Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through September 12, 2007
Author Thread: Archive through September 12, 2007
Username: Depalmaj
Wa.
Post Number: 38
its ok im just a stickler for correctness no hard feelings ment its all good or will be when bin fix is out
Username: Silver1123
Mexico, DF
Mexico
Post Number: 175
For some strange reason, with the change done today by DN, some channels take the keys on the 01 box and other channels take the keys on the 00 box. DN is changing the second digits in both of the key lines.
To fix it:
Turn autorolls off
Enter current keys in both 00 and 01 lines
0: 5F 9C C4 5B FB 7F 53 45 AF 5C CA AE 22 2C 81 09 New Active
01: 9B 9A DE F1 A3 98 28 FD 06 1D F3 4C 5D 06 DA F4
Check 9C and 9A on each line.
That fixed for me
I have a cool*sat with current keys entered and everyting is opened
Username: Fredy
Post Number: 21
Juan Cavazos: Yes my 9C and 9A change on my fortec. but i can't put autoroll off.. you have another idea?
Username: Depalmaj
Wa.
Post Number: 39
juan Cavazos are these channels working
140,200,205,300
Username: Ligiuta
Post Number: 10
do you have the new keys for Globecast? Anyone?
Thank you, Ligia
Mexico, DF
Mexico
Post Number: 178
Zo Dee:
Yes, workinf perfectly I just checked them.
I did this:
1, Turned all autoroll options off.
2. On line 00 I had 5F DF C4 5B... etc. I changed DF for 9C
On line 01 I had : 98 FC 0D 27 EF etc....
I change FC for BF and it reads like this:
01: 98 BF 0D 27 EF D7 F9 FE 30 D2 80 3A 11 8D AF 9F
Username: Depalmaj
Wa.
Post Number: 40
must be pansat3500 has 4 channels down not bad really
Mexico, DF
Mexico
Post Number: 179
I have this keys and all channels are opened, including ESPN, HB0, CNN, Univision.
For the first time in many months, both key lines, 00 and 01 most be modified, not as before where only one line was active:
00: 5F 9C C4 5B FB 7F 53 45 AF 5C CA AE 22 2C 81 09
Be sure that the second digits are correct on both lines
Username: Depalmaj
Wa.
Post Number: 41
OK every 1 reading every few minutes Juan is correct all channels working if numbers above are correct i had to triple check wow who knew this was so easy yet hard
Username: Depalmaj
Wa.
Post Number: 42
140,200,205,300 ALL working with keys
Mexico, DF
Mexico
Post Number: 181
Zo Dee and et all:
Just be sure to update on both lines when keys are updated.
And keep looking for new bin fixes, they should start to appear in three days at the most.
Username: Depalmaj
Wa.
Post Number: 43
i belong to future fta they email me the fix release hoorah!!
Mexico, DF
Mexico
Post Number: 183
Great Zo Dee, good luck!
Username: Ligiuta
Post Number: 11
does anyone know the keys for Globcast? Please!!!!
Username: Lklives
Post Number: 11841
DN implimented a new B1 into the stream tonight...it is actually a new key change Morph routine...causing certain channels to use certain active keys....
Username: Scottwong
Please Help........ I installed a pansat 2500 but I cant't get the Nagravision 2 on the CAS SYSTEM screen. Can anyone show me how. Thanks so much.
Username: Banej
Post Number: 281
here you go Ligia
Gcast AKA Gloria - 8:00 PM 9/10/2007
00 - 75DEF828058150878CE7064C84718D88
01 - 55181AB7FF6C4C459205E45339D496C2
Username: Lklives
Post Number: 11843
X-05BL_0700910_327_api_NOCARD.zip
New file for Pansat 3500SD v327. Don't worry about the NOCARD. It loads fine with the SD card.
You may want to keep autoroll off for a bit, but it will still roll if it needs to, from what I hear.
NOT CLONE SAFE!!
http://www.dsscommunity.co*m/forums/viewtopic.php?t=4833
Also here's the new Captiveworks (CW) Premium 147 Autoroll fix
http://www.dsscommunity.co*m/forums/viewtopic.php?p=12832#12832
REMOVE the * in links above....
Enjoy!
BTW...new DN working AR Coo*lsat, Captive works,Conexsat, Neosat and other files are already being released...
Username: Bluegillbill
Post Number: 10
juan you have 2 posts one i get espn and nothing els the other iget 110 86 no espn i have pansat 2500 not clone
Post Number: 11
juan i have these codes in now oo-5f9cc45bfb7f5345af5ccaae222c8109 01-98bfod27efd7f9fe30d2803a118daf9f get all on 110&86 no espn
Username: Ciscomx
Hi all-
I used the above mentioned code for my Pansat 2700E. The same code is all over the net.It worked for about one minute and then died.
Maybe we'll see a new code tomorrow.
Username: Nanjes
Hialeah, Fl
I have a Vortex 3500 sd, how can put the keys, can any one tell me? please.
Thanks, Nanjes.
Username: Dude123
Post Number: 1153
chuck make sure your autoroll is turned off..
Username: Dude123
Post Number: 1154
Chuck
Make sure your autoroll is off and then enter the keys manually again if your autorol is ON it is not gonna work and keep doing what it is right now so turn the autoroll option off first and then enter the keys again save and exit
Username: Poochi425
Mis, On
Post Number: 12
Hi juan / LK / ZO_dee
i've tried the above set of keys on my ARIZA700 but nothing seems to be working. i still get black screen + error msg displayed on it: "bad/scrambled channel"
i've taken utmost care to input both set of keys 00 / 01 and my autoroll is off as well.
should i try new bin 298 or wait for a new fix ??
plz. help
thx
Username: Nydas
Post Number: 3683
The DN ECM has changed only slightly in concept..
If you have new BIN since yesterday install it and it will correct the problem
If you do not have a new BIN, let the new keys roll in under the old BIN
and then turn autoroll off and change the second number of Key 00 and 2nd number of Key 01.
You can either use new key posted and do a manual change.
Or if you know hex arithmetic, do a XOR o\with 43 of the 2nd numbers as stated
Or use the table below on the second numbers.
Basically, the attention of the ECM has shifted from the first number in each key to the second number of each key
1st Digit ……… 2nd Digit --------- 1st Digit ……… 2nd Digit
0 = 4 .………… 0 = 3 ---------------- 8 = C ………. 8 = B
1 = 5 .………… 1 = 2 ---------------- 9 = D ………. 9 = A
2 = 6 .………… 2 = 1 ---------------- A= E ………. A = 9
3 = 7 .………… 3 = 0 ---------------- B = F ………. B = 8
4 = 0 .………… 4 = 7 ---------------- C = 8 ………. C = F
5 = 1 .………… 5 = 6 ---------------- D = 9 ………. D = E
6 = 2 .………… 6 = 5 ---------------- E = A ………. E = D
7 = 3 .………… 7 = 4 ---------------- F = B ………. F = E
Username: Indopak
Post Number: 29
new keys?
Username: Alliston
new keys pleaseeeeee
Username: Babaali
Post Number: 24
key pl
Username: Nydas
Post Number: 3686
Keys and other instructions have already been posted - please read above.
Username: Rexandpansat
Post Number: 39
Nalin,
I do not always have access to Internet. So the
Table idea looks very attractive to me. But it's not very clear to me.
Could you kindly explain (preferably with an example - you may use last night's key change)
Thanks,
Username: Indopak
Post Number: 30
what is the new keys?? it just changed!!
Username: Sting77
Post Number: 25
any body knows where can i see 20/20 cricket worldcup
plz
Username: Lklives
Post Number: 11858
ALL the new DN autoroll fixes are released and posted at all the sites... ...no need to manually input keys unless u own a dinosaur receiver like a pansat 2500 or its clones..and if U do, then its time u upgrade...or should have learned how to shut off autoroll and input keys a VERY LONG time ago!....U will NOT see any Autoroll fixes for Panast 2500 or its clones ever again!
Username: Karbum
Post Number: 18
new keys for DN plz
Username: Nydas
Post Number: 3688
Canadian: Look at
juan Cavazos
Post on Monday, September 10, 2007 - 10:49 pm:
"2. On line 00 I had 5F DF C4 5B... etc. I changed DF for 9C
I have a cool*sat with current keys entered and everyting is opened"
You will notice that it works on C00LSAT too.
He saw 2nd number on Key 00 as FC.
F is the first digit and that according to my table changes to B
C is the second digit and that according to my table changes to F
Key changes are occurring frequently, and if you either use XOR with 43. or use the table. You will not have to try and get into the internet or into a site to get the new keys ---- till such time as you get a new BIN.
Username: Aman25
Mississauga, Ontario
Post Number: 19
86: 5F 9C C4 5B FB 7F 53 45 AF 5C CA AE 22 2C 81 09
96: 98 BF 0D 27 EF D7 F9 FE 30 D2 80 3A 11 8D AF 9F new
Username: Nervatola
Hey LK,
I've got the viewsat extreme and I uploaded the fixes last week. Everything was great until 10 minutes ago. What is the next move??? Change keys? Or are you saying that the fix should take care of it and I shouldn't have to.
Any advice would help please.
Thanks.
Username: Lklives
Post Number: 11862
Dish Network (0101)
(Last update: (Last Update: Tue. Sep 11, 11:02 AM EST) )
key00/86: 5F 9C C4 5B FB 7F 53 45 AF 5C CA AE 22 2C 81 09
Key/01/96: 98 BF 0D 27 EF D7 F9 FE 30 D2 80 3A 11 8D AF 9F New
Bell ExpressVu (0901)
(Last update: Sat. Sep 8, 12:29 AM EST )
86: 4D 72 C7 59 38 FE 2D 3F 1D 97 2E 64 68 80 4E 23 New
96: 56 D2 D0 C4 8A BC 0D D0 CA AB 86 5F 83 1A 83 5F
Bell ExpressVu PB (0905)
(Last update: 2007/03/15 1:01 AM PDT )
86: B7 2F 03 35 70 4A CD B0 6D 43 33 59 92 E2 1D F3
96: D5 51 BA FE 58 50 BE 61 A4 BD 09 F3 54 4F C5 FC
Bell ExpressVu HD (0906)
(Last update: 2007/03/15 17:17 PM PDT )
86: 8D 1A 1C F4 2C B9 7F 85 38 65 D6 7A 5D 59 5D 88
96: 11 FE 27 1D 89 9E D3 B4 DB 8E CB C8 10 D3 E7 F7
Bell ExpressVu New Provider ID (0907)
(Last update: Sun. Sep 9, 11:02 AM EST )
86: 7E EE 27 6D 90 7B AE 79 17 F1 D0 DA 00 FE E6 31
96: 37 25 BD 57 61 81 A4 92 12 07 F7 67 30 24 3D 9C
Globecast (C101)
(Last update: 2007/08/11 12:00 PM PDT )
86: 75 DE F8 28 05 81 50 87 8C E7 06 4C 84 71 8D 88
96: 02 69 13 13 FF 8A 14 F2 06 D2 9A FA 4F 32 1F D3
All U people should be using the new files released today for autorolls ....instead of manually entering these keys unless u own a dinosaur receiver which U should replace!
Username: Nydas
Post Number: 3691
In the last 24 hours or so, there have been new files released for
Viewsats
Sonicviews
Pansats except 2500A
and C00LSATS
If your BIN is two days old, see if there is new BIN.
http://www.totalfta.com (
http://www.f2atv.com
http://dssrookie.com
http://www.future-fta.info
Username: Cailo
Post Number: 14
Well
Thank you LK
Username: Vaderpapp
Post Number: 18
i need the program to upload the bins into my receiver. where can i get it?
Username: Swredneck
Halifax, N.s.
Post Number: 14
those are old keys for dish
Username: Nydas
Post Number: 3694
a b: I have just posted URLs to 4 sites - look at two posts above yours.
Username: Nydas
Post Number: 3695
jerry: These are working NOW.
Dish Network (0101)Last Update:Tue.11th Sept, 11:02 AM Eastern)
KEY 00(86):
5F 9C C4 5B FB 7F 53 45....AF 5C CA AE 22 2C 81 09
KEY 00(96):
98 BF 0D 27 EF D7 F9 FE....30 D2 80 3A 11 8D AF 9F
Username: Swredneck
Halifax, N.s.
Post Number: 15
thanks alot nalin how old are u we shout date lol u take care!!!
Username: Vaderpapp
Post Number: 19
i still dont get it how to fix the BEV with my sonicview sv-1000. i tried uploading the bin into my receiver but it wount work for some reason, what kind of cable do u guys use?
Post Number: 40
Nalin,
I responded too quickly. The Table you gave make
good sense. Alternatively, XOR'ing 43 with the 2nd byte of both keys, is simple enough too.
Thanks Nalin, for your great idea. Really appreciate ! Please keep up the good work !!
Username: Synister
Post Number: 13
keys please
Username: Coolsat70
Post Number: 12
I have a cool sat 4000 pro and I download a channel list with several channels from Las vegas,pittsburgh,denver,etc. I want to know how can I see these channels, specially Pittsburgh channels. Thank you in advance.
Username: Aafl_dragon
Post Number: 178
D!SH - Last Update: 09/10/07 05:20 pm
01: 98 BF 0D 27 EF D7 F9 FE 30 D2 80 3A 11 8D AF 9F (active)
B3V - Last Update: 08/30/07 11:20 pm
00: 4D 72 C7 59 38 FE 2D 3F 1D 97 2E 64 68 80 4E 23(active)
01: 56 D2 D0 C4 8A BC 0D D0 CA AB 86 5F 83 1A 83 5F
Username: Donnie1973
Post Number: 755
lol, u got a date Nalin. Maybe Jerry is a 14 yr old boy and ur soulmate? Good luck honey.
Username: Todorica
Atlanta, GA
Post Number: 9
anyone got the new keys please?
Username: Hamad786
Post Number: 13
does anyone have any new dish keys
Username: Espn3
Post Number: 61
xxx, Hamad Mirza, the DN keys posted by somedude are good at the time of this post.
Username: Todorica
Atlanta, GA
Post Number: 10
thank you, J.J. , I was fooled by the fact that all the keys were the same as last night except BF instead of FC at 01
Username: Neris
Ottawa, Ontario
Post Number: 36
which one are the new keys
Username: Lklives
Post Number: 11880
Dish Network (0101)
(Last update: (Last Update: Tue. Sep 11, 5:27 PM EST) )
86: 86 53 EC 83 1D 5A 2A 63 2B 2D 95 05 2D 82 BA FB New
Globecast (C101)
Username: Swredneck
Halifax, N.s.
Post Number: 16
i was jkoin around so don t be ignorant dantetn
Username: Efrainjr
WEST PALM BEACH, FLORIDA
UNITED STATES
Post Number: 12
DOES ANY ONE HAVE THE NEW KEYS
Username: Tvvfanatica
These keys are not working
Post Number: 765
jerry, sry, that was not meant for u. It was 4 nalin. And u used the word ignorant in the wrong context. U coulda used dumbazz. lol
Username: Lklives
Post Number: 11881
yes they are working...
Dish Network (0101)
Key 00/86: 86 53 EC 83 1D 5A 2A 63 2B 2D 95 05 2D 82 BA FB New
Key 01/96: 98 BF 0D 27 EF D7 F9 FE 30 D2 80 3A 11 8D AF 9F
Globecast (C101)
Sorry i re-entered them again and they are WORKING
Username: Hanz
Post Number: 370
LK, is the 'fight network' on your BEV working with this new ViewSat Ultra bin?
Username: Shua_raza9
u sure they are working cuz they went out an hour ago??
Username: Hanz
Post Number: 372
Well shua, do you have the program 'keymaster 4.0'?
Post Number: 766
its free to get keymaster. If u have the internet, and I know u all do... download it. Then u can get the keys in seconds after they change. And without asking anyone over and over for them. Simple. At some point we need to do things for ourselves.
Username: Letmeon
Post Number: 154
would creating BEV new provider entry on a digiwave dg6800, get BEV back ??
Username: Priyesh89
i have a sonicview SV4000 and someone please post a tutorial on how to manually enter keys and if there is any new bin released please post the link
Username: Ritz23
I am guessing Ariza Extreme doesn't have a fix yet?
Username: Jpz
MTL, QC
CAnada
Post Number: 246
thanks for the keys
Username: Lklives
Post Number: 11891
To Manually enter SonicView Keys
Menu > Entertainment Tab > Enter 7890 and "Code" will appear > Choose Nagravision for CAs and then choose Dish or Bev on the line under CAS
*Notice the two sections for Dish, being 0001 and 0101 - 0101 is the one you want to edit
-The bottom 4 lines for Dish are the ones you want to edit.
*Notice the two sections for Bev, being 0801 and 0901 - 0901 is the one you want to edit for Bev..
1) Press MENU
2) Go to ENTERTAINMENT category and press 7890
3) A CODE option will appear, press OK
4) Press the down arrow and make sure the category is on DISH <01>
5) Highlight line number "20" then press the right arrow and start entering the first 8 numbers of the active key
6) Highlight line number "21" then press the right arrow and start entering the second 8 numbers of the active key
7) Press EXIT - Click "OK" on "YES" to save the changes
8) Go into SYSTEM SETTINGS - USER OPTIONS and turn Autoroll to "OFF"
9) EXIT out of everything and wait 30 seconds, your tv should be back on.
Note: Row 10,11 are for Key 00 and 20 and 21 are for key 01
new sonicview 4000 AUTOROLL bin is at www.totalfta.com ....setit and forget it....no need to manually enter the keys...
Username: Afaizi
Post Number: 15
I had converted my FLU to a Pansat 2700 a couple weeks ago, however now I am not getting any channels as it says Scrambled or Bad Channel. When I manually enter the new keys nothing happens and it continues to say Scrambled or Bad Channel. What can I do for this? Is there a new bin out, if so which one is it and where can i find it?
Username: Ritz23
Post Number: 7
does ariza extreme have a fix yet?
Username: Pu_da_munda
Post Number: 24
I just got the C00lsat 5000. Can any one tell me how to enter the keys?
Username: Waleedhany
can anyone pls post the new dish network keyz ??????????
Post Number: 25
Username: Hades305
Post Number: 9
Coolsats:
Code:
1. Either Enter 8282 on your remote, or you can ht the “Mute” button on your
remote and then hit the “Exit” button.
2. Then Making sure that you have the very top box says 1 Nagravision for Dish
Net, or 2 Nagravision for OFF LIMITS.
3. To enter your keys, you can use the numbers on the number pad, and the info
button to change letters. Hit the Info button until you get the letter you want, then
hit the Right Arrow to change slots.
4. Or, you can hit the OK button and a new menu will pop up. Just use your arrows
to select the numbers and letters you want and hit the OK button after each one.
(Hit the exit button one time to get out of the little pop up screen.)
5. Now scroll down to the data in line 10. Enter the first half of KEY 86 (or Key 00)
in this line.
6. The go to line 11 and enter the second half of Key 86 (or Key 00) in this line.
7. Then go to line 20 and enter the first half of Key 96 (or Key 01) in this line.
8. Next go to line 21 and enter the second half of Key 96 (or Key 01) in this line.
9. Now hit the Exit button.
10. When the next screen pops up asking if you want to save changes, Use your
arrows and select “Yes” and hit the “OK” button.
11. Now, change your channel, and watch TV.
Post Number: 782
Username: Rainman62
Post Number: 27
Is there a software to build a bin for coo1sat? in particular coo1sat 5000?
Post Number: 26
Thanks Hades305
Username: Outlaw0_0
did the keys just get changed?
Username: Outlaw0_0
never mind got it working
sorry i'm new to all this .. where can i find this keymaster program and can anyone pls just post the keys for now .. thx
Username: Espn3
Post Number: 68
waleed, go above on this thread till you find the keys. they are latest one. and remember:
KEYS ARE THE SAME FOR ALL BOXES.
there is also a post about keymaster program.
Mexico, DF
Mexico
Post Number: 186
SamS:
http://ftabins.net/forumdisplay.php?f=104
You can get c00lsat bins. You don't need to build one, they are already available
Mexico, DF
Mexico
Post Number: 187
Download Keymaster:
http://ftasignalmex.com/claves.html
Check new keys:
http://www.ftasolutions.blogspot.com/
Username: Sheena123
any one have the new keys for bev i want to watch the match 20/20
Username: Nydas
Post Number: 3712
juan Cavazos : That was an excellent way of answering SamS regarding building BINs. I wish more people use such tact.
Username: Sheena123
its coming on ckrt 1 on bel 91.0w BUT SCH OR BAD CHANEL AND AFTER A WHILE WAIT FOR PIC CAN ANY ONE HELP ME I AM NEW HERE
Username: Banti
Post Number: 200
u have to input the codes and turn autoroll off thats the only way
Username: Fasoy
I have 3 dishes installed 110, 119 & 61.5 and now I want to change one of them to BEV. Do I need a new bin file for BEV? what is the direction for BEV? I have Viewsat Extreme....any help appreciated.
Username: Hydro_blazer
Post Number: 12
New Keys Please
Username: Saaju
NEW KEYS??
Username: Saaju
96: 7E FE C3 C1 2F 09 26 DD 45 C4 74 3E 26 02 52 40
Username: Sskhan
Mississauga, On
NEW KEYS PLS
Username: Pakistan786
Centralislip, Ny
Usa
new keys?plz
Username: Fasoy
Username: Fasoy
I have 3 dishes installed 110, 119 & 61.5 and now I want to change one of them to BEV. Do I need a new bin file for BEV? what is the direction for BEV? I have Viewsat Extreme....any help appreciated.plzzzzzzzzzzzzz help me....
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through September 12, 2007 [ « Previous ] [ Next » ]
