Thread: PanSat 3500sd Assistance Needed |
Bronze Member Username: Jryevols
Little rock,
Arkansas
Post Number: 21 Registered: Mar-07
| Posted on Monday, September 03, 2007 - 12:50 pm: |
Just received new Pansat 3500sd. I am told by seller that Imust download software to get Dishnet. The last Pansat 3500sd that I received all I had to do was load in bin numbers manually. Can anyone tell me where I get the software that will open the autoroll , nagravision or I guess it is called the CAS System. Thanks |
Bronze Member Username: Nbn
Post Number: 61 Registered: Aug-07
| Posted on Monday, September 03, 2007 - 01:27 pm: |
Is it a real pansat ? I have a clone and use the vortex 3500 SD bin. It works flawless, found at ftabins.net |
Platinum Member Username: Lklives
Post Number: 11580 Registered: Jan-06
| Posted on Monday, September 03, 2007 - 01:36 pm: |
Yes Vortex emailed us that 3025 bin awhile back...its posted in the CLONES section at dsscommunity.co*m also...the clone 35.01 loader is there too ...works great on all 3500 and clones.. also have the Vortex 2700 clone bin 2008 for all 2700's and their clones....with clone loaderr 27.02.....and also have the clone 2700 b75 boot upgrade entire package http://www.dsscommunity.co*m/forums/viewtopic.php?t=4564 |
Gold Member Username: Nydas
Post Number: 3577 Registered: Jun-06
| Posted on Monday, September 03, 2007 - 03:46 pm: |
Here is a list of sites where you will find a lot of information. It has been modded. from a list published here. Future FTA - Blacklist's Site: http://www.future-fta.info/forum/index.php (Pansat) FTA Tech - Free To Air Community: http://www.ftatech.net/forums/ (All receivers) Free To Air: http://www.f2atv.com/ (C00LSAT and All receivers) DSS Newbies: http://www.dss-newbies.net/forums/ (All receivers) DSS Rookie: http://www.dssrookie.com/forums/ (All receivers) Total FTA http://www.totalfta.com (VIEWSAT and All receivers) FTA Support www.ftaprosupport.com (all receivers) Cut and Paste these into your browser: REMOVE the * in links below: This site allows downloads of files without registering. http://forums.dsstester.c*om/ (All receivers) This site is agood alternative site for Pansat and Pansat clone files. http://www.al7bar.t*k/ (All receivers) This site was free but now has a small fee for files, but is the best site for Clone receivers in general.. http://www.pantecf2a.com/support (Pantecs,all clones and all receivers) File Share Site - No Registration Required: -------------------------------------------------- Good for gettting Original factory firmware: http://www.ftacentral.c*om/ (All receivers) Satellite Finders (Look Angle Calculators) ------------------------------------------------- http://www.arachnoid.com/satfinder (Dish 500 support) http://www.satellitenut.com/calculators/SatelliteHeading.html http://www.hollsco.com/Products/SatCalc/ http://www3.telus.net/rampage/skew.htm (Dish 500 support) http://www.remotesat.com/lookangle.htm Satellite Charts -------------------------------------------------- For information on all satellites and channels they offer http://www.lyngsat.c*om/america.html http://www.satcodx.com/ Best site for DISHNET info, channels, transponders and changes etc.. http://ekb.dbstalk.com/dishlist.htm Direct links to current Dishnet and Bev keys: www.tvkeyz.com/ www.dss-keys.com/ www.fta123.blogspot.com |
Post Number: 3578 Registered: Jun-06
| Posted on Monday, September 03, 2007 - 03:52 pm: |
http://www.dssrookie.com http://www.future-fta.info http://www.totalfta.com http://www.f2atv.com |
