Thread: VCR Recording |
New member Username: Shannama
Seattle,
Wa
Post Number: 1 Registered: Oct-07
| Posted on Friday, October 12, 2007 - 10:57 pm: |
I have an Insignia NS-DVDVCR and a Westinghouse SK-19H210S tv. I can watch dvd's and vcr tapes, but I can't record from my basic tv. When I try to record all I get is a blue screen. I do not have a cable box to connect anything to and my vcr doesn't allow me to change channels on it. Would an s-video cable fix this? There's a place to connect one on my vcr/dvd that says s-video out and a corresponding connection on my tv.} |
Relevant Product Info
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 1840 Registered: Feb-04
| Posted on Sunday, October 14, 2007 - 05:46 pm: |
Shannon, by now you have probably found out that your Insignia doesn't have a tuner. The only thing it's good for is playing DVDs and tapes. If that Westinghouse TV has A/V line outputs you could record from those, but the TV will have to be powered up and you can't watch anything else at the same time. |
New member Username: Jimjams
Mobile,
AL
U.S.
Post Number: 1 Registered: Dec-07
| Posted on Monday, December 24, 2007 - 02:58 pm: |
Have a Magnavox VCR model MVR4440 I am trying to use for surveillance recording...can't figure out how to reset for 8hr tape or EP mode...any suggestions? |
Columbus,
Ohio
US
Post Number: 1984 Registered: Feb-04
| Posted on Tuesday, December 25, 2007 - 09:06 am: |
Jim, the speed selector should be on the VCR's remote. If you don't have the original remote control, you'll have to find a suitable replacement because there's no other way to change the record speed. Only T-160 cassettes will yield 8 hours record time on the SLP (EP) record speed. |
New member Username: Lily_m
Post Number: 1 Registered: Jan-08
| Posted on Saturday, January 19, 2008 - 05:46 pm: |
I have a sanyo VCR,it's a VHR-M467 model, to wich I have lost the user's mannuel. Iwas wondering if you can program the recording so it'll start on it's own. And if so how to do it. |
Columbus,
Ohio
US
Post Number: 2069 Registered: Feb-04
| Posted on Wednesday, January 23, 2008 - 07:22 am: |
Lily, hopefully you didn't lose the VCR's original remote control. That remote has a "PROGRAM" button on it that brings up the on-screen programming you need for timer recording. Can you set the clock to the correct time? |
New member Username: Davisgilbert
Post Number: 1 Registered: Jun-08
| Posted on Sunday, June 29, 2008 - 11:14 am: |
I’ve just hooked up my digital to analog converter box MicroGem2000 to my outside antenna, then to my Toshiba W-528 VCR, which is then hooked up to my Sharp TV (model #27F543). Though the HD reception (as well as range of "new" stations) is impressive, here is my problem: I cannot program my VCR to record the HD stations. When I set the VCR to record it brings in the non-HD channels, which are barely viewable. Is there some way to program the VCR to capture the HD images? Thanks for your help in this vexing matter. G.R.Davis |
Gold Member Username: Samijubal
Post Number: 3876 Registered: Jul-04
| Posted on Sunday, June 29, 2008 - 11:47 am: |
Connect the converter box to the VCR with RCA cables and set the VCR to line. |
