Thread: Norcent Plasma |
New member Username: Gwb
Post Number: 2 Registered: Oct-07
| Posted on Monday, October 15, 2007 - 01:48 pm: |
I have had a Norcent PT4231 for several years now. A while back, the screen simply went blank. The sound is still there, just no picure. I have gotten no support from the company and no service centers in my area will touch the unit because they consider it an "off brand". Is there anything I can do to possibly troubleshoot and repair it myself or am I stuck? Thanks in advance. |
Silver Member Username: Rysa3
Houston, Texas
Post Number: 232 Registered: Nov-06
| Posted on Tuesday, October 16, 2007 - 07:08 pm: |
I do not recall if the Norcent brand is still being sold actually. A plasma is really three components put together; electronics, glass and power supply. You have an electronics problem. Since plasmas at 42 inches are now under 1 grand, you have to weigh how much expense you want to put into this. As far sa a DYI approach, you could open the back and look at the boards and try and observe for a fried capacitor or something obvious. If you find it, youd then have to get that board and replace. This is a guess. |
Post Number: 3 Registered: Oct-07
| Posted on Tuesday, October 16, 2007 - 07:58 pm: |
I'll look into it. Thanks. I will also post any findings of substance. |
