Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through September 26, 2007
Author Thread: Archive through September 26, 2007
Username: Silver1123
Mexico, DF
Mexico
Post Number: 240
Bigga, Laura, Kamran:
To avoid entering keys manually, you can install the latest software bins in your boxes, then, the keys will be loaded automatically and you will not lose your channels.
To do this, you have to use your computer, and need a cable, usually a standard RS 232 printer cable, with 9 pins on the connection. Some newer boxes carry a USB port.
You need to download two pieces of software:
1. The loader
2. The bin
You get these at any of these sites:
http://www.dssrookie.com/forums/
http://ftabins.net/index.php
http://www.dsstester com/
They are free. Some sites require that you register, but its simple.
When you enter any of these sites, look for the brand (Pansat, Viewsat, Fortec, etc.) and model of your receiver, then you will download the proper software.
Also, you will find instructions on how to download, unzip and install the software.
When you install the latest bins, your box gets the new keys from the signal stream, and you dont need to input keys manually every time they change.
Keep in mind that bins are updated occasionally.
And, while you install the bins, so that you donīt need to wait for keys to be posted, here you can find them:
http://www.dss-keys.com/
http://www.ftasolutions.blogspot.com/
Username: Uptgangsta
hi, i have a fortec lifetime ultra FTA reciever, but when i go to the main menu in the system info it says:
X-85
API: 2.88T a_EU
Boot Ver: 05
18.Jan.2007
Future-FTA.info
Now, my question is that do i get the bin for 'fortec lifetime ultra' or 'pansat'?? because im not sure which one to get...nd my reciever is NOT a clone...sum1 please help. i would truly appreciate it
Username: Ashim786
does anyone have the new keys as of 3pm.... thanks
Username: Srpskkisiin
Post Number: 80
dish provider new 3pm change
key00: 2E 79 BB 5B 8D CA A7 23 56 C0 21 A1 0D 90 48 99
key01: 43 E5 E1 CC 43 28 D5 02 A2 B6 6F F2 F1 AB 31 82
http://www.jordinclub.com for more info
Username: Kingusama
Post Number: 338
new keys posted at www.ftasolutions.blogspot.com!!!
Username: Sydfahim
Dear All
I have fortec ultra, I have a friend has same receiver but he download software to transform it to pansat 2700 then the keys change automatically and solved the problem of BEV. Would you please tell me how?
Username: Kikim
Windsor, Ontario
Post Number: 33
hello ,when im downloading the bin for pansat 2700 the reciever cout faster then the pc and it's not working,i need help please.(i download the old was ok but now no)
Username: Bigga123
thanks for the keys man
Username: K98
Post Number: 91
keys not working for d.n. help plz
Username: Briffdogg
Post Number: 26
well they are good keys, i usuually have this problem with black screen like 40 percent of the time with good keys, i just unplug the receiever and let it go through 1-5 steps a second or more times and it catches
Username: Hello112
can sum plz post the new keyzz
Username: Hello112
can some1 plz post the new dn keys
Username: Asharfi
Post Number: 826
Dishnetwork Keys (0101)
(Last Updated: Friday, September 21, 2:42 PM EST)
Key 00: 2E 79 BB 5B 8D CA A7 23 56 C0 21 A1 0D 90 48 99 (Active)
Key 01: 43 E5 E1 CC 43 28 D5 02 A2 B6 6F F2 F1 AB 31 82
Username: Rekman
Mntl-Quebec-...
Post Number: 222
NEED HELP
Since i loaded BIN 149 for cools*t 5000.... no channels working... its only saying NO OR BAD SIGNAL..
we turn the DISH to different position.. still NO OR BAD SIGNAL.
Also we have notice the Dish setting is not pointing Neither to 119 Nor 121 echostar west or east.....
Please HELP ME , Please HELP ME , Please HELP ME , Please HELP ME , Please HELP ME
I BEG uuuuuuuuuuuuu ....
Please HELP ME
Username: Lklives
Post Number: 12185
If it all worked until U changed the bin, then it wouldn't be a hardware problem....U just needed to recheck the antenna settings in the receiver...
so if the dish is aimed correctly, do a factory default reset, upload bin 149 again, recheck the antenna settings, scan the sats, let the keys roll (be patient may take 5 - 30 minutes or so), and watch TV...and if U have any more problems, REBOOT receiver OFF for 5 minutes and then ON using the REAR switch...
Username: Got_bev
I am putting BEV 86 and 96 keys in DN 00 and 01. Nothing is working. Well actually this is my first time with BEV, have always used DN before with no problems.
Anybody with BEV experience, please point me to the right direction. I love reading but when my searches return 7005 results I run out of time to do that much reading.
Help please.Thanks.
Username: Asharfi
Post Number: 828
Got,
So, you're saying that you're putting BellExpressVu keys inside Dishnetwork's key-code space? If that's what you're doing ... then nothing will work.
Username: Way2smart
CANADA
Moderator Ū
Post Number: 178
Hello can anyone tell me that is (cool sat 7000 micro pvr bell ready) bell Express i think
Username: Rekman
Mntl-Quebec-...
Post Number: 223
Yes LK.... Tomorrow during the day.. we gonna move the Dish to the previous position and we"ll do as you said: factory reset etcc......
Finger cross Hope it will work ......
thanks Indeed for your Kindful Help...
Thanks
Username: Got_bev
Yes AV this is what i am doing. I tried putting 0907 (Bell Express Vu ID) but then I only get slot for key 00. Left right arrows would not show me second slot (01 or 96). I am not sure where is the slot for BEV keys. Please help. I am using Fortec Ultra. Apreciated your response.
Username: Asharfi
Post Number: 831
Got,
First, I think you should convert your Fortec STAR Lifetime Ultra to a Pansat 2700 and then use the BEV with the latest bin. FLUs are dying now .... a lot of people are having weird problems with their FTA boxes (FLUs)
Username: Sydfahim
Please Lk or AV tell me how to convert Fortec lifetime ultra to Pansat 2700
Username: Asharfi
Post Number: 836
syd,
Please visit my thread (http://forum.ecoustics.com/bbs/messages/2/382668.html). It`ll give you all the files and the instructions that you need to successfully convert your FLU to a Pansat 2700. Open the instructions file with WORD PAD, which is in your computer if you`re using WINDOWS.
Username: Fizzy
Post Number: 11
YOUR MOM
Username: Asharfi
Post Number: 837
Now, are you saying that in a Negative Way or Positive (just for fun) way ?
Username: Lklives
Post Number: 12187
Nagra2 Keys
Dish Provider 0101: Last Updated (20 Sep '07 11:45 PM EST)
Key 0: 2E 79 BB 5B 8D CA A7 23 56 C0 21 A1 0D 90 48 99 (Active)
Key 1: 43 E5 E1 CC 43 28 D5 02 A2 B6 6F F2 F1 AB 31 82
Bev Provider 0901: Last Updated (16 Aug '07 6:30 PM EST)
Key 0: 4D 72 C7 59 38 FE 2D 3F 1D 97 2E 64 68 80 4E 23
Key 1: C5 EE E1 73 65 73 6F 86 19 36 57 2B A6 DB D7 84 (Active)
Bell ExpressVu PB (0905)
(Last update: 2007/03/15 1:01 AM PDT )
86: B7 2F 03 35 70 4A CD B0 6D 43 33 59 92 E2 1D F3
96: D5 51 BA FE 58 50 BE 61 A4 BD 09 F3 54 4F C5 FC
Bell ExpressVu HD (0906)
(Last update: 2007/03/15 17:17 PM PDT )
86: 8D 1A 1C F4 2C B9 7F 85 38 65 D6 7A 5D 59 5D 88
96: 11 FE 27 1D 89 9E D3 B4 DB 8E CB C8 10 D3 E7 F7
Bell ExpressVu New Provider ID (0907)
(Last update: (Last Update: Mon. Sep 17, 9:35 PM EST) )
86: 7E EE 27 6D 90 7B AE 79 17 F1 D0 DA 00 FE E6 31
96: 37 25 BD 57 61 81 A4 92 12 07 F7 67 30 24 3D 9C New
Globecast (C101)
(Last update: Sep 17, 10:27 PM EST )
86: 93 78 EA 2A 8B 7C D9 86 94 96 8D 4B EF A0 15 F6
96: A3 47 8F 1F F3 7E 2C 94 B5 E6 B8 4E 6F 13 B5 25
Username: Peeman
WUZ UP GUYS
Username: Nydas
Post Number: 3834
chris guinveras:
The FLU will work at present with 294T BIN. Look for it in Fortec Ultra section of many sites and get the 294T BIN. Make sure it has a T at the end.
This BIN will work fine up to a point. You will need to manually enter two numbers after a new set of keys autorolls. For details, go to
http://forum.ecoustics.com/bbs/messages/2/389642.html
You may also want to consider upgrading it to a Pansat 2700. There are very good reports of it. The procedure is a little more difficult than a simple upgrade of BIN, but you might consider it worthwhile.
AV and Abby are two of the people who have been active in supporting this kind of an effort. For full detail, go to
You will need to read in the forums where you download the files.
http://www.future-fta.com
http://www.f2atv.com
Username: Prince
Post Number: 41
I was trying to convert Fortec star Ultra to Pansat 2700. I download the bin files, loader and instructions from dsscentral site. As per the instructions I was to load two bin files (j27_205_1 & cs_208T _serial). I was able to load the first bin with no isues. But for some reason I am not able to load the second bin. Please advice what should I do.
Username: Nydas
Post Number: 3839
king: Look at the post above yours for a list of reliable sites where you will find everything you are looking for.
Username: Prince
Post Number: 42
Thanks
Username: Prince
Post Number: 43
Nalin - I was just wonderng if you could send me the link. So i can obtains the required files and information on how to convert FLU to pansat 2700.
Username: Asharfi
Post Number: 842
King,
Checkout this thread: http://forum.ecoustics.com/bbs/messages/2/389206.html
Username: Nydas
Post Number: 3843
There are several files. If you want to do the job properly read what AV has to say in his link.
then go to:
http://www.dssrookie.com/forums/b-font-color-cd2626-ultra-files-font-b/
to get the files and instructions there.
Make sure you unzip files before using.
Username: Prince
Post Number: 44
Thanks AV - Have a quick question for you. I downloaded the files as per your instructions. When I click on download It said Waiting for connection STB and then afer few mins got a error message saying Sorry Connection Failed. Also on the STB I have numbers showing as 5818.
Username: Asharfi
Post Number: 843
King,
Do you have MSN? I'm ONLINE right now .... try coming ONLINE so I can provide LIVE help .... my email is asharfivig@msn.com .... add me if you can ....
Username: Tiger9
hey I was wondering if there were any new keys for DN I have a C**l sat 5000 and the latest keys arent working thnx.
Username: Prince
Post Number: 45
Is there a website for "Black Death Repair Kit for FLUs" or can someone give me the link. Thanks
Username: Asharfi
Post Number: 844
Go to http://www.hostclip.com/download.php?file=e8d2b6e48e5a3e0560cdb4be4ee8c4b2 and download the Boot 6 file for FLUs
Username: Andreasmith
Post Number: 26
Hello,
Does any one have an idea how to get the chanl 799 to appear (Gemni TV). Right now I am getting a message, the channel is moved.
Tx
Andy
Username: Asharfi
Post Number: 858
Andrea Smith,
Try rescanning your satellite. Here's some channel details:
Channel Name: Gemini TV
Channel Number: 799
Language: Telugu
Satellite Provider: Dishnetwork (0101)
Available on:
Dish 118.0 (Transponder - 7)
Dish 121.0 (Echostar 9) (Transponder - 15)
Username: Biggun
Is anyone else down? I went down this afternoon with "scramble channel" like when the keys change but I haven't seen any posts about them changing. Is something else going on?
Thanks,
BIGGUN
Username: Asharfi
Post Number: 861
Mike,
Dishnetwork is stiil working, but if you wanna know the latest keys, then here you go:
(Last Updated: Friday September 21, 2:42 PM EST)
If you already have these keys, but still getting that "Bad or Scrambled Channel" message, then please turn OFF your receiver from the back, then wait 20 seconds, and then turn it back ON.
Post Number: 27
Hi AV
Thanks for the information.
I am getting the channel, but the message says that the channel is moved Please contact DN. Are you able to see the channel? If so, can you please provide the polarity at which the channel comes. I have CS8000
Tx
Andy.
Username: Asharfi
Post Number: 863
Which sat are you using ... dish 118 or 121?
Post Number: 28
Tx
Andy
Username: Dimwitt
Post Number: 128
Channel 1, Gemini TV, Siurya TV and TV5 are all mirrored on channels 5714-5717 at 121° for some reason. Each channel appears to be an identical mirror available to subscribed customers.
Update: The original channel slots for these channels (731, 799, 800, 806) all moved to tp 13 at 121.
Username: Lklives
Post Number: 12224
Yes if U want ANY DN channel, satellite or TP info...go here..theres even switch, LNB, dish pointing and other info linked from here..not ONLY channel info..
http://ekb.dbstalk.com/dishlist.htm
Username: Nydas
Post Number: 3875
You don't need to go anywhere on the internet to find new keys.
Most receivers have a new BIN that will do an autoroll and you will get the keys. This will happen when you are watching TV.
There are a few,. notably Pansat 2500A,clone Pansat 2500A, fortec Ultra, Pantec.
For these, you let the receiver do the autoroll. It will show waiting...205% etc. Let it cycle through and when that message goes off the screen, go to Parental control, turn off autoroll.
Look at the Nagravision 2 keys and change the 2nd number in Key 00 and Key 01
To change the 2nd number, you will need a scientific calculator or use the calculator in your computer under windows.
Go to scientific mode. Tick Hex for number system
Then enter the number you are going to change, select XOR as the operation, and use 43 hex number after that. Press = and you will have the new number. Enter that number in place of the 2nd number.
Do the same with the 2nd number of both key 00 and key 01. Exit,Exit, Exit and watch TV or turn off and on and watch TV.
There is also a table available. Download the table and print it. Keep it by your side when you are watching TV, and change the 2nd number in Key 00 and Key 01 when necessary using the table.
The table:
Post Number: 29
Thanks Tooter. That is exactly what i wanted. Now i could see the channel
Tx again
Andy
Post Number: 30
Thanks LK. That is quite a wonderful info.
Tx
Andy
Username: Rida
Hello there... How can I program my receiver for an automatic fix and how safe is it? I heard those programs carry viruses that can total your receiver...
Thanks
Username: Lklives
Post Number: 12231
U heard wrong...bin/files carry NO viruses...its as safe as U keep it...the "how to's" are posted everywhere, just read them...go to the therad/subject "list of recommended sites' , pick one and go there and read ther simple manuals..
Username: Jokerisback
Post Number: 39
hey is there a new autoroll program for pansat 2700a
Username: Cpreatty
Post Number: 7
New keys please?
Username: Trinity
Post Number: 31
Hello,
I have got a new c**lsat 6000 premium. wouod someone be able to tell me how to put in new keys
Username: Nydas
Post Number: 3881
Rida:
LK provided misleading information to you.
You heard rightâ€Ķ bin/files sometimes carry “viruses”. They are called clone killers.
If you have a Pansat 2500 clone, you do not use genuine Pansat BINs but instead use clone safe BINs ending with a “T” – Latest is 294T
If you have a Pansat 2700 clone, you do not use genuine Pansat BINs but instead use clone safe BINs called Tivo Latest is Pansat-C 2700 213v1 Tivo
Also clone killers in Pansat 3500 files. Use only clone-safe BINs.
Similarly there are clonesafe BINs for Megasat and other C00LSAT clones. You do not use original C00LSAT BINs.
Username: Lklives
Post Number: 12240
Bin files do NOT carry VIRUSES!....I thought U were this puter whiz, OBVIOUSLY NOT...also Dss sites check these files when they post them...so nalin again is providing WRONG BOGUS info!
also...use of wrong bins will corrupt the eeprom in the receiver, BUT thats NOT a VIRUS!...and CLONE KILLERS are NOT a VIRUS...and are NOT contagious...Clone killers simply corrupt the Eeprom of a receiver, requiring sometimes a Jtag to correct the eeprom....and receivers are NOT killed by ANY viruses, but ONLY by use of the WRONG bin file for your receiver...each receiver has specific bins files made for it that are PERFECTLY SAFE...
nalin...STFU and quit giving out BOGUS INFO!
Username: Nydas
Post Number: 3884
Rida: You heard LK .
Lesson No. 1. Never contradict her in this forum.
SHE IS ALWAYS RIGHT!!
There are no viruses, just dead receivers from vviirruusseess.
Lesson No. 2.
LK is unique.
Lesson No. 3.
Nobody, just nobody uses profanity in this forum.
Well, mostly nobody. You are unique if you use profanity, and only unique people may use profanity.
Username: Cacalad
Post Number: 33
new keys for dish please
Username: Lklives
Post Number: 12255
NO CHANGES...U should look before U post!
Dish Network (0101)
[Last update: Sun. Sep 23, 8:07 PM EST]
86: 2E 79 BB 5B 8D CA A7 23 56 C0 21 A1 0D 90 48 99 New
96: 43 E5 E1 CC 43 28 D5 02 A2 B6 6F F2 F1 AB 31 82
Bell ExpressVu (0901)
[Last update: Sun. Sep 23, 7:16 PM EST]
86: 4D 72 C7 59 38 FE 2D 3F 1D 97 2E 64 68 80 4E 23
96: C5 EE E1 73 65 73 6F 86 19 36 57 2B A6 DB D7 84 New
Username: Vinthan
Post Number: 13
ANY ONE HAVE ANY IDEA WHERE I CAN GET THE AUTO ROLL FOR THE PANTECH RECEIVER
thank you
Username: Nydas
Post Number: 3891
Aravinthan: I replied to you
on Thursday, September 20, 2007 - 05:42 pm:
in this thread.
Mexico, DF
Mexico
Post Number: 241
Trinity:
Enter channel 8282 and a screen will appear.
You will see 4 lines, two for 00 keys and two for 01 keys.
Be sure on top Nagra1 is selected.
If you press OK in your remote, keys will appear.
Also, when finished, key exit and when the reciever prompts you select "yes" to changes.
Be sure to turn autoroll options off when entering manual keys, so that the keys dont change.
if you donīt want to enter keys manually, intall a new bin, you can find it at:
http://ftabins.net
Where you also get instructions, for example, copied from that site, how to enter keys on a cool^sat
ok click 8282 or mute than exit this will get you to your keys
then :
10:xx xx xx xx xx xx xx xx|
11:xx xx xx xx xx xx xx xx|key00
20:xx xx xx xx xx xx xx xx|
21:xx xx xx xx xx xx xx xx|key01
key00-xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
key01-xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
and that's all there is to it............. JRPCA
Mexico, DF
Mexico
Post Number: 242
Rida:
Its very safe to install new bins, but as others have posted, you should be careful to avoid damaging your box.
Usually, downloads from http://ftabins.net are safe
Read the posts and instructions about your particular box, before installing new software.
Also, its advisable to have the factory bin, just in case something goes wrong, you can reinstall the factory bin
Username: Lilmoe
Windsor, Ontario
thanks for the keys.lol!
Username: Lilmoe
Windsor, Ontario
ill be givin keys to people just ask me if u need ok
Username: Rekman
Mntl-Quebec-...
Post Number: 224
LK & Nalini Nyda
I am still having big problem with my COOLSA*T 5000. NO OR BAD SIGNAL.
Can you please guide me how should I set the DISH SETTING properly..which frequence , comitted etcc...
We moved our dish to different position .. it did not point neither to 119 west nor 121 Echostar...
The level is 85-90%
the Quality is 10-15%
they are both RED color.
CAN YOU please explain to me about ANGLE CALCULATION.. friend told me to go on http://satcalculator.freehostia.com/..
I entered my City name
and About the SET UP... but was NOT sure which one I should choose.. Either Dish Network Dish500 (110-119)
OR Dish Network Dish1000 (110-119-129)
OR Dish Network SuperDish 121 (110-119-121)
I live in Quebec Montreal. The result which I Got was as Follows........
True Azimuth: 234.76 ..Magnetic azimuth should be used when using an uncorrected compass
Magn. Azimuth: 249.86
Skew Angle: 120.4
Dish Elevation: 23.48
CAN YOU PLEASE EXPLAIN TO ME WHAT IS magnetic azimuth....
PLEASE HELP ME.... SINCE 3 DAYS I AM turning round n round with the dish position...
THANKS}
Username: Lklives
Post Number: 12287
which dish do u have?...and what sats do u want?...just select the sats u want and use the elevation and azimuth markings on the actual dish itself as a general guide...then slightly tweak it VERY slowly...takes 2 people. or a sat finder and a TV on the roof...and using a DN receiver is the simplest way...
there are MANY "Dish Pointing Tips" posted at all sites...
Username: Rekman
Mntl-Quebec-...
Post Number: 225
i have Cools*t 5000 platinium
I am looking for Echostar 121 WEST... for East Indian Channels....
Username: Rekman
Mntl-Quebec-...
Post Number: 226
Dish Network FTA
Receiver cools*t 5000 Platinium
Username: Lklives
Post Number: 12289
again...what DISH do U have?
Satellite Finders (Look Angle Calculators)
http://www.arachnoid.com/satfinder (Dish 500 support)
http://www.hollsco.com/Products/SatCalc/
http://www3.telus.net/rampage/skew.htm (Dish 500 support)
http://www.remotesat.com/lookangle.htm
Username: Lklives
Post Number: 12290
Pointing at: 121š EchoStar 9
Your location:
CANADA - QC - Quebec North Latitude: 46.793
West Longitude: 71.391
True Azimuth: 238.2
Magn. Azimuth: 255.18
Magnetic azimuth should be used when using an uncorrected compass.
Dish Elevation: 18.08
LNB Angle: 35.6 Always make sure your mast is installed corectly and that it's plumb all around or these settings may not work for you.
Username: Rekman
Mntl-Quebec-...
Post Number: 227
What is AZIMUTH
and what is Elevation Degrees
where can I find these instrument to measure...
Username: Lklives
Post Number: 12293
How to align a dish...
http://www.dsscommunity.co*m/forums/viewforum.php?f=85
http://www.dsscentral.ne*t/dishtips/ ...Much more than the below at this link...
Dish Pointing Tips
General Site Survey
To get a signal, the satellite dish must be pointed directly at the satellite, with NO obstructions between the two. This means NO trees and NO buildings. Take into consideration future tree growth, house remodeling or additions and new construction in your area.
The satellite signal WILL NOT PASS through leaves or branches.
Use our Satellite Look Angle calculator to determine the proper dish angles.
Finding a Clear Line of Sight
Get yourself a good compass, the best you can afford. Check the "Azimuth" and "Elevation" for your location here!
Locate at least one site on your property that has a clear view to the satellite.
Do you have at least one clear view to the satellite? Remember, no trees, leaves, or buildings can be between the dish and the satellite.
If the answer is NO, your site may not be suitable for installing the satellite system.
If the answer is MAYBE, you may want to contact a local digital satellite dealer for information about having a professional installer conduct a thorough site survey.
If the answer is YES, your site should be suitable for installing the system. Go ahead to the next section of these instructions.
Where Is Intelsat America 5 Satellite?
The satellite is always located south of Texas. That means if you live in Florida, you must have a clear line of sight to the southwest; if you live in California, you must have a clear line to the southeast.
Depending on where you live, the satellite will be at an elevation angle between 30 and 60 degrees. Southern states point more toward 60 degrees; northern states point more toward 30 degrees. Use our Satellite Look Angle calculator to determine your dish elevation and azimuth.
LNBF Polarization Tilt (skew):
Your LNB is marked with a label indicating the polarization tilt. Your local LNB polarity offset information varies by location. If you are in Houston, TX your LNB polarization is to be set at 0 degrees. But if you are on the California coast your LNB polarization could be as much as minus 30 degrees (clockwise rotation). And if you are in Maine your LNB polarization could be as much as plus 30 degree (counter-clockwise rotation). Peaking the dish and adjusting the polarity of the LNB will greatly improve your Signal Quality reading.
When adjusting your LNB, it's not going to be turned more than 31 degrees (unless you live in Hawaii). Also be sure you don't leave that LNB plastic bracket loose. The LNB won't pick up the satellite if the bracket is loose, and it's slightly off. Finally, when thinking about degrees, remember that 30 degrees is about 5 minutes on a clock. Don't turn the LNB too much!
Make certain that the pole or tri-mast assembly is vertically plumb. Check it with an Angle Finder or a level. If the pole or tri-mast is not plumb, your azimuth and elevation will not be accurate and will cause difficulty when pointing the dish. Also, if you are using a pole mount, make certain you pour a sufficient footing that will provide proper ballast. A pole that does not have sufficient ballast will lean over time, causing you to lose the signal. Your mount must be very strong and can not wobble. You must use at least 4 lag screws (correct size for your installation) in the base mount one on each corner.
When pointing the satellite dish, allow 5-10 seconds between any movements of the dish. This allows the receiver to complete a signal scan, and lock indicating that you have located the signal.
A reasonable signal strength is between 50 and 80. If it is lower than that range, you are either pointing into an object (e.g. trees, shrubs, or structures) or pointing above or below the satellite. Your antenna installation position must have a clear view angle of the satellite you are trying to receive.
There are other satellites within 2 degrees to the left or right that may use the same frequency. This will provide a strong signal strength reading but no signal quality or signal lock. If you have a high strength reading but are not able to lock on, try adjusting the dish slightly to the right or left.
When you are attempting to set up a satellite dish in a heavily wooded area or one with lots of man made obstructions, it helps to understand how the dish really works. One common misconception is that the dish points 'directly' at the satellite. This isn't the case for most dish designs. The apparent elevation of the dish is 15 or more degrees lower than it's actual receiving window. Have a look at this diagram.... it's easier to see it than it is to explain it.....
If you complete the above steps properly, your chance of a successful installation is 99.9%.
Be aware that when you have finished your mechanical installation and you are trying to aim your dish that the receiver waits about 3-5 seconds after it locks on to the correct signal before it registers on the receiver's signal meter on the antenna aiming screen on your TV. Move your dish in very small increments (2 deg East or West each instance until you find the signal then 1 deg to peak signal). If you move the dish too fast and do not pause between moves you might go thru the signal before the receiver can tell you that you are on the signal.
If you use a signal meter you can hook it into the system right at the dish and it responds to the signal immediately making it much easier to aim your dish. You do not need any one else to help you if you use a meter at the dish.
Compare Signal Strength and Quality
Zero Strength and Zero Quality:
If this is the symptom you are experiencing, then the receiver is currently not receiving the signal from the dish. Check all connections between your receiver and the dish. Make sure that they are all plugged in to the proper place and are tight.
One of the most common connection problems is to have the cable coming from the dish plugged in to the connection marked "In from Antenna," which is incorrect. The cable coming from the dish needs to be plugged in to the connection marked "In from Dish, Digital In, or LNB IN"
Also, the cables might have developed a short or might have gotten moisture in them, especially out at the dish. If this is a possibility, you may want to have an installer check the cables or take them to an installer yourself.
0-30 Strength and Zero Quality:
If you are experiencing these levels of strength and quality, you are getting only noise signals. Make sure that there are no obstacles between the dish and satellite.
40-60 Strength and Zero Quality:
With this level of strength and a lack of quality, it is very likely that the dish has moved since its initial installation or you are still off alignment. We recommend going through the Dish Installation pointing steps and finding the satellite signal again. This will likely take just a few minor adjustments of the dish since it should not have moved very much. Key causes for this problem include bolts not being tightened properly, heavy winds, or the dish being struck or bumped by something. Once the signal has been found again, make certain all bolts are tightened well.
We also recommend that once you have everything tightened down and have your signal back, make a mark from the cap mount to the pole with paint or some other permanent substance. This will give you a reference point, should any future problems occur. You can also make a mark on the side of the cap mount where your elevation markings are imprinted.
40-60 Strength and 30-70 Quality:
This level of strength and quality indicates that the dish needs to be fine-tuned to the satellite. You may have noticed that prior to getting the "Bad or No Signal" message your picture was occasionally blotchy and your audio may have been out of sync with the picture. These are all symptoms of the need to fine-tune the dish. Optimum signal quality is between 70 and 100.
TIP: You can fine-tune your dish by going back to the signal strength screen. While the signal bar is running, have someone out at the dish. He will need to loosen the collar that holds the LNB. This is done by slightly loosening the two screws that hold the collar together. Once these screws are loose, slowly twist the LNB a fraction of an inch. After each movement allow 5 seconds for the receiver to register the change and update your quality reading. If the quality readings immediately begin to get lower while the adjustments are being made, then the LNB needs to be turned in the other direction. Once the LNB fine tuning is complete, tighten the two screws on the LNB collar. You may then complete the scan by pressing START.
Elevation - The Up/Down positioning of the satellite dish
Azimuth - The Left/Right positioning of the satellite dish
Username: Rekman
Mntl-Quebec-...
Post Number: 229
OK LK.
tomorrow I gonna buy a compass.. and will try to position the Dish as you said.....
All these problems happen after strong Wind last week,...
Thank you .. Will be back to you tomorrow .
Thanks Indeed
Username: Ligiuta
Post Number: 14
does anybody know the keys for Globecast?
Username: Demon101
Rochester , Ny
America
Post Number: 52
anyone keys for globecast?
Username: Lorna
Hi guys - i need the keys for DN pls be nice - thanks
Username: Lklives
Post Number: 12311
they are posted above...scroll up!
Username: Lorna
thank u LK
Username: Mellow
The only keys I see are from 2 days ago. Am I missing something? I never post I have been reading and learning for over a year now. I can not get the new Keymaster 4 to stay loaded on my puter. It just disappears everytime so I come here to get keys now. Thanks for all the help, I am just a little confused this time.
Username: Sydfahim
Post Number: 7
Thank you AV you are the best
Username: Mellow
I figured it out. Thanks again.
Username: Mellow
Sorry if this is a repeat but the keys changed right after I got the correct ones found. Any knew ones?
Username: Lklives
Post Number: 12318
No they haven't changed...U're doing something wrong..
Username: Mellow
Thank you. I put it in and 15 seconds later it rolls. I have turned disnet auto off and it is staying in, but will I have to input all the keys next time it changes?I have only been changing the 2nd set of numbers after it rolls for the last 2 weeks.
Username: Vaderpapp
Post Number: 21
how do u make ur receiver find the code by itself? i have a sonicview sv-1000. wheres the fix to put in the receiver?
Username: Rtap
FL
Post Number: 481
ab you can find the fix at these sites.in order for the receiver to autoroll the keys depends on the bin file you load.good luck
www.totalfta*com
www.ftabins*net
replace the * for .
Username: Vaderpapp
Post Number: 22
thx RTAP, and whats the lastest BIN files?
Username: Vaderpapp
Post Number: 23
like the number. is it 264 bin?
Username: Nydas
Post Number: 3906
Mellow : Turn autoroll of and autotp off.
Change key 00 and key 01 - check all 16 numbers in each. Save.
Turn of TV at back and turn it on after 20 seconds or so.
Make sure you enter DN keys in ID 0101 and BEV in ID 0901 and GC keys in ID C101
Username: Mellow
Thanks Nalin, alls well. For now.
Username: Johnnieb75
may i have some keys and some locations to find them at. thank you
Username: Mmosalem
hello.i have a pansat 2700E and idont know what kind of dish do i need to buy and where to buy it and how to install it and what direction should my dish face ,,and in case if im looking for the arabic chanell and the american one .how many dish do i need to buy ,,if someone can assist me please..thank you
Username: Nydas
Post Number: 3909
uuuyyt : Read at
http://www.lyngsat dot com
Username: Bajetown
what are the new codes
Username: Ligiuta
Post Number: 15
Nalin, do you have the keys for Globecast? Please !!
Thank you, Ligia
Username: Questharley
I have a sonicview 4000. I need to know how to reset the password as I am locked out of some channels. Any help would be appreciated. Does anyone have the master code?
Username: Jjnelly
I have Vista on my computer. Will it program sonic view 4000 or do i need windows xp? I realize that there is special software for programing these I'm just wondering if Vista supports this software/
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through September 26, 2007 [ « Previous ] [ Next » ]
