Thread: Sima |
New member Username: Kaljo17
Post Number: 3 Registered: Aug-07
| Posted on Friday, September 07, 2007 - 02:04 pm: |
i have heard that you can use a sima product to get around copyright protected materials. which one is the best? and is there a place where i can find these products for cheap? any information would be helpful. thanks. |
Relevant Product Info
Gold Member Username: Samijubal
Post Number: 3535 Registered: Jul-04
| Posted on Friday, September 07, 2007 - 08:56 pm: |
I don't think Sima makes stabilizers anymore. If you want one you'll have to look on Ebay or Amazon marketplace. Either way it won't be cheap. |
Post Number: 4 Registered: Aug-07
| Posted on Friday, September 07, 2007 - 11:29 pm: |
is there another kind of product that i can use to bypass the copyright protection? |
Post Number: 3537 Registered: Jul-04
| Posted on Saturday, September 08, 2007 - 12:23 am: |
On what? |
Post Number: 5 Registered: Aug-07
| Posted on Saturday, September 08, 2007 - 09:38 am: |
sorry, i have a vcr/dvd recorder combo and i was looking to make dvd copies of all my vhs tapes. |
Post Number: 3539 Registered: Jul-04
| Posted on Saturday, September 08, 2007 - 01:49 pm: |
With most combos you'll need a seperate VCR. Look for a video stabilizer on Ebay. The only one I can say that should work for sure is the Dimax Grex, it's about $90. |
