Thread: Pansat 250 sm |
New member Username: Chilli
Post Number: 10 Registered: Jan-07
| Posted on Monday, September 03, 2007 - 10:05 pm: |
how do you manually input the keys into the pansat 250 sm.Thanks |
Bronze Member Username: Chilli
Post Number: 11 Registered: Jan-07
| Posted on Monday, September 03, 2007 - 10:06 pm: |
can you use the usb memory stick to put in new bins or will it kill the receiver |
Silver Member Username: Alfons_ramahotmailcom
Call me when...
Albanian
Post Number: 109 Registered: Jan-07
| Posted on Monday, September 03, 2007 - 10:35 pm: |
no that will no kill you receiver by using your USb stick. Everything runs fine but when I lock a channel with a password, it still shows the channel. Is that just a bug or what ? |
Bronze Member Username: Tigger_woods
Post Number: 99 Registered: Jun-07
| Posted on Monday, September 03, 2007 - 10:38 pm: |
Drop on over to my silver anniversary party, maybe we can get you goin. |
Silver Member Username: Tigger_woods
Post Number: 108 Registered: Jun-07
| Posted on Tuesday, September 04, 2007 - 08:23 am: |
INSTRUCTIONS FOR PAUL DIAS Join Date: Jan 2001 Location: Earth Posts: 2,588 Rep Power: 250 Rep Points: 9715 Key Change for Various Receivers -------------------------------------------------------------------------------- Feel free to add any receivers that are missing. PANSAT Hit menu > Parent Control > second password > type 0000 Scroll down to Nagravision 2, hence not one.... Arrow down to where the 16 digits are and ignore 01 and 02, just go straight to the keys Enter in the top row of keys (first 16 digits) 3D 73 19 22 27 5D C2 C9 then go to the line under that and enter the next 16 digits 97 96 5A 0C A5 79 27 F9 After that's done, hit OK twice (to make sure it's saved). You DONT have to hit "set default" because you guys did that before (hopefully). Exit out of everything and it should work. If it doesnt work, try simple things like > Changing the diseq settings, make sure your satellites are getting quality > Are the keys correct, maybe you typed one wrong, it happens > Did you save > Do you have the latest bin (currently 261, available here) Pansat Key Change with 123 bin and Higher -------------------------------------------------- 1. Press Menu button, then scroll down and Select Parental Controls goto 2nd PIN/enter 0000. 2. Scroll down to Nagravision 2, press OK. 3. On the Provider ID BOX, provider ID 0101, 4. Scroll down to KEY NUMBER BOX, you should have 00. 5. scroll down to KEY DATA BOX, enter the new N2 key00: 3D 73 19 22 27 5D C2 C9 6. scroll down to KEY DATA BOX, enter the new N2 key01: 97 96 5A 0C A5 79 27 F9 7. Confirm the N2 keys are correct, then press OK to save the new key. Then press EXIT a few times, and you will watching TV right away. How To Manually Enter Keys For Viewsats: |
