to convert, and good and bad experiences.
Check the posts.
Good Luck
Username: Kimykim1
Toronto
what about cool sat 5000 platinium :-(
Mexico, DF
Mexico
Post Number: 301
Kim, welcome to the club, thats my reciever also.
Be patient, for some strange reason, Cool sat bins are the last to roll out, usually one day after the viewsat bins are released.
Go here to check for updates:
http://ftabins.net/forumdisplay.php?f=104
Username: Jerseynigga007
Post Number: 27
How do i go to change the Keys!!!!
if i have the new bin file installed in my fortec ultra
Username: Karbum
Post Number: 23
----------->> what file to download from ftabin for viewsat extreme??? there's a long list of it and the oldest file was 6 days old, which one is it? someone knows?? plz
Username: Nydas
Post Number: 4167
Pnasat 2500 clone. Sonicview 4000
Echo 3 is down. Echo 8.1 - PPVs are down, but many others channels working.
AV in this forum is reporting than converted Flu to 2700 are also similarly down.
Username: Kingusama
Post Number: 431
Username: Diggy101
Post Number: 15
I'm with ahmed which is it!
Mexico, DF
Mexico
Post Number: 302
Jersey:
If you have the new bin, you shouldnt need to enter keys manually.
Check here for instructions on how to enter keys and to activate autoroll
http://ftabins.net/showthread.php?t=733
Mexico, DF
Mexico
Post Number: 303
Chip ahmed:
Always download the latest bin, the one that was posted most recently.
Username: Karbum
Post Number: 25
Username: Lklives
Post Number: 13030
There are NO new Working Viewsat files released anyplace yet!...some clown posted bogus ones, and some sites NEVER checked them out originally and posted them...ftabins was one of those.....its impossible to stop people from posting bogus files, but I myself wil not post any file until I know its a good one!....
ONLY new working ESPN and other DN channel fix files now are out and posted are at...
www.ftaprosupport.com
www.ftabins.net
www.dsscommunity.c*om
and they are ONLY for the
Captiveworks
Pansat
Conexsat
All other receivers do NOT have fixes yet, but shpould sometime tonite or tomorrow...
Username: Karbum
Post Number: 26
it doesn't say whether it's a bin or something on any of the files on ftabins.net , how do i know if i'm downloading the right bin, can someone just say the filename so others like me aren't confused about it
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through October 23, 2007 [ « Previous ] [ Next » ]
