Thread: Uploading channels to converted Pansat 2700 from 2500 |
Bronze Member Username: Nyc_alien
Staten island,
Ny
Us
Post Number: 61 Registered: Dec-04
| Posted on Monday, September 03, 2007 - 08:58 pm: |
Hey all, I have successfully converted my Pan5at 2500A to 2700A. However, I cannot upload channel list using Gtools or Channel updater. Both programs not connecting to the box. I'm still using Straight DB9 cable. Do I have to change it to Null since the Box is acting as a 2700? A satellite scan is not giving me the whole channels that I used to have. Please help. If there is a better program, please provide the location. |
Silver Member Username: Asharfi
Post Number: 763 Registered: Aug-06
| Posted on Monday, September 03, 2007 - 09:46 pm: |
Just simply re-scan your satellite(s). You'll get some new channels, too from Dishnetwork. |
Bronze Member Username: Sam5002
Ny,
Ny
Usa
Post Number: 15 Registered: Jan-06
| Posted on Monday, September 03, 2007 - 10:24 pm: |
Now, my FLU has been converted to 2700.When i go to installation/antenna setup/ I can only see echo 110,119,nimiq 1/3 on left pane.I have my original channel list from FLU as *.bin file before conversion. How can i write this channel list to my receiver using channel master or any other channel programs? Is it safe to do so? |
Bronze Member Username: Tigger_woods
Post Number: 97 Registered: Jun-07
| Posted on Monday, September 03, 2007 - 10:35 pm: |
You are all invited to the Tiger Woods Silver membership presentation...shortly |
Staten island,
Ny
Us
Post Number: 62 Registered: Dec-04
| Posted on Monday, September 03, 2007 - 11:47 pm: |
I did the re-scan. But still the same channels. Need to know the program that I can upload an channel list. |
Silver Member Username: Viruscauser
Leesburg,
Georgia
Post Number: 144 Registered: Mar-07
| Posted on Tuesday, September 04, 2007 - 12:11 am: |
nyc alien, do a factory reset first and then try the installation menu for rescanning. Set the correct values for the LNB and the Diseqc switch. If you rescan (my preferred method) do a BLIND scan not a sat scan. Yes you use the same straight cable that you used to use with your box when it was a 2500. The software has changed, the hardware is the same. I don't know why you had a problem getting the Channel Master to work because it works fine for me. Try getting a fresh copy of the Channel Master. Maybe your data is corrupt? Try looking for (google "SAIDias Megamaster") a ready channel list and try with that. Like I said, I get the best results with a fresh blind scan. |
New member Username: Armaniousm
Post Number: 1 Registered: Aug-07
| Posted on Tuesday, September 04, 2007 - 02:41 am: |
I have all the channels, but my pansat 2700 will not list what is on when i push epg (to get guide). So I do not know what is on. Is there a fix? |
