Thread: Power on issue after FLU to 2700 upgrade |
New member Username: Joe_sceptical
New York
United States
Post Number: 4 Registered: Aug-07
| Posted on Monday, September 03, 2007 - 09:07 pm: |
Ever since the upgrade, I need to power off the unit and then back on to get it started. What's up with that? Is there a fix? |
Bronze Member Username: Tigger_woods
Post Number: 98 Registered: Jun-07
| Posted on Monday, September 03, 2007 - 10:37 pm: |
Sorry I cant help you with that, but drop by for my Silver anniversary party. |
Silver Member Username: Viruscauser
Leesburg,
Georgia
Post Number: 143 Registered: Mar-07
| Posted on Monday, September 03, 2007 - 11:05 pm: |
Joe Sceptical the new fix has a bug that causes it to lose a sat once in a while. Reboot usually fixes that. If your problem is bigger than that, I suggest you flash with the jvvh_208 bin one more time. That might help improve matters. |
New member Username: Mancella
Post Number: 4 Registered: May-06
| Posted on Tuesday, September 04, 2007 - 06:56 pm: |
Same thing here. I have been losing signal constantly. Either 110 or 119 goes down where one works and not the other. Then I have to turn off the power on back and restart. Also, occasionally when I turn off using the power button and try to turn back on, the thing will just stay showing the clock and not turn on. Once again, I have to turn off the switch and back on. Don't get me wrong, it's great when it works..but it does have some bugs. |
