Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through October 03, 2007
Author Thread: Archive through October 03, 2007
Username: Jowhar
Post Number: 116
hi
Username: Lklives
Post Number: 12333
Vista works fine...U just need to be aware and careful of your Security seetings and antivirus type programs, when DL files from various sites.....
Username: Jjnelly
Thanks for your help
Username: Abbasusa77
Post Number: 14
keys for dish plzzzzzzzzzzzzzzzzzzzzzz......
Username: Mkvl1490
Post Number: 124
where can i get the channel master from
Username: Demon101
Rochester , Ny
America
Post Number: 54
does anyone got the keys for globecast?
Username: Mkvl1490
Post Number: 125
http://www.dss-keys.c o m/
always go there for the keys
Username: Jjnelly
Are you still able to use the old atmega 128 cards or are these recivers good paper weights? Just wondering I have FTA but wanted to use the other reciver in the kids play room. I used to have private skript on this system but would rather not go back to that. I am wondering if these are still good and if so were do I find info to flash and program the reciver myself.
Username: Laurad
Post Number: 29
Are there any new keys out for Dish. It just went down. Thanks
Username: Lklives
Post Number: 12346
Keys have NOT changed...same as above and for awhile now...
Atmega files..
http://www.ftaprosupport.com/forums/forumdisplay.php?f=367
Username: Donnie1973
Post Number: 948
johnny, look at dsstester.c0m
Username: Nydas
Post Number: 3912
jenn :
Right arrow to Entertainment. Do not press OK.
Then
Try 7890
Post Number: 971
http://forum.ecoustics.com/bbs/messages/2/390296.html
for u jenn
Post Number: 973
http://forum.ecoustics.com/bbs/messages/2/390294.html
how to enter keys in all receivers
Username: Jpz
MTL, QC
CAnada
Post Number: 251
hi all
Username: Mikemo
Torrance, California
Usa
hi
new DN key plzzzzz
Username: Nydas
Post Number: 3915
mikeymo : Keys have not changed.
DN Provider ID 0101
Key 00 (86):
2E 79 BB 5B 8D CA A7 23
56 C0 21 A1 0D 90 48 99
Key 01 (96):
43 E5 E1 CC 43 28 D5 02
A2 B6 6F F2 F1 AB 31 82
Username: Ariana_70
Sorel-Tracy, Quebec
Post Number: 97
Username: Demon101
Rochester , Ny
America
Post Number: 55
anyone got globecast keys?
Username: Nydas
Post Number: 3916
THERE ARE NO VALID GC KEYS TILL WE GET NEW BINS
Username: Destine0429
Quebec
Post Number: 287
BEV isn't working at all now. Is it a key problem or is it a bin problem? I have bin jwh_213 on my converted Pansat 2500.
Quebec
Post Number: 288
Ok nevermind, I just shut off the A/R and had to manually enter in the keys for BEV. I thought that bin 213 was A/R
Username: Roxy06
Post Number: 28
what are the keys for BEV? My dish is down and i'd really like to have it working again...any help?
Username: Offline
Post Number: 7
BEV
86: 4D 72 C7 59 38 FE 2D 3F 1D 97 2E 64 68 80 4E 23
96: C5 EE E1 73 65 73 6F 86 19 36 57 2B A6 DB D7 84 New
Username: Jainivas
Hi,
I have Viewsat Extreme receiver, 2 satellites, pointing to 110, 82.5.
I get dish network without any problems...however, I dont get any BEV channels.
I use to get the channels till last week.
The signal is 80% but there is no quality.
I tried changing the frequency in the setup and while doing that i get some quality but it goes away after some time.
any help will be appriciated.
Thanks,
Username: Ddlj
Post Number: 12
hi all,
anyone can tell me how to set up the cricket match series between india australia....which channel which frequency....on dish.
Thanks
Username: Ddlj
Post Number: 13
Anyone here a CRICKET freak....I need Australia and India cricket match series....
Thanks.
Username: Ddlj
Post Number: 14
Can anyone tell me to set up channel 576 on Dish Network.
Thanks.
DDLJ
Username: Lklives
Post Number: 12433
FYI...Bev has NOT changed keys in a VERY long time...these posts above are VERY misleading...Bev is fine..
Username: Crazy_greek
Post Number: 1175
Cricket.... 1st Test
India Vs Australia ...Oct. the 2nd. Tues, 09:00.
ZEE Sports Channel...576
A) EchoStar 3 @ 61.5W (tp12) Freq.
12384 (Pol.H) SR 20,000.
B) EchoStar 7 @ 119.oW (tp21) Freq.12516
(Pol.V) SR 20,000
Username: Nitehawk
New keys for echostar 110?
Username: Nydas
Post Number: 3917
For those who have not scanned Echo 3 recently - ZeeSA (Zee Sports) was not available before and is available now. Use info provide by Kevin above to do a TP scan - or do a blind scan to get all the current channels.
576 is working
Username: Miamihitman09
NEW KEYS PLEASE FOR DISH???
Username: Kiki09
Nalin Nyda... i tried doing what kevin said and u said... but i dont why but the channel 576 zee sports is not coming.....plz... can anyone help me......
Username: Nitehawk
I found by unplugging my receiver for 30 seconds and then reinstalling the same codes for both DISH and BEV they work
nitehawk, How do I get Bev to work as well as Dish? I am in south Florida
Username: Nitehawk
BEV is 91 degrees west using south as 90 degrees. Here the elevation is 30 degrees but there it may be higher, like 35 or 36. Also, I believe the LNB is different for BEV than DISH, but try it. I have 2 dishes that is why I can get both
Post Number: 1186
kiki
Check your Receiver to see if you have
these TPs and Freq.
Username: Kiki09
i do have them, but i dont get the channel...
Username: Lklives
Post Number: 12455
ZEE Sports America ZEESA
channel 576
Transponder(TP) 12 sat 61.5° Echo3 Freq.12384 ...
or on the 119W echo 7 sat on TP 21 Freq.12516
Its there, U just must scan the Transponder or satellite..
Username: Lilmoe
Windsor, Ontario
new keys:86:2E 79 BB 5B 8D CA A7 23 56 C0 21 A1 0D 90 48 99
96:43 E5 E1 CC 43 28 D5 02 A2 B6 6F F2 F1 AB 31 82
Username: Climes
Post Number: 10
hey everyone. i was wondering if there was anyway to get the SUNDAY TICKET working for bev? i have the cool sat 5000. anyone have any advice?
Username: Nydas
Post Number: 3918
Kiki:
Kevin Reno has the correct information regarding Zee sports channel. I will repeat it from his post.
Freq. 12384 (Pol.H) SR 20,000.
B) EchoStar 7 @ 119.0W (tp21)
Freq.12516 (Pol.V) SR 20,000
It should come through doing a Blind scan
Username: Nydas
Post Number: 3920
For those who were inquiring GC keys, Pansat 3500S/SD and Pansat 2800 new autoroll files dated today.
Note that this is a fix for Globecast, and if you are not wanting Globecast, there is no need to upgrade.
http://future-fta.info/Forums/showthread.php?t=61987
(TBL version 330) GlobeCast A/R Fix for Pansat 3500S/SD
TeamBlackList
X-05BL_070929_330_api_NOCARD.zip (461.4 KB)
http://future-fta.info/Forums/showthread.php?t=61986
(TBL version 425) GlobeCast A/R Fixed for Pansat 2800
TeamBlackList
X-88BL_070929_425eubx_api.zip (436.5 KB)
Username: Lklives
Post Number: 12472
yes...Pansat released all NEW Globecast (GC) autorolling bins today except for the 2500 and the 2700...
That should tell u something about the 2700....due to all the 2500-2700 conversions, the 2700 is next not to be supported (I'm sure they will have a GC fix out soon, but for how much longer is limited , IMO)...pansat is NOT happy ith this 2500-2700 conversion...in fact U will be banned from their site for even discussing it!
BTW...www.ftaprosupport.com and www.dsscommunity.c*om have ALL the new globecast bins..and NO traffic!
Username: Climes
Post Number: 11
anybody out there know anything about the NFL sunday ticket for bev? or is it not happening?
thanks
Username: Jainivas
Nalin, once again, same question...
how do i fix BEV quality?
I used to get the channels but all of a sudden it stopped working.
Please help//
Username: Elvirm
Post Number: 8
I don't have picture on my DN, 4 days ago started problems and today I have just NO SIGNAL.
Username: Lklives
Post Number: 12474
matt...no NFL Ticket on Bev for hackers, only subscribers....BUT if U read my "NFL games and channels" thread here, u can get almost every game every week on Dishnet!
Username: Lklives
Post Number: 12476
matt...NFL info here..
http://forum.ecoustics.com/bbs/messages/2/388036.html
Username: Climes
Post Number: 12
LK..thanks for the info. but i only have bev
Username: Nitehawk
Elvim...try unplugging your unit for about 30 seconds then plug it back in to see if that doesn't clear it up...worked for me.
Username: Lklives
Post Number: 12494
NO CHANGES IN AWHILE...FEW DAYS-1 WEEK..
Dish Network (0101)
% [0101][Date]%%
86: 2E 79 BB 5B 8D CA A7 23 56 C0 21 A1 0D 90 48 99 New
96: 43 E5 E1 CC 43 28 D5 02 A2 B6 6F F2 F1 AB 31 82
Bell ExpressVu (0901)
%[0901][Date]%%
86: 9B CE 5C 9B 8B DE A5 ED 1E D3 9E 16 68 73 22 C2 New
Bell ExpressVu PB (0905)
%[0905][Date]%%
86: B7 2F 03 35 70 4A CD B0 6D 43 33 59 92 E2 1D F3
96: D5 51 BA FE 58 50 BE 61 A4 BD 09 F3 54 4F C5 FC
Bell ExpressVu HD (0906)
% [0906][Date]%%
86: 8D 1A 1C F4 2C B9 7F 85 38 65 D6 7A 5D 59 5D 88
96: 11 FE 27 1D 89 9E D3 B4 DB 8E CB C8 10 D3 E7 F7
Bell ExpressVu New Provider ID (0907)
%[0907][Date]%%
86: EE 84 3E 3A 94 18 00 F1 18 2D A7 26 23 DF 85 CD
96: 37 25 BD 57 61 81 A4 92 12 07 F7 67 30 24 3D 9C
Globecast (C101)
% [C101][Date]%%
86: 93 78 EA 2A 8B 7C D9 86 94 96 8D 4B EF A0 15 F6
96: A3 47 8F 1F F3 7E 2C 94 B5 E6 B8 4E 6F 13 B5 25
Username: Lklives
Post Number: 12503
New BEV keys tonite...
Bell ExpressVu (0901) [Last update: Sun. Sep 30, 5:42 PM EST]
Username: Nydas
Post Number: 3922
TeamBlackList
TeamBlackList
Username: Dier
On sat 110 some channels are good and some I can't watch
any one help me?
Username: Ligiuta
Post Number: 16
Nalin, I found the new bin for 2700 for GC Globecast autoroll fixed
X-87BL_070929_B75_215_api_1.zip
NOT for Clones or Converted 2500's...
For Genuine 2700's ONLY! If I download it, is this going to mess up my Dish Net. bin ?
Thank you,
Ligia
Username: Ligiuta
Post Number: 17
Here are the new keys for Globecast. I didn't dowloaded any new bin and it works just fine.
Update: 10/01/07 08:20 pm
00: F5 EC 58 86 8C 5C 28 27 16 08 D8 89 A5 38 7F A3
01: BA 3F A2 8A 22 6A F7 F7 78 C5 28 76 84 D8 D4 93
Username: Lklives
Post Number: 12533
Dish Network (0101) [Last update: Sun. Sep 23, 8:07 PM EST]
Bell ExpressVu (0901) [Last update: Sun. Sep 30, 9:30 PM EST]
Bell ExpressVu PB (0905) [Last update: Thurs. Mar 15, 3:01 AM EST]
Bell ExpressVu HD (0906) [Last update: Thurs. Mar 15, 7:17 PM EST]
Bell ExpressVu New Provider ID (0907) [Last update: Sun. Sep 23, 7:09 PM EST]
Globecast (C101) [Last update: Mon. Oct 1, 10:54 PM EST]
86: F5 EC 58 86 8C 5C 28 27 16 08 D8 89 A5 38 7F A3 New
96: BA 3F A2 8A 22 6A F7 F7 78 C5 28 76 84 D8 D4 93
Username: Nydas
Post Number: 3923
ligia girboan : As long as you are sure you have a Genuine Pansat 2700, you can use the 215 BIN. It will work with GC. If you don not need GC, then you can stay with 213 BIN for DN, or upgrade - either way it will not mess up the DN except that you might have to rescan.
If you have a Pansat 2500 to 2700 conversion, use the jvvh 215 BIN - it is out and is subject of my next post
Username: Nydas
Post Number: 3924
jvvh 215 BIN - good for GC autoroll.
FLU/2500 to 2700 jvvh215 10/01/07 (TESTERS ONLY)
FOR TESTERS ONLY, USE AT YOUR OWN RISK
I tested the jvvh215 A/R on all and D/N
Thanks to jvvh for the bin file
I use the 2700 to 2500 loader on top of the 213 bin no problem
set key default
I added all loaders, 2700 to 2500, BL1.4, and Fortecstar stb 4.0
DO NOT DO FACTORY RESET
Username: Sccrskills
Post Number: 52
does zee sports have soccer on it or no?
Username: Nydas
Post Number: 3926
ZEESA is one of the latest additions to the Echo 3 list, and has mostly cricket etc.
SETA (406) is Sentana sports and has soccer etc. This also is a newly added channel on Echo 3.
I believe there are equivalents at 121W and 148W
Username: Lklives
Post Number: 12549
nice going nalin.....LMAO....maybe if U TESTED something once in awhile, U might KNOW something instead of your BS copy/paste...
Three people have posted here that they had their receivers die with this jvvh 215 bin...and others elsewhere...and NOTHING is said about its OK for GC....even jvvh himself doesn't say its SAFE, and may have a killer bug...
http://www.dssrookie.com/forums/img-src-images-pansat-png-border-0-b-font-color- 0000ee-pansat-font-discussion-b/new-jvvh-release-215-bug-159437.html#post1000654
Username: Dr_dss
Yeah coming from the person who copy&pasted the cell phone don't call list Hoax really means alot.
Both of you only as good as your key boards crtl c crtl v keys.
Username: Nydas
Post Number: 3931
There was a bug in the original release by jvvh for converted recivers, i.e. receivers converted from 2500, clones and from FLU. It has apparently been fixed.
http://www.dssrookie.com/forums/b-font-color-cd2626-ultra-files-font-b/flu-2500- to-2700-jvvh215-10-01-07-testers-only-159460.html
Bug fix for 2.15 2500 convert
Fix for the prev 215 release--there was a bug that did not defeat a bomb.
Sorry did not catch it--it is initiated by a key roll, so if your box has not had a key update just load this bin and you will be OK. If you have had a key update then your boot code is overwitten and if your box is still running then load a boot, if box is not running then it is jtag time.
jvvh_215_pTd_1.ZIP (420.2 KB)
Username: Lklives
Post Number: 12556
Nalin is NOT a tester...which she has admitted here many times....I don't think she even owns a FTA receiver....she has KILLED many receivers over the past year....and will continue to do so...all she does is copy/paste from others....and often provide bogus info..
she ONLY reads and sees what she wants to and doesn't THOROUGHLY do any research.., cause next to the file she linked above, there was another thread that I linked, WARNING people NOT to use this 215 bin that she initially copied/pasted and linked...
Username: Lklives
Post Number: 12557
Shke killed many receivers today with her Bogus copy/paste and link to a killer bin!...send her the Jtag bill!
Username: Eecco
Post Number: 20
all my pay per view are down, i have auto roll on, can someone please help me
Username: Eecco
Post Number: 21
key posted are the one i have. any other suggestion
Username: Nydas
Post Number: 3933
LK: You are a skunk, and everybody can smell you in every thread. You are a Pansat hater, do not own a Pansat 2700, so you just SHUT UP- don't talk about Pansats any more.
You have been chased off this thread dozens of times but you keep on coming back. You tell people not to use Pansats - you tell people to go buy new receivers with working autoroll, and then come in this thread to post keys! Have you no sense of what you are saying and doing?
Username: Eecco
Post Number: 22
Username: Psychmonster
Chi town, Il
Post Number: 94
from Nalin...psychmonster: You are as psychologically deranged if not more than your boss LK.
Get this clearly though your deranged head. I DID NOT create the jvvh BIN - he, i.e jvvh, created it and he i.e, jvvh posted it for everybody to use, and he, i.e jvvh retracted with the following words
So if you want to take your venom out at anybody go and do it to jvvh, not me.
AND PSYCH - GO AND TAKE YOUR PILLS.
psychmonster
chi town , il
Post Number: 93
Posted on Tuesday, October 02, 2007 - 11:04 pm: \
MY REPLY
Nalin...u are the idiot who in her/it/ that/him zeal who wants to be first poster of some new bin, and posted a killer bin without testing it ...u are the idiot...jvvh was wrong in posting a bin that was not fully tested, but u cannot compound that by posting stuff untested..and Cartier1 ...the factory setting erases all privious bins...use that function at the beginning of the process , not the end like u stated
Username: Tommya77
Post Number: 9
Sorry to bother you all. My wife is driving me nuts wanting to switch to BellVu, so she can watch some soap. What do I need to do to switch from Dish to bell?
Thanks for any help
Username: Nydas
Post Number: 3936
Psychomontster:
Your name makes it clear what you are.
You are a psycho and a monster, who cannot understand the workings of FTA software writers. So go and find somebody else to abuse, or go and worship LK - that is what you are fit for.
You do not even know that Factory setting does NOT erase the just loaded BIN - you stupid monster! And you have the nerve to come and criticise me. Cartier even corrected you and you still did not understand.
One can and often does do factory setting to start the process of rescanning. The only thing Cartier might not have explained clearly is that you will have to do User setup of time, date etc before scanning.
And Cartier said it correctly to do set default key to let the autoroll work and load the fresh keys.
All you psychos forget to take your pills and then come here to bash regular helpers.
Username: Lklives
Post Number: 12566
U need to
1... NEVER listen to Nalin Nyda..
2...realign your dish to the Bev sats 82W and/or 91W
3...scan the Bev satellites
4...and do everything else the same as U did for DN ( antenna settings, let Bev keys autoroll, upload latest bin (they all have both DN and Bev), etc
BTW....IMO, DN is 100x better than Bev...much more and better channels..
Username: Tommya77
Post Number: 10
Thanks LK, was worried if I would get an answer since I walked into the middle of the flame war lol.
I am with ya on DN being better, but wife let me buy 3 gigs of ram and new video card if I let her switch to bellvu for her soap.
btw. how do i get rid of the current dish bin and get the new bv one. sorry i am a complete noob.
Username: Lklives
Post Number: 12568
U don't need to change bins...all bins have BOTH DN and Bev capabilities..
BTW...this is NOT a flame war....nalin has been here for over 1 year giving out BOGUS info and killing many people's receivers...which she did again today!....we all know her and her ways, but she has the newbies convinced and fooled......I believe she is a mole for DN and Bev, and does this on purpose!...and she will NEVER admit her OBVIOUS Bogus postings!...her ego is too big for that too...
Username: Nydas
Post Number: 3941
Username: Tommya77
Post Number: 11
I hear ya. You have always been here to help me, so thank you for that. I am on an old vortex pro, so I will jump outside tomorrow and point the dish over there tomorrow. DN is nagravision for new keys, what is BV?
Thanks for the help. maybe those who talk trash about you will leave.
Chi town, Il
Post Number: 99
Nalin...one last thing...I meant Factory Settings erases last scans..not bins..at least I will admit when I use the kings english and make a mistake, I will admit to my errors...when is the last time you apoligised for burning out units when peps took your word as gospel?
Username: Nydas
Post Number: 3945
The simple fact remains that you, psychomonster, do not know enough about FTAs and BINs and should not be here criticising me or others.
Username: Thadragun
Kingston, Ontario
Post Number: 14
I have a ViewSat Pro and my Bev paperview is down. Any new keys out there yet to fix it?
thanks
Username: Nydas
Post Number: 3947
Marcel: There have been many problems with BEV and PPV (pay-per-View) often was the first to go with the older BINs. You must load the latest BIN
Username: Tommya77
Post Number: 12
so where do i get the latest bin.. well safe bin?
Username: Thadragun
Kingston, Ontario
Post Number: 15
nope, thats not it. I have the latest Bin: VSPRO-070928A
I guess I just have to wait for the next update. I'm sure it will be in the next day or so
Username: Nitehawk
Having a tad of a problem here...hope someone can help. I have a dish with 2 LNB...one is sighted for 110 and the other for 119.... I can pull in 110 fine but I am not able to find 119. It should right beside it... any suggestion will help
Username: Lorna
need the keys for dn pls
Username: Lklives
Post Number: 12577
BEV PPV/Po*rn Issues..
As some of you already know, BEV ppv/po*rn are currently having issues. Please note first of all that new keys will not solve the issue as it has to do with a re-vamped rev 248. Not too much is known at this point but what is known is fixes are the only solution for the issue for devices that have been affected.
Testing Devices affected:
- Some FTA
- Atmega
- Some EMU/ROM
Please be patient, this new counter measure isn't a big thing. Yet..
Bev is using post processing for the PPV and po*rno channels now,same way they used for the last two weeks NFL channels.
Packets show ecm index byte 40,and encrypted headers for cmd 07.
dish is updating cards to 10C.
Packets from USW 1052 to USW 1061 today.
By the weekend all cards will be updated,approximately.
Username: Lorna
hi guys i need the keys for DN pls
Username: Lklives
Post Number: 12583
scroll up...no changes..
Post Number: 1069
Nitehawk, this is the keys thread. Open a new thread for help. Make sure ur skew is right on ur dish
Username: Lklives
Post Number: 12586
Nalin and Dr S are BUSTED....heres the proof!
http://forum.ecoustics.com/bbs/messages/2/392779.html
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through October 03, 2007 [ « Previous ] [ Next » ]
