Thread: Sonicview 4000 Master Guide.. |
Platinum Member Username: Lklives
Post Number: 11591 Registered: Jan-06
| Posted on Monday, September 03, 2007 - 05:52 pm: |
Master Guide for SV4000 ...c/p Guide includes: 1.How to upload bin file via USB. 2.How to upload softkey via USB. 3.How to manually enter keys. 4.How to program SV remote. 5.Master password for remote. 6.How to populate EPG. 7.How to scan satellites. SonicView 4000 Guide How to Load Bin to Sv-4000 With USB Memory Stick 1. unzip file 2. save unzipped file to memory stick 3. press menu 4. insert memory sick into front USB port 5. choose installation 6. scroll down and choose USB mass storage 7. press ok 8. scroll down and choose correct file 9. press red button and file will load 10. don't touch file will load and machine will reboot on its own How to update softkey on SV 4000 via USB 1. Turn Auto Roll off on your STB 2. Download the program 3. Use it to generate a softkey. 4. Copy the softkey on a USB memory stick. 5. Connect the USB key to your STB. 6. Go to Menu > Install > USB Mass Storage. 7. Scroll down to the softkey and push red to install. 8. Reboot the STB using the back switch. How to enter keys manually for SV receivers 1. Set auto roll to off under system settings -> user options 2. Go to Menu 3. Select Entertainment and enter 7890 4. CODE will come up at the bottom - scroll down to code then click OK 5. Look for Cas <nagravision> 6. Dish 01 01 00 7. Scroll down to line 10 and 11 for Keys 0 8. Scroll down to line 20 and 21 for keys 1 Key 00/86 Line 10: 00 00 00 00 00 00 00 00 Line 11: 00 00 00 00 00 00 00 00 Keys 01/96 Line 20: 00 00 00 00 00 00 00 00 Line 21: 00 00 00 00 00 00 00 00 How to program the Sonic view remote Manual remote code entry: * Press the TV button (or selected device) * Hold the TV button and OK (or selected device) until it stay light up * Enter the code (locate in the Universal Remote Control Key list in the Manual * Press the OK button to confirm (selected device will blinks 3 time) Auto code search: * Press the TV button (or selected device) * Hold the TV button and OK (or selected device) until it stay light up * Press the Channel Up (CH+) button until the device turns off or on * Press the OK button to confirm (selected device will blinks 3 time) How to recover your PIN if you forget it In case you change the default pin number (0000) on your sonicview receiver by accident or later on forget what the PIN number was, you need to use the sonicview MASTER PIN to reset the PIN on your receiver. Here is the MASTER PIN for all sonicview receivers. 2242 How to fully populate your EPG (electronic programming guide) Make sure "Stand-by EPG" is turned on by going to Menu > System Setting > User Option > Stand-by-mode EPG and turn it "ON", if it is not already turned on. Now exit out of menu and put the receiver is in stand-by by pushing the big red power key on your remote control. Wait for 5 minutes and then turn the receiver back ON. Now your EPG should be fully populated. If you turn the receiver off using the back switch, you need to repeat the above EPG population ------------------------------------------------------------------------------- by valiant ever wonder what channels populate epg better then others? here’s a list of some popular satellite their tps and channels. transponders and channels for egp satellite 61.5w 12632 R tp 29 channels 607/615/620/778 satellite 82w 12224 R tp 1 channels 260/337/574/578/654/716/ 718/719 satellite 91.3w 12268 L tp 4 channels 158/211/212/507/521/559/ 615/621/627 satellite 105w 11740 H tp 2 channels 7000/9385/9386/9387/9388/ 9390/9391/9392 satellite 110w 12326 L tp 8 channels 503/506/507/510/516/521/523/524/100 satellite 118.8w 11840 R tp 7 channels 799/800 satellite 119w 12472 L tp 18 channels 146/239/418/424/427/436/438/572/ 12486 R tp 19 channels 200/202/303/320/333 satellite 121w 12016 V tp 21 channels 733/734/737/738/761/766 satellite 129w none satellite 148w 12486 R tp 19 channels 607/609/615/620/778 hope this helps "why does Dish 119 info fill up, but Dish 110 doesn't"? To get a 7-Day Guide on Dish 110 and 119, press the SAT button on your remote. Highlight "Dish Package" and press "OK". If you don't have both 110 and 119, then select the Dish Sat that you do have. Exit out of the menu and Press the Guide button. leave it sit on that channel for a few minutes. The longer it sits, the more EPG will fill up, 7-Days max. To get a 3-Day Guide on BEV, press the SAT button on your remote. Highlight "BEV package" If you don't have both 82 and 91, then select the BEV Sat that you do have. Exit out of the menu and Press the Guide button. leave it sit on that channel for a few minutes. The longer it sits, the more EPG will fill up, 2-3 Days max. The EPG can NOT fill up if you've selected "All SAT" from the SAT LIST button. Also, it can not fill the BEV EPG while watching Dish and vice-versa...that is just NOT possible, because the EPG fills GUIDE data ONLY from the provider you are watching. How To Rescan Satellites Just a guide I prepared for some friends to rescan satellite. Rescanning Instructions for Sonicview SV-1000 First off, you will have to delete the present scanned in channels before you scan in the new ones or you will get duplicates of some channels. You must write down your present settings so you can input them again later. Click Menu Make sure you are in Installation Menu. If not, right arrow until you are. Down arrow to Dish Settings...click OK Turn off the Lnb power to the other Satellite you have hooked up to get a clean scan without interference from the other lnb's. Make sure the Sat you want to rescan is on the line that says Satellite. (Right arrow until the one you want is showing) Dish 110 is Echo Star 6,8 ...110.0W Dish 119 is Echo Star 7 ...119.0W Dish 61.5 is Echo Star 3 ...61.5W Dish 121 is Echo Star 9 ....121.0W **** 91 is Nimiq 1,3 ...91.0W **** 82 is Nimiq 2 ....82.0W Write down the settings that are listed. LNB Power LNB Type LNB Frequency Transponder 22KHz Search Option Network Search DiSEqC Motor Legacy Switch You will need these settings later. Make sure the sat you want to rescan is highlighted at the top. Click OK Another menu will pop up. Make sure the sat you want to rescan is highlighted there as well. Down arrow until it is. Press green button on remote. When the Delete Satellite screen pops up, make sure "yes" is highlighted and click OK (Don't worry, you are just deleting the channels that were scanned in, not deleting the actual satellite from your receiver) Click Exit Input the settings you wrote down earlier by using the down arrow to get to the settings to be changed and right clicking until the settings show up correctly. (You DID write them down..right?) After the settings are correct, then press the Red button on the remote and the channels and transponders will be scanned in. This will take a minute or two. When complete, a window will pop up asking you "Do you want to save?" Click OK Turn the LNB power back on for the other satellite you are aimed at. Now that wasn't that hard was it? Just repeat the same steps for any other satellite you want to rescan in. After you are used to doing this, it is not too hard at all. It should not be necessary to do this very often. Only do this if you think the provider has changed transponders for some channels and you are missing channels you were getting before. Or if you think you are missing some of the games that should be in the Centre Ice Package. If those channels weren't "live" when you did your original scan, you may not have them all at game time. The best time to do this in that case, is on a Saturday night at about 8PM when most of the channels are "Live" CREDIT’S FOR THIS GUIDE There are many guides sitting in sonic view forum so I wanted to have one master guide that we may use on daily basis. This guide is not my work, it is from many knowledgeable users at FTA FOR ALL forums. I have merely combined them. |
New member Username: Nick000000
Montreal,
QC
Post Number: 2 Registered: Sep-07
| Posted on Monday, September 03, 2007 - 05:56 pm: |
-------------------------------------------------------------------------------- Can anyone tell me plz Why do i need to turn my 2500a into 2700 is there a reason for that and if i do will i steel be able to use it for BEV and DN at a same time and what kined of bins will i be using after the conversion? thx |
Silver Member Username: Wakenbake
Post Number: 338 Registered: Mar-06
| Posted on Monday, September 03, 2007 - 06:00 pm: |
1- maybe no more bins for 2500 2- yes 3- must use modded bins by jvvh |
Post Number: 11594 Registered: Jan-06
hey...can't U see this is about Sonicview 4000...and not a Pansat!...post correctly... |
New member Username: Amyginger
Post Number: 4 Registered: Aug-07
| Posted on Tuesday, September 04, 2007 - 11:02 pm: |
THANKYOU thankyou thankyou Great info LK!!! |
