Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > Fixes are available for the following...
Author Thread: Fixes are available for the following stb
Username: Rtap
FL
Post Number: 698
files can be found ftabins*net.replace the *
Ariza 750
Captive Works
Captive Works CW-600
Captive Works CW-600 Premium
Captive Works CW-800PVR
NFusion
Viewsat VS2000 Lite/Platinum
Viewsat VS2000 Xtreme
Viewsat VS2000 Ultra
Visionsat
Visionsat IV200
Username: Vhl71
Post Number: 76
conaxsat fix is also out..
Username: Rtap
FL
Post Number: 701
hey king hows never never land.lol
Username: Simplyme
Post Number: 16
Anyone tried the new pansat fixes everywhere?
Username: Vsp
Post Number: 147
what abt Pansat
Username: Simplyme
Post Number: 17
C/P from rookie.
Thumbs down OUT of hand
THIS is getting out of hand!!! THERE is NO fix yet for the new provider ID for VS!!! WHEN one comes out it will be tested and POSTED in the appropriate files forum. IF you want to be notified go the the files forum and SUBSCRIBE, (YOU will get an email when the fix is posted).
The NEXT person who starts a NEW thread asking if a fix is out or their VS is DOWN is GOING ON VACATION!!!!!
__________________
In memory of a truly GREAT tester. HILLBILLY, Lest we forget.
PLEASE read what forum you are posting in BEFORE hitting the submit button. Also always remember to OBEY all site rules
Username: Cartier1
Post Number: 1274
RTAP . YOU ARE LOW CLASS CHEAP WH*ORE. WHERE THE F 8UCK U SEE FIXES. DONT LIE LOOSER. NO FIX IS YET FOR ANY BOX. FTASOLUTION IS THE WORST SITE TO GO GUYS .
Username: Geeker
The Great Wh...
Post Number: 237
y arent the new VS files on Total?
Username: Chrisduclo
Post Number: 50
pansat says fix is here with todays new bin... am going to test now... will be back in a few.
Username: Vsp
Post Number: 148
get back soon Chrisduclo
Username: Hshakarchi
Post Number: 124
RTAP, when you say:
(files can be found ftabins*net)
did you check that cause I just visited the site and there are no fix at least for VS ultra...
did I miss something
Post Number: 51
future-fta.info is where it says the fix is at.
brought toyou from blacklist
Username: Vsp
Post Number: 149
chrisduclo
did u check if neew pansat bin is workin
Username: Pathfinder191
Post Number: 203
I tried new bin for 2700A. All channels are back.
Username: Bant07
Post Number: 9
what do we do for 2500????????
Post Number: 52
a report of WAIT FOR PICTURE 350% ON PANSAT2700
Username: Bant07
Post Number: 10
YES YES i got that SAMEEEEEE problem but the new keys do not work!!!!..
Username: Vndpatel
Post Number: 254
ok so ALL PANSATS HAVE FIXES
Post Number: 53
for the 2500 there is a software fix to change the firmware to a 2700. but with that change there is also a "special" bin that needs to be made for these "special" stbs.
Username: Simplyme
Post Number: 19
Wait.Patiently.Gratefully.Respectively.
Post Number: 54
confirmed... pansat 2700... working with new bin.
Username: Simplyme
Post Number: 20
Thanks for confirming.
Username: Tscon
Post Number: 13
"new keys do not work!!!!.."
Then that means DN just implement new encryption
algorithm. And we have to wait a while for the
fixes to come out.
Username: Kirankumar
What is a bin ?please help me,I am very new to this
Username: Tscon
Post Number: 14
Can anyone point to the instructions how to
convert FLU to Pansat 2700? I know there was complete instructions somewhere..
Thanks.
Username: Vndpatel
Post Number: 255
ftabins.net and www.ftasolutions.blogspot.com are the only one so far that have the PANSAT FIXES and they work
Username: Cartier1
Post Number: 1277
BOB JOHN . YOU ARE AN OTHER IDIOT LOW LIFE SCAMER . YOU WANNA SEE YOUR USER NAME AGAIN
? SO DONT LIE TO YOUR FELLAS SPAMMER F*UCK
Username: Ill0_ill
Is there a fix fortec ultra ?
Username: Ill0_ill
Is there a fix fortec Ultra?
Username: Lklives
Post Number: 13031
Only NEW WORKING DN fixes released today
Captiveworks
Pansat
Conexsat
others will follow tonite or tomorrow
Username: Indopak
Post Number: 41
is there a new bin for fortec ultra or fortec classic na, or even digiwave 7000, or any clone files?
Username: Jhniner
Atlanta, Ga
Usa
anything yet for viewsat plat?
Username: Asharfi
Post Number: 957
nope
Username: Ill0_ill
okay thanks LK :-)
anything for c**lsat?
Username: Nydas
Post Number: 4175
None for C00LSATS yet. Viewsat new BIN report was a bogus.
Nalin: can u tell me what is a bin please
Username: Nydas
Post Number: 4179
BIN is short for a BINary file. That is the one loaded into a rewritable memory in your receiver, called flash ROM. It makes the receiver work properly. Now and then a new BIN is published and available on various sites on the internet. You upload it into your receiver using another software called a loader or uploader.
Each receiver has different BIN and uses a different uploader. You need a special cable - one of the two types, either a RS232 straight or a null modem. Always get the instructions from the site where you get your files.
As of now, the sites are all busy, and if you not already a member, you might not get into the site.
Username: Golbole
Post Number: 15
There are two files available for viewsat ultra dated oct 7 and 8. One ends with 'GC'. Can somebody please tell which is the right file and what does 'gc' stand for?
Post Number: 7
Nalin: Thank u so much u are very helpful
Username: Nydas
Post Number: 4180
jas: Please read above. <i> Viewsat new BIN report was a bogus. </b> Look for a viewsat file with today's date or later date. The ones you mentioned are history.
Username: Tigger_woods
Flutopia
Post Number: 157
GC stands for Globe Cast I believe??? If you speak English, walk upright and live in North America, then you do not need it. Truth of the matter they probably both work for you, but the one that has no GC would be my choice....
Username: Golbole
Post Number: 16
thank you dear...
Username: Rtap
FL
Post Number: 703
cartier your an idiot.go to this link and u will see the time the bins came out.example CW came 11 hours ago.http://ftabins.net/forumdisplay.php?f=35
LEARN HOW TO SEARCH INSTEAD OF WAITING FOR YOUR GIRLFRIEND NALIN TO GIVE U BOGUS ANSWERS.DICKKKKKKKKKKKKKKKKKKKKKKKKKKK
Username: Cartier1
Post Number: 1278
RTAP
Username: Rtap
FL
Post Number: 698
Posted on Tuesday, October 23, 2007 - 04:09 pm:
Ariza 750
Captive Works
NFusion
Visionsat
Visionsat IV200
tha's what you wrote d*ickkkk head . no viewsat fix in there the time you suggested to go to the site. spammerrrrrrrrrrrrrrrrrrrrrrrrr
Username: Charm
Need key for sat 7000
Username: Cartier1
Post Number: 1279
sanju go do yourself a favor. go rewad read read read read read read . and u will get the keys magicaly by yourself.
or call locksmith 1800-locksmith .
Username: Xcable
Rochester, NY
Post Number: 77
One Koolsat fix,The 6100 private, Check dsscentral for that one
Username: Dishall
Post Number: 43
i can not find fix for vs pro or extreme on above listed sites, any help.
Username: Shawn0101
which gt loader should use for new bin pansat 2700
Username: Satgrl
Post Number: 27
u can use v3.35...
Post Number: 9
Sanju: go to this site http://www.ftasolution.com/
Username: Tscon
Post Number: 21
"Only NEW WORKING DN fixes released today
Captiveworks
Pansat
Conexsat
others will follow tonite or tomorrow"
Released where? Could you please point to Pansat
latest bin for clones?
Thanks. ;)
Username: Harchi777
Surrey, Bc
i have eagle star.can any one pl tell what kind of reciever is this. and what bin is needed
Username: Donnie1973
Post Number: 1280
S/V fix is at total
Username: Leafs
www.ftasolutions.blogspot.com is not a bad site to visit...
Post Number: 1282
loser
Username: Albino_midget
Post Number: 623
eagle star = pansat 2500 clone
best bet is to do the conversion to a pansat 2700 and use only the JVVH files after the conversion
Username: Lklives
Post Number: 13052
There are NO new Sonicview or Viewsat fixes at ANY sites now!...whats posted at Total, are OLD SV files!
Username: Abpatel49508
ST JOSEPH, MICHIGAN
Post Number: 11
I have pansat 2700E. Can somebody tell me what bin do I need to download?Where can I find it?
Username: Harchi777
Surrey, Bc
Thanks everybody.But is there a bin for it till now and pl also tell me whats the name of the software to transfer the bin .I am quite new to these things.
Thanks in advance
Post Number: 1311
U will have to tell us what reciever u have... we can not guess at that.
Username: Harchi777
Surrey, Bc
I mean for 2500 pansat clone (Any bin is still there or not)
Post Number: 1312
no clone fixes out yet.
Username: Tale
Post Number: 10
Arvind , here is your file for Pansa* 2700
http://freedomfta.net/forums/showthread.php?t=9452
You need to register first.
Username: Lklives
Post Number: 13059
There are Clone fixes for the Pansat 2700 and 3500...and for genuine receivers..
Since Pansat and Team Blacklist no longer support the 2500, there will never be support again for 2500 clones!
The sonicview fixes at totalFta are in fact good and working..
There still are NO viewsat or coo*lsat fixes yet!
There is NO converted 2500-2700 fix yet!
Username: Lionking
Post Number: 37
where do we find clone fixes
Username: Tale
Post Number: 11
This is good site for clones
http://www.abadss.com/forum/163-pansat-2700a-downloads/
Username: Leafs
visit www.ftasolutions.blogspot.com for latest keys...
Username: Vick0901
Post Number: 15
All my channels say scrambled. I have a pantec which is 2700 clone receiver. Is the new bin file available for clones and has anyone tested it? I found a bin fix file on ftaprosupport.c*m (VorteX_87VX_071023_B75_2018...23 October.zip) should I get this file?
Username: Lklives
Post Number: 13061
yes use that Vortex 2018 bin with the clone loader 27.02
Username: Vick0901
Post Number: 16
Where can I find the clone loader 27.02? someone add me on messenger aegisrx@hotmail.com and send it plz!!
Username: Lklives
Post Number: 13067
Only NEW WORKING DN fixes released so far
Captiveworks
Pansat
Conexsat
Sonicview
Nfusion
Neusat
Visionsat
Buzz 2020
Neosat 2000
Vortex...2700 & 3500 pansat clones
Username: Jbourikos
Post Number: 50
i havent heard anyone complain about coolsaht LOL
guess not too many people have them kikin anymore
my damn neighbour is good friends with my mom and breaks my balls to fix her stupid coolsaht 5k
i think one day im gonna fry the junkbox so she can have an excuse to get a new one
i will blame it on an electrical failure or somethin
Username: Arshaddar
Post Number: 7
any news on viewsat dgway 7000?
Username: Lklives
Post Number: 13075
JB...Coo*lsat 5000 is a great little older box...and great pic quality...
Username: India101
Post Number: 13
how do i load the new pansat files in to receiver what loader do i use. i try to use
X-87BL Loader v27.02[X-87BL].exe and i load the files. Then i started the reciver and click on download but its only says "Downloading......"
it does not do anything. do i have to wait for some time or what?
Username: Yousuf2221
Chicago, Il
Usa
2500 clones!try t290bin still working
Username: Bashir77ca
mohammed are you sure its workink?
Username: Jbourikos
Post Number: 56
thats true...but i guess it doesnt matter on her little 19 inch antique tv
Username: Nydas
Post Number: 4219
DN version of 290T is working the same as 293T - in a limited way with the locals on 119W, ABC, NBC, PBS, etc. Even VOD is working. No PPV.
All of Echo 3 (61.5W) does not work with 290T or with 293T or 294T.
Username: Bobcunk
anything for dish network 311 receiver
Post Number: 1330
look at ftaprosupport.com
towards the bottom
Username: Sonu
Dear LK
Which one is the best FTA receiver to buy and why. price is no consideration.
second need bin for coolset 5000 platinum
Username: Masterstylz
Post Number: 38
ANY NEWS ON VIEWSAT LITE FIX?
Post Number: 1332
not yet. will come out at totalfta first
Flutopia
Post Number: 159
where do we find clone fixes....................
CLONING is a democrat thang...not ok with God.
Username: Asharfi
Post Number: 1001
lol .... CLONE fixes are not out yet ..... keep wating .... lol .... watching this movie on DVD ... LMAO
Post Number: 1337
c/p from LK
Username: Satgrl
Post Number: 64
what about today any fix for converted 2500-2700 yet???? hurry someone reply i need help!! everyone said i might be out yesterday or today!!..thnxs
Username: Dr_dss
Post Number: 84
Damn grl you need a big bottle of chill pills
Username: Satgrl
Post Number: 73
hehe...can u please let me know if they got a file for converteed pansats? thanksss
Username: Dr_dss
Post Number: 86
Nah nothing yet! Don't worry it will be plastered all over the place once it breaks. The only thing is, it's not a sure thing! The J-man posted a message a few weeks back that this is getting old. Everyone wants the bin but few offer to help in the project. It sounds like he is getting burnt-out and may drop the project but who knows.
Username: Satgrl
Post Number: 79
oh man i hope not !!
Username: Afrimpeja
Forest hills, Ny
Usa
Post Number: 53
what abot MAGNUM any fixes?
Username: Satgrl
Post Number: 89
i doubt it nope..keep waiting
Username: Satgrl
Post Number: 95
}...is the pansat 2700A (original) bin out yet the one with the new PID fix? and does it have to be b-75 upgraded in order to load this new "bin"
Username: Scorp7
Post Number: 62
Whats happening? Why the COOl Sat camp is silent... No fix yet!!!! Any news when its coming out? Thanks
Username: Rtap
FL
Post Number: 743
coolsats files are available at fatbins*net for the
coolsats 5000-6000-6100-7000
Username: Tale
Post Number: 12
There are some fixes for Coolsa* !!!
Look here !
http://freedomfta.net/forums/forumdisplay.php?f=352
Username: Tale
Post Number: 13
...or here !
http://www.dssfeedback.com/forums/forumdisplay.php?f=114
Username: Satgrl
Post Number: 182
Any news on the jvvh files? for converted pansat 2500's?...thnxs for da help!!i thought they said it was suppose to come out today!!..its taken long
Username: Asharfi
Post Number: 1016
Nope, no new files for those receivers at this moment .... looks like JVVH got arrested ... LMAO .... anyway ... we're all waiting ..... GO JVVH!
Username: Nydas
Post Number: 4258
AV: It is OK - he was arrested for speeding only.
Username: Asharfi
Post Number: 1018
lol ...
Post Number: 204
Does anyone know if the file DBPSW-071024P for VS2000 Lite/Platinum working or not?
Thanks
Username: Asharfi
Post Number: 1019
Yes, that bin is working ... BEV and DN are both up and working fine ... :-)
Username: Tlmolto
London, Ont
Is there a fix yet for the Ariza 700? Also wanting to get a new receiver which 1 would be the best.
Username: Satgrl
Post Number: 227
any fix for ppancrap jvvh sorry to bother if anyone noes id like an update....appreciate ur help
Username: Dr_dss
Post Number: 96
Well I got into work today. Poured a nice big cup of coffee. Logged into server checked reports and logs then said to myself while switching into stalker mode lets go see how many messages the neurotic grl has posted so far today.
Oh Neurotic one. You are better off for your own well being, before you have a nervous break down. To check around on sites J-man visits himself. He doesn't come around to zoocoustics.
Username: Satgrl
Post Number: 228
haha ok DR DSS are u wide awake to stalk people today...is that ur "WORK" that u went to today? anwyas what is ur job?
Username: Dr_dss
Post Number: 103
Well seeing this a public forum and I being a stalker I should keep that type of information to myself. Your reverse psychology tactics have failed :-(
Username: Poochi425
Mis, On
Post Number: 28
where do u see a fix for ariza750 ???????
Username: Harchi777
Surrey, Bc
Hi There;any one can tell me if there is any fix for eagle star(2500 clone) .
If not, Should i buy viewsat ultra?Is it ok?I am new to fta.
pl answer
Username: Lklives
Post Number: 13250
Buy the Ultra or sonicview 4000....or conexsat mini...all are good...eaglestar 2500 is basically NFG, unless u convert it to a 2700 clone...but jvvh is no longer making the modded bins..and expects others to do it, based on his teachings..
Username: Harchi777
Surrey, Bc
Thanks a lot LK
Username: Nydas
Post Number: 4362
harcharan singh : The Eaglestar is a Pansat 2500 clone. In this forum there are many threads about converting Pansat 2500 and clones to a Pansat 2700. As of now, these conversions work well.
Whether or not you wish to live with this uncertainty of support is entirely your decision. You can just discard your Eagle star and buy one of the following receivers
Viewsat Ultra - about $180
Sonicview 4000 - about $165
Captiveworks 600P- about $105
The first two have USB and serialinput for new fiels
The last one has only serial input.
Username: Harchi777
Surrey, Bc
Post Number: 9
Thanks dear ,I have bought a viewsat ultra.
but what has happened again today??
Is it again file problem?and i dont know if it will autoroll keys or i have to do it manually.
Pl tell me how do we fix Viewsat.(it worked very very good)
Username: Silver1123
Mexico, DF
Mexico
Post Number: 357
Koolsat bin 152 at
http://ftabins.net/forumdisplay.php?f=104
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > Fixes are available for the following... [ « Previous ] [ Next » ]
