Home > Message Board > Home Video > Satellite TV > Archive through September 05, 2007 > COMPLETE INSTRUCTIONS FOR ENTERING KE...
Author Thread: COMPLETE INSTRUCTIONS FOR ENTERING KEYS ON PANSAT FOR PAUL DIAS
Username: Tigger_woods
Post Number: 109
Rep Points: 9715
Key Change for Various Receivers
Feel free to add any receivers that are missing.
PANSAT
Hit menu > Parent Control > second password > type 0000
Scroll down to Nagravision 2, hence not one....
Arrow down to where the 16 digits are and ignore 01 and 02, just go straight to the keys
Enter in the top row of keys (first 16 digits)
3D 73 19 22 27 5D C2 C9
then go to the line under that and enter the next 16 digits
97 96 5A 0C A5 79 27 F9
After that's done, hit OK twice (to make sure it's saved). You DONT have to hit "set default" because you guys did that before (hopefully). Exit out of everything and it should work.
If it doesnt work, try simple things like
> Changing the diseq settings, make sure your satellites are getting quality
> Are the keys correct, maybe you typed one wrong, it happens
> Did you save
> Do you have the latest bin (currently 261, available here)
Pansat Key Change with 123 bin and Higher
1. Press Menu button, then scroll down and Select Parental Controls goto 2nd PIN/enter 0000.
2. Scroll down to Nagravision 2, press OK.
3. On the Provider ID BOX, provider ID 0101,
4. Scroll down to KEY NUMBER BOX, you should have 00.
5. scroll down to KEY DATA BOX, enter the new N2 key00: 3D 73 19 22 27 5D C2 C9
6. scroll down to KEY DATA BOX, enter the new N2 key01: 97 96 5A 0C A5 79 27 F9
7. Confirm the N2 keys are correct, then press OK to save the new key. Then press EXIT a few times, and you will watching TV right away.
How To Manually Enter Keys For Viewsats:
Home > Message Board > Home Video > Satellite TV > Archive through September 05, 2007 > COMPLETE INSTRUCTIONS FOR ENTERING KE... [ « Previous ] [ Next » ]
