Thread: Archive through October 15, 2007 |
Gold Member Username: Tetuscosmicus
Post Number: 1458 Registered: Nov-06
| Posted on Sunday, October 14, 2007 - 02:30 pm: |
HOLA EVA... COMO ESTAS...GUSTO DE LEERTE CUIDATE MUCHO...... |
Post Number: 1459 Registered: Nov-06
SALUDOS RAZA...COMO ESTAN.... |
Gold Member Username: Nikk
Post Number: 2460 Registered: Sep-06
| Posted on Sunday, October 14, 2007 - 02:32 pm: |
mario andres.... Si lo bajaste de ftabins....en el post donde viene ese file dice especificamente que el password es dInErO ........ |
Bronze Member Username: Dario
Post Number: 82 Registered: May-06
| Posted on Sunday, October 14, 2007 - 02:33 pm: |
Buenas tardes, tengo una pansat 2700A, le instale el ultimo bin, pero al darle blin scan este solo me carga 8 transponder en ambos canales.. alguien me puede guiar sobre esto? Gracias |
Post Number: 2461 Registered: Sep-06
saludos mi javi..... |
Post Number: 83 Registered: May-06
| Posted on Sunday, October 14, 2007 - 02:34 pm: |
Buenas tardes, tengo una pansat 2700A, le instale el ultimo bin, pero al darle blin scan este solo me carga 8 transponder en ambos satelite, cuando normalmente carga hasta 20.. alguien me puede guiar sobre esto? Gracias |
Post Number: 1460 Registered: Nov-06
| Posted on Sunday, October 14, 2007 - 02:35 pm: |
HOLA..MI NIKK...SABA BIEN... CUIDATE MUCHO....... |
Post Number: 2462 Registered: Sep-06
dario.... Mucho tiempo que no te leiamos....saludos... Que bin tienes???... Revisa tambien las conexiones a tu Diseqc.... |
Post Number: 2463 Registered: Sep-06
| Posted on Sunday, October 14, 2007 - 02:36 pm: |
saludos hetor.... |
Bronze Member Username: Rocas
Humble,
Tx
Harris
Post Number: 48 Registered: Aug-07
NIKK MTY EFECTIVAMENTE ESO HACE YA MIRE LA INFORMACION Y DICE 211 ESE ES DE SEPTIEMBRE SI NO ME EQUIVOCO PERO NO TRABAJA TODAVIA SI TIENEN OTRA SUGERENCIA GRACIAS SI NO GRACIAS DE CUALQUIER MANERA |
Post Number: 84 Registered: May-06
| Posted on Sunday, October 14, 2007 - 02:45 pm: |
Hola Nikk y a todos los demas, si hacia rato no posteaba, solo me limitaba a leer. Tengo el bin 217. Gracias |
Post Number: 85 Registered: May-06
| Posted on Sunday, October 14, 2007 - 02:50 pm: |
Nikk Como deberian ser las conexiones al Diseqc? |
Bronze Member Username: Marioandres
Post Number: 28 Registered: Apr-07
| Posted on Sunday, October 14, 2007 - 02:51 pm: |
Nikk Mty BAJE EL ARCHIVO WINRAR DE EXPRESSFR.COM ENSAYE EL PASSWORD QUE ME SUGERISTE Y NO FUNCIONO |
Gold Member Username: Evadelparaiso
Puerto Rico
Post Number: 2471 Registered: May-06
| Posted on Sunday, October 14, 2007 - 02:57 pm: |
JUAN Gonzalez Trata el bin original de la caja y luego correle el nuevo bien. Suerte |
Puerto Rico
Post Number: 2472 Registered: May-06
| Posted on Sunday, October 14, 2007 - 02:58 pm: |
Mario te sugiero que busques el bin en winzip, avanzaras mas. Suerte |
Humble,
Tx
Harris
Post Number: 49 Registered: Aug-07
| Posted on Sunday, October 14, 2007 - 03:00 pm: |
EVA QUERES DECIR EL ORIGINAL DEL 2500a no le afecta haora que esta convertido a 2700? |
Post Number: 2464 Registered: Sep-06
| Posted on Sunday, October 14, 2007 - 03:21 pm: |
mario andres.... Acabo de probar y el password funciona... El detalle es que es "case sensitive"..esto es, hay que poner el password tal como esta escrito, mayusculas y minusculas... es d minuscula es I mayuscula es n minuscula es E mayuscula es r minuscula es O mayuscula si estas usando el winzip, entonces requieres ir al menu de opciones y entrar donce dice password y volver a ponerlo, quitale la palomita a donde dice "Mask Password" para que lo puedas ver.. |
Post Number: 2465 Registered: Sep-06
| Posted on Sunday, October 14, 2007 - 03:26 pm: |
juan gonzales... Si ya convertiste tu equipo entonces no le puedes poner el bin de fabrica para 2500... Intenta bajarle primero el 213....y ve que pasa...probaste con el bin 217 de ftabins??? Si no has probado ese aun ve alla, descarga el que posteo un miembro de nombre greeny e intentalo de nuevo.... |
Gold Member Username: Javy_gza
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1015 Registered: Oct-06
| Posted on Sunday, October 14, 2007 - 03:29 pm: |
PARA REGRESAR A 2500 DE 2700 JUAN GZZ |
Post Number: 2466 Registered: Sep-06
| Posted on Sunday, October 14, 2007 - 03:32 pm: |
mario andres.... Fui a expressfr y no encontre el bin Tivo que dices....ve aqui y bajalo.... http://www.ftabins.net/showthread.php?t=9959 ese yo lo probe y se descomprime sin problemas |
Post Number: 2467 Registered: Sep-06
| Posted on Sunday, October 14, 2007 - 03:35 pm: |
dario... Que bin tenias antes de ese???... Revisa que las conexiones esten bien apretadas y que tu antena este bien orientada.. Te baja TP's de horizontal y vertical??? o solo de una polaridad??? |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1016 Registered: Oct-06
| Posted on Sunday, October 14, 2007 - 03:39 pm: |
Guide and Files for 2700 back to 2500/Pantec/FLU - By Chancysand greeny EN FTA BINS ESTAN ESOS ARCHIVOS P REGRESAR A 2500 JUAN GZZ ESTO ES EN CASO Q UIERAS EMPEZAR OTRA VEZ |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1017 Registered: Oct-06
| Posted on Sunday, October 14, 2007 - 03:46 pm: |
MARIO I BAJE EL WINRAR DE PRUEBA DE 40 DIAS Y SE VENCIO PERO SIGUIO TRABAJNDO NOMAS TE PONIA Q TENIAS Q COMPRAR PERO SI FUNCIONA INTENTALO . |
Post Number: 86 Registered: May-06
| Posted on Sunday, October 14, 2007 - 03:48 pm: |
Nikk, la antena no se ha movido desde su posicion original....Antes tenia el bin 203... Solo me baja 8transponder en vertical y horizontal....Yo si le hice un reset de fabrica, sera por ese lado? |
Gold Member Username: Nadadesat
Post Number: 1031 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 04:00 pm: |
MIRA JUAN RAMIREZONE, SIEMPRE TE HE PEDIDO PAZ, NO SE QUE TRAES CONMIGO. YO SIEMPRE HE PEDIDO LA PAZ PARA ESTE FORO, PERO NO SE QUE SIENTES TU Y TU GRUPO DE AMIGOS. LA VERDAD YO TE LO VUELVO A REPETIR, YO NO QUIERO QUE ESTE FORO SE SIGA DEGENERANDO, NI INSULTANDONOS. Y MENOS AHORA QUE HA LLEGADO UNA VERDADERA MAESTRA COMO LO ES EVA. YO HE LEIDO SUS POST Y SE CUANDO UNA PERSONA SABE. TAMBIEN A NICK MTY LE HE EXPRESADO MIS RESPETOS PORQUE EL SABE, AYER LO HICE Y CREO QUE FUE DE LA MANERA MAS APROPIADA QUE SE PUEDE. PERO SABES QUE TU SIEMPRE ATACAS, AHORA ME DICES "TINTERILLODE CHAQUETILLA" QUE ES ESO? UNA OFENSA MAS DE TU PARTE. YO TE DIJE SIGUEME ATACANDO Y ME VAS A HACE*R MAS FAMOSO, YO NO TE QUIERO ATACAR, NO LO DESEO, PORQUE TE LO DIGO EL FORO MERECE RESPETO. SI ME SIGUES ATACANDO ME VAS HACE¨*R MAS FAMOSO QUE CUALQUIER POLITICO, HASTA EN EL NEW YORK TIMES, EN LA PORTADA VOY A SALIR. MIRA YO NO SOY TONTO, ESE CUATE QUE ESTA AL OTRO LADO, "EL TAL MONSTRUO", ES UNA PERSONA QUE ENTRA AQUI Y NO DUDO QUE TU ESTES ORQUESTANDO TODO, ES DECIR, QUE ESTES ATRAS DE TODO ESTO, TU O UNO DE TUS AMIGOS. OYE QUE NO CONOCES LA CORDURA?. YO NO TE PIDO QUE TE VAYAS, QUEDATE, PERO YA NO ME INSULTES, DESDE AHORA TE LO DIGO NO TE VAS A SALIR CON LA TUYA. ENTRE MAS ME TIRES MAS FAMOSO ME HACES. TE DIGO UNA COSA HASTA INOCENTE PARA HACE*R TRAVESURAS SALISTE, YO PENSE QUE ERAS MAS INTELIGENTE. Y NO TE EQUIVOCAS, YO SOY MEXICANO Y TAMBIEN TENGO LA RESIDENCIA DE LOS ESTADOS UNIDOS Y PROXIMAMENTE LA CIUDADANIA. YO CONOZCO A LOS GRINGOS, COMO NO LOS VOY A CONOCER SI MI PADRE NACIO EN LOS ANGELES CALIFORNIA Y MI MADRE VIVE EN UNA CIUDAD ESTADOUNIDENSE Y MIS FAMILIARES Y NO CREAS QUE ANDAN TRABAJANDO EN TRABAJOS CUALQUIERA, ELLOS TIENEN SUS NEGOCIOS Y LES VA MUY BIEN. BUENO NO ESTOY DICIENDO QUE CUALQUIER TRABAJO ES INDIGNO, TODO TRABAJO ES RESPETUOSO Y DIGNIFICA AL HOMBRE. MIS RESPETOS A TODO TRABAJO QUE TENGA CUALQUIER SER HUMANO SEA DE ESTE FORO O DE CUALQUIERA. YA LEEI LOS POST SIGUIENTES QUE LE DIRIJIERON AL MONSTRUO, QUE HA DE SER UNO DE TUS AMIGOS. FIJATE ME DI EL LUJO DE INSULTARLO. Y AHORA TE VOY A DECIR UNA COSA, EMPLEE PALABRAS VULGARES Y ME ARRREPIENTO, PORQUE ESO ME DENIGRA. PERO SABES QUE EL FORO NO LO VAN A CERRAR. YA DEJATE DE ANDAR DE MALANDRIN Y TE DIGO ASI, PORQUE EN VERDAD, YO LIDIO CON VERDADEROS DELINCUENTES QUE SI SABEN HACE*R DAÑO A LA GENTE. NO COMO TU, QUE HACES PURAS TRAVESURAS DE NIÑOS. YO TE PIDO PAZ. MIS RESPETOS A TODOS Y QUE BIEN QUE HAYA REGRESADO UNA MAESTRA QUE SI SABE Y OJALA QUE DURE MUCHO TIEMPO PARA APRENDERLE, PORQUE CREEMELO DE TI NO HE APRENDIDO NADA, NOMAS LO QUE TE HE APRENDIDO ES A PELEAR VULGARMENTE. SALUDOS A TODOS Y DE NUEVO UNA DISCULPA. POR ULTIMO, YA TE HAN CORRIDO DE OTROS FOROS Y DE LOS GRINGOS, AQUI TE HAN DICHO MALDICIONES, A MI LOS UNICOS QUE ME HAN DICHO COSAS SON TUS AMIGOS Y ALIADOS. PERO SABES QUE MIS RESPETOS PARA ELLOS Y TODAS MIS BENDICIONES. QUE LES VAYA BIEN EN LA VIDA. SALUDOS A TODOS. POR ULTIMO GRACIAS A TI O CUALQUIERA DE TUS ALIADOS O A QUIEN HAYA SIDO POR ABRIRME UN ESPACIO EN LOS FOROS GRINGOS. THANKS. |
Bronze Member Username: Albertson
Post Number: 55 Registered: Jul-07
| Posted on Sunday, October 14, 2007 - 04:12 pm: |
Hola para todos.esta el Pansat 2500A activo para coger signal o necesariamente hay que ha*cer la conversion a 2700? y de estar activo es el ultimo bin y loader?, esto es para ayudarle a un vecino. Gracias por su ayuda. Al |
Post Number: 1032 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 04:20 pm: |
psychmonster Silver Member Username: Psychmonster chi town , il USA Post Number: 106 Registered: Jul-06 Posted on Sunday, October 14, 2007 - 12:17 am: I express this to the "Solo Hispanos"......u are only 3 or 4 idiots that keep bullS>>iting amongst yourself. hetor - ERNESTO M. M. javier garza gonzale I want you to keep your crap on your side of the border...this is a link that helps people who are looking for real help via FTA...hetor - ERNESTO M. M. javier garza gonzale ...keep your crap to your self and leave english language links alone and start your own obvious cross border hom o-sex ual love fest between you all or get another "love thread" so that all 4 of u can continue this trist in your native language and not subject us all who are normal english speaking people, you are making my kids take spanish because of PC correctness...I am sick and tired of dialing my bank and asked to speak Mexican (spanish)...you better learn my lanquage...press 1 to kiss my azz Top of pagePrevious messageNext messageBottom of page Link to this message ERNESTO M. M. Gold Member Username: Nadadesat Post Number: 1026 Registered: Jun-07 Posted on Sunday, October 14, 2007 - 02:17 am: chingas a toda tu madre monster. i like your buttocks. i want to f*uck you. Top of pagePrevious messageNext messageBottom of page Link to this message THE ONLY PAISA LEFT Bronze Member Username: Guanajuatos_best Post Number: 83 Registered: Jul-07 Posted on Sunday, October 14, 2007 - 12:36 pm: psychmonster Silver Member Username: Psychmonster chi town , il USA Post Number: 106 Registered: Jul-06 PLEASE EXCUSE MY LANGUAGE, BUT I THINK THAT YOU ARE ONE OF THOSE STUPID GRINGOS THAT DONT KNOW SH*IT ABOUT OTHER CULTURES. I THINK THAT IT IS GOOD THAT YOUR KIDS ARE TAKING SPANISH, AT LEAST THEY WILL KNOW MORE ABOUT LIFE Top of pagePrevious messageNext messageBottom of page Link to this message Eva Gold Member Username: Evadelparaiso Puerto Rico Post Number: 2468 Registered: May-06 Posted on Sunday, October 14, 2007 - 01:44 pm: /ignore :P Top of pagePrevious messageNext messageBottom of page Link to this message AV Silver Member Username: Asharfi Post Number: 938 Registered: Aug-06 Posted on Sunday, October 14, 2007 - 02:17 pm: Welcome back, EVA! Top of pagePrevious messageNext messageBottom of page Link to this message LK Platinum Member Username: Lklives Post Number: 12861 Registered: Jan-06 Posted on Sunday, October 14, 2007 - 02:33 pm: obviouisly Eva never left...but reared his/her head just for this...in fact she was one of the members that agreed to keep and maintain ALL Spanish speaking posts within the Solo Hispano thread... but now I see that the Spanish are breaking their promises and agreements, and starting other threads and speaking spanish wherever they feel like it.. Top of pagePrevious messageNext messageBottom of page Link to this message cali Bronze Member Username: Cali Post Number: 77 Registered: May-06 Posted on Sunday, October 14, 2007 - 02:43 pm: LK, your such a geek. Get a life you fat fukc. Go smoke another cigarette and bang your sister you imbred POS. Top of pagePrevious messageNext messageBottom of page Link to this message Pilar Marchese New member Username: Pili Post Number: 10 Registered: Jun-06 Posted on Sunday, October 14, 2007 - 02:49 pm: Hello Everybody, I was wondering how can I watch the soccer's game Colombia Vs, Brasil. I don't know if my receiver (Buzz) is good enough, so any ideas?? Top of pagePrevious messageNext messageBottom of page Link to this message sada Silver Member Username: Saqeeb90 Post Number: 134 Registered: Dec-06 Posted on Sunday, October 14, 2007 - 02:51 pm: how do we kick them out..phycomonster any suggestion// Top of pagePrevious messageNext messageBottom of page Link to this message cali Bronze Member Username: Cali Post Number: 78 Registered: May-06 Posted on Sunday, October 14, 2007 - 02:51 pm: This malparido LK gets not attention in real life hence his creating a virtual life online. Dude can't even make a friend for Dungeons and Dragons. LK does this board make you feel important? Why are you always so eager for virtual attention? It speaks volumes of your low self-esteem. You freaking anglo-tard. Top of pagePrevious messageNext messageBottom of page Link to this message cali Bronze Member Username: Cali Post Number: 79 Registered: May-06 Posted on Sunday, October 14, 2007 - 02:53 pm: Colombia Brasil wlil be on PPV. 457. LK will be watching Oxygen. He's a fat unfit cutn. Top of pagePrevious messageNext messageBottom of page Link to this message juan Cavazos Silver Member Username: Silver1123 Mexico , DF mexico Post Number: 245 Registered: Jul-07 Posted on Sunday, October 14, 2007 - 02:55 pm: Hey, Aqui se habla Espanol. Better learn Spanish, its going to be the Official US language in a couple of years. Top of pagePrevious messageNext messageBottom of page Link to this message cali Bronze Member Username: Cali Post Number: 80 Registered: May-06 Posted on Sunday, October 14, 2007 - 02:59 pm: Verdad no? LK es un come mierd pendeja. Un hijueputa resentido porque su hermana le termino. Pobre Guebon! Illiterate monolithic non-Spanish speaking loser. Top of pagePrevious messageNext messageBottom of page Link to this message Pilar Marchese Bronze Member Username: Pili Post Number: 11 Registered: Jun-06 Posted on Sunday, October 14, 2007 - 02:59 pm: Esta bien en español, alguna idea acerca del juego Colombia vs, Brasil, es posible ver el juego?? mi decodificador es Buzz, y apreciaria alguna informacion.!! Add Your Message Here |
Post Number: 1033 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 04:21 pm: |
bueno por hoy los dejo y sigan ayudando ala gente. saludos a todos. |
New member Username: Alineerodrigo
Post Number: 2 Registered: Oct-07
| Posted on Sunday, October 14, 2007 - 04:33 pm: |
tengo 1 vortex 7700 e se murio q program tengo q poner en la vortex p volver a vida? |
Post Number: 2468 Registered: Sep-06
| Posted on Sunday, October 14, 2007 - 05:00 pm: |
dario.... Intenta poniendole primero el 211, luego el 213 y por ultimo el 217....el 215 no lo pongas.... |
Post Number: 2469 Registered: Sep-06
| Posted on Sunday, October 14, 2007 - 05:02 pm: |
Albertson... El 2500 lo puedes tener trabajando con el bin 293 o 294...el problema es que tienes que ponerle las llaves manualmente.....si lo conviertes ya hay bines con autoroll para los equipos convertidos |
Post Number: 2470 Registered: Sep-06
| Posted on Sunday, October 14, 2007 - 05:07 pm: |
rodrigo benavides... El 7700 es un clon de Pansat 2500 tambien, si se murio lo mas seguro es que habias hecho la conversion y le bajaste el bin 215....es asi???... Si es asi entonces puedes intentar efectuar de nuevo todo el porcedimiento de conversion, intenta bajarle el bin 205 que es el que trae el nuevo boot, solo que como no hay luces, apagalo del boton trasero, luego lo enciendes de nuevo y sin esperar intenta descargarle ese bin, luego si funciona, le descrgas el 208 y los que siguen excepto el 215.... Tal vez tengas que intentar descargarle el 205 varias veces hasta que en una de ellas lo acepte...de otra manera hay que seguir el procedimiento de conversion a 2700 por medio de JTag.... |
Post Number: 12867 Registered: Jan-06
| Posted on Sunday, October 14, 2007 - 05:48 pm: |
U spanish want war...well now u got it!...U started this crap with me and others here..payback time! Week 1 THU, SEP 6 HI PASSING HI RUSHING HI RECEIVING Indianapolis 41, New Orleans 10 Manning 288 Addai 118 Wayne 115 SUN, SEP 9 HI PASSING HI RUSHING HI RECEIVING Green Bay 16, Philadelphia 13 Favre 206 Westbrook 85 Driver 66 Houston 20, Kansas City 3 Schaub 225 Green 73 Johnson 142 Denver 15, Buffalo 14 Cutler 304 Henry 139 Walker 119 Pittsburgh 34, Cleveland 7 Anderson 184 Parker 109 Winslow 83 Carolina 27, St. Louis 13 Delhomme 201 Foster 94 Smith 118 Minnesota 24, Atlanta 3 Harrington 199 Peterson 103 Peterson 60 New England 38, NY Jets 14 Brady 297 Maroney 72 Moss 183 Washington 16, Miami 13 Campbell 222 Portis 98 Randle El 162 Tennessee 13, Jacksonville 10 Garrard 204 Brown 175 Northcutt 57 San Diego 14, Chicago 3 Rivers 190 Benson 42 Gates 107 Seattle 20, Tampa Bay 6 Hasselbeck 222 Alexander 105 Galloway 72 Detroit 36, Oakland 21 McCown 313 Bell 87 Curry 133 Dallas 45, NY Giants 35 Romo 345 Ward 89 Burress 144 MON, SEP 10 HI PASSING HI RUSHING HI RECEIVING Cincinnati 27, Baltimore 20 McNair 203 McGahee 77 Johnson 95 San Francisco 20, Arizona 17 Smith 126 James 92 Battle 60 Week 2 SUN, SEP 16 TIME (ET) TV RESOURCES LOCATION Buffalo at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Houston at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium Atlanta at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium New Orleans at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Green Bay at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium San Francisco at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Cincinnati at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Indianapolis at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at Detroit 4:05 PM Fox Tickets | Travel Ford Field Dallas at Miami 4:05 PM Fox Tickets | Travel Dolphin Stadium Seattle at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium NY Jets at Baltimore 4:15 PM CBS Tickets | Travel M&T Bank Stadium Oakland at Denver 4:15 PM CBS Tickets | Travel Invesco Field Kansas City at Chicago 4:15 PM CBS Tickets | Travel Soldier Field San Diego at New England 8:15 PM NBC Tickets | Travel Gillette Stadium MON, SEP 17 TIME (ET) TV RESOURCES LOCATION Washington at Philadelphia 8:30 PM ESPN Tickets | Travel Lincoln Financial Field Week 3 SUN, SEP 23 TIME (ET) TV RESOURCES LOCATION Detroit at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Miami at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium Buffalo at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Arizona at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium St. Louis at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium San Francisco at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field Indianapolis at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium San Diego at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field Minnesota at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium Cleveland at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum Jacksonville at Denver 4:05 PM CBS Tickets | Travel Invesco Field Cincinnati at Seattle 4:05 PM CBS Tickets | Travel Qwest Field NY Giants at Washington 4:15 PM Fox Tickets | Travel FedEx Field Carolina at Atlanta 4:15 PM Fox Tickets | Travel Georgia Dome Dallas at Chicago 8:15 PM NBC Tickets | Travel Soldier Field MON, SEP 24 TIME (ET) TV RESOURCES LOCATION Tennessee at New Orleans 8:30 PM ESPN Tickets | Travel Superdome Week 4 SUN, SEP 30 TIME (ET) TV RESOURCES LOCATION Green Bay at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Oakland at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium NY Jets at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Houston at Atlanta 1:00 PM CBS Tickets | Travel Georgia Dome Chicago at Detroit 1:00 PM Fox Tickets | Travel Ford Field Baltimore at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium St. Louis at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Carolina 4:05 PM Fox Tickets | Travel Bank of America Stadium Seattle at San Francisco 4:05 PM Fox Tickets | Travel Monster Park Kansas City at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium Pittsburgh at Arizona 4:15 PM CBS Tickets | Travel Cardinals Stadium Denver at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome Philadelphia at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium MON, OCT 1 TIME (ET) TV RESOURCES LOCATION New England at Cincinnati 8:30 PM ESPN Tickets | Travel Paul Brown Stadium · Bye: Tennessee, New Orleans, Washington, Jacksonville Week 5 SUN, OCT 7 TIME (ET) TV RESOURCES LOCATION Miami at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Atlanta at Tennessee 1:00 PM Fox Tickets | Travel LP Field Jacksonville at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium NY Jets at NY Giants 1:00 PM CBS Tickets | Travel Giants Stadium Carolina at New Orleans 1:00 PM Fox Tickets | Travel Superdome Arizona at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Cleveland at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Seattle at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field Detroit at Washington 1:00 PM Fox Tickets | Travel FedEx Field Tampa Bay at Indianapolis 4:05 PM Fox Tickets | Travel RCA Dome San Diego at Denver 4:15 PM CBS Tickets | Travel Invesco Field Baltimore at San Francisco 4:15 PM CBS Tickets | Travel Monster Park Chicago at Green Bay 8:15 PM NBC Tickets | Travel Lambeau Field MON, OCT 8 TIME (ET) TV RESOURCES LOCATION Dallas at Buffalo 8:30 PM ESPN Tickets | Travel Ralph Wilson Stadium · Bye: Cincinnati, Oakland, Minnesota, Philadelphia Week 6 SUN, OCT 14 TIME (ET) TV RESOURCES LOCATION Minnesota at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Miami at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Washington at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Cincinnati at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Tennessee at Tampa Bay 1:00 PM CBS Tickets | Travel Raymond James Stadium St. Louis at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium Houston at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Philadelphia at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium Carolina at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Oakland at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium New England at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium New Orleans at Seattle 8:15 PM NBC Tickets | Travel Qwest Field MON, OCT 15 TIME (ET) TV RESOURCES LOCATION NY Giants at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome · Bye: Buffalo, Denver, Detroit, Indianapolis, Pittsburgh, San Francisco Week 7 SUN, OCT 21 TIME (ET) TV RESOURCES LOCATION Tennessee at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Baltimore at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Minnesota at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Detroit 1:00 PM Fox Tickets | Travel Ford Field Arizona at Washington 1:00 PM Fox Tickets | Travel FedEx Field San Francisco at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium Atlanta at New Orleans 1:00 PM Fox Tickets | Travel Superdome New England at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Kansas City at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum NY Jets at Cincinnati 4:05 PM CBS Tickets | Travel Paul Brown Stadium Chicago at Philadelphia 4:15 PM Fox Tickets | Travel Lincoln Financial Field St. Louis at Seattle 4:15 PM Fox Tickets | Travel Qwest Field Pittsburgh at Denver 8:15 PM NBC Tickets | Travel Invesco Field MON, OCT 22 TIME (ET) TV RESOURCES LOCATION Indianapolis at Jacksonville 8:30 PM ESPN Tickets | Travel ALLTEL Stadium · Bye: Cleveland, Green Bay, San Diego, Carolina Week 8 SUN, OCT 28 TIME (ET) TV RESOURCES LOCATION Indianapolis at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium Cleveland at St. Louis 1:00 PM CBS Tickets | Travel Edward Jones Dome NY Giants at Miami 1:00 PM Fox Tickets | Travel Philadelphia at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Pittsburgh at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Detroit at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Oakland at Tennessee 1:00 PM CBS Tickets | Travel LP Field Buffalo at NY Jets 4:05 PM CBS Tickets | Travel Giants Stadium Jacksonville at Tampa Bay 4:05 PM CBS Tickets | Travel Raymond James Stadium Houston at San Diego 4:05 PM CBS Tickets | Travel Qualcomm Stadium New Orleans at San Francisco 4:15 PM Fox Tickets | Travel Monster Park Washington at New England 4:15 PM Fox Tickets | Travel Gillette Stadium MON, OCT 29 TIME (ET) TV RESOURCES LOCATION Green Bay at Denver 8:30 PM ESPN Tickets | Travel Invesco Field · Bye: Atlanta, Dallas, Kansas City, Arizona, Seattle, Baltimore Week 9 SUN, NOV 4 TIME (ET) TV RESOURCES LOCATION Denver at Detroit 1:00 PM CBS Tickets | Travel Ford Field San Francisco at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome Cincinnati at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Carolina at Tennessee 1:00 PM Fox Tickets | Travel LP Field Green Bay at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium San Diego at Minnesota 1:00 PM CBS Tickets | Travel Metrodome Jacksonville at New Orleans 1:00 PM CBS Tickets | Travel Superdome Washington at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium Arizona at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Seattle at Cleveland 4:05 PM Fox Tickets | Travel Cleveland Browns Stadium New England at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome Houston at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum Dallas at Philadelphia 8:15 PM NBC Tickets | Travel Lincoln Financial Field MON, NOV 5 TIME (ET) TV RESOURCES LOCATION Baltimore at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field · Bye: Chicago, St. Louis, Miami, NY Giants Week 10 SUN, NOV 11 TIME (ET) TV RESOURCES LOCATION Cleveland at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Philadelphia at Washington 1:00 PM Fox Tickets | Travel FedEx Field Atlanta at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium St. Louis at New Orleans 1:00 PM Fox Tickets | Travel Superdome Buffalo at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Denver at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Jacksonville at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Cincinnati at Baltimore 4:05 PM CBS Tickets | Travel M&T Bank Stadium Dallas at NY Giants 4:15 PM Fox Tickets | Travel Giants Stadium Detroit at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium Chicago at Oakland 4:15 PM Fox Tickets | Travel McAfee Coliseum Indianapolis at San Diego 8:15 PM NBC Tickets | Travel Qualcomm Stadium MON, NOV 12 TIME (ET) TV RESOURCES LOCATION San Francisco at Seattle 8:30 PM ESPN Tickets | Travel Qwest Field · Bye: New England, NY Jets, Tampa Bay, Houston Week 11 SUN, NOV 18 TIME (ET) TV RESOURCES LOCATION Cleveland at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium San Diego at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Miami at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field Pittsburgh at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium Oakland at Minnesota 1:00 PM CBS Tickets | Travel Metrodome Kansas City at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Carolina at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Washington at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome New Orleans at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium New England at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Arizona at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium NY Giants at Detroit 4:15 PM Fox Tickets | Travel Ford Field St. Louis at San Francisco 4:15 PM Fox Tickets | Travel Monster Park Chicago at Seattle 8:15 PM NBC Tickets | Travel Qwest Field MON, NOV 19 TIME (ET) TV RESOURCES LOCATION Tennessee at Denver 8:30 PM ESPN Tickets | Travel Invesco Field Week 12 THU, NOV 22 TIME (ET) TV RESOURCES LOCATION Green Bay at Detroit 12:30 PM Fox Tickets | Travel Ford Field NY Jets at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium Indianapolis at Atlanta 8:15 PM NFL Tickets | Travel Georgia Dome SUN, NOV 25 TIME (ET) TV RESOURCES LOCATION Seattle at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Minnesota at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium Buffalo at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium New Orleans at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Washington at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Houston at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Tennessee at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Denver at Chicago 1:00 PM CBS Tickets | Travel Soldier Field Oakland at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium San Francisco at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Baltimore at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium Philadelphia at New England 8:15 PM NBC Tickets | Travel Gillette Stadium MON, NOV 26 TIME (ET) TV RESOURCES LOCATION Miami at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field Week 13 THU, NOV 29 TIME (ET) TV RESOURCES LOCATION Green Bay at Dallas 8:15 PM NFL Tickets | Travel Texas Stadium SUN, DEC 2 TIME (ET) TV RESOURCES LOCATION San Diego at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Houston at Tennessee 1:00 PM CBS Tickets | Travel LP Field Jacksonville at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Buffalo at Washington 1:00 PM CBS Tickets | Travel FedEx Field San Francisco at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Detroit at Minnesota 1:00 PM Fox Tickets | Travel Metrodome NY Jets at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Atlanta at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Seattle at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Tampa Bay at New Orleans 1:00 PM Fox Tickets | Travel Superdome Cleveland at Arizona 4:05 PM CBS Tickets | Travel Cardinals Stadium Denver at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum NY Giants at Chicago 4:15 PM Fox Tickets | Travel Soldier Field Cincinnati at Pittsburgh 8:15 PM NBC Tickets | Travel Heinz Field MON, DEC 3 TIME (ET) TV RESOURCES LOCATION New England at Baltimore 8:30 PM ESPN Tickets | Travel M&T Bank Stadium Week 14 THU, DEC 6 TIME (ET) TV RESOURCES LOCATION Chicago at Washington 8:15 PM NFL Tickets | Travel FedEx Field SUN, DEC 9 TIME (ET) TV RESOURCES LOCATION Carolina at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium NY Giants at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Pittsburgh at New England 1:00 PM CBS Tickets | Travel Gillette Stadium St. Louis at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium Tampa Bay at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium Miami at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Oakland at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field Dallas at Detroit 1:00 PM Fox Tickets | Travel Ford Field San Diego at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at San Francisco 4:05 PM Fox Tickets | Travel Monster Park Arizona at Seattle 4:05 PM Fox Tickets | Travel Qwest Field Cleveland at NY Jets 4:15 PM CBS Tickets | Travel Giants Stadium Kansas City at Denver 4:15 PM CBS Tickets | Travel Invesco Field Indianapolis at Baltimore 8:15 PM NBC Tickets | Travel M&T Bank Stadium MON, DEC 10 TIME (ET) TV RESOURCES LOCATION New Orleans at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome Week 15 THU, DEC 13 TIME (ET) TV RESOURCES LOCATION Denver at Houston 8:15 PM NFL Tickets | Travel Reliant Stadium SAT, DEC 15 TIME (ET) TV RESOURCES LOCATION Cincinnati at San Francisco 8:15 PM NFL Tickets | Travel Monster Park SUN, DEC 16 TIME (ET) TV RESOURCES LOCATION Jacksonville at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Atlanta at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Seattle at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Green Bay at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Baltimore at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium NY Jets at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Arizona at New Orleans 1:00 PM Fox Tickets | Travel Superdome Buffalo at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Tennessee at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Indianapolis at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum Detroit at San Diego 4:15 PM Fox Tickets | Travel Qualcomm Stadium Philadelphia at Dallas 4:15 PM Fox Tickets | Travel Texas Stadium Washington at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium MON, DEC 17 TIME (ET) TV RESOURCES LOCATION Chicago at Minnesota 8:30 PM ESPN Tickets | Travel Metrodome Week 16 THU, DEC 20 TIME (ET) TV RESOURCES LOCATION Pittsburgh at St. Louis 8:15 PM NFL Tickets | Travel Edward Jones Dome SAT, DEC 22 TIME (ET) TV RESOURCES LOCATION Dallas at Carolina 8:15 PM NFL Tickets | Travel Bank of America Stadium SUN, DEC 23 TIME (ET) TV RESOURCES LOCATION Oakland at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Washington at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Miami at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Philadelphia at New Orleans 1:00 PM Fox Tickets | Travel Superdome Kansas City at Detroit 1:00 PM CBS Tickets | Travel Ford Field Cleveland at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Green Bay at Chicago 1:00 PM Fox Tickets | Travel Soldier Field NY Giants at Buffalo 1:00 PM Fox Tickets | Travel Ralph Wilson Stadium Houston at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Atlanta at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Baltimore at Seattle 4:15 PM CBS Tickets | Travel Qwest Field NY Jets at Tennessee 4:15 PM CBS Tickets | Travel LP Field Tampa Bay at San Francisco 8:15 PM NBC Tickets | Travel Monster Park MON, DEC 24 TIME (ET) TV RESOURCES LOCATION Denver at San Diego 8:00 PM ESPN Tickets | Travel Qualcomm Stadium Week 17 SAT, DEC 29 TIME (ET) TV RESOURCES LOCATION New England at NY Giants 8:15 PM NFL Tickets | Travel Giants Stadium SUN, DEC 30 TIME (ET) TV RESOURCES LOCATION Buffalo at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field Cincinnati at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Pittsburgh at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium Dallas at Washington 1:00 PM Fox Tickets | Travel FedEx Field Carolina at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Tennessee at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome New Orleans at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Jacksonville at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Seattle at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome Detroit at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field San Francisco at Cleveland 1:00 PM Fox Tickets | Travel Cleveland Browns Stadium Minnesota at Denver 4:15 PM Fox Tickets | Travel Invesco Field San Diego at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum St. Louis at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium if not go to http://sports.espn.go.com/nfl/schedule?campaign=PSGeneral Kansas City at NY Jets 8:15 PM NBC Tickets | Travel Giants Stadium |
Mexico,
DF
Mexico
Post Number: 249 Registered: Jul-07
| Posted on Sunday, October 14, 2007 - 06:20 pm: |
LK, no speak English here. |
Post Number: 12870 Registered: Jan-06
| Posted on Sunday, October 14, 2007 - 06:29 pm: |
Bronze Member Username: Balcano
Monterrey,
Nuevo Leon
Mexico
Post Number: 88 Registered: Oct-06
| Posted on Sunday, October 14, 2007 - 06:45 pm: |
AYUDA PLEASE !!! Hola a todos ya tenia tiempo sin postear pero siempre que puedo los leo, es una lastima como se ha transformado este foro, antes no habia tantas broncas, epero que se soluciones sus diferencias y no tengamos que cambiarle el nombre del foro a "SOLO BRONCAS" A lo FTA: Tengo un problema con un TECHNOSAT 1010 hasta ayer estaba funcionando bien solo que se inhibio lo apague del boton de atras me espere un poco lo volvi a encender. El problema es que se borraron todas las keys incluyendo las del cajon M1 y X1 y pues aunque le ponga las llaves del cajon 00 y 01 no se ven los canales de $ solo libres Alguien que sepa cuales son las llaves que lleva en dichos cajones ???? Ya busque bastante en internet y ya he puesto unas que encontre y nada Ojala puedan Ayudarme Saludos a todos espero y esten bien |
Monterrey,
Nuevo Leon
Mexico
Post Number: 89 Registered: Oct-06
| Posted on Sunday, October 14, 2007 - 06:58 pm: |
aca la imagen |
Gold Member Username: Juancho
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1533 Registered: Dec-06
| Posted on Sunday, October 14, 2007 - 07:09 pm: |
maximus, ponle el bin otra vez. es todo, facil y simple |
Monterrey,
Nuevo Leon
Mexico
Post Number: 90 Registered: Oct-06
| Posted on Sunday, October 14, 2007 - 07:16 pm: |
Juan ya lo havia pensado el problema esque no tengo el cable Null, solo consigo prestado el cable (Straight through) para un lava3200 que tengo jalando y tengo entendido no son iguales Esa sera la unica opcion conseguir el cable null ??? gracias por responder Saludos |
Bronze Member Username: Josh85
Gordon,
PA
Post Number: 12 Registered: Oct-07
| Posted on Sunday, October 14, 2007 - 07:20 pm: |
I just made pÖÖp. |
Silver Member Username: Nica
Matagalpa,
Matagalpa
Nicaragua
Post Number: 193 Registered: Dec-06
| Posted on Sunday, October 14, 2007 - 07:21 pm: |
Dish ------------01 01 00------------ 21 A7 75 45 15 52 4B 1C D7 B0 51 69 62 EC B7 CC 90 E1 49 4F BF 57 04 DF D8 06 51 15 75 A6 97 75 Bev ------------09 01 00------------ 59 98 07 83 BE 02 78 4D 75 1B D5 71 B9 E3 DA 0F 2B E1 34 1C 37 14 A7 D4 07 0C E7 AC D2 2F 57 2E |
Mexico,
DF
Mexico
Post Number: 262 Registered: Jul-07
| Posted on Sunday, October 14, 2007 - 07:22 pm: |
Reporten al pendejete de LK a: admin@ecoustics.com |
Post Number: 1034 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 08:20 pm: |
COMO HA ESTADO COMPADRE JUAN CAVAZOS. |
Post Number: 1035 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 08:30 pm: |
ME GUSTARIA QUE SE DIERA UNOS CAVEZASOS CON EL SUPUESTO CANADIENSE.JAJAJAJAJAJAJAJAJ DICE QUE VA A EMPEZAR LA GUERRA. OK. |
Post Number: 1036 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 08:33 pm: |
THE WAR YEAHHHHHHHHHHHHHHHHHHHHHHHHH. I LIKE IT. MAN. LETS GO. |
Silver Member Username: Garibaldi
Post Number: 145 Registered: Jan-07
| Posted on Sunday, October 14, 2007 - 08:34 pm: |
Hola Raza!!! pues ya tenia dias que no entrba al foro pero miro que aun estan buenas las peleas pero las deven de pasar por PPV para que se ganen una lana y no por esta foro que no es para eso, esta foro es para las personas que queremos aprender algo de FTA pero con esas peleas no se puede.........saludos. |
Post Number: 1037 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 08:35 pm: |
PERO SI NO SE METE ESE YO ME VOY A METER Y LE VOY A TUMBAR LAS TORRES DE SU FORILLO. |
Gordon,
PA
Post Number: 15 Registered: Oct-07
I like tacos. |
Post Number: 1038 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 08:47 pm: |
THE FIRST FIGHT IS BETWEEN LK VS JUAN RAMIREZONE. MY FAVORITE FIGHTER IS LK. YOU CAN WIN THE BATTLE. I PAY 10,000 AMERICAN DOLLARS. YOU ARE WATCHING "SOLO HISPANOS" CHANNEL. |
Gordon,
PA
Post Number: 19 Registered: Oct-07
| Posted on Sunday, October 14, 2007 - 08:52 pm: |
They give me gas though.... |
Post Number: 1039 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 08:54 pm: |
WAR, WAR, WAR, WAR, WAR, WAR, WAR, WAR, WAR, WAR, WAR, WAR, WAR,EAR, WAR. WHERE IS THE BLOOD? WAR. WAR. WAR. LK YOU ARE A SOLDIER. WAR, WAR, WAR, WAR, WAR, WAR, BLOOD, BLOOD, BLOOD, BLOD, BLOOD. BLOOD AND DEATH. JAJAJAJAJAJAJAJAJAJAJAJAJAAJAJJAAJJAJAJAJAJAA. |
Mexico,
DF
Mexico
Post Number: 266 Registered: Jul-07
| Posted on Sunday, October 14, 2007 - 08:59 pm: |
Hola compadre Ernesto M.M. Pues yo bien, gracias, acá en el DF, pero viajando mucho a Guadalajara de trabajo. El señor o señora LK, porque en unos foros le dicen "She", nomas se la pasa chin*gando. Ni sus propios paisanos lo aguantan por ojete. Pero el pendejete se siente dueño de los foros, no se que le pasa. En fin, asi hay gente. Yo ya fui por las caguamas y las botanas para ver la pelea de LK vs. Juan Ramirezone |
Post Number: 1040 Registered: Jun-07
ANDALE JUANCHO NO QUE TE GUSTAN LOS BULYS. JUAN RAMIREZONE. |
Gordon,
PA
Post Number: 20 Registered: Oct-07
| Posted on Sunday, October 14, 2007 - 09:00 pm: |
Post Number: 1041 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 09:02 pm: |
JAJAJAJAJA COMPADRE VA A ESTAR BUENA ESTA PELEA. SALUDOS COMPADRE JUAN CAVAZOS. SI YA SE DE EL. QUE BUENO QUE HA ESTADO BIEN. UN SALUDO PARA USTED. YA SABE QUE SIEMPRE LO HE RESPETADO, TODO ESTO LO EMPEZO JUAN RAMIREZONE. |
Post Number: 1042 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 09:06 pm: |
QUE BIEN COMPADRE JUAN CAVAZOS QUE TENGA MUCHO TRABAJO Y YA SABE QUE DIOS ME LO CUIDE Y ME LO BENDIGA. UN REGIOMONTANO COMO USTED LE DEBE DE IR BIEN Y SABE SE LE EXTRAÑA POR ACA. SALUDOS A USTED. |
Mexico,
DF
Mexico
Post Number: 269 Registered: Jul-07
| Posted on Sunday, October 14, 2007 - 09:09 pm: |
Gracias Ernesto... Igualmente, espero que estés bien por allá, rolandola en Santa Lucía... Oye, si, vi que el Juan Ramizezone anduvo calentando al LK... Por cierto, por ahi hay un post nuevo, de un cuate que dice que cuidado con lo que se escriba, por eso de las demandas. Tu que eres abogado, podrías echarle un ojo. Se refiere a los gringos, pero nunca está por demas. Un abrazo |
Post Number: 1044 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 09:14 pm: |
SI COMPADRE, LO QUE USTED MANDE ESTAMOS A SUS ORDENES. Y TODO BIEN POR SANTA LUCIA. AHORITA VOY PARA AQUEL LUGAR. COMO QUIERA YO LE ECHO UN OJO A ESE POST. SALUDOS COMPADRE Y QUE BUENO QUE VINO A ESTE FORO. AL RATO LO VEO COMPADRE. UN ABRAZO. |
Silver Member Username: Rrios01
Monterrey,
N.L.
Mexico
Post Number: 267 Registered: Oct-06
saludos compadre ernesto como ha estado oiga le agradesco sus palabras del otro dia yo tambien lo estimo mucho y lo considero un amigo si algo aprecio en una persona es que sea congruente y que no ande con puñaladas por la espalda. y hablando de puñaladas o mejor dicho puñales, ese post contra los solo hispanos fue juan ramirezone el que lo inicio el jotillo como siempre actuando por la espalda como esta acostumbrado a llegarle por la espalda a su muedealmuadas el moises quiere ha_cer lo mismo aqui, jajaja, bueno por aqui andamos. saludos javi garza, yo ando miedo pedo para olvidar la derrota de mis tigres y para acabarla tambien mi equipo de la NFL perdio, en lo deportivo no fue mi dia. |
Post Number: 56 Registered: Jul-07
| Posted on Sunday, October 14, 2007 - 09:21 pm: |
Nickk. no te respondi antes, pues estaba viendo el partido Colombia-Brazil. La pregunta que tengo es: el b75 que funciona para el 2700A sirve para el 2500A o existe uno diferente? ya que cuando le pregunte al senor por el system info me dijo que tiene el" x85bl-api294 con el Boot 6.0, Aug 12,07 Future/fta info" y el recibidor esta: "%waiting for picture". Podrias describirme el procedimiento para hacerle el upgrade?, se que lo encuentro en los archivos del post pero realmente no tengo mucho tiempo para buscarlos y te estaria altamente agradecido. En cuanto a la conversion, la decision la toma el dueno del recibidor pues yo solamente trabajo con mi 2700A. Gracias de antemano. Al |
Bronze Member Username: Pureenergy
Post Number: 12 Registered: Jul-06
| Posted on Sunday, October 14, 2007 - 09:22 pm: |
HOLA A TODOS COMO PUEDO REVIVIR 2 PANSATS 2500A ORIGINALES TOTALMENTE MUERTOS REVIVIRLOS SIN JTAG GRACIAS SALUDOS NO PRENDE NADA |
Bronze Member Username: Calin
Post Number: 78 Registered: Jun-06
| Posted on Sunday, October 14, 2007 - 09:27 pm: |
Buenas... noches, amigos foristas. Disculpen la pregunta, por enesima vez, pero no pude encontrar el post con esta informacion. El lugar en donde vivo es una comunidad mayormente chilena y el directorio provee a los inquilinos con la senal de TV Chile, pero como todos sabemos ya DN no la transmite y me han preguntado si se puede ver, en que satelite y con que equipo, mucho agradecere la respuesta de los maestros que por aqui se mantienen ayudando con sus links y conocimientos. gracias por adelantado por la respuesta. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1020 Registered: Oct-06
| Posted on Sunday, October 14, 2007 - 09:30 pm: |
saludos a toda la raza jejeje acabo de llegar de paseo jejeje como va todo x aqi saludos |
Mexico,
DF
Mexico
Post Number: 272 Registered: Jul-07
| Posted on Sunday, October 14, 2007 - 09:44 pm: |
Javier, por acá divertidos, porque Juanramiezone se bonqueó con LK, y el tal o la tal LK nos declaró la guerra a los latinos, mexicanos y habla hispanos. fuera de eso, los tigres perdieron, en Veracruz tumbaron la estatua de Fox y acá en el DF la fórmula uno estuvo buena. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1022 Registered: Oct-06
| Posted on Sunday, October 14, 2007 - 09:45 pm: |
alexandro , conviertelo a 2700 y si no se puede entonces vas a tener q aser jtag con wall |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1023 Registered: Oct-06
| Posted on Sunday, October 14, 2007 - 09:52 pm: |
ia esta juan cavazos saludos y ai aqi estaremos jejeje |
Post Number: 13 Registered: Jul-06
| Posted on Sunday, October 14, 2007 - 09:55 pm: |
javier garza pero como lo convierto si no prende nada saludos |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1024 Registered: Oct-06
| Posted on Sunday, October 14, 2007 - 10:12 pm: |
alexandro priemro asle la conversion aunq no prenda no pierdes nada si no entonces asle jatag con wall |
Post Number: 14 Registered: Jul-06
| Posted on Sunday, October 14, 2007 - 10:21 pm: |
ok |
Post Number: 15 Registered: Jul-06
| Posted on Sunday, October 14, 2007 - 10:22 pm: |
ok lo voy a intentar gracias |
Bronze Member Username: Titu72
Tecate,
Baja california
Mexico
Post Number: 84 Registered: Nov-06
Hola saludos a todos ya no peleen por favor  |
Tecate,
Baja california
Mexico
Post Number: 85 Registered: Nov-06
| Posted on Sunday, October 14, 2007 - 10:26 pm: |
Les pido recuerden por favor la original intencion de este foro en el cual muchos hemos aprendido de los maestros por favor amor y paz saludos a todos |
Tecate,
Baja california
Mexico
Post Number: 86 Registered: Nov-06
| Posted on Sunday, October 14, 2007 - 10:29 pm: |
Bueno es mi humilde opinion se perfectamente que no soy nadie aqui por eso les pido con humildad amor y paz haganlo por los que no sabemos mucho y necesitamos su orientacion y apoyo es muy bonito que al tener una duda sabemos donde encontrar la ayuda por favor que reine la paz feliz domingo |
Post Number: 16 Registered: Jul-06
| Posted on Sunday, October 14, 2007 - 11:07 pm: |
no sirvio javier esta totalmente muertos los 2500a pansat convertidos a 2700a los quise regresar a 2500a pero no hay comunicacion algun otra idea sin jtag saludos |
Post Number: 1045 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 11:13 pm: |
Link to this message psychmonster Silver Member Username: Psychmonster chi town , il USA Post Number: 107 Registered: Jul-06 Posted on Sunday, October 14, 2007 - 12:25 am: I express this to the "Solo Hispanos"......u are only 3 or 4 idiots that keep bullS>>iting amongst yourself. hetor - ERNESTO M. M. javier garza gonzale I want you to keep your crap on your side of the border...this is a link that helps people who are looking for real help via FTA...hetor - ERNESTO M. M. javier garza gonzale ...keep your crap to your self and leave english language links alone and start your own obvious cross border hom o-sex ual love fest between you all or get another "love thread" so that all 4 of u can continue this trist in your native language and not subject us all who are normal english speaking people, you are making my kids take spanish because of PC correctness...I am sick and tired of dialing my bank and asked to speak Mexican (spanish)...you better learn my lanquage...press 1 to kiss my azz Top of pagePrevious messageNext messageBottom of page Link to this message psychmonster Silver Member Username: Psychmonster chi town , il USA Post Number: 108 Registered: Jul-06 Posted on Sunday, October 14, 2007 - 12:53 am: just to get this tread started Top of pagePrevious messageNext messageBottom of page Link to this message ERNESTO M. M. Gold Member Username: Nadadesat Post Number: 1030 Registered: Jun-07 Posted on Sunday, October 14, 2007 - 02:37 am: jajajajajajajajaj ga¨*y. Top of pagePrevious messageNext messageBottom of page Link to this message Bo Arizpe Bronze Member Username: Shadow45 Monterrey , Nuevo Leon Mexico Post Number: 85 Registered: Aug-07 Posted on Sunday, October 14, 2007 - 04:37 am: wow, take it easy psycho, I do agree that some people that have started to mess up the SOLO HISPANOS thread should get kicked/banned from there/here. But thats about it, whatever the agreement was to have a spanish thread here shouldn´t "make" anyone´s kids take spanish lessons, lol. And no, it isn´t "only 4 people" posting in that thread there are a lot more, the fact that some idiots like to make 20 million posts of worthless bullsh*it doesn´t necessarly mean that´s it. And just a sugestion , if you don´t like that your bank has the "spanish"(not mexican) option in their prompts, well simple as switching to another bank or typing an e-mail to complaint about it....and uh, that would be to THEIR head office. Top of pagePrevious messageNext messageBottom of page Link to this message JJJ Bronze Member Username: Jrpistonsfan Post Number: 61 Registered: Jun-06 Posted on Sunday, October 14, 2007 - 09:24 am: lol you are really psycho man.... Add Your Message Here |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1025 Registered: Oct-06
| Posted on Sunday, October 14, 2007 - 11:14 pm: |
alexandro ai q aserle jtag con wall (con el cable jtag) |
Post Number: 1046 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 11:15 pm: |
QUE ONDA COMPADRE CHINO, FUI A DAR UNA VUELTA A SANTA LUCIA, FUE RAPIDO. PUES ME QUEDE DE VER CON UNAS PERSONAS PARA LOS BOLETOS DE UNOS EVENTOS. SALUDOS A USTED. YO PIENSO QUE CON EL RESPALDO DE MI COMPADRE JUAN CAVAZOS TENEMOS. |
Post Number: 17 Registered: Jul-06
| Posted on Sunday, October 14, 2007 - 11:19 pm: |
javier me pudes explicar jatag ya se que es pero con wall que es porfa |
Tecate,
Baja california
Mexico
Post Number: 87 Registered: Nov-06
| Posted on Sunday, October 14, 2007 - 11:31 pm: |
Hola saludos a todos ¿que lnb es el mejor para dish?} |
Post Number: 1047 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 11:40 pm: |
jajajajajaja COMPADRES JUAN CAVAZOS Y EL CHINO , YA LOS VI TIRANDOLE AL LK, EN EL FORO AMERICANO. POR ESO: MEXICANOS AL GRITO DE GUERRA EL ACERO APRESTAD Y EL BRIDON Y RETIEMBLE EN SUS CENTROS LA TIERRA, AL SONORO RUGIR DEL CAÑON. .... MAS SI OSARE UN EXTRAÑO ENEMIGO PROFANAR CON SU PLANTA TU SUELO. PIENSA, OH PATRIA QUERIDA QUE EL CIELO UN SOLDADO EN CADA HIJ*O TE DIO. ESTAMOS LISTOS. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1026 Registered: Oct-06
fco javier el lnb mejor p dis es el circular osea este o como este  |
Post Number: 1048 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 11:42 pm: |
TAMBIEN CONTRA EL PINCHE JOTO DEL JUAN RAMIREZONE. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1027 Registered: Oct-06
| Posted on Sunday, October 14, 2007 - 11:46 pm: |
ai va alexandro el jtag |
Post Number: 1049 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 11:53 pm: |
PINCHE JUAN RAMIREZONE ERES UN PINCHE RETRASADO MENTAL, VETE A CHINGAR A TODA TU MADRE OJETE, TU Y TODOS TUS PINCHES LEANDROS QUE TIENES. YA QUE VALGA MADRE ESTO. |
Post Number: 1050 Registered: Jun-07
| Posted on Sunday, October 14, 2007 - 11:56 pm: |
ESE GUEY NO ES CANADIENSE VIVE EN MEXICO EN UN PINCHE RANCHO, ANDA DESCALZO Y PIDIENDO QUE LE DEN DE TRAGAR DE CASA EN CASA, ES UN PINCHE MUERTO DE HAMBRE. |
Silver Member Username: Ricky_nauta
Post Number: 197 Registered: Aug-06
| Posted on Sunday, October 14, 2007 - 11:59 pm: |
javier garza Me regalaron un Pansat 2700a como nuevo, supuestamente original y lo maté en tiempo record. je je je Le instalé el 217 y duró como dos horas funcionando de maravillas pero luego se murió y cuando digo se murió es muerto bien muerto. Ni una sola lucecita enciende. Lo que quería preguntar a ti o cualquier otro de los gurus es: ¿En tu opinión a que crees que se deba esa muerte subita? ¿No era original? ...y la pregunta mas importante: Un receptor que no da muestras de vida, (ni una sola luz) crees que pueda ser devuelto a la vida de alguna manera? Saludos y gracias por adelantado. |
Post Number: 18 Registered: Jul-06
| Posted on Monday, October 15, 2007 - 12:08 am: |
ok javier voy a estudiarlo para crear el jtag gracias por la ayuda saludos a todos y ya no se peleen recuerden que ustedes son los que nos ayudan a nosotros los que casi no entendemos de estas cosas de programacion, yo los he estado siguiendo desde mucho como año y medio y siempre han estado unidos si los gringos pelean es mejor ignorarlos para no entrar en su juego,,,,saludos desde tijuana baja cal. mexico |
Post Number: 198 Registered: Aug-06
| Posted on Monday, October 15, 2007 - 12:11 am: |
No me he querido involucrar en este conflicto donde se está llegando a muy bajo nivel, pero tengo que decir que es muy triste que unos pocos estén llevando este foro que tanta ayuda a brindado a muchos de nosotros por un camino que inevitablemente conducirá a su cierre, pero bueno, que le vamos a h.acer, demasiado habían tardado en aparecer los que no les importa que los demas perdamos este espacio con tal de drenar aqui sus envidias y frustraciones. Hay que tener muy poco cerebro para no darse cuenta que atacando a los gringos en este espacio los que podemos salir perdiendo somos nosotros, porque cierran esto y el daño al final va a ser para todos los latinos que aquí compartimos información. ¿O será que esa es la intención de fondo? Que cierren este foro. Vamos muchachos, les pido humildemente que recapaciten y si les es posible y tienen una vida que no gire exclusivamente en torno a este foro, retirense por un tiempo a tomar aire fresco para que regresen aliviados de tanto veneno y no provoquen que a los que no nos interesan sus rencillas personales perdamos este espacio. Están dando una pésima imagen de su país y su cultura, no lo dañen más de lo que ya lo han hecho. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1028 Registered: Oct-06
| Posted on Monday, October 15, 2007 - 12:22 am: |
MIRA RIKI NAUTA EN MI OPINION IO NUNCA ME MUERO EN EL INSTANTE IO LUCHO ASTA EL FINAL JEJEJE Y SI , TE DIGO Q SE PUEDE INTENTAR Y CHANCE Y UNAS DE LAS PROBABILIDADES TE FAVOR3SCA ESTA CON MAUSER X ESO INTENTA TODO Y SI NO QUIERES ASI PS NOMAS ASLE JTAG CON WALL Y LISTO. SALUDOS |
Post Number: 1051 Registered: Jun-07
| Posted on Monday, October 15, 2007 - 12:30 am: |
BIEN RICKY NAUTA, ESTA BIEN LO QUE DICES Y TAMBIEN LO QUE DICE EL OTRO COMPAÑERO, ALEJANDRO SICARIOS Y FRANCISCO JAVIER, PERO ES QUE DA CORAJE QUE UNA PERSONA QUE SE DICE MUY INTELIGENTE Y SE CREE DIOS, QUIERA ENSEÑARNOS A CAMINAR, TU YA SABES A QUIEN LE ESTOY TIRANDO, PERO A ESE YA LO HAN CORRIDO DE MUCHOS LUGARES. YO RESPETO A VARIOS. MAESTROS DE AQUI, PERO ESE NO TIENE PARA QUE DIGO, ANDA PONIENDO TRAMPAS JUNTO CON SUS AMIGOS, EL ES EL VWERDADERO CULPABLE. Y DEJA QUE VENGAN LOS GRINGOS, NI APOYO TIENEN, NOMAS ECHALE UNA HOJEADA A SU FORO. BUENO A LOS QUE VIENEN A AMENAZAR AQUI. JUNTO CON EL MEXICANO QUE SE CREE CANADIENSE. SALUDOS A TI. |
Post Number: 199 Registered: Aug-06
| Posted on Monday, October 15, 2007 - 12:34 am: |
OK. Voy a buscar la información del JTAG para intentarlo y luego te cuento. Y comparto tu opinión de luchar hasta el final, por eso mismo ando buscando información sobre lo qué se puede h.acer para revivirlo(el que se murió fue el receptor. Mejor dicho, lo maté je je je) Saludos y gracias por tan pronta respuesta. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1029 Registered: Oct-06
| Posted on Monday, October 15, 2007 - 12:41 am: |
ALGO DE JTAG  2.8 K | JTAG.txt "Upload" | | |
New member Username: Packacartier
Post Number: 7 Registered: Oct-07
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1030 Registered: Oct-06
| Posted on Monday, October 15, 2007 - 12:46 am: |
OK ALGO DE JTAG |
Post Number: 200 Registered: Aug-06
| Posted on Monday, October 15, 2007 - 12:57 am: |
Bueno Ernesto, por lo menos estás dejando claro que es posible dialogar. Ya eso es algo positivo. Te propongo algo con mucho respeto y humildad: Es evidente que tienes claro que este foro fue creado para compartir información del tema que a todos los que estamos aquí nos interesa, es decir, tener funcionando lo mejor que sea posible los receptores de satélite (supuestamente FTA) ¿Qué te parece si nos dedicamos exclusivamente a ese tema y evitamos entrar en discusiones en el terreno personal, ni los problemas de tipo político o sociales de nuestras naciones latinas? Con eso le haríamos un gran favor a quienes vienen a este foro a buscar información sobre "FTA" y al mismo tiempo de esa manera no caemos en la confrontación ni conflictos por diferencias de opiniones. Esos temas además de ser ajenos al objetivo del foro, por otro lado nos hace más difícil encontrar la información que a veces buscamos. Entonces ¿Estarías de acuerdo en dejar el conflicto hasta donde llegó y dedicarnos a FTA? Existen miles de foros de muchos otros temas donde pueden confrontar sus diferencias, les pido en nombre de muchísima gente que acostumbra leer y no intervienen que no desvíen más la temática a cosas que no tienen nada que ver con FTA. Y aclaro que yo no soy nadie para venir a pretender decirle a los demás que h.acer y que no, pero te aseguro que muchos les vamos a agradecer que nos centremos en el tema que nos interesa y de esa manera evitemos que cierren esto. Un saludo para ti también y gracias por responder. |
Post Number: 1052 Registered: Jun-07
| Posted on Monday, October 15, 2007 - 01:01 am: |
OHHHHHHHHHH A YELLOW BUS, GREAT NEWS. GO AWAY MAN. NOBODY NEED YOUR HELP. PLZ. |
Post Number: 1053 Registered: Jun-07
| Posted on Monday, October 15, 2007 - 01:05 am: |
OK RICKY NAUTA.ESTA BIEN AMIGO. DESDE AHORA NADA DE DIALOGOS DIVERSOS AL FORO, A MENOS QUE SEA EN DEFENSA PROPIA. AUNQUE YO CREO QUE EL FORO SE VA A QUEDAR SOLO. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1031 Registered: Oct-06
| Posted on Monday, October 15, 2007 - 01:06 am: |
WENO LA AGRESION Q ESTAMOS PASANDO AI Q TOMARLA COMO UN PASATIEMPO LA GENTE CUANDO SE VE EN PELIGRO O ACORRALADA (EN ESTE CASO INFERIOR IA SEA EN NUMEROS O EN ESTADISTICASS EMPIEZA A AGREDIR A LOS Q ESTAMOS BIEN X ESO ,MANTENGANSE TRANQUILOS NO PASA NADA TODOS LO Q PASA VA A PASAR JEJEJE IA ESTA SALU8DOS. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1032 Registered: Oct-06
| Posted on Monday, October 15, 2007 - 01:10 am: |
COMO ESTA SR LIC IA ESTA EN PIE DE GUERRA O Q JAJAJAJA SALUDOS. |
MONTERREY ,
NUEVO LEON
Mexico
Post Number: 1033 Registered: Oct-06
| Posted on Monday, October 15, 2007 - 01:18 am: |
A I STO V A X NUESTRA SELECCION Q PERDIO HOI ,HOI
