Home > Message Board > Home Video > Satellite TV > Archive through September 05, 2007 > Tiger Woods celebrates Silver members...
Author Thread: Tiger Woods celebrates Silver membership....ALL WELCOME
Username: Tigger_woods
Post Number: 102
That`s right folks, I have been inducted into the Silver hall of fame.
I would like to take this time to thank the little people that I stepped on along the way. With out them this would not be possible.
Feel free to ask me for bits of wisdom etc...
And they claim Neosats and Bluejay are working????
Username: Chilli
Post Number: 12
getting started with my new 250sm.what is the bin that i need and how do you manualy enter the keys
Post Number: 104
I no longer have a Pansat....but from memory...go to menu,hit parental control, put in password 0000, hit nagra 2,then find the sat you are looking for. Dish 0101 for 119 and 110
type in the keys...under 01/ put in the 01 keys
under 02/ put in the 02 keys. thats the best from my memory. hit save and hopefully watch tv.
Username: Yashmatharu
Brampton, Ont
Post Number: 103
i am planning to retire my pansat 2500a. which receiver do you have?
Username: Chilli
Post Number: 13
just got a new pansat 250sm do you know what i need to do to get it up and runnig.like what bin i need.when i go to parental control it asks for the password and to confirm it but that is it.some help would be great.
Username: Asharfi
Post Number: 764
Congratulations, Tiger Woods!
Username: Amex
Post Number: 522
Post Number: 106
Thanks, I am touched
Means so much, especially after the thumping I took from Phil yesterday. I will look for a how to for paul dias.
Post Number: 107
Here ya go paul dias
Rep Points: 9715
Key Change for Various Receivers
Feel free to add any receivers that are missing.
PANSAT
Hit menu > Parent Control > second password > type 0000
Scroll down to Nagravision 2, hence not one....
Arrow down to where the 16 digits are and ignore 01 and 02, just go straight to the keys
Enter in the top row of keys (first 16 digits)
3D 73 19 22 27 5D C2 C9
then go to the line under that and enter the next 16 digits
97 96 5A 0C A5 79 27 F9
After that's done, hit OK twice (to make sure it's saved). You DONT have to hit "set default" because you guys did that before (hopefully). Exit out of everything and it should work.
If it doesnt work, try simple things like
> Changing the diseq settings, make sure your satellites are getting quality
> Are the keys correct, maybe you typed one wrong, it happens
> Did you save
> Do you have the latest bin (currently 261, available here)
Pansat Key Change with 123 bin and Higher
1. Press Menu button, then scroll down and Select Parental Controls goto 2nd PIN/enter 0000.
2. Scroll down to Nagravision 2, press OK.
3. On the Provider ID BOX, provider ID 0101,
4. Scroll down to KEY NUMBER BOX, you should have 00.
5. scroll down to KEY DATA BOX, enter the new N2 key00: 3D 73 19 22 27 5D C2 C9
6. scroll down to KEY DATA BOX, enter the new N2 key01: 97 96 5A 0C A5 79 27 F9
7. Confirm the N2 keys are correct, then press OK to save the new key. Then press EXIT a few times, and you will watching TV right away.
How To Manually Enter Keys For Viewsats:
Username: Lklives
Post Number: 11612
congrats DD...
Home > Message Board > Home Video > Satellite TV > Archive through September 05, 2007 > Tiger Woods celebrates Silver members... [ « Previous ] [ Next » ]
