Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through September 01, 2007
Author Thread: Archive through September 01, 2007
Username: Johnner
Miami, Florida
Post Number: 1197
keymaster 4.0
http://dsscentral.net/files2007/uploads/keymaster4.0.zip
Username: Vaderpapp
Post Number: 12
bev keys dont work
Username: Cacalad
Post Number: 32
dish keys please
Username: Jpz
MTL, QC
CAnada
Post Number: 244
BEV keys are not working guys !!!!!!
Username: Phlyer
Ontario
help please, i have put in the new bin for my pansat 2700 and now all i have are lines across my system instead of numbers can someone please guide me
Username: Phlyer
Ontario
i have turned off and still nothing my connections are fine,did I perhaps short out my box? I don't know, any ideas?
Username: Vaderpapp
Post Number: 13
word is that BEV has major cracked down, even paid customers are down too. is that true?
Username: Destine0429
Quebec
Post Number: 259
Bev is not working. It is down for everyone. Regardless of how many times you enter in the proper keys, it will not work. Fix your dish so it is aiming another satellite other then Bev. DN is working fine. Keys have been perfect all day.
If you do not believe me, enter them in and see for yourself. For DN make sure the autoroll is off before entering in the new keys. Otherwise, it will only work for a few minutes.
D!SH - Last Update: 08/29/07 09:43 pm
00: 75 82 0F 40 52 1F 72 2F 83 68 56 6A 03 0D C5 F2 (NEW)
01: 30 62 43 D1 2F BE 28 22 E6 57 B1 C0 4C 52 B8 A1
B3V - Last Update: 08/30/07 03:58 am
00: 7E EE 27 6D 90 7B AE 79 17 F1 D0 DA 00 FE E6 31 (NEW)
01: 56 D2 D0 C4 8A BC 0D D0 CA AB 86 5F 83 1A 83 5F
Username: Hanz
Post Number: 350
No a b. Bev's satelite fell from the sky, that's all.
That's pretty funny though if paid customers are down.
Quebec
Post Number: 260
a b , no that is not true. I have friends who subscribe to the Bev and it is working perfectly.
Quebec
Post Number: 261
Helen, if you are using the BEV, and it says scrambled or bad channel, than it is because BEV is down for everyone. Best bet is to repoint your dish to DN
Username: Snw7619
Bahamas
Post Number: 23
those new key dont work with my pansat 2500
it says "scrambled or bad channel"
send help
Username: Araza
Post Number: 25
shannon see if it says "wait for picture". if it does then put new DN keys in if not then check how strong your signal is.
Username: Mikek
Post Number: 33
Can any body suggest, which one is the best receiver to buy these days?
Username: Hanz
Post Number: 351
Is Bev down completely now? Or are there a few channels here and there still left?
Username: Araza
Post Number: 26
DISH - last update 08/29/07 12:18 am EST
key 86: 75 82 0F 40 52 1F 72 2F 83 68 56 6A 03 0D C5 F2
Key 96: 30 62 43 D1 2F BE 28 22 E6 57 B1 C0 4C 52 B8 A1 < ACTIVE
Username: Araza
Post Number: 27
I think there are only a few that are working
Username: Araza
Post Number: 28
mike try pansat 2500a it works most of the time
Username: Snw7619
Bahamas
Post Number: 24
AHMED how do i check signal?
Username: Jasooon
Post Number: 9
any bin for FLU ?
Username: Canndy
Post Number: 432
All latest files @ www.livefta.com when they are out. All latest news and updates @ www.livefta.com
Latest keys can be found at @ www.fta123.blogspot.com
Username: Snw7619
Bahamas
Post Number: 25
my dish network pansat not working "scrambled or bad channel"
help please.
Quebec
Post Number: 262
MIKE, do not buy a Pansat 2500a. This receiver will be running out of space soon and will not be able to handle anymore bins. Try buying something alittle more advanced. Like a Viewsat Extreme or Viewsat Ultra
Username: Gagan
yoo someppl said thtth dishnetwork is wrkin bh i entered the new keys/ turned off autorolll nun is happenin soooo someone plzz help or atleast clariffy weather it is wrkin or nah
Username: Phlyer
Ontario
i know the system is down,i can't get the box to turn on after i downloaded a new bin from my pc.all i get are short flashing lines that are moving across the box front where the numbers are supposed to be.
Username: Phlyer
Ontario
thanks for the responses that you have given me
Username: Dude123
Post Number: 1116
whats you box? and which file did you download?
Username: Kns
Brampton, Ontario
Post Number: 30
hey guys are there any new dn keys? thanxs
Username: Bud_electric
Winnipeg, Manitoba
any 1 know whats wrong with veiwsat?
Username: Dude123
Post Number: 1118
whats the problem? give some details
Username: Phlyer
Ontario
Post Number: 7
the one ,pansat 2700 x87BL_070816_B75_208_api.zip. this is what i downloaded
Username: Dude123
Post Number: 1119
did you upgrade your receiver with the boot B-75 fiile first before downloading that file?
Username: Dude123
Post Number: 1120
you have to upgrade your receiver first with
Boot_2700A(b75)_(07)0310
and then you can download the latest bin file which is
X-87BL_070816_B75_208_api
but its only for Dish Network right now BEV is down...
Username: Phlyer
Ontario
Post Number: 8
i un plugged the pansat from my tv, brought to my pc ,downloaded a new bin ,plugged it back to my tv and i had no number in the front of the box, just a flashing little line, i can't bring up the menu or anything the box is not responding
Username: Dude123
Post Number: 1121
well you might have just downloaded the bin 208 on the older boot file which was B70. so as I said download the B75 file first and then download bin 208 once again...
Username: Phlyer
Ontario
Post Number: 9
that will get my box working again if i download Boot_2700A(b75)_(07)0310 , i know that BEV is down,i just need to get the darn box going. thanks
Username: Dude123
Post Number: 1122
yes download Boot_2700A(b75)_(07)0310 first and then you also have to download X-87BL_070816_B75_208_api and that should get your box up and running....
Username: Phlyer
Ontario
Post Number: 10
thanks so much , one more thing where can i get that file
Username: Dude123
Post Number: 1123
future-fta.info you will have to register there for free and then you can download the file from "pansat 2700 A/E" section
after downloading it to your computer dont forget to unzip the file before puting in onto your receiver and turn autoroll ON after its done let it autoroll and you will be good to go.....GOOD LUCK!!!!
Username: Gagan
is there something rongg with viewsat???
Username: Dude123
Post Number: 1124
Username: Oleg1474
New port richey, Fl
Usa
Post Number: 370
Please Help !!!to setup dish (Intel-5)97.0(G-25)Thank you...
Username: Kamranca
Post Number: 31
Hi all plz any one help me i have FTA ultra time reciver and daily i need to change keys (2 times a day atleast)..is there any BIN FILE for my reciver for Update keys automatically..
Thanks in advance thanks verey much
reply me please im waiting
Username: Dude123
Post Number: 1126
nope you gotta enter them manually...no autoroll for those receivers ...
Username: Kamranca
Post Number: 33
:-(: thanks for this information the one ....and plz one more question which recever should i buy in which keyes updated automatically..with the help of BIN FILE
thankss in advance
Username: Kamranca
Post Number: 34
plz reply me imm waiting
Username: Dude123
Post Number: 1127
the best ones out there right now is viewsat ultra with the best support....but I wouldnt buy anything right now because there are rumours that FTA might be dead FOREVER!!!! don't mean to scare you but I wouldn't get anything right now because BEV is down and DN will follow what BEV just did so just have some paitience and be happpy with munual key entry!
Username: Aafl_dragon
Post Number: 173
Right now viewsat is rolling fine and pansat 2700a but I recommend you buy viewsat.
Username: Sokol
Post Number: 23
The One
I have asked this question this morning and Nalin gave ma partial answer but i was thinking that you may now better
I have pansat 2700A (original not clone) with the latest bin which is X-87BL_070816_B75_208_api.zip. I mam trying to place the keys for C1 01 which is Globecast however i have all zeros for the key entries (key data) (0) and i am not able to add any other values i click on the remote control the objects are moving but they stay zero and cannot be chaned. Before loading the latest bin i was able to change the values. Any help would be appreciated.
Thanks in advance
Sokol
Username: Dude123
Post Number: 1128
Sokol
Read this it might help
http://forum.ecoustics.com/bbs/messages/2/384695.html
Username: Sokol
Post Number: 24
Many Thanks The One, the link with the info fix the problem.
Thanks again and have a good night
Sokol
Username: Dude123
Post Number: 1131
My Pleasure!!! Answers are always there you just gotta read a little bit...thats it!!!!
Username: Juanjose
Post Number: 39
DN and Bev Keys Feed
Nag2 keys
Dish Provider 0101: Last Updated (30 Aug '07 12:18 AM EST)
Key 0: 75 82 0F 40 52 1F 72 2F 83 68 56 6A 03 0D C5 F2
Key 1: 30 62 43 D1 2F BE 28 22 E6 57 B1 C0 4C 52 B8 A1(Active)
Bev Provider 0901: Last Updated (29 Aug '07 2:10 PM EST)
Key 0: 4D 72 C7 59 38 FE 2D 3F 1D 97 2E 64 68 80 4E 23 (Active)
Key 1: 56 D2 D0 C4 8A BC 0D D0 CA AB 86 5F 83 1A 83 5F
thanks jhonner
Username: Juanjose
Post Number: 40
this keys are working fine for bev
Username: Beenthere
Post Number: 8
I put the keys in and still down. What else do I have to do?
Username: Fizzy
Post Number: 9
Hey how is everyone i just wanted to stop and say thank you to everyone in this forum without you guys man i just dont know i guess we would have to pay for sattelite tv and we all know everyone in here is too cheap to pay for it anywys thanks again for everyones help
Username: Curler
Post Number: 38
I have a fortec star ultra. The keys don't work (just scrambled channels). I think the bin number needs to be changed. Could someone please help me out, whether keys or bin. I would like the bin number that works.
Username: Phlyer
Ontario
Post Number: 11
thanks so much the one for your help last night,keeping my fingers cross that this works. have a good day.
Username: Curler
Post Number: 39
I should have said I'm on the bev.
Username: Nanny
Que
i have buzz s2010azan.
bev is down. i download file (03 Aug2007) and change the keys.
now i have ( please wait for up date )on my screen Tv.
Please help. thanks
Username: Dude123
Post Number: 1132
DF
BEV is down for 2 days now, and there won't be a fix anytime soon. I suggest you point yout dish to any DN direction for the time being....
Username: Hanz
Post Number: 352
The Fight Channel on Bev is still working as of last night when I checked.
Username: Sennis
i cant get my 600s premium to work. everything comes up as scrambled channel. is this just something to do with hte box cause my actual expressvu reciever is still working fine
Username: Aanaa
Post Number: 188
BEV some channels are working
but not PPV/xx/
again on 82 --same some working not all
Username: Nydas
Post Number: 3553
DF: You need 294T from
http://www,dssrookie.com
http://www.f2atv.com
BEV is down for the past 24 hours or so.
Username: Jaz06
Post Number: 32
what are the latest dish keys please?
Username: Johnner
Miami, Florida
Post Number: 1200
DISH - August 28
BEV - August 29
86: 4D 72 C7 59 38 FE 2D 3F 1D 97 2E 64 68 80 4E 23
96: 56 D2 D0 C4 8A BC 0D D0 CA AB 86 5F 83 1A 83 5F
GCast - Aug 28
86: AF 7E B4 AE AE AD EE 24 C5 EB 4F 38 CA 7A 3A 76
96: 02 69 13 13 FF 8A 14 F2 06 D2 9A FA 4F 32 1F D3
Username: Teajay101
Arkansas
Post Number: 8
Johnner and Jaz....The latest Dish keys I have, and they're working, are:
86: 5C D9 1C 90 A5 8E A9 A5 A8 67 0C D8 ED 4C 4E 1A
96: 30 62 43 D1 2F BE 28 22 E6 57 B1 Co 4C 52 B8 A1
Username: Codigies
Where do you go to download the new keys onto your USB. We have a viewsat ultra and are totally new to this. Right now we have it pointing to BEV but I guess that's down so we are going to try to get the DN keys. Can you download keys on a MAC?
Username: Snw7619
Bahamas
Post Number: 26
dish keys not working with my pansat 2500
Username: Snw7619
Bahamas
Post Number: 27
is something wrong with my reciever because it's sunny outside on clouds and it been like this with no satillite since yesterday
Username: Snw7619
Bahamas
Post Number: 28
is pansat 2500 done should i trash it now?
Username: Araza
Post Number: 29
shannon my pansat is working perfectly check how much signal its getting.
Username: Araza
Post Number: 30
press ENTER on any channel. then look at the bottom right hand corner. the RED line is the the signal. if the is NO signal there then try reseting your pansat. if the problem still continues contact your DN provider.
Username: Godsgift
bev is back up and working...all channels thank god
Username: Snw7619
Bahamas
Post Number: 29
ok i fixed it myself
had to restore default factory keys
then put new keys in
thanks anyways.
Username: Vaderpapp
Post Number: 14
bev keys plz
Username: Snw7619
Bahamas
Post Number: 31
aww back off again
which are the new keys which are working now please guys
Username: Nydas
Post Number: 3556
DN keys posted by Johnner are working fine.
BEV is mostly down, according to reports.
GC is available With Pansat 2700 and others
Most receivers have a good autoroll BIN. It is working well with DN but currently not working with BEV. We do not know how long this may last and whether DN will follow suit. Hold off buying a new receiver as "The one" has already cautioned.
Fortec Ultra and Pansat 2500A and its clones have BIN 292T, which works up to a point. Let the keys roll in and when it goes to a second round after 300% or 450%, go to Nagra2 and change the first number in both Key 00 and key 01. You will probably not need to update other numbers.
Switching off at the back for 30-40 seconds is good for getting apicture. The 294T BIN at installation gives current date as 01/01/2006. You must change it ot current, and set the time and time zone as well.
Please do not keep on asking for new keys. If there is key change it gets posted here usually BEFORE it is posted at the key getting sites. This simply because people who have active autoroll BINs see the download of keys and immediately post here. So read and check instead of posting.
BEV is mostly down. There are a couple of threads on the forum about this subject - go and read there.
Username: Codigies
Any advice for me yet?????
Username: Snw7619
Bahamas
Post Number: 32
Nalin help me with this i put in new keys it says "scrambled or bad channel"
how do i get it to say 10%ect downloading so keys will work
pansat 2500
Username: Nydas
Post Number: 3559
Codi Gies
http://www.totalfta.com - Viewsat semi-official site.
http://www.dssrookie.com
Get the file on your computer. UNZIP it. put the unzipped version into your USB drive and then load it into your viewsat ultra following the manual instructions.
Username: Carles
I have a Pansat 2500a and have not changed the file for I can't remember when and other than set the default key and put in the DN numbers its just keeps on ticking..so far.}
Username: Bertoro
Toronto, Ontario
Post Number: 668
carole.....and?
Username: Johnner
Miami, Florida
Post Number: 1203
Nalin Nyda
BEV is now working back to 100%
Tommy Johnson
In Dish the key that is active is currently 01 that is why yours are working too.
DISH - August 28
BEV - August 29
GCast - Aug 28
Username: Godsgift
bev keys that johnner has posted are working fine bev back up cause paying members were losing signalDown also...........
Username: Jimminiquick
Pansat 2700a - i have new keys everything seems to be set, but it continues to scan for a picture over and over ("Wait for Picture!!!(450%))
any ideas??
Username: Sennis
i use bell expressvu dish, and i am new to this, which keys do i use? the dish ones or the bev ones or the gcast ones? wahts the diff?
Username: Serazoo
Post Number: 27
Hi all...
Howcome BEV is back on 100% ? I'm extremely glad, but I would like an expert to tell un the full story.
Is this only a tease from Bell, and that the real storm is coming ?
I've read many boards about Bell changing their systems, so what's going on then ?
thank you
long live FTA !
Username: Hanz
Post Number: 356
jeff kusak, it's been said that the little bev blackout caused even bev subscribers to get hit, so there's probably been a glitch in their new system.
Username: Serazoo
Post Number: 28
ok I see...
I presume the new system of BEV will be a softwear change, I find it a litle far fetched that it could be a hardwear change meaning that every customer of Bell's will have to change their unit.
So if my hunch is correct, do you think we'll be able to bypass this new system change ?
anyone ?
cheers
thanks for the insight!
Username: Drbell
Bell 3100 receiver Pay Per View just went down is anybody facing the same??????}}
Username: Nydas
Post Number: 3561
There is an ECM by Bell. It was off for a while and seems to be on again.
Username: Carittopqt
Funny...my BEV numbers are working but I'm not getting any PPV!
Username: Johnner
Miami, Florida
Post Number: 1209
BEV
ECM in progress...
PPV, PORN, and some HDS are down.....
B3V - Last Update: 08/30/07 11:20 pm
00: 4D 72 C7 59 38 FE 2D 3F 1D 97 2E 64 68 80 4E 23
Sorry, I guess I should have read back farther. LK (always steers me right) reported what was going on on the 29th of AUG. I just didn't go back far enough.
Thank you for the info!
Username: Fastbeatz
Post Number: 224
whatr the latest dish net keys i have these
but they dont work!!!
Username: Kingusama
Post Number: 293
visit www.ftasolutions.blogspot.com!!!
Username: Shervin62
Post Number: 14
anyone has the new keys for bev?
Username: Codigies
What's an ECM? When will the ppv be back up?
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through September 01, 2007 [ « Previous ] [ Next » ]
