Thread: Basic cable run through hd tuner? |
New member Username: Kokopoko
Post Number: 1 Registered: Oct-07
| Posted on Thursday, October 04, 2007 - 05:11 pm: |
I have a Panasonic hdtv with the coax/cable connector ripped off. I have an hd tuner and hd antenna I have been using for years to get the over the air hd and regular channels. I just went with the bundle deal at the local phone/isp/cable provider as it saves me money. So now I'm getting basic cable. Can I take the cable from the basic cable connector on the wall, connect it to my hd tuner box and get basic cable channels to show up on the tv? Thanks for helping as I'm confused. Christine |
Relevant Product Info
Gold Member Username: Tapeman
New York City in-HD,
NY
Post Number: 1553 Registered: Oct-06
| Posted on Thursday, October 04, 2007 - 06:55 pm: |
Yes yo can For sure yo'll get the analog channels Maybe some of the digital channels if they are in clear. Depending on your HD tuner and cable service, yo and your luck. I would give it a try. |
Gold Member Username: Samijubal
Post Number: 3565 Registered: Jul-04
| Posted on Thursday, October 04, 2007 - 07:50 pm: |
Unless the HD tuner is made to receive cable channels, it won't work. You might get a few, the low channels that use the same band as OTA channels. Most cable channels use a different band than OTA channels, so a receiver made for OTA channels won't work. You can use a VCR or DVD recorder tuner though. |
Post Number: 2 Registered: Oct-07
| Posted on Friday, October 05, 2007 - 12:26 pm: |
Well running basic cable through the hd tuner does not work. It couldn't find any channels. So I need to get something that will take in a coax cable and have outputs for the 3 color cable I'm using to go to the hdtv. I have no idea if anything like that is even made. Does anyone know? |
Post Number: 3567 Registered: Jul-04
| Posted on Friday, October 05, 2007 - 06:27 pm: |
Use a VCR tuner and the RCA composite outputs. If you want to be able to use the component outputs, you can use a DVD recorder. Some DVD recorders even have HDMI and upconversion. |
